[PATCH 4/9] spport_err01: New test split from sp09
Jennifer Averett
jennifer.averett at oarcorp.com
Thu Mar 27 15:30:01 UTC 2014
This test verifies rtems_port_XXX error tests from sp09 screen 9.
testsuites/sptests/Makefile.am | 2 +-
testsuites/sptests/configure.ac | 1 +
testsuites/sptests/sp09/Makefile.am | 2 +-
testsuites/sptests/sp09/screen09.c | 150 -----------------------
testsuites/sptests/sp09/sp09.scn | 10 --
testsuites/sptests/sp09/system.h | 2 -
testsuites/sptests/sp09/task1.c | 3 -
testsuites/sptests/spport_err01/Makefile.am | 22 ++++
testsuites/sptests/spport_err01/init.c | 150 +++++++++++++++++++++++
testsuites/sptests/spport_err01/spport_err01.doc | 25 ++++
testsuites/sptests/spport_err01/spport_err01.scn | 11 ++
testsuites/sptests/spport_err01/system.h | 64 ++++++++++
12 files changed, 275 insertions(+), 167 deletions(-)
delete mode 100644 testsuites/sptests/sp09/screen09.c
create mode 100644 testsuites/sptests/spport_err01/Makefile.am
create mode 100644 testsuites/sptests/spport_err01/init.c
create mode 100644 testsuites/sptests/spport_err01/spport_err01.doc
create mode 100644 testsuites/sptests/spport_err01/spport_err01.scn
create mode 100644 testsuites/sptests/spport_err01/system.h
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index a4c3b01..625b6d6 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -30,7 +30,7 @@ SUBDIRS = \
spsimplesched03 spnsext01 spedfsched01 spedfsched02 spedfsched03 \
spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
spregion_err01 sppartition_err01 spratemon_err01 spintr_err01 \
- spsignal_err01
+ spsignal_err01 spport_err01
SUBDIRS += spprofiling01
SUBDIRS += spcache01
SUBDIRS += sptls03
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 62ab10c..809957d 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -197,6 +197,7 @@ spnotepad01/Makefile
spnsext01/Makefile
spobjgetnext/Makefile
sppagesize/Makefile
+spport_err01/Makefile
spprintk/Makefile
spprivenv01/Makefile
spqreslib/Makefile
diff --git a/testsuites/sptests/sp09/Makefile.am b/testsuites/sptests/sp09/Makefile.am
index f486853..5e92d87 100644
--- a/testsuites/sptests/sp09/Makefile.am
+++ b/testsuites/sptests/sp09/Makefile.am
@@ -1,7 +1,7 @@
rtems_tests_PROGRAMS = sp09
sp09_SOURCES = init.c delay.c isr.c screen01.c screen02.c screen03.c screen04.c \
- screen05.c screen06.c screen07.c screen08.c screen09.c \
+ screen05.c screen06.c screen07.c screen08.c \
task1.c task2.c task3.c \
system.h
diff --git a/testsuites/sptests/sp09/screen09.c b/testsuites/sptests/sp09/screen09.c
deleted file mode 100644
index f0c0ccc..0000000
--- a/testsuites/sptests/sp09/screen09.c
+++ /dev/null
@@ -1,150 +0,0 @@
-/* Screen9
- * This routine generates error screen 9 for test 9.
