[PATCH 1/4] score: Thread life cycle re-implementation
Sebastian Huber
Thu Mar 27 13:20:21 UTC 2014
The thread deletion is now supported on SMP.
This change fixes the following PRs:
PR1814: SMP race condition between stack free and dispatch
PR2035: psxcancel reveals NULL pointer access in _Thread_queue_Extract()
The POSIX cleanup handler are now called in the right context (should be
called in the context of the terminating thread).
http://pubs.opengroup.org/onlinepubs/009695399/functions/xsh_chap02_09.html
Add a user extension the reflects a thread termination event. This is
used to reclaim the Newlib reentrancy structure (may use file
operations), the POSIX cleanup handlers and the POSIX key destructors.
cpukit/libcsupport/include/rtems/libcsupport.h | 7 +-
cpukit/libcsupport/src/newlibc_reent.c | 13 +-
cpukit/libcsupport/src/resource_snapshot.c | 5 +-
cpukit/libmisc/monitor/mon-prmisc.c | 2 +
cpukit/posix/include/rtems/posix/pthreadimpl.h | 4 +-
cpukit/posix/src/keyrundestructors.c | 24 +-
cpukit/posix/src/pthread.c | 22 ++-
cpukit/posix/src/pthreadexit.c | 82 +++----
cpukit/rtems/include/rtems/rtems/tasksimpl.h | 3 +
cpukit/rtems/src/taskdelete.c | 37 +---
cpukit/rtems/src/tasks.c | 29 ++-
cpukit/rtems/src/taskvariable_invoke_dtor.c | 2 +-
cpukit/score/Makefile.am | 2 +-
cpukit/score/include/rtems/score/statesimpl.h | 4 +
cpukit/score/include/rtems/score/thread.h | 46 ++++-
cpukit/score/include/rtems/score/threadimpl.h | 56 ++++-
cpukit/score/include/rtems/score/userext.h | 134 +++++++----
cpukit/score/include/rtems/score/userextimpl.h | 16 ++
cpukit/score/src/heapfree.c | 27 +--
cpukit/score/src/threadclose.c | 101 --------
cpukit/score/src/threadinitialize.c | 2 +
cpukit/score/src/threadrestart.c | 303 +++++++++++++++++++++++-
cpukit/score/src/userextiterate.c | 14 +
testsuites/psxtests/psxcleanup01/init.c | 9 +
testsuites/smptests/smpthreadlife01/init.c | 72 ++++++-
testsuites/smptests/smpunsupported01/init.c | 3 -
26 files changed, 708 insertions(+), 311 deletions(-)
delete mode 100644 cpukit/score/src/threadclose.c
diff --git a/cpukit/libcsupport/include/rtems/libcsupport.h b/cpukit/libcsupport/include/rtems/libcsupport.h
index 8e56e4d..7d40084 100644
--- a/cpukit/libcsupport/include/rtems/libcsupport.h
+++ b/cpukit/libcsupport/include/rtems/libcsupport.h
@@ -90,6 +90,10 @@ void newlib_delete_hook(
rtems_tcb *deleted_task
+void newlib_terminate_hook(
+ rtems_tcb *current_task
#define RTEMS_NEWLIB_EXTENSION \
newlib_create_hook, /* rtems_task_create */ \
@@ -99,7 +103,8 @@ void newlib_delete_hook(
0, /* task_switch */ \
__RTEMS_NEWLIB_BEGIN, /* task_begin */ \
0, /* task_exitted */ \
- 0 /* fatal */ \
+ 0, /* fatal */ \
+ newlib_terminate_hook /* thread terminate */ \
typedef struct {
diff --git a/cpukit/libcsupport/src/newlibc_reent.c b/cpukit/libcsupport/src/newlibc_reent.c
index 88e5e18..cd3ac2a 100644
--- a/cpukit/libcsupport/src/newlibc_reent.c
+++ b/cpukit/libcsupport/src/newlibc_reent.c
@@ -66,13 +66,16 @@ void newlib_delete_hook(
- struct _reent *ptr;
+ (void) current_task;
- ptr = deleted_task->libc_reent;
- deleted_task->libc_reent = NULL;
+ _Workspace_Free(deleted_task->libc_reent);
- _reclaim_reent(ptr);
- _Workspace_Free(ptr);
+ _reclaim_reent(current_task->libc_reent);
#endif
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index 8ebbbdc..8c66f0f 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -22,8 +22,9 @@
#include <rtems/libio_.h>
#include <rtems/malloc.h>
-#include <rtems/score/wkspace.h>
#include <rtems/score/protectedheap.h>
+#include <rtems/score/threadimpl.h>
+#include <rtems/score/wkspace.h>
#include <rtems/extensionimpl.h>
@@ -116,6 +117,8 @@ void rtems_resource_snapshot_take(rtems_resource_snapshot *snapshot)
free_all_delayed_blocks();
+ _Thread_Kill_zombies();
_Protected_heap_Get_information(RTEMS_Malloc_Heap, &snapshot->heap_info);
_Thread_Disable_dispatch();
diff --git a/cpukit/libmisc/monitor/mon-prmisc.c b/cpukit/libmisc/monitor/mon-prmisc.c
index 75c9ecf..1d6fef5 100644
--- a/cpukit/libmisc/monitor/mon-prmisc.c
+++ b/cpukit/libmisc/monitor/mon-prmisc.c
@@ -135,6 +135,8 @@ static const rtems_assoc_t rtems_monitor_state_assoc[] = {
{ "Wrwlk", STATES_WAITING_FOR_RWLOCK, 0 },
{ "Wisig", STATES_INTERRUPTIBLE_BY_SIGNAL, 0 },
{ "Wwkup", STATES_WAITING_FOR_BSD_WAKEUP, 0 },
+ { "Wterm", STATES_WAITING_FOR_TERMINATION, 0 },
+ { "ZOMBI", STATES_ZOMBIE, 0 },
{ 0, 0, 0 },
diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h b/cpukit/posix/include/rtems/posix/pthreadimpl.h
index af68990..02d8bca 100644
--- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
@@ -23,7 +23,7 @@
#include <rtems/posix/config.h>
#include <rtems/posix/threadsup.h>
-#include <rtems/score/thread.h>
#ifdef __cplusplus
@@ -217,6 +217,8 @@ int rtems_pthread_attribute_compare(
RTEMS_INLINE_ROUTINE Thread_Control *_POSIX_Threads_Allocate( void )
return (Thread_Control *) _Objects_Allocate( &_POSIX_Threads_Information );
diff --git a/cpukit/posix/src/keyrundestructors.c b/cpukit/posix/src/keyrundestructors.c
index 762e2e6..96147a5 100644
--- a/cpukit/posix/src/keyrundestructors.c
+++ b/cpukit/posix/src/keyrundestructors.c
@@ -7,7 +7,7 @@
* Copyright (c) 2012 Zhongwei Yao.
