[PATCH 7/9] spevent_err03: New test split from sp09 screen 4.
Jennifer Averett
jennifer.averett at oarcorp.com
Thu Mar 27 15:30:04 UTC 2014
testsuites/sptests/Makefile.am | 2 +-
testsuites/sptests/configure.ac | 1 +
testsuites/sptests/sp09/Makefile.am | 2 +-
testsuites/sptests/sp09/screen04.c | 108 ---------------------
testsuites/sptests/sp09/sp09.scn | 11 ---
testsuites/sptests/sp09/task1.c | 3 -
testsuites/sptests/spevent_err03/Makefile.am | 22 +++++
testsuites/sptests/spevent_err03/init.c | 107 ++++++++++++++++++++
testsuites/sptests/spevent_err03/spevent_err03.doc | 25 +++++
testsuites/sptests/spevent_err03/spevent_err03.scn | 12 +++
testsuites/sptests/spevent_err03/system.h | 47 +++++++++
11 files changed, 216 insertions(+), 124 deletions(-)
delete mode 100644 testsuites/sptests/sp09/screen04.c
create mode 100644 testsuites/sptests/spevent_err03/Makefile.am
create mode 100644 testsuites/sptests/spevent_err03/init.c
create mode 100644 testsuites/sptests/spevent_err03/spevent_err03.doc
create mode 100644 testsuites/sptests/spevent_err03/spevent_err03.scn
create mode 100644 testsuites/sptests/spevent_err03/system.h
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index a09c5d5..d5e43ae 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -31,7 +31,7 @@ SUBDIRS = \
spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
spregion_err01 sppartition_err01 spratemon_err01 spintr_err01 \
spsignal_err01 spport_err01 spmsgq_err01 spmsgq_err02 spsem_err01 \
- spsem_err02 sptask_err01
+ spsem_err02 sptask_err01 spevent_err03
SUBDIRS += spprofiling01
SUBDIRS += spcache01
SUBDIRS += sptls03
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index db0c0a2..545d1f8 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -143,6 +143,7 @@ spedfsched03/Makefile
sperror01/Makefile
sperror02/Makefile
sperror03/Makefile
+spevent_err03/Makefile
spfatal01/Makefile
spfatal02/Makefile
spfatal03/Makefile
diff --git a/testsuites/sptests/sp09/Makefile.am b/testsuites/sptests/sp09/Makefile.am
index b001205..2b4e16f 100644
--- a/testsuites/sptests/sp09/Makefile.am
+++ b/testsuites/sptests/sp09/Makefile.am
@@ -1,6 +1,6 @@
rtems_tests_PROGRAMS = sp09
-sp09_SOURCES = init.c delay.c isr.c screen01.c screen02.c screen03.c screen04.c \
+sp09_SOURCES = init.c delay.c isr.c screen01.c screen02.c screen03.c \
task1.c task2.c task3.c \
system.h
diff --git a/testsuites/sptests/sp09/screen04.c b/testsuites/sptests/sp09/screen04.c
deleted file mode 100644
index 99f5fc0..0000000
--- a/testsuites/sptests/sp09/screen04.c
+++ /dev/null
@@ -1,108 +0,0 @@
-/* Screen4
- * This routine generates error screen 4 for test 9.
