[PATCH 3/3] score: Delete CORE_mutex_Control::lock
Thu Mar 27 13:49:43 UTC 2014
The holder field is enough to determine if a mutex is locked or not.
 cpukit/libmisc/monitor/mon-sema.c                |    8 +++++---
 cpukit/posix/src/mutexinit.c                     |    7 +------
 cpukit/rtems/src/semcreate.c                     |    2 +-
 cpukit/score/include/rtems/score/coremutex.h     |    3 ---
 cpukit/score/include/rtems/score/coremuteximpl.h |   20 +++++---------------
 cpukit/score/src/apimutex.c                      |    2 +-
 cpukit/score/src/coremutex.c                     |    5 ++---
 cpukit/score/src/coremutexsurrender.c            |    3 +--
 8 files changed, 16 insertions(+), 34 deletions(-)
diff --git a/cpukit/libmisc/monitor/mon-sema.c b/cpukit/libmisc/monitor/mon-sema.c
index df474ea..1044866 100644
--- a/cpukit/libmisc/monitor/mon-sema.c
+++ b/cpukit/libmisc/monitor/mon-sema.c
@@ -35,15 +35,17 @@ rtems_monitor_sema_canonical(
 	rtems_sema->Core_control.semaphore.Attributes.maximum_count;
     else {
+      /* we have a binary semaphore (mutex) */
       Thread_Control *holder = rtems_sema->Core_control.mutex.holder;
       if (holder != NULL) {
         canonical_sema->holder_id = holder->Object.id;
+        canonical_sema->cur_count = 0;
+      } else {
+        canonical_sema->cur_count = 1;
-      /* we have a binary semaphore (mutex) */
-      canonical_sema->cur_count        = rtems_sema->Core_control.mutex.lock;
-      canonical_sema->max_count        = 1; /* mutex is either 0 or 1 */
+      canonical_sema->max_count = 1; /* mutex is either 0 or 1 */
diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
index 73d3101..fdaa609 100644
--- a/cpukit/posix/src/mutexinit.c
+++ b/cpukit/posix/src/mutexinit.c
@@ -172,12 +172,7 @@ int pthread_mutex_init(
    *  Must be initialized to unlocked.
-  _CORE_mutex_Initialize(
-    &the_mutex->Mutex,
-    NULL,
-    the_mutex_attr,
-    CORE_MUTEX_UNLOCKED
+  _CORE_mutex_Initialize( &the_mutex->Mutex, NULL, the_mutex_attr, false );
   _Objects_Open_u32( &_POSIX_Mutex_Information, &the_mutex->Object, 0 );
diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
index 5cd9568..fb597d1 100644
--- a/cpukit/rtems/src/semcreate.c
+++ b/cpukit/rtems/src/semcreate.c
@@ -179,7 +179,7 @@ rtems_status_code rtems_semaphore_create(
       &the_semaphore->Core_control.mutex,
       _Thread_Get_executing(),
       &the_mutex_attr,
-      (count == 1) ? CORE_MUTEX_UNLOCKED : CORE_MUTEX_LOCKED
+      count != 1
     if ( mutex_status == CORE_MUTEX_STATUS_CEILING_VIOLATED ) {
diff --git a/cpukit/score/include/rtems/score/coremutex.h b/cpukit/score/include/rtems/score/coremutex.h
index a29aee5..ccf6066 100644
--- a/cpukit/score/include/rtems/score/coremutex.h
+++ b/cpukit/score/include/rtems/score/coremutex.h
@@ -155,9 +155,6 @@ typedef struct {
    *  behavior.
   CORE_mutex_Attributes   Attributes;
-  /** This element contains the current state of the mutex.
-  uint32_t                lock;
   /** This element contains the number of times the mutex has been acquired
    *  nested.  This must be zero (0) before the mutex is actually unlocked.
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index 4978438..cf327e8 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -99,16 +99,6 @@ typedef enum {
 #define CORE_MUTEX_STATUS_LAST CORE_MUTEX_STATUS_CEILING_VIOLATED
- *  This is the value of a mutex when it is unlocked.