- * Copyright (c) 2010 embedded brains GmbH.
+ * Copyright (c) 2010-2014 embedded brains GmbH.
* COPYRIGHT (c) 1989-2014.
* On-Line Applications Research Corporation (OAR).
@@ -22,6 +22,7 @@
#endif
#include <rtems/posix/keyimpl.h>
+#include <rtems/score/assert.h>
@@ -44,14 +45,15 @@ void _POSIX_Keys_Run_destructors(
POSIX_Keys_Control *the_key;
Objects_Locations location;
- _Thread_Disable_dispatch();
chain = &thread->Key_Chain;
iter = (POSIX_Keys_Key_value_pair *) _Chain_First( chain );
while ( !_Chain_Is_tail( chain, &iter->Key_values_per_thread_node ) ) {
next = (POSIX_Keys_Key_value_pair *)
_Chain_Next( &iter->Key_values_per_thread_node );
+ the_key = _POSIX_Keys_Get( iter->key, &location );
+ _Assert( location == OBJECTS_LOCAL );
* remove key from rbtree and chain.
* here Chain_Node *iter can be convert to POSIX_Keys_Key_value_pair *,
@@ -64,21 +66,19 @@ void _POSIX_Keys_Run_destructors(
_Chain_Extract_unprotected( &iter->Key_values_per_thread_node );
- * run key value's destructor if destructor and value are both non-null.
- the_key = _POSIX_Keys_Get( iter->key, &location );
destructor = the_key->destructor;
value = iter->value;
- if ( destructor != NULL && value != NULL )
- (*destructor)( value );
+ _POSIX_Keys_Key_value_pair_free( iter );
_Objects_Put( &the_key->Object );
- _POSIX_Keys_Key_value_pair_free( iter );
+ * run key value's destructor if destructor and value are both non-null.
+ if ( destructor != NULL && value != NULL )
+ (*destructor)( value );
iter = next;
- _Thread_Enable_dispatch();
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 0416e28..8d1a8eb 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -274,21 +274,30 @@ static void _POSIX_Threads_Delete_extension(
Thread_Control *deleted
+ _Workspace_Free( deleted->API_Extensions[ THREAD_API_POSIX ] );
+static void _POSIX_Threads_Terminate_extension(
+ Thread_Control *executing
Thread_Control *the_thread;
POSIX_API_Control *api;
void **value_ptr;
- api = deleted->API_Extensions[ THREAD_API_POSIX ];
+ api = executing->API_Extensions[ THREAD_API_POSIX ];
* Run the POSIX cancellation handlers
- _POSIX_Threads_cancel_run( deleted );
+ _POSIX_Threads_cancel_run( executing );
+ _Thread_Disable_dispatch();
* Wakeup all the tasks which joined with this one
- value_ptr = (void **) deleted->Wait.return_argument;
+ value_ptr = (void **) executing->Wait.return_argument;
while ( (the_thread = _Thread_queue_Dequeue( &api->Join_List )) )
*(void **)the_thread->Wait.return_argument = value_ptr;
@@ -296,9 +305,7 @@ static void _POSIX_Threads_Delete_extension(
if ( api->schedpolicy == SCHED_SPORADIC )
(void) _Watchdog_Remove( &api->Sporadic_timer );
- deleted->API_Extensions[ THREAD_API_POSIX ] = NULL;
- _Workspace_Free( api );
+ _Thread_Enable_dispatch();
@@ -350,7 +357,8 @@ User_extensions_Control _POSIX_Threads_User_extensions = {
NULL, /* switch */
NULL, /* begin */
_POSIX_Threads_Exitted_extension, /* exitted */
- NULL /* fatal */
+ NULL, /* fatal */
+ _POSIX_Threads_Terminate_extension /* terminate */
diff --git a/cpukit/posix/src/pthreadexit.c b/cpukit/posix/src/pthreadexit.c
index 8ffb54e..40cd160 100644
--- a/cpukit/posix/src/pthreadexit.c
+++ b/cpukit/posix/src/pthreadexit.c
@@ -21,6 +21,7 @@
#include <pthread.h>
#include <rtems/score/apimutex.h>
@@ -30,65 +31,46 @@ void _POSIX_Thread_Exit(
void *value_ptr
- Objects_Information *the_information;
- Thread_Control *unblocked;
- POSIX_API_Control *api;
- the_information = _Objects_Get_information_id( the_thread->Object.id );
+ Thread_Control *unblocked;
+ POSIX_API_Control *api;
+ bool previous_life_protection;
api = the_thread->API_Extensions[ THREAD_API_POSIX ];
+ _Assert( _Debug_Is_thread_dispatching_allowed() );
- * The_information has to be non-NULL. Otherwise, we couldn't be
- * running in a thread of this API and class.
- * NOTE: Lock and unlock in different order so we do not throw a
- * fatal error when locking the allocator mutex. And after
- * we unlock, we want to defer the context switch until we
- * are ready to be switched out. Otherwise, an ISR could
- * occur and preempt us out while we still hold the
- * allocator mutex.
