[PATCH 9/9] "sptests: New tests split from sp09 screen 1 and screen 2.
Jennifer Averett
jennifer.averett at oarcorp.com
Thu Mar 27 15:30:06 UTC 2014
Split sp09 screen 1 into new test sptask_err04.
Split sp09 screen 2 into new tests sptask__err02 and spclock_err01,
as well as moving one verification into sptimer_err01.
testsuites/sptests/Makefile.am | 5 +-
testsuites/sptests/configure.ac | 4 +-
testsuites/sptests/sp09/Makefile.am | 24 --
testsuites/sptests/sp09/delay.c | 29 --
testsuites/sptests/sp09/init.c | 104 -------
testsuites/sptests/sp09/isr.c | 28 --
testsuites/sptests/sp09/screen01.c | 266 -----------------
testsuites/sptests/sp09/screen02.c | 313 ---------------------
testsuites/sptests/sp09/sp09.doc | 29 --
testsuites/sptests/sp09/sp09.scn | 59 ----
testsuites/sptests/sp09/system.h | 101 -------
testsuites/sptests/sp09/task1.c | 35 ---
testsuites/sptests/sp09/task2.c | 49 ----
testsuites/sptests/sp09/task3.c | 54 ----
testsuites/sptests/spclock_err01/Makefile.am | 22 ++
testsuites/sptests/spclock_err01/delay.c | 29 ++
testsuites/sptests/spclock_err01/init.c | 216 ++++++++++++++
testsuites/sptests/spclock_err01/spclock_err01.doc | 26 ++
testsuites/sptests/spclock_err01/spclock_err01.scn | 23 ++
testsuites/sptests/spclock_err01/system.h | 69 +++++
testsuites/sptests/sptask_err02/Makefile.am | 22 ++
testsuites/sptests/sptask_err02/init.c | 117 ++++++++
testsuites/sptests/sptask_err02/sptask_err02.doc | 25 ++
testsuites/sptests/sptask_err02/sptask_err02.scn | 12 +
testsuites/sptests/sptask_err02/system.h | 37 +++
testsuites/sptests/sptask_err04/Makefile.am | 22 ++
testsuites/sptests/sptask_err04/init.c | 89 ++++++
testsuites/sptests/sptask_err04/sptask_err04.doc | 27 ++
testsuites/sptests/sptask_err04/sptask_err04.scn | 24 ++
testsuites/sptests/sptask_err04/system.h | 45 +++
testsuites/sptests/sptask_err04/task1.c | 277 ++++++++++++++++++
testsuites/sptests/sptimer_err01/init.c | 15 +
testsuites/sptests/sptimer_err01/sptimer_err01.scn | 2 +-
33 files changed, 1104 insertions(+), 1095 deletions(-)
delete mode 100644 testsuites/sptests/sp09/Makefile.am
delete mode 100644 testsuites/sptests/sp09/delay.c
delete mode 100644 testsuites/sptests/sp09/init.c
delete mode 100644 testsuites/sptests/sp09/isr.c
delete mode 100644 testsuites/sptests/sp09/screen01.c
delete mode 100644 testsuites/sptests/sp09/screen02.c
delete mode 100644 testsuites/sptests/sp09/sp09.doc
delete mode 100644 testsuites/sptests/sp09/sp09.scn
delete mode 100644 testsuites/sptests/sp09/system.h
delete mode 100644 testsuites/sptests/sp09/task1.c
delete mode 100644 testsuites/sptests/sp09/task2.c
delete mode 100644 testsuites/sptests/sp09/task3.c
create mode 100644 testsuites/sptests/spclock_err01/Makefile.am
create mode 100644 testsuites/sptests/spclock_err01/delay.c
create mode 100644 testsuites/sptests/spclock_err01/init.c
create mode 100644 testsuites/sptests/spclock_err01/spclock_err01.doc
create mode 100644 testsuites/sptests/spclock_err01/spclock_err01.scn
create mode 100644 testsuites/sptests/spclock_err01/system.h
create mode 100644 testsuites/sptests/sptask_err02/Makefile.am
create mode 100644 testsuites/sptests/sptask_err02/init.c
create mode 100644 testsuites/sptests/sptask_err02/sptask_err02.doc
create mode 100644 testsuites/sptests/sptask_err02/sptask_err02.scn
create mode 100644 testsuites/sptests/sptask_err02/system.h
create mode 100644 testsuites/sptests/sptask_err04/Makefile.am
create mode 100644 testsuites/sptests/sptask_err04/init.c
create mode 100644 testsuites/sptests/sptask_err04/sptask_err04.doc
create mode 100644 testsuites/sptests/sptask_err04/sptask_err04.scn
create mode 100644 testsuites/sptests/sptask_err04/system.h
create mode 100644 testsuites/sptests/sptask_err04/task1.c
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 1a5e81d..89ad6fe 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -3,7 +3,7 @@ ACLOCAL_AMFLAGS = -I ../aclocal