- * Input parameters: NONE
- * Output parameters: NONE
- * COPYRIGHT (c) 1989-2009.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include "system.h"
-void Screen4()
- rtems_event_set event_out;
- rtems_time_of_day time;
- struct timeval tv;
- time_t seconds;
- rtems_status_code status;
- status = rtems_event_receive(
- RTEMS_EVENT_16,
- RTEMS_NO_WAIT,
- RTEMS_NO_TIMEOUT,
- NULL
- fatal_directive_status(
- status,
- RTEMS_INVALID_ADDRESS,
- "rtems_event_receive NULL param"
- puts( "TA1 - rtems_event_receive - NULL param - RTEMS_INVALID_ADDRESS" );
- RTEMS_EVENT_16,
- RTEMS_NO_WAIT,
- RTEMS_NO_TIMEOUT,
- &event_out
- status,
- RTEMS_UNSATISFIED,
- "rtems_event_receive unsatisfied (ALL)"
- puts( "TA1 - rtems_event_receive - RTEMS_UNSATISFIED ( all conditions )" );
- RTEMS_EVENT_16,
- RTEMS_EVENT_ANY | RTEMS_NO_WAIT,
- RTEMS_NO_TIMEOUT,
- &event_out
- status,
- "rtems_event_receive unsatisfied (ANY)"
- puts( "TA1 - rtems_event_receive - RTEMS_UNSATISFIED ( any condition )" );
- puts( "TA1 - rtems_event_receive - timeout in 3 seconds" );
- RTEMS_EVENT_16,
- RTEMS_DEFAULT_OPTIONS,
- 3 * rtems_clock_get_ticks_per_second(),
- &event_out
- status,
- RTEMS_TIMEOUT,
- "rtems_event_receive"
- puts( "TA1 - rtems_event_receive - woke up with RTEMS_TIMEOUT" );
- status = rtems_event_send( 100, RTEMS_EVENT_16 );
- status,
- RTEMS_INVALID_ID,
- "rtems_event_send with illegal id"
- puts( "TA1 - rtems_event_send - RTEMS_INVALID_ID" );
- puts( "TA1 - rtems_task_wake_after - sleep 1 second - RTEMS_SUCCESSFUL" );
- status = rtems_task_wake_after( rtems_clock_get_ticks_per_second() );
- directive_failed( status, "rtems_task_wake_after" );
- build_time( &time, 2, 5, 1988, 8, 30, 45, 0 );
- print_time( "TA1 - rtems_clock_set - ", &time, "" );
- status = rtems_clock_set( &time );
- directive_failed( status, "rtems_clock_set" );
- puts( " - RTEMS_SUCCESSFUL" );
- status = rtems_clock_get_tod_timeval( &tv );
- directive_failed( status, "clock_get_tod_timeval OK" );
- seconds = tv.tv_sec;
- printf( "TA1 - current time - %s\n", ctime(&seconds) );
diff --git a/testsuites/sptests/sp09/sp09.scn b/testsuites/sptests/sp09/sp09.scn
index db1f2a6..fc35d23 100644
--- a/testsuites/sptests/sp09/sp09.scn
+++ b/testsuites/sptests/sp09/sp09.scn
@@ -73,15 +73,4 @@ TA1 - rtems_task_create - 9 created - RTEMS_SUCCESSFUL
TA1 - rtems_task_create - 10 created - RTEMS_SUCCESSFUL
TA1 - rtems_task_create - 11 - RTEMS_TOO_MANY
TA1 - rtems_task_create - RTEMS_MP_NOT_CONFIGURED
-<pause - screen 4>
-TA1 - rtems_event_receive - NULL param - RTEMS_INVALID_ADDRESS
-TA1 - rtems_event_receive - RTEMS_UNSATISFIED ( all conditions )
-TA1 - rtems_event_receive - RTEMS_UNSATISFIED ( any condition )
-TA1 - rtems_event_receive - timeout in 3 seconds
-TA1 - rtems_event_receive - woke up with RTEMS_TIMEOUT
-TA1 - rtems_event_send - RTEMS_INVALID_ID
-TA1 - rtems_task_wake_after - sleep 1 second - RTEMS_SUCCESSFUL
-TA1 - rtems_clock_set - 08:30:45 02/05/1988 - RTEMS_SUCCESSFUL
-TA1 - current time - Fri Feb 5 08:30:45 1988
*** END OF TEST 9 ***
diff --git a/testsuites/sptests/sp09/task1.c b/testsuites/sptests/sp09/task1.c
index 82daf64..5b09822 100644
--- a/testsuites/sptests/sp09/task1.c
+++ b/testsuites/sptests/sp09/task1.c
@@ -32,9 +32,6 @@ rtems_task Task_1(
rtems_test_pause_and_screen_number( 3 );
Screen3();
- rtems_test_pause_and_screen_number( 4 );