- * Input parameters: NONE
- * Output parameters: NONE
- * COPYRIGHT (c) 1989-2009.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include "system.h"
-void Screen9()
- void *converted;
- rtems_status_code status;
- status = rtems_port_create(
- 0,
- Internal_port_area,
- External_port_area,
- sizeof( Internal_port_area ),
- &Junk_id
- fatal_directive_status(
- status,
- RTEMS_INVALID_NAME,
- "rtems_port_create with illegal name"
- puts( "TA1 - rtems_port_create - RTEMS_INVALID_NAME" );
-#if defined(_C3x) || defined(_C4x)
- puts( "TA1 - rtems_port_create - RTEMS_INVALID_ADDRESS - SKIPPED" );
-#else
- Port_name[ 1 ],
- &((char *)Internal_port_area)[ 1 ],
- &Junk_id
- status,
- RTEMS_INVALID_ADDRESS,
- "rtems_port_create with illegal address"
- puts( "TA1 - rtems_port_create - bad range - RTEMS_INVALID_ADDRESS" );
-#endif
- Port_name[ 1 ],
- NULL
- status,
- "rtems_port_create null Id"
- puts( "TA1 - rtems_port_create - null id - RTEMS_INVALID_ADDRESS" );
- Port_name[ 1 ],
- &Junk_id
- status,
- RTEMS_TOO_MANY,
- "rtems_port_create of too many"
- puts( "TA1 - rtems_port_create - RTEMS_TOO_MANY" );
- status = rtems_port_delete( 0 );
- status,
- RTEMS_INVALID_ID,
- "rtems_port_delete with illegal id"
- puts( "TA1 - rtems_port_delete - RTEMS_INVALID_ID" );
- status = rtems_port_ident( 0, &Junk_id );
- status,
- "rtems_port_ident with illegal name"
- puts( "TA1 - rtems_port_ident - RTEMS_INVALID_NAME" );
- status = rtems_port_external_to_internal(
- 100,
- &converted
- status,
- RTEMS_INVALID_ID,
- "rtems_port_external_to_internal with illegal id"
- 100,
- NULL
- status,
- "rtems_port_external_to_internal with NULL param"
- puts( "TA1 - rtems_port_external_to_internal - RTEMS_INVALID_ADDRESS" );
- status = rtems_port_internal_to_external(
- 100,
- &converted
- status,
- RTEMS_INVALID_ID,
- "rtems_port_internal_to_external with illegal id"
- puts( "TA1 - rtems_port_internal_to_external - RTEMS_INVALID_ID" );
- 100,
- NULL
- status,
- "rtems_port_internal_to_external with NULL param"
diff --git a/testsuites/sptests/sp09/sp09.scn b/testsuites/sptests/sp09/sp09.scn
index a7d6615..5807ebe 100644
--- a/testsuites/sptests/sp09/sp09.scn
+++ b/testsuites/sptests/sp09/sp09.scn
@@ -175,14 +175,4 @@ TA1 - rtems_message_queue_delete - delete Q 1 - RTEMS_SUCCESSFUL
TA1 - rtems_task_wake_after - yield processor - RTEMS_SUCCESSFUL
TA3 - rtems_message_queue_receive - woke up with RTEMS_OBJECT_WAS_DELETED
TA3 - rtems_task_delete - delete self - RTEMS_SUCCESSFUL
-<pause - screen 9>
-TA1 - rtems_port_create - RTEMS_INVALID_NAME
-TA1 - rtems_port_create - bad range - RTEMS_INVALID_ADDRESS
-TA1 - rtems_port_create - null id - RTEMS_INVALID_ADDRESS
-TA1 - rtems_port_create - RTEMS_TOO_MANY
-TA1 - rtems_port_delete - RTEMS_INVALID_ID
-TA1 - rtems_port_ident - RTEMS_INVALID_NAME
-TA1 - rtems_port_external_to_internal - RTEMS_INVALID_ADDRESS
-TA1 - rtems_port_internal_to_external - RTEMS_INVALID_ID
*** END OF TEST 9 ***
diff --git a/testsuites/sptests/sp09/system.h b/testsuites/sptests/sp09/system.h
index 2e1b4df..92d66fd 100644
--- a/testsuites/sptests/sp09/system.h
+++ b/testsuites/sptests/sp09/system.h
@@ -61,8 +61,6 @@ void Screen7( void );
void Screen8( void );
-void Screen9( void );
/* configuration information */
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
diff --git a/testsuites/sptests/sp09/task1.c b/testsuites/sptests/sp09/task1.c
index 1e8bf6f..6ebb5c1 100644
--- a/testsuites/sptests/sp09/task1.c
+++ b/testsuites/sptests/sp09/task1.c