## Test names are spaced to indicate gaps in numbering from tests being
## deleted over the years.
SUBDIRS = \
- sp01 sp02 sp03 sp04 sp05 sp06 sp07 sp08 sp09 \
+ sp01 sp02 sp03 sp04 sp05 sp06 sp07 sp08 \
sp10 sp11 sp12 sp13 sp14 sp15 sp16 sp17 sp18 sp19 \
sp20 sp21 sp22 sp23 sp24 sp25 sp26 sp27 sp27a sp28 sp29 \
sp30 sp31 sp32 sp33 sp34 sp35 sp37 sp38 sp39 \
@@ -31,7 +31,8 @@ SUBDIRS = \
spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
spregion_err01 sppartition_err01 spratemon_err01 spintr_err01 \
spsignal_err01 spport_err01 spmsgq_err01 spmsgq_err02 spsem_err01 \
- spsem_err02 sptask_err01 spevent_err03 sptask_err03
+ spsem_err02 sptask_err01 spevent_err03 sptask_err03 sptask_err02 \
+ sptask_err04 spclock_err01
SUBDIRS += spprofiling01
SUBDIRS += spcache01
SUBDIRS += sptls03
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index a4f1bda..b20d519 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -59,7 +59,6 @@ sp05/Makefile
sp06/Makefile
sp07/Makefile
sp08/Makefile
-sp09/Makefile
sp10/Makefile
sp11/Makefile
sp12/Makefile
@@ -135,6 +134,7 @@ spcbssched02/Makefile
spcbssched03/Makefile
spchain/Makefile
spclockget/Makefile
+spclock_err01/Makefile
spclock_err02/Makefile
spcoverage/Makefile
spedfsched01/Makefile
@@ -222,7 +222,9 @@ sptimespec01/Makefile
spwatchdog/Makefile
spwkspace/Makefile
sptask_err01/Makefile
+sptask_err02/Makefile
sptask_err03/Makefile
+sptask_err04/Makefile
sptimer_err01/Makefile
sptimer_err02/Makefile
spcpuset01/Makefile
diff --git a/testsuites/sptests/sp09/Makefile.am b/testsuites/sptests/sp09/Makefile.am
deleted file mode 100644
index 2c6f903..0000000
--- a/testsuites/sptests/sp09/Makefile.am
+++ /dev/null
@@ -1,24 +0,0 @@
-rtems_tests_PROGRAMS = sp09
-sp09_SOURCES = init.c delay.c isr.c screen01.c screen02.c \
- task1.c task2.c task3.c \
- system.h
-dist_rtems_tests_DATA = sp09.scn
-dist_rtems_tests_DATA += sp09.doc
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-LINK_OBJS = $(sp09_OBJECTS)
-LINK_LIBS = $(sp09_LDLIBS)
-sp09$(EXEEXT): $(sp09_OBJECTS) $(sp09_DEPENDENCIES)
- @rm -f sp09$(EXEEXT)
- $(make-exe)
-include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/sp09/delay.c b/testsuites/sptests/sp09/delay.c
index cdd54c8..0000000
--- a/testsuites/sptests/sp09/delay.c
+++ /dev/null
@@ -1,29 +0,0 @@
-/* Delayed_routine
- * This routine is used as the timer routine for Timer Manager tests.
- * Input parameters:
- * ignored - this parameter is ignored
- * Output parameters: NONE
- * COPYRIGHT (c) 1989-1999.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include "system.h"
-rtems_timer_service_routine Delayed_routine(
- rtems_id ignored_id,
- void *ignored_address
diff --git a/testsuites/sptests/sp09/init.c b/testsuites/sptests/sp09/init.c
index 60a320a..0000000
--- a/testsuites/sptests/sp09/init.c
+++ /dev/null
@@ -1,104 +0,0 @@
- * COPYRIGHT (c) 1989-2014.