- Screen4();
puts( "*** END OF TEST 9 ***" );
rtems_test_exit( 0 );
diff --git a/testsuites/sptests/spevent_err03/Makefile.am b/testsuites/sptests/spevent_err03/Makefile.am
new file mode 100644
index 0000000..ce31f95
--- /dev/null
+++ b/testsuites/sptests/spevent_err03/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = spevent_err03
+spevent_err03_SOURCES = init.c system.h
+dist_rtems_tests_DATA = spevent_err03.scn
+dist_rtems_tests_DATA += spevent_err03.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spevent_err03_OBJECTS)
+LINK_LIBS = $(spevent_err03_LDLIBS)
+spevent_err03$(EXEEXT): $(spevent_err03_OBJECTS) $(spevent_err03_DEPENDENCIES)
+ @rm -f spevent_err03$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spevent_err03/init.c b/testsuites/sptests/spevent_err03/init.c
index 0000000..3930cd8
--- /dev/null
+++ b/testsuites/sptests/spevent_err03/init.c
@@ -0,0 +1,107 @@
+ * COPYRIGHT (c) 2014.
+ * On-Line Applications Research Corporation (OAR).
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+rtems_task Init(
+ rtems_task_argument argument
+ rtems_event_set event_out;
+ rtems_time_of_day time;
+ struct timeval tv;
+ time_t seconds;
+ rtems_status_code status;
+ puts( "\n\n*** TEST EVENT ERROR 03 ***" );
+ status = rtems_event_receive(
+ RTEMS_EVENT_16,
+ RTEMS_NO_WAIT,
+ RTEMS_NO_TIMEOUT,
+ NULL
+ fatal_directive_status(
+ status,
+ RTEMS_INVALID_ADDRESS,
+ "rtems_event_receive NULL param"
+ puts( "TA1 - rtems_event_receive - NULL param - RTEMS_INVALID_ADDRESS" );
+ RTEMS_EVENT_16,
+ RTEMS_NO_WAIT,
+ RTEMS_NO_TIMEOUT,
+ &event_out
+ status,
+ RTEMS_UNSATISFIED,
+ "rtems_event_receive unsatisfied (ALL)"
+ puts( "TA1 - rtems_event_receive - RTEMS_UNSATISFIED ( all conditions )" );
+ RTEMS_EVENT_16,
+ RTEMS_EVENT_ANY | RTEMS_NO_WAIT,
+ RTEMS_NO_TIMEOUT,
+ &event_out
+ status,
+ "rtems_event_receive unsatisfied (ANY)"
+ puts( "TA1 - rtems_event_receive - RTEMS_UNSATISFIED ( any condition )" );
+ puts( "TA1 - rtems_event_receive - timeout in 3 seconds" );
+ RTEMS_EVENT_16,
+ RTEMS_DEFAULT_OPTIONS,
+ 3 * rtems_clock_get_ticks_per_second(),
+ &event_out
+ status,
+ RTEMS_TIMEOUT,
+ "rtems_event_receive"
+ puts( "TA1 - rtems_event_receive - woke up with RTEMS_TIMEOUT" );
+ status = rtems_event_send( 100, RTEMS_EVENT_16 );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_event_send with illegal id"
+ puts( "TA1 - rtems_event_send - RTEMS_INVALID_ID" );
+ puts( "TA1 - rtems_task_wake_after - sleep 1 second - RTEMS_SUCCESSFUL" );
+ status = rtems_task_wake_after( rtems_clock_get_ticks_per_second() );
+ directive_failed( status, "rtems_task_wake_after" );
+ build_time( &time, 2, 5, 1988, 8, 30, 45, 0 );
+ print_time( "TA1 - rtems_clock_set - ", &time, "" );
+ status = rtems_clock_set( &time );
+ directive_failed( status, "rtems_clock_set" );
+ puts( " - RTEMS_SUCCESSFUL" );
+ status = rtems_clock_get_tod_timeval( &tv );
+ directive_failed( status, "clock_get_tod_timeval OK" );
+ seconds = tv.tv_sec;
+ printf( "TA1 - current time - %s\n", ctime(&seconds) );
+ puts( "*** END TEST EVENT ERROR 03 ***" );
diff --git a/testsuites/sptests/spevent_err03/spevent_err03.doc b/testsuites/sptests/spevent_err03/spevent_err03.doc
index 0000000..9418933
--- /dev/null
+++ b/testsuites/sptests/spevent_err03/spevent_err03.doc
@@ -0,0 +1,25 @@
+# COPYRIGHT (c) 1989-2014.