@@ -47,9 +47,6 @@ rtems_task Task_1(
rtems_test_pause_and_screen_number( 8 );
Screen8();
- rtems_test_pause_and_screen_number( 9 );
- Screen9();
puts( "*** END OF TEST 9 ***" );
rtems_test_exit( 0 );
diff --git a/testsuites/sptests/spport_err01/Makefile.am b/testsuites/sptests/spport_err01/Makefile.am
new file mode 100644
index 0000000..8617a4b
--- /dev/null
+++ b/testsuites/sptests/spport_err01/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = spport_err01
+spport_err01_SOURCES = init.c system.h
+dist_rtems_tests_DATA = spport_err01.scn
+dist_rtems_tests_DATA += spport_err01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spport_err01_OBJECTS)
+LINK_LIBS = $(spport_err01_LDLIBS)
+spport_err01$(EXEEXT): $(spport_err01_OBJECTS) $(spport_err01_DEPENDENCIES)
+ @rm -f spport_err01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spport_err01/init.c b/testsuites/sptests/spport_err01/init.c
index 0000000..baab6c6
--- /dev/null
+++ b/testsuites/sptests/spport_err01/init.c
@@ -0,0 +1,150 @@
+ * COPYRIGHT (c) 2014.
+ * On-Line Applications Research Corporation (OAR).
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+rtems_task Init(
+ rtems_task_argument argument
+ void *converted;
+ rtems_status_code status;
+ puts( "\n\n*** TEST PORT ERROR 01 ***" );
+ Port_name[ 1 ] = rtems_build_name( 'D', 'P', '1', ' ' );
+ status = rtems_port_create(
+ 0,
+ Internal_port_area,
+ External_port_area,
+ sizeof( Internal_port_area ),
+ &Junk_id
+ fatal_directive_status(
+ status,
+ RTEMS_INVALID_NAME,
+ "rtems_port_create with illegal name"
+ puts( "TA1 - rtems_port_create - RTEMS_INVALID_NAME" );
+#if defined(_C3x) || defined(_C4x)
+ puts( "TA1 - rtems_port_create - RTEMS_INVALID_ADDRESS - SKIPPED" );
+#else
+ Port_name[ 1 ],
+ &((char *)Internal_port_area)[ 1 ],
+ &Junk_id
+ status,
+ RTEMS_INVALID_ADDRESS,
+ "rtems_port_create with illegal address"
+ puts( "TA1 - rtems_port_create - bad range - RTEMS_INVALID_ADDRESS" );
+#endif
+ Port_name[ 1 ],
+ NULL
+ status,
+ "rtems_port_create null Id"
+ puts( "TA1 - rtems_port_create - null id - RTEMS_INVALID_ADDRESS" );
+ Port_name[ 1 ],
+ &Junk_id
+ status,
+ RTEMS_TOO_MANY,
+ "rtems_port_create of too many"
+ puts( "TA1 - rtems_port_create - RTEMS_TOO_MANY" );
+ status = rtems_port_delete( 0 );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_port_delete with illegal id"
+ puts( "TA1 - rtems_port_delete - RTEMS_INVALID_ID" );
+ status = rtems_port_ident( 0, &Junk_id );
+ status,
+ "rtems_port_ident with illegal name"
+ puts( "TA1 - rtems_port_ident - RTEMS_INVALID_NAME" );
+ status = rtems_port_external_to_internal(
+ 100,
+ &converted
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_port_external_to_internal with illegal id"
+ 100,
+ NULL
+ status,
+ "rtems_port_external_to_internal with NULL param"
+ puts( "TA1 - rtems_port_external_to_internal - RTEMS_INVALID_ADDRESS" );
+ status = rtems_port_internal_to_external(
+ 100,
+ &converted
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_port_internal_to_external with illegal id"
+ puts( "TA1 - rtems_port_internal_to_external - RTEMS_INVALID_ID" );
+ 100,
+ NULL
+ status,
+ "rtems_port_internal_to_external with NULL param"
+ puts( "*** END TEST PORT ERROR 01 ***" );
diff --git a/testsuites/sptests/spport_err01/spport_err01.doc b/testsuites/sptests/spport_err01/spport_err01.doc
index 0000000..8dec606
--- /dev/null
+++ b/testsuites/sptests/spport_err01/spport_err01.doc
@@ -0,0 +1,25 @@
+# COPYRIGHT (c) 1989-2014.