-#endif
-#define CONFIGURE_INIT
-rtems_task Init(
- rtems_task_argument argument
- rtems_status_code status;
- puts( "\n\n*** TEST 9 ***" );
- Task_name[ 1 ] = rtems_build_name( 'T', 'A', '1', ' ' );
- Task_name[ 2 ] = rtems_build_name( 'T', 'A', '2', ' ' );
- Task_name[ 3 ] = rtems_build_name( 'T', 'A', '3', ' ' );
- Task_name[ 4 ] = rtems_build_name( 'T', 'A', '4', ' ' );
- Task_name[ 5 ] = rtems_build_name( 'T', 'A', '5', ' ' );
- Task_name[ 6 ] = rtems_build_name( 'T', 'A', '6', ' ' );
- Task_name[ 7 ] = rtems_build_name( 'T', 'A', '7', ' ' );
- Task_name[ 8 ] = rtems_build_name( 'T', 'A', '8', ' ' );
- Task_name[ 9 ] = rtems_build_name( 'T', 'A', '9', ' ' );
- Task_name[ 10 ] = rtems_build_name( 'T', 'A', 'A', ' ' );
- Semaphore_name[ 1 ] = rtems_build_name( 'S', 'M', '1', ' ' );
- Semaphore_name[ 2 ] = rtems_build_name( 'S', 'M', '2', ' ' );
- Semaphore_name[ 3 ] = rtems_build_name( 'S', 'M', '3', ' ' );
- Queue_name[ 1 ] = rtems_build_name( 'M', 'Q', '1', ' ' );
- Queue_name[ 2 ] = rtems_build_name( 'M', 'Q', '2', ' ' );
- Port_name[ 1 ] = rtems_build_name( 'D', 'P', '1', ' ' );
- Period_name[ 1 ] = rtems_build_name( 'T', 'M', '1', ' ' );
- /* priority of 0 error */
- status = rtems_task_create(
- Task_name[1],
- 0,
- RTEMS_MINIMUM_STACK_SIZE,
- RTEMS_DEFAULT_MODES,
- RTEMS_DEFAULT_ATTRIBUTES,
- &Task_id[ 1 ]
- fatal_directive_status(
- status,
- RTEMS_INVALID_PRIORITY,
- "rtems_task_create with illegal priority"
- puts( "INIT - rtems_task_create - priority of 0 - RTEMS_INVALID_PRIORITY" );
- /* priority > 255 error */
- Task_name[1],
- 257,
- &Task_id[ 1 ]
- status,
- puts(
- "INIT - rtems_task_create - priority too high - RTEMS_INVALID_PRIORITY"
- Task_name[ 1 ],
- 4,
- RTEMS_MINIMUM_STACK_SIZE * 3,
- &Task_id[ 1 ]
- directive_failed( status, "rtems_task_create of TA1" );
- status = rtems_task_restart( Task_id[ 1 ], 0 );
- status,
- RTEMS_INCORRECT_STATE,
- "rtems_task_restart of DORMANT task"
- puts( "INIT - rtems_task_restart - RTEMS_INCORRECT_STATE" );
- status = rtems_task_start( Task_id[ 1 ], Task_1, 0 );
- directive_failed( status, "rtems_task_start of TA1" );
- status = rtems_task_delete( RTEMS_SELF );
- directive_failed( status, "rtems_task_delete of RTEMS_SELF" );
diff --git a/testsuites/sptests/sp09/isr.c b/testsuites/sptests/sp09/isr.c
index 1144760..0000000
--- a/testsuites/sptests/sp09/isr.c
+++ /dev/null
@@ -1,28 +0,0 @@
-/* Service_routine
- * This routine is used as the timer routine for Interrupt Manager tests.
-#endif
-rtems_isr Service_routine(
- rtems_vector_number ignored
diff --git a/testsuites/sptests/sp09/screen01.c b/testsuites/sptests/sp09/screen01.c
index 004e5c5..0000000
--- a/testsuites/sptests/sp09/screen01.c
+++ /dev/null
@@ -1,266 +0,0 @@
-/* Screen1
- * This routine generates error screen 1 for test 9.
- * COPYRIGHT (c) 1989-2009.