+# On-Line Applications Research Corporation (OAR).
+# The license and distribution terms for this file may be
+# found in the file LICENSE in this distribution or at
+# http://www.rtems.com/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name: spevent_err03
+directives:
+ ev_receive, ev_send
+concepts:
+ a. Verifies all error codes returned by the executive in single
+ processor configurations.
+ b. Verifies error conditions in the following kernel routines or macros:
+ _Ck_date_time, _Expired, _Q_submit, _Get_mnodes, _Get_node,
+ _Free_mem, _Get_mem, _Valid_block, _Set_tcb, _Set_resource,
+ _In_range, _On_boundary
diff --git a/testsuites/sptests/spevent_err03/spevent_err03.scn b/testsuites/sptests/spevent_err03/spevent_err03.scn
index 0000000..4d0a9e5
--- /dev/null
+++ b/testsuites/sptests/spevent_err03/spevent_err03.scn
@@ -0,0 +1,12 @@
+*** TEST EVENT ERROR 03 ***
+TA1 - rtems_event_receive - NULL param - RTEMS_INVALID_ADDRESS
+TA1 - rtems_event_receive - RTEMS_UNSATISFIED ( all conditions )
+TA1 - rtems_event_receive - RTEMS_UNSATISFIED ( any condition )
+TA1 - rtems_event_receive - timeout in 3 seconds
+TA1 - rtems_event_receive - woke up with RTEMS_TIMEOUT
+TA1 - rtems_event_send - RTEMS_INVALID_ID
+TA1 - rtems_task_wake_after - sleep 1 second - RTEMS_SUCCESSFUL
+TA1 - rtems_clock_set - 08:30:45 02/05/1988 - RTEMS_SUCCESSFUL
+TA1 - current time - Fri Feb 5 08:30:45 1988
+*** END TEST EVENT ERROR 03 ***
diff --git a/testsuites/sptests/spevent_err03/system.h b/testsuites/sptests/spevent_err03/system.h
index 0000000..9cb2b39
--- /dev/null
+++ b/testsuites/sptests/spevent_err03/system.h
@@ -0,0 +1,47 @@
+ * This include file contains information that is included in every
+ * function in the test set.
+ * COPYRIGHT (c) 1989-2014.
+#include <tmacros.h>
+/* functions */
+rtems_task Init(
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 10
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES 2
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
+#define CONFIGURE_MAXIMUM_PERIODS 1
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 0
+#define CONFIGURE_TICKS_PER_TIMESLICE 100
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_EXTRA_TASK_STACKS (20 * RTEMS_MINIMUM_STACK_SIZE)
+#include <rtems/confdefs.h>
+/* global variables */
+TEST_EXTERN rtems_id Task_id[ 11 ]; /* array of task ids */
+TEST_EXTERN rtems_name Task_name[ 11 ]; /* array of task names */
+/* end of include file */
1.8.1.4