- _RTEMS_Lock_allocator();
- the_thread->Wait.return_argument = value_ptr;
+ previous_life_protection = _Thread_Set_life_protection( true );
- * Process join
- if ( api->detachstate == PTHREAD_CREATE_JOINABLE ) {
- unblocked = _Thread_queue_Dequeue( &api->Join_List );
- if ( unblocked ) {
- do {
- *(void **)unblocked->Wait.return_argument = value_ptr;
- } while ( (unblocked = _Thread_queue_Dequeue( &api->Join_List )) );
- } else {
- _Thread_Set_state(
- the_thread,
- STATES_WAITING_FOR_JOIN_AT_EXIT | STATES_TRANSIENT
- /* FIXME: Lock order reversal */
- _RTEMS_Unlock_allocator();
- /* now waiting for thread to arrive */
+ the_thread->Wait.return_argument = value_ptr;
- * Now shut down the thread
- _Thread_Close( the_information, the_thread );
+ * Process join
+ if ( api->detachstate == PTHREAD_CREATE_JOINABLE ) {
+ unblocked = _Thread_queue_Dequeue( &api->Join_List );
+ if ( unblocked ) {
+ do {
+ *(void **)unblocked->Wait.return_argument = value_ptr;
+ } while ( (unblocked = _Thread_queue_Dequeue( &api->Join_List )) );
+ } else {
+ _Thread_Set_state(
+ the_thread,
+ STATES_WAITING_FOR_JOIN_AT_EXIT | STATES_TRANSIENT
+ /* now waiting for thread to arrive */
- _POSIX_Threads_Free( the_thread );
+ * Now shut down the thread
+ _Thread_Close( the_thread, _Thread_Executing );
+ _Thread_Set_life_protection( previous_life_protection );
void pthread_exit(
diff --git a/cpukit/rtems/include/rtems/rtems/tasksimpl.h b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
index fbee00e..2a99812 100644
--- a/cpukit/rtems/include/rtems/rtems/tasksimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
@@ -19,6 +19,7 @@
#ifdef __cplusplus
extern "C" {
@@ -84,6 +85,8 @@ void _RTEMS_Tasks_Invoke_task_variable_dtor(
RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate( void )
return (Thread_Control *) _Objects_Allocate( &_RTEMS_tasks_Information );
diff --git a/cpukit/rtems/src/taskdelete.c b/cpukit/rtems/src/taskdelete.c
index b92f5f2..dc9a2a1 100644
--- a/cpukit/rtems/src/taskdelete.c
+++ b/cpukit/rtems/src/taskdelete.c
@@ -27,32 +27,15 @@ rtems_status_code rtems_task_delete(
rtems_id id
- Thread_Control *the_thread;
- Objects_Locations location;
-#if defined( RTEMS_SMP )
- if ( rtems_configuration_is_smp_enabled() ) {
- return RTEMS_NOT_IMPLEMENTED;
-#endif
+ Thread_Control *the_thread;
+ Objects_Locations location;
the_thread = _Thread_Get( id, &location );
switch ( location ) {
case OBJECTS_LOCAL:
- #if defined(RTEMS_DEBUG)
- if ( !the_information ) {
- _Objects_Put( &the_thread->Object );
- return RTEMS_INVALID_ID;
- /* This should never happen if _Thread_Get() works right */
- #endif
#if defined(RTEMS_MULTIPROCESSING)
if ( the_thread->is_global ) {
_Objects_MP_Close( &_RTEMS_tasks_Information, the_thread->Object.id );
@@ -64,19 +47,16 @@ rtems_status_code rtems_task_delete(
#endif
- _RTEMS_tasks_Free( the_thread );
return RTEMS_SUCCESSFUL;
case OBJECTS_REMOTE:
_Thread_Dispatch();
return RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
#endif
@@ -84,6 +64,7 @@ rtems_status_code rtems_task_delete(
break;
diff --git a/cpukit/rtems/src/tasks.c b/cpukit/rtems/src/tasks.c
index c859d24..5946950 100644
--- a/cpukit/rtems/src/tasks.c
+++ b/cpukit/rtems/src/tasks.c
@@ -113,31 +113,35 @@ static void _RTEMS_tasks_Delete_extension(
+ * Free API specific memory
+ (void) _Workspace_Free( deleted->API_Extensions[ THREAD_API_RTEMS ] );
+static void _RTEMS_tasks_Terminate_extension(
rtems_task_variable_t *tvp, *next;
* Free per task variable memory
- tvp = deleted->task_variables;
- deleted->task_variables = NULL;
+ tvp = executing->task_variables;
+ executing->task_variables = NULL;
while (tvp) {
next = (rtems_task_variable_t *)tvp->next;
- _RTEMS_Tasks_Invoke_task_variable_dtor( deleted, tvp );
+ _RTEMS_Tasks_Invoke_task_variable_dtor( executing, tvp );
tvp = next;
* Run all the key destructors
- _POSIX_Keys_Run_destructors( deleted );
- * Free API specific memory
- (void) _Workspace_Free( deleted->API_Extensions[ THREAD_API_RTEMS ] );
- deleted->API_Extensions[ THREAD_API_RTEMS ] = NULL;
+ _POSIX_Keys_Run_destructors( executing );
@@ -189,7 +193,8 @@ User_extensions_Control _RTEMS_tasks_User_extensions = {
_RTEMS_tasks_Switch_extension, /* switch */
NULL, /* begin */
NULL, /* exitted */
- NULL /* fatal */
+ NULL, /* fatal */
+ _RTEMS_tasks_Terminate_extension /* terminate */
diff --git a/cpukit/rtems/src/taskvariable_invoke_dtor.c b/cpukit/rtems/src/taskvariable_invoke_dtor.c
index a23e5e5..51b9453 100644
--- a/cpukit/rtems/src/taskvariable_invoke_dtor.c
+++ b/cpukit/rtems/src/taskvariable_invoke_dtor.c
@@ -31,7 +31,7 @@ void _RTEMS_Tasks_Invoke_task_variable_dtor(
void *value;
dtor = tvp->dtor;
- if (_Thread_Is_executing(the_thread)) {
+ if (_Thread_Get_executing() == the_thread) {
value = *tvp->ptr;
*tvp->ptr = tvp->gval;
} else {
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index c6dd47b..e2d23a4 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -272,7 +272,7 @@ libscore_a_SOURCES += src/rbtree.c \
## THREAD_C_FILES
libscore_a_SOURCES += src/thread.c src/threadchangepriority.c \
- src/threadclearstate.c src/threadclose.c src/threadcreateidle.c \
+ src/threadclearstate.c src/threadcreateidle.c \
src/threaddelayended.c src/threaddispatch.c \
src/threadenabledispatch.c src/threaddisabledispatch.c \
src/threadget.c src/threadhandler.c src/threadinitialize.c \
diff --git a/cpukit/score/include/rtems/score/statesimpl.h b/cpukit/score/include/rtems/score/statesimpl.h
index 913922b..842d108 100644
--- a/cpukit/score/include/rtems/score/statesimpl.h
+++ b/cpukit/score/include/rtems/score/statesimpl.h
@@ -78,6 +78,10 @@ extern "C" {
#define STATES_WAITING_FOR_SYSTEM_EVENT 0x40000
/** This macro corresponds to a task waiting for BSD wakeup. */
#define STATES_WAITING_FOR_BSD_WAKEUP 0x80000
+/** This macro corresponds to a task waiting for a task termination. */
+#define STATES_WAITING_FOR_TERMINATION 0x100000
+/** This macro corresponds to a task being a zombie. */
+#define STATES_ZOMBIE 0x200000
/** This macro corresponds to a task which is in an interruptible
* blocking state.
