C++ Exception Test Failure on Sparc SIS.
JunBeom Kim (Coressent)
jbkim at coressentkorea.co.kr
Fri Mar 21 16:45:08 UTC 2014
Dear Gedare,
After installing all toolset according to RSB, I rebuilt rtems source tree
for SIS.
When I check this, current problem is not resolved.
I think that this problem is not related with toolchain by RSB.
Please could you let me know another option for resolving this ?
Best Regards,
JunBeom
-----Original Message-----
From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of
Gedare Bloom
Sent: Saturday, March 22, 2014 12:29 AM
To: JunBeom Kim (Coressent)
Cc: RTEMS Devel
Subject: Re: C++ Exception Test Failure on Sparc SIS.
On Fri, Mar 21, 2014 at 11:12 AM, JunBeom Kim (Coressent)
<jbkim at coressentkorea.co.kr> wrote:
> Dear Gedare,
> Thank you for your reply.
> First of all, I set breakpoint in _Unwind_RaiseException. also,
> software crash is occurred in _Unwind_RaiseException function certainly.
> When I see location of address 0x02034A43, it's location is
> classify_object_over_fdes.
> As I check google search with "classify_object_over_fdes C++
> exception", I am guessing that there is a bug in binutils.
> On referencing, I built sparc-rtems4.11-xxx toolchain according to
> http://www.rtems.org/wiki/index.php/Building_Tools
> If possible, please let me know your advice for next step.
Try using the RSB to build your tools:
http://www.rtems.org/wiki/index.php/RSB
> Best Regards,
> JunBeom
> Of Gedare Bloom
> Sent: Friday, March 21, 2014 9:38 PM
> Cc: RTEMS Devel
> On Fri, Mar 21, 2014 at 2:42 AM, JunBeom Kim (Coressent)
>> Dear Sir,
>> After I built RTEMS kernel for Sparc SIS, I downloaded examples-v2.
>> Also, I am testing cxx example.
>> When I test cxx example on SIS, C++ exception(throw->catch) is not
> working.
>> Console message is below;
>> SIS - SPARC instruction simulator 2.7.5, copyright Jiri Gaisler 1995
>> Bug-reports to jgais at wd.estec.esa.nl
>> sis> load cxx_throw.exe
>> sis> go
>> resuming at 0x02000000
>> Hey I'm in base class constructor number 1 for 0x2081318.
>> Hey I'm in base class constructor number 2 for 0x2081320.
>> Hey I'm in derived class constructor number 3 for 0x2081320.
>> *** CONSTRUCTOR/DESTRUCTOR TEST ***
>> Hey I'm in base class constructor number 4 for 0x208c724.
>> Hey I'm in base class constructor number 5 for 0x208c71c.
>> Hey I'm in base class constructor number 6 for 0x208c714.
>> Hey I'm in base class constructor number 7 for 0x208c70c.
>> Hey I'm in derived class constructor number 8 for 0x208c70c.
>> Testing a C++ I/O stream
>> before try block
>> Unexpected trap ( 7) at address 0x02034A54
>> memory address not aligned
>> IU in error mode (257)
>> 826787 02036f14 91d02000 Address 0x02036f14 is out of bounds.
>> I want to know how to receive this problem.
> Use sparc-rtems-4.11-objdump -d option to disassemble the executable
> binary, then see what is the location of address 0x02034A54. Set a
> breakpoint in debugger at that function, see what memory address is
> causing the alignment fault. Determine where the memory address gets
> computed, and why there is an alignment problem. The compiler should
> not cause an alignment problem unless it gets the wrong flags or the
> code uses some tricks to coerce data types, so perhaps the code where
> the fault happens has got a bad set of compiler flags.
> That's where I would start anyway. Good luck, Gedare
>> Best Regards,
>> JunBeom Kim
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
