[rtems commit] librpc: Use POSIX key instead of task variables
Mon Mar 24 17:34:26 UTC 2014
Hello Joel,
On 03/24/2014 05:59 PM, Joel Sherrill wrote:
> Grep'ing to see what was left, I see two things:
> + privateenv.c
what is your opinion on removing rtems_libio_share_private_env()?
http://www.rtems.org/pipermail/rtems-devel/2014-March/006134.html
This would dramatically simplify the implementation.  What was the use
case for this function?
> + rpc used task_variable in the names of its types and data.
> Should that be changed?
I don't know who uses this stuff outside of the RTEMS tree.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