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index 33c69ad..e22c59e 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -11,6 +11,8 @@
+ * Copyright (c) 2014 embedded brains GmbH.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.org/license/LICENSE.
@@ -412,8 +414,47 @@ typedef struct {
Chain_Control Chain;
} Thread_Action_control;
+ * @brief Thread life states.
+ * The thread life states are orthogonal to the thread states used for
+ * synchronization primitives and blocking operations. They reflect the state
+ * changes triggered with thread restart and delete requests.
+typedef enum {
+ THREAD_LIFE_NORMAL = 0x0,
+ THREAD_LIFE_PROTECTED = 0x1,
+ THREAD_LIFE_RESTARTING = 0x2,
+ THREAD_LIFE_PROTECTED_RESTARTING = 0x3,
+ THREAD_LIFE_TERMINATING = 0x4,
+ THREAD_LIFE_PROTECTED_TERMINATING = 0x5,
+ THREAD_LIFE_RESTARTING_TERMINTING = 0x6,
+ THREAD_LIFE_PROTECTED_RESTARTING_TERMINTING = 0x7
+} Thread_Life_state;
+ * @brief Thread life control.
typedef struct {
+ * @brief Thread life action used to react upon thread restart and delete
+ * requests.
Thread_Action Action;
+ * @brief The current thread life state.
+ Thread_Life_state state;
+ * @brief The terminator thread of this thread.
+ * In case the thread is terminated and another thread (the terminator) waits
+ * for the actual termination completion, then this field references the
+ * terminator thread.
+ Thread_Control *terminator;
} Thread_Life_control;
@@ -486,9 +527,10 @@ struct Thread_Control_struct {
* thread and thread dispatching is necessary. On SMP a thread dispatch on a
* remote processor needs help from an inter-processor interrupt, thus it
* will take some time to complete the state change. A lot of things can
- * happen in the meantime.
+ * happen in the meantime. This field is volatile since it is polled in
+ * _Thread_Kill_zombies().
- bool is_executing;
+ volatile bool is_executing;
#if __RTEMS_HAVE_SYS_CPUSET_H__
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 2e31753..d0c7933 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -11,6 +11,8 @@
* COPYRIGHT (c) 1989-2008.
@@ -194,6 +196,8 @@ bool _Thread_Restart(
Thread_Entry_numeric_type numeric_argument
+bool _Thread_Set_life_protection( bool protect );
void _Thread_Life_action_handler(
Thread_Control *executing,
Thread_Action *action,
@@ -202,16 +206,24 @@ void _Thread_Life_action_handler(
- * @brief Frees all memory associated with the specified thread.
+ * @brief Kills all zombie threads in the system.
- * This routine frees all memory associated with the specified
- * thread and removes it from the local object table so no further
- * operations on this thread are allowed.
+ * Threads change into the zombie state as the last step in the thread
+ * termination sequence right before a context switch to the heir thread is
+ * initiated. Since the thread stack is still in use during this phase we have
+ * to postpone the thread stack reclamation until this point. On SMP
+ * configurations we may have to busy wait for context switch completion here.
-void _Thread_Close(
- Objects_Information *information,
+void _Thread_Kill_zombies( void );
+ * @brief Closes the thread.
+ * Closes the thread object and starts the thread termination sequence. In
+ * case the executing thread is not terminated, then this function waits until
+ * the terminating thread reached the zombie state.
+void _Thread_Close( Thread_Control *the_thread, Thread_Control *executing );
* @brief Removes any set states for @a the_thread.
@@ -710,6 +722,34 @@ RTEMS_INLINE_ROUTINE void _Thread_Add_post_switch_action(
_Thread_Action_release_and_ISR_enable( cpu, level );
+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_restarting(
+ Thread_Life_state life_state
+ return ( life_state & THREAD_LIFE_RESTARTING ) != 0;
+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_terminating(
+ return ( life_state & THREAD_LIFE_TERMINATING ) != 0;
+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_protected(
+ return ( life_state & THREAD_LIFE_PROTECTED ) != 0;
+RTEMS_INLINE_ROUTINE bool _Thread_Is_life_changing(
+ return ( life_state & THREAD_LIFE_RESTARTING_TERMINTING ) != 0;
#if !defined(__DYNAMIC_REENT__)
* This routine returns the C library re-enterant pointer.
diff --git a/cpukit/score/include/rtems/score/userext.h b/cpukit/score/include/rtems/score/userext.h
index 91e7f97..2bd8f8a 100644
--- a/cpukit/score/include/rtems/score/userext.h
+++ b/cpukit/score/include/rtems/score/userext.h
@@ -43,9 +43,7 @@ typedef void User_extensions_routine RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
* @brief Task create extension.
