[PATCH 01/10] score: Add get/set affinity to Scheduler Framework.
Tue Mar 25 12:08:21 UTC 2014
On Tue, Mar 25, 2014 at 3:20 AM, Sebastian Huber
> On 2014-03-24 19:39, Jennifer wrote:
>> @@ -184,6 +205,43 @@ void _Scheduler_default_Start_idle(
>>     Per_CPU_Control *processor
>> +#if defined(__RTEMS_HAVE_SYS_CPUSET_H__) && defined(RTEMS_SMP)
>> +   * @brief Get affinity for the default scheduler.
>> +   * @param[in] thread The associated thread.
>> +   * @param[in] cpusetsize The size of the cpuset.
>> +   * @param[out] cpuset Affinity set containing all CPUs.
>> +   * @retval 0 Successfully got cpuset
>> +   * @retval -1 The cpusetsize is invalid for the system
>> +  int _Scheduler_default_Get_affinity(
>> +    Thread_Control *thread,
>> +    size_t          cpusetsize,
>> +    cpu_set_t      *cpuset
>> +   * @brief Set affinity for the default scheduler.
>> +   * @param[in] cpuset Affinity new affinity set.
>> +   *  This method always returns successful and does not save
>> +   *  the cpuset.
>> +  int _Scheduler_default_Set_affinity(
>> +    cpu_set_t      *cpuset
>> +#endif
> I would rather use bool or an enum for the return status instead of this
> int.
> The default set affinity operation should accept only CPU sets that specify
> the complete set of available processors, e.g. for a three processor system
> it should be bits 0, 1, and 2 set, all other bits cleared (e.g. (1 << CPU
> count) - 1).
> The default get affinity operation should return the CPU sets reflecting all
> available processors.
I agree with the logic for the defaults Sebastian suggests.
> rtems-devel mailing list
> rtems-devel at rtems.org