-#define CORE_MUTEX_UNLOCKED 1
- *  This is the value of a mutex when it is locked.
-#define CORE_MUTEX_LOCKED   0
  *  @brief Initializes the mutex based on the parameters passed.
  *  This routine initializes the mutex based on the parameters passed.
@@ -117,7 +107,8 @@ typedef enum {
  *  @param[in,out] executing The currently executing thread.
  *  @param[in] the_mutex_attributes is the attributes associated with this
  *         mutex instance
- *  @param[in] initial_lock is the initial value of the mutex
+ *  @param[in] initially_locked If true, then the mutex is initially locked by
+ *  the executing thread.
  *  @retval This method returns CORE_MUTEX_STATUS_SUCCESSFUL if successful.
@@ -125,7 +116,7 @@ CORE_mutex_Status _CORE_mutex_Initialize(
   CORE_mutex_Control           *the_mutex,
   Thread_Control               *executing,
   const CORE_mutex_Attributes  *the_mutex_attributes,
-  uint32_t                      initial_lock
+  bool                          initially_locked
@@ -357,7 +348,7 @@ RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_locked(
-  return the_mutex->lock == CORE_MUTEX_LOCKED;
+  return the_mutex->holder != NULL;
@@ -452,7 +443,6 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock_body(
   executing->Wait.return_code = CORE_MUTEX_STATUS_SUCCESSFUL;
   if ( !_CORE_mutex_Is_locked( the_mutex ) ) {
-    the_mutex->lock       = CORE_MUTEX_LOCKED;
     the_mutex->holder     = executing;
     the_mutex->nest_count = 1;
     if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ||
@@ -499,7 +489,7 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock_body(
       /* if ( current < ceiling ) */ {
         executing->Wait.return_code = CORE_MUTEX_STATUS_CEILING_VIOLATED;
-        the_mutex->lock       = CORE_MUTEX_UNLOCKED;
+        the_mutex->holder = NULL;
         the_mutex->nest_count = 0;     /* undo locking above */
         executing->resource_count--;   /* undo locking above */
         _ISR_Enable( level );
diff --git a/cpukit/score/src/apimutex.c b/cpukit/score/src/apimutex.c
index 7899934..ec2fbdc 100644
--- a/cpukit/score/src/apimutex.c
+++ b/cpukit/score/src/apimutex.c
@@ -61,7 +61,7 @@ void _API_Mutex_Allocate(
   mutex = (API_Mutex_Control *)
     _Objects_Allocate_unprotected( &_API_Mutex_Information );
-  _CORE_mutex_Initialize( &mutex->Mutex, NULL, &attr, CORE_MUTEX_UNLOCKED );
+  _CORE_mutex_Initialize( &mutex->Mutex, NULL, &attr, false );
   _Objects_Open_u32( &_API_Mutex_Information, &mutex->Object, 1 );
diff --git a/cpukit/score/src/coremutex.c b/cpukit/score/src/coremutex.c
index 1c6c3db..96b11c9 100644
--- a/cpukit/score/src/coremutex.c
+++ b/cpukit/score/src/coremutex.c
@@ -27,7 +27,7 @@ CORE_mutex_Status _CORE_mutex_Initialize(
@@ -37,9 +37,8 @@ CORE_mutex_Status _CORE_mutex_Initialize(
   the_mutex->Attributes    = *the_mutex_attributes;
-  the_mutex->lock          = initial_lock;
-  if ( initial_lock == CORE_MUTEX_LOCKED ) {
+  if ( initially_locked ) {
diff --git a/cpukit/score/src/coremutexsurrender.c b/cpukit/score/src/coremutexsurrender.c
index de1c744..fff3cd7 100644
--- a/cpukit/score/src/coremutexsurrender.c
+++ b/cpukit/score/src/coremutexsurrender.c
@@ -217,8 +217,7 @@ CORE_mutex_Status _CORE_mutex_Surrender(
           break;
-  } else
   return CORE_MUTEX_STATUS_SUCCESSFUL;
1.7.7