* It corresponds to _Thread_Initialize() (used by the rtems_task_create()
- * directive). The first parameter points to the currently executing thread
- * which created the new thread. The second parameter points to the created
- * thread.
+ * directive and pthread_create()).
* It is invoked after the new thread has been completely initialized, but
* before it is placed on a ready chain.
@@ -59,140 +57,173 @@ typedef void User_extensions_routine RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
* It can be assumed that the executing thread locked the allocator mutex.
* The only exception is the creation of the idle thread. In this case the
- * allocator mutex is not locked. Since the allocator mutex is non-recursive,
- * it is prohibited to call the normal memory allocation routines. It is
- * possible to use internal rountines like _Workspace_Allocate() or
- * _Heap_Allocate() for heaps which are protected by the allocator mutex.
+ * allocator mutex is not locked. Since the allocator mutex allows nesting the
+ * normal memory allocation routines can be used.
+ * @param[in] executing The executing thread.
+ * @param[in] created The created thread.
- * @retval true The thread create extension was successful.
+ * @retval true Successful operation.
* @retval false A thread create user extension will frequently attempt to
* allocate resources. If this allocation fails, then the extension should
* return @a false and the entire thread create operation will fail.
typedef bool ( *User_extensions_thread_create_extension )(
- Thread_Control *,
- Thread_Control *
+ Thread_Control *executing,
+ Thread_Control *created
* @brief Task delete extension.
* It corresponds to _Thread_Close() (used by the rtems_task_delete()
- * which deleted the thread. The second parameter points to the deleted
- * thread.
+ * directive, pthread_exit() and pthread_cancel()).
- * It is invoked before all resources of the thread are deleted.
+ * It is invoked before all resources of the thread are deleted. The executing
+ * and deleted arguments are never equal.
* Thread dispatching is enabled. The executing thread locked the allocator
* mutex.
+ * @param[in] deleted The deleted thread.
typedef void( *User_extensions_thread_delete_extension )(
- Thread_Control *,
- Thread_Control *
+ Thread_Control *deleted
* @brief Task start extension.
* It corresponds to _Thread_Start() (used by the rtems_task_start()
- * which started the thread. The second parameter points to the started
- * thread.
+ * directive).
* It is invoked after the environment of the thread has been loaded and the
* thread has been made ready.
* Thread dispatching is disabled. The executing thread is not the holder of
* the allocator mutex.
+ * @param[in] started The started thread.
typedef void( *User_extensions_thread_start_extension )(
- Thread_Control *,
- Thread_Control *
+ Thread_Control *started
* @brief Task restart extension.
* It corresponds to _Thread_Restart() (used by the rtems_task_restart()
- * which restarted the thread. The second parameter points to the restarted
- * thread.
+ * directive).
* It is invoked in the context of the restarted thread right before the
- * execution context is restarted. The executing and restarted arguments are
- * equal. The thread stack reflects the previous execution context.
+ * execution context is reloaded. The executing and restarted arguments are
+ * always equal. The thread stack reflects the previous execution context.
* Thread dispatching is enabled. The thread is not the holder of the
+ * allocator mutex. The thread life is protected. Thread restart and delete
+ * requests issued by restart extensions lead to recursion.
+ * @param[in] restarted The executing thread. Yes, the executing thread.
typedef void( *User_extensions_thread_restart_extension )(
- Thread_Control *,
- Thread_Control *
+ Thread_Control *restarted
* @brief Task switch extension.
- * It corresponds to _Thread_Dispatch(). The first parameter points to the
- * currently executing thread. The second parameter points to the heir thread.
+ * It corresponds to _Thread_Dispatch().
* It is invoked before the context switch from the executing to the heir
* thread.
* Thread dispatching is disabled. The state of the allocator mutex is
- * arbitrary.
+ * arbitrary. Interrupts are disabled and the per-CPU lock is acquired on SMP
+ * configurations.
- * The context switches initiated through _Thread_Start_multitasking() and
- * _Thread_Stop_multitasking() are not covered by this extension. The
- * executing thread may run with a minimal setup, for example with a freed task
- * stack.
+ * The context switches initiated through _Thread_Start_multitasking() are not
+ * covered by this extension.
+ * @param[in] heir The heir thread.
typedef void( *User_extensions_thread_switch_extension )(
- Thread_Control *,
- Thread_Control *
+ Thread_Control *heir
* @brief Task begin extension.
- * It corresponds to _Thread_Handler(). The first parameter points to the
- * currently executing thread which begins now execution.
+ * It corresponds to _Thread_Handler().
typedef void( *User_extensions_thread_begin_extension )(
- Thread_Control *
* @brief Task exitted extension.
- * currently executing thread which exitted before.
+ * It corresponds to _Thread_Handler() after a return of the entry function.
* arbitrary.
typedef void( *User_extensions_thread_exitted_extension )(
- Thread_Control *
* @brief Fatal error extension.
- * It corresponds to _Terminate() (used by the
- * rtems_fatal_error_occurred() directive). The first parameter contains the
- * error source. The second parameter indicates if it was an internal error.
- * The third parameter contains the error code.
+ * It corresponds to _Terminate() (used by the rtems_fatal() directive).
* This extension should not call any RTEMS directives.
+ * @param[in] source The fatal source indicating the subsystem the fatal
+ * condition originated in.
+ * @param[in] is_internal Indicates if the fatal condition was generated
+ * internally to the executive.
+ * @param[in] code The fatal error code. This value must be interpreted with
+ * respect to the source.
typedef void( *User_extensions_fatal_extension )(
- Internal_errors_Source,
- bool,
- Internal_errors_t
+ Internal_errors_Source source,
+ bool is_internal,
+ Internal_errors_t code
+ * @brief Task termination extension.
+ * This extension is invoked by _Thread_Life_action_handler() in case a
+ * termination request is recognized.
+ * It is invoked in the context of the terminated thread right before the
+ * thread dispatch to the heir thread. The POSIX cleanup and key destructors
+ * execute in this context.
+ * Thread dispatching is enabled. The thread is not the holder of the
+ * requests issued by terminate extensions lead to recursion.