+# On-Line Applications Research Corporation (OAR).
+# The license and distribution terms for this file may be
+# found in the file LICENSE in this distribution or at
+# http://www.rtems.com/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name: spport_err01
+directives:
+ p_create, p_delete, p_ident, p_extoin
+concepts:
+ a. Verifies all error codes returned by the executive in single
+ processor configurations.
+ b. Verifies error conditions in the following kernel routines or macros:
+ _Ck_date_time, _Expired, _Q_submit, _Get_mnodes, _Get_node,
+ _Free_mem, _Get_mem, _Valid_block, _Set_tcb, _Set_resource,
+ _In_range, _On_boundary
diff --git a/testsuites/sptests/spport_err01/spport_err01.scn b/testsuites/sptests/spport_err01/spport_err01.scn
index 0000000..6c0499a
--- /dev/null
+++ b/testsuites/sptests/spport_err01/spport_err01.scn
@@ -0,0 +1,11 @@
+*** TEST PORT ERROR 01 ***
+TA1 - rtems_port_create - RTEMS_INVALID_NAME
+TA1 - rtems_port_create - bad range - RTEMS_INVALID_ADDRESS
+TA1 - rtems_port_create - null id - RTEMS_INVALID_ADDRESS
+TA1 - rtems_port_create - RTEMS_TOO_MANY
+TA1 - rtems_port_delete - RTEMS_INVALID_ID
+TA1 - rtems_port_ident - RTEMS_INVALID_NAME
+TA1 - rtems_port_external_to_internal - RTEMS_INVALID_ADDRESS
+TA1 - rtems_port_internal_to_external - RTEMS_INVALID_ID
+*** END TEST PORT ERROR 01 ***
diff --git a/testsuites/sptests/spport_err01/system.h b/testsuites/sptests/spport_err01/system.h
index 0000000..76426b2
--- /dev/null
+++ b/testsuites/sptests/spport_err01/system.h
@@ -0,0 +1,64 @@
+ * This include file contains information that is included in every
+ * function in the test set.
+ * COPYRIGHT (c) 1989-2014.
+#include <tmacros.h>
+/* functions */
+rtems_task Init(
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 10
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES 2
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
+#define CONFIGURE_MAXIMUM_PERIODS 1
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 0
+#define CONFIGURE_TICKS_PER_TIMESLICE 100
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_EXTRA_TASK_STACKS (20 * RTEMS_MINIMUM_STACK_SIZE)
+#include <rtems/confdefs.h>
+/* global variables */
+TEST_EXTERN rtems_id Task_id[ 11 ]; /* array of task ids */
+TEST_EXTERN rtems_name Task_name[ 11 ]; /* array of task names */
+TEST_EXTERN rtems_name Semaphore_name[ 4 ]; /* array of semaphore names */
+TEST_EXTERN rtems_id Semaphore_id[ 4 ]; /* array of semaphore ids */
+TEST_EXTERN rtems_name Queue_name[ 3 ]; /* array of queue names */
+TEST_EXTERN rtems_id Queue_id[ 3 ]; /* array of queue ids */
+TEST_EXTERN rtems_name Port_name[ 2 ]; /* array of port names */
+TEST_EXTERN rtems_id Port_id[ 2 ]; /* array of port ids */
+TEST_EXTERN rtems_name Period_name[ 2 ]; /* array of period names */
+TEST_EXTERN rtems_id Period_id[ 2 ]; /* array of period ids */
+TEST_EXTERN rtems_id Junk_id; /* id used to return errors */
+#define Internal_port_area (void *) 0x00001000
+#define External_port_area (void *) 0x00002000
+/* end of include file */
1.8.1.4