+ * @param[in] terminated The terminated thread.
+typedef void( *User_extensions_thread_terminate_extension )(
+ Thread_Control *terminated
@@ -207,6 +238,7 @@ typedef struct {
User_extensions_thread_begin_extension thread_begin;
User_extensions_thread_exitted_extension thread_exitted;
User_extensions_fatal_extension fatal;
+ User_extensions_thread_terminate_extension thread_terminate;
} User_extensions_Table;
diff --git a/cpukit/score/include/rtems/score/userextimpl.h b/cpukit/score/include/rtems/score/userextimpl.h
index 25c6f00..04808e1 100644
--- a/cpukit/score/include/rtems/score/userextimpl.h
+++ b/cpukit/score/include/rtems/score/userextimpl.h
@@ -142,6 +142,12 @@ void _User_extensions_Fatal_visitor(
const User_extensions_Table *callouts
+void _User_extensions_Thread_terminate_visitor(
+ void *arg,
+ const User_extensions_Table *callouts
* @brief Iterates through all user extensions and calls the visitor for each.
@@ -239,6 +245,16 @@ static inline void _User_extensions_Fatal(
_User_extensions_Iterate( &ctx, _User_extensions_Fatal_visitor );
+static inline void _User_extensions_Thread_terminate(
+ _User_extensions_Iterate(
+ executing,
+ _User_extensions_Thread_terminate_visitor
diff --git a/cpukit/score/src/heapfree.c b/cpukit/score/src/heapfree.c
index c45c294..4e69146 100644
--- a/cpukit/score/src/heapfree.c
+++ b/cpukit/score/src/heapfree.c
@@ -83,26 +83,13 @@
bool do_free = true;
Heap_Block *const next = block->Protection_begin.next_delayed_free_block;
- * Sometimes after a free the allocated area is still in use. An example
- * is the task stack of a thread that deletes itself. The thread dispatch
- * disable level is a way to detect this use case.
- if ( _Thread_Dispatch_is_enabled() ) {
- if ( next == NULL ) {
- _Heap_Protection_delay_block_free( heap, block );
- do_free = false;
- } else if ( next == HEAP_PROTECTION_OBOLUS ) {
- _Heap_Protection_check_free_block( heap, block );
- } else {
- _Heap_Protection_block_error( heap, block );
- } else if ( next == NULL ) {
- * This is a hack to prevent heavy workspace fragmentation which would
- * lead to test suite failures.
- _Heap_Protection_free_all_delayed_blocks( heap );
+ if ( next == NULL ) {
+ _Heap_Protection_delay_block_free( heap, block );
+ do_free = false;
+ } else if ( next == HEAP_PROTECTION_OBOLUS ) {
+ _Heap_Protection_check_free_block( heap, block );
+ } else {
+ _Heap_Protection_block_error( heap, block );
return do_free;
diff --git a/cpukit/score/src/threadclose.c b/cpukit/score/src/threadclose.c
deleted file mode 100644
index 12896f5..0000000
--- a/cpukit/score/src/threadclose.c
+++ /dev/null
@@ -1,101 +0,0 @@
- * @file
- * @brief Thread Close
- * @ingroup ScoreThread
- * COPYRIGHT (c) 1989-2011.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/score/threadimpl.h>
-#include <rtems/score/schedulerimpl.h>
-#include <rtems/score/threadqimpl.h>
-#include <rtems/score/userextimpl.h>
-#include <rtems/score/watchdogimpl.h>
- * Now we are in a dispatching critical section again and we
- * can take the thread OUT of the published set. It is invalid
- * to use this thread's Id after this call. This will prevent
- * any other task from attempting to initiate a call on this task.
- _Objects_Invalidate_Id( information, &the_thread->Object );
- * We assume the Allocator Mutex is locked when we get here.
- * This provides sufficient protection to let the user extensions
- * run but as soon as we get back, we will make the thread
- * disappear and set a transient state on it. So we temporarily
- * unnest dispatching.
- _Thread_Unnest_dispatch();
- _User_extensions_Thread_delete( the_thread );
- * to use this thread's Id OR name after this call.
- _Objects_Close( information, &the_thread->Object );
- * By setting the dormant state, the thread will not be considered
- * for scheduling when we remove any blocking states.
- _Thread_Set_state( the_thread, STATES_DORMANT );
- if ( !_Thread_queue_Extract_with_proxy( the_thread ) ) {
- if ( _Watchdog_Is_active( &the_thread->Timer ) )
- (void) _Watchdog_Remove( &the_thread->Timer );
- * Free the per-thread scheduling information.
- _Scheduler_Free( the_thread );
- * The thread might have been FP. So deal with that.
-#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
-#if ( CPU_USE_DEFERRED_FP_SWITCH == TRUE )
- if ( _Thread_Is_allocated_fp( the_thread ) )
- _Thread_Deallocate_fp();
-#endif
- the_thread->fp_context = NULL;
- _Workspace_Free( the_thread->Start.fp_context );
-#endif
- * Free the rest of the memory associated with this task
- * and set the associated pointers to NULL for safety.
- _Thread_Stack_Free( the_thread );
- the_thread->Start.stack = NULL;
- _Workspace_Free( the_thread->extensions );
- the_thread->extensions = NULL;
- _Workspace_Free( the_thread->Start.tls_area );
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index c851320..fd52742 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -244,6 +244,8 @@ bool _Thread_Initialize(
&the_thread->Life.Action,
+ the_thread->Life.state = THREAD_LIFE_NORMAL;
+ the_thread->Life.terminator = NULL;
* Open the object
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index b8fbd23..5b0e8a8 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -9,6 +9,8 @@
* COPYRIGHT (c) 1989-1999.
@@ -19,9 +21,129 @@
#endif
+#include <rtems/score/apimutex.h>
+#include <rtems/score/chainimpl.h>
+#include <rtems/score/isrlock.h>
+#include <rtems/score/schedulerimpl.h>
+#include <rtems/score/sysstate.h>
+typedef struct {
+ Chain_Control Chain;
+ ISR_lock_Control Lock;
+} Thread_Zombie_control;
+static Thread_Zombie_control _Thread_Zombies = {
+ .Chain = CHAIN_INITIALIZER_EMPTY( _Thread_Zombies.Chain ),
+ .Lock = ISR_LOCK_INITIALIZER( "thread zombies" )
+static void _Thread_Make_zombie( Thread_Control *the_thread )
+ ISR_lock_Context lock_context;
+ Thread_Zombie_control *zombies = &_Thread_Zombies;
+ _Thread_Set_state( the_thread, STATES_ZOMBIE );
+ _Thread_queue_Extract_with_proxy( the_thread );
+ _Watchdog_Remove( &the_thread->Timer );
+ _ISR_lock_ISR_disable_and_acquire( &zombies->Lock, &lock_context );
+ _Chain_Append_unprotected( &zombies->Chain, &the_thread->Object.Node );
+ _ISR_lock_Release_and_ISR_enable( &zombies->Lock, &lock_context );
+static void _Thread_Free( Thread_Control *the_thread )
+ _User_extensions_Thread_delete( the_thread );
+ * Free the per-thread scheduling information.
+ _Scheduler_Free( the_thread );
+ * The thread might have been FP. So deal with that.
+#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
+#if ( CPU_USE_DEFERRED_FP_SWITCH == TRUE )
+ if ( _Thread_Is_allocated_fp( the_thread ) )
+ _Thread_Deallocate_fp();
+#endif
+ _Workspace_Free( the_thread->Start.fp_context );
+#endif
+ * Free the rest of the memory associated with this task
+ * and set the associated pointers to NULL for safety.
+ _Thread_Stack_Free( the_thread );
+ _Workspace_Free( the_thread->extensions );
+ _Workspace_Free( the_thread->Start.tls_area );
+ _Objects_Free(
+ _Objects_Get_information_id( the_thread->Object.id ),
+ &the_thread->Object
+static void _Thread_Wait_for_execution_stop( Thread_Control *the_thread )
+#if defined(RTEMS_SMP)
+ * It is very unlikely that we see an executing thread here. It can happen
+ * in case the thread termination sequence is interrupted by a slow interrupt
+ * service on a remote processor.
+ while (the_thread->is_executing) {
+ /* Wait */
+#else
+ (void) the_thread;
+#endif
+ the_thread = (Thread_Control *) _Chain_Get_unprotected( &zombies->Chain );
+ while ( the_thread != NULL ) {
+ _Thread_Wait_for_execution_stop( the_thread );
+ _Thread_Free( the_thread );
+static void _Thread_Start_life_change_for_executing(
+ _Assert( executing->Timer.state == WATCHDOG_INACTIVE );
+ _Assert(
+ executing->current_state == STATES_READY
+ || executing->current_state == STATES_SUSPENDED
+ _Thread_Add_post_switch_action( executing, &executing->Life.Action );
@@ -30,15 +152,59 @@ void _Thread_Life_action_handler(
ISR_Level level
+ Thread_Life_state previous_life_state;
(void) action;
+ previous_life_state = executing->Life.state;
+ executing->Life.state = THREAD_LIFE_PROTECTED;
- _User_extensions_Thread_restart( the_thread );
+ if ( _Thread_Is_life_terminating( previous_life_state ) ) {
+ _User_extensions_Thread_terminate( executing );
+ } else {
+ _Assert( _Thread_Is_life_restarting( previous_life_state ) );
+ _User_extensions_Thread_restart( executing );
- _Thread_Load_environment( executing );
- _Thread_Restart_self( executing );
+ _Thread_Make_zombie( executing );
+ if ( executing->Life.terminator != NULL ) {
+ _Thread_Clear_state(
+ executing->Life.terminator,
+ STATES_WAITING_FOR_TERMINATION
+ _Assert_Not_reached();
+ } else {
+ if ( _Thread_Is_life_terminating( executing->Life.state ) ) {
+ /* Someone deleted us in the mean-time */
+ _Thread_Start_life_change_for_executing( executing );
+ } else {
+ _Assert(
+ executing->Life.state = THREAD_LIFE_NORMAL;
+ _Thread_Load_environment( executing );
+ _Thread_Restart_self( executing );
static void _Thread_Start_life_change(
@@ -64,10 +230,78 @@ static void _Thread_Start_life_change(
static void _Thread_Request_life_change(
- Priority_Control priority
+ Priority_Control priority,
+ Thread_Life_state additional_life_state
- _Thread_Start_life_change( the_thread, priority );
+ Per_CPU_Control *cpu;
+ ISR_Level level;
+ cpu = _Thread_Action_ISR_disable_and_acquire( the_thread, &level );
+ previous_life_state = the_thread->Life.state;
+ the_thread->Life.state = previous_life_state | additional_life_state;
+ _Thread_Action_release_and_ISR_enable( cpu, level );
+ if ( the_thread == executing ) {
+ executing->real_priority = priority;
+ _Thread_Set_priority( executing, priority );
+ } else if ( previous_life_state == THREAD_LIFE_NORMAL ) {
+ _Thread_Start_life_change( the_thread, priority );
+ } else {
+ _Thread_Clear_state( the_thread, STATES_SUSPENDED );
+ if ( _Thread_Is_life_terminating( additional_life_state ) ) {
+ the_thread->real_priority = _Scheduler_Highest_priority_of_two(
+ the_thread->real_priority,
+ priority
+ if (
+ _Scheduler_Is_priority_higher_than(
+ priority,
+ the_thread->current_priority
+ _Thread_Change_priority( the_thread, priority, false );
+ _Assert( _Thread_Is_life_protected( executing->Life.state ) );
+ _Objects_Close(
+ if ( _States_Is_dormant( the_thread->current_state ) ) {
+ _Thread_Make_zombie( the_thread );
+ } else {
+ if (
+ the_thread != executing
+ && !_Thread_Is_life_terminating( executing->Life.state )
+ * Wait for termination of victim thread. If the executing thread is
+ * also terminated, then do not wait. This avoids potential cyclic
+ * dependencies and thus dead lock.
+ the_thread->Life.terminator = executing;
+ _Thread_Set_state( executing, STATES_WAITING_FOR_TERMINATION );
+ _Thread_Request_life_change(
+ the_thread,
+ executing,
+ executing->current_priority,
@@ -84,7 +318,8 @@ bool _Thread_Restart(
the_thread,
executing,
- the_thread->Start.initial_priority
+ the_thread->Start.initial_priority,
return true;
@@ -92,3 +327,59 @@ bool _Thread_Restart(
return false;
+ ISR_Level level;
+ Thread_Control *executing;
+ cpu = _Thread_Action_ISR_disable_and_acquire_for_executing( &level );
+ executing = cpu->executing;
+ previous_life_protection = _Thread_Is_life_protected( previous_life_state );
+ if ( protect ) {
+ executing->Life.state = previous_life_state | THREAD_LIFE_PROTECTED;
+ } else {
+ executing->Life.state = previous_life_state & ~THREAD_LIFE_PROTECTED;
+ * On SMP configurations it is possible that a life change of an executing
+ * thread is requested, but this thread didn't notice it yet. The life
+ * change is first marked in the life state field and then all scheduling and
+ * other thread state updates are performed. The last step is to issues an
+ * inter-processor interrupt if necessary. Since this takes some time we
+ * have to synchronize here.
+ if (
+ !_Thread_Is_life_protected( previous_life_state )
+ && _Thread_Is_life_changing( previous_life_state )
+#endif
+ if (
+ !protect
+ return previous_life_protection;
diff --git a/cpukit/score/src/userextiterate.c b/cpukit/score/src/userextiterate.c
index c912501..beeee95 100644
--- a/cpukit/score/src/userextiterate.c
+++ b/cpukit/score/src/userextiterate.c
@@ -124,6 +124,20 @@ void _User_extensions_Fatal_visitor(
+ void *arg,
+ User_extensions_thread_terminate_extension callout =
+ callouts->thread_terminate;
+ if ( callout != NULL ) {
+ (*callout)( executing );
void _User_extensions_Iterate(
void *arg,
User_extensions_Visitor visitor
diff --git a/testsuites/psxtests/psxcleanup01/init.c b/testsuites/psxtests/psxcleanup01/init.c
index d29a891..f38b48e 100644
--- a/testsuites/psxtests/psxcleanup01/init.c
+++ b/testsuites/psxtests/psxcleanup01/init.c
@@ -96,6 +96,15 @@ static void test_restart_with_cleanup(void)
wait_for_restart_task();
rtems_test_assert(restart_cleanup_arg == 1);
+ wait_for_restart_task();
+ sc = rtems_task_delete(id);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ rtems_test_assert(restart_cleanup_arg == 2);
static void cleaner(void *arg)
diff --git a/testsuites/smptests/smpthreadlife01/init.c b/testsuites/smptests/smpthreadlife01/init.c
index ee36068..83e742e 100644
--- a/testsuites/smptests/smpthreadlife01/init.c
+++ b/testsuites/smptests/smpthreadlife01/init.c
@@ -19,6 +19,7 @@
#include "tmacros.h"
+#include <rtems/libcsupport.h>
#include <rtems/score/smpbarrier.h>
const char rtems_test_name[] = "SMPTHREADLIFE 1";
@@ -28,6 +29,7 @@ const char rtems_test_name[] = "SMPTHREADLIFE 1";
typedef struct {
volatile rtems_task_argument main_arg;
volatile rtems_task_argument worker_arg;
+ volatile bool terminated;
SMP_barrier_Control barrier;
SMP_barrier_State worker_barrier_state;
} test_context;
@@ -37,6 +39,29 @@ static test_context test_instance = {
.worker_barrier_state = SMP_BARRIER_STATE_INITIALIZER
+static void restart_extension(
+ rtems_test_assert(executing == restarted);
+static void delete_extension(
+ rtems_test_assert(executing != deleted);
+static void terminate_extension(Thread_Control *executing)
+ test_context *ctx = &test_instance;
+ ctx->terminated = true;
static void worker_task(rtems_task_argument arg)
@@ -59,6 +84,9 @@ static void test(void)
rtems_status_code sc;
rtems_id id;
rtems_task_argument arg;
+ rtems_resource_snapshot snapshot;
+ rtems_resource_snapshot_take(&snapshot);
sc = rtems_task_create(
rtems_build_name('W', 'O', 'R', 'K'),
@@ -90,6 +118,42 @@ static void test(void)
rtems_test_assert(ctx->worker_arg == arg);
+ rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
+ for (arg = 31; arg < 57; ++arg) {
+ ctx->main_arg = arg;
+ ctx->worker_arg = 0;
+ ctx->terminated = false;
+ sc = rtems_task_create(
+ rtems_build_name('W', 'O', 'R', 'K'),
+ 1,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &id
+ sc = rtems_task_start(id, worker_task, arg);
+ _SMP_barrier_Wait(&ctx->barrier, &barrier_state, CPU_COUNT);
+ rtems_test_assert(ctx->worker_arg == arg);
+ rtems_test_assert(!ctx->terminated);
+ rtems_test_assert(ctx->terminated);
static void Init(rtems_task_argument arg)
@@ -113,7 +177,13 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_INITIAL_EXTENSIONS \
+ .thread_restart = restart_extension, \
+ .thread_delete = delete_extension, \
+ .thread_terminate = terminate_extension \
+ RTEMS_TEST_INITIAL_EXTENSION
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/smptests/smpunsupported01/init.c b/testsuites/smptests/smpunsupported01/init.c
index ffa4013..3a819b8 100644
--- a/testsuites/smptests/smpunsupported01/init.c
+++ b/testsuites/smptests/smpunsupported01/init.c
@@ -28,9 +28,6 @@ static void test(void)
rtems_test_assert(rtems_configuration_is_smp_enabled());
- sc = rtems_task_delete(RTEMS_SELF);
- rtems_test_assert(sc == RTEMS_NOT_IMPLEMENTED);
sc = rtems_task_variable_add(RTEMS_SELF, NULL, NULL);
1.7.7