-#endif
-#include <rtems/rtems/tasksimpl.h>
-void Screen1()
- uint32_t notepad_value;
- rtems_id self_id;
- rtems_task_priority previous_priority;
- /* bad Id */
- status = rtems_task_is_suspended( 100 );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_set_priority with illegal id"
- puts( "TA1 - rtems_task_is_suspended - RTEMS_INVALID_ID" );
- /* bad Id */
- status = rtems_task_delete( 100 );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_delete with illegal id"
- puts( "TA1 - rtems_task_delete - RTEMS_INVALID_ID" );
- /* NULL return */
- status = rtems_task_get_note( RTEMS_SELF, RTEMS_NOTEPAD_FIRST, NULL );
- status,
- RTEMS_INVALID_ADDRESS,
- "rtems_task_get_note with NULL param"
- puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_ADDRESS" );
- /* note too high */
- status = rtems_task_get_note( RTEMS_SELF, 100, ¬epad_value );
- status,
- RTEMS_INVALID_NUMBER,
- "rtems_task_get_note with illegal notepad"
- puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_NUMBER" );
- /* bad Id */
- status = rtems_task_get_note( 100, RTEMS_NOTEPAD_LAST, ¬epad_value );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_get_note with illegal id"
- puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_ID" );
- /* unused Id so invalid now */
- _RTEMS_tasks_Information.maximum_id,
- RTEMS_NOTEPAD_LAST,
- ¬epad_value
- status,
- RTEMS_INVALID_ID,
- _RTEMS_tasks_Information.minimum_id + (3L<<OBJECTS_API_START_BIT),
- ¬epad_value
- status,
- RTEMS_INVALID_ID,
- rtems_build_id( OBJECTS_CLASSIC_API, 2, 1, 1 ),
- ¬epad_value
- status,
- RTEMS_INVALID_ID,
- "rtems_task_get_note with non-task ID"
- /* NULL param */
- status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, NULL );
- status,
- "rtems_task_ident NULL param"
- puts( "TA1 - rtems_task_ident - RTEMS_INVALID_ADDRESS" );
- /* OK */
- status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &self_id );
- directive_failed( status, "rtems_task_ident of self" );
- if ( self_id != Task_id[ 1 ] ) {
- puts( "ERROR - rtems_task_ident - incorrect ID returned!" );
- puts( "TA1 - rtems_task_ident - current task RTEMS_SUCCESSFUL" );
- status = rtems_task_ident( 100, RTEMS_SEARCH_ALL_NODES, &Junk_id );
- status,
- RTEMS_INVALID_NAME,
- "rtems_task_ident with illegal name (local)"
- puts( "TA1 - rtems_task_ident - global RTEMS_INVALID_NAME" );
- status = rtems_task_ident( 100, 1, &Junk_id );
- status,
- "rtems_task_ident with illegal name (global)"
- puts( "TA1 - rtems_task_ident - local RTEMS_INVALID_NAME" );
- * This one case is different if MP is enabled/disabled.
- status = rtems_task_ident( 100, 2, &Junk_id );
-#if defined(RTEMS_MULTIPROCESSING)
- status,
- RTEMS_INVALID_NODE,
- "rtems_task_ident with illegal node"
-#else
- status,
-#endif
- puts( "TA1 - rtems_task_ident - RTEMS_INVALID_NODE" );
- status = rtems_task_restart( 100, 0 );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_restart with illegal id"
- puts( "TA1 - rtems_task_restart - RTEMS_INVALID_ID" );
- status = rtems_task_resume( 100 );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_resume with illegal id"
- puts( "TA1 - rtems_task_resume - RTEMS_INVALID_ID" );
- status = rtems_task_resume( RTEMS_SELF );
- status,
- "rtems_task_resume of ready task"
- puts( "TA1 - rtems_task_resume - RTEMS_INCORRECT_STATE" );
- /* NULL param */
- status = rtems_task_set_priority( RTEMS_SELF, RTEMS_CURRENT_PRIORITY, NULL );
- status,
- "rtems_task_set_priority with NULL param"
- puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_ADDRESS" );
- /* bad priority */
- status = rtems_task_set_priority( RTEMS_SELF, 512, &previous_priority );
- status,
- "rtems_task_set_priority with illegal priority"
- puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_PRIORITY" );
- /* bad Id */
- status = rtems_task_set_priority( 100, 8, &previous_priority );
- status,
- RTEMS_INVALID_ID,
- puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_ID" );
- status = rtems_task_set_note(
- RTEMS_SELF,
- RTEMS_NOTEPAD_LAST+10,
- notepad_value
- status,
- "rtems_task_set_note with illegal notepad"
- puts( "TA1 - rtems_task_set_note - RTEMS_INVALID_NUMBER" );
- status = rtems_task_set_note( 100, RTEMS_NOTEPAD_LAST, notepad_value );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_set_note with illegal id"
- puts( "TA1 - rtems_task_set_note - RTEMS_INVALID_ID" );
- status = rtems_task_start( 100, Task_1, 0 );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_start with illegal id"
- puts( "TA1 - rtems_task_start - RTEMS_INVALID_ID" );
- /* already started */
- status = rtems_task_start( RTEMS_SELF, Task_1, 0 );
- status,
- "rtems_task_start of ready task"
- puts( "TA1 - rtems_task_start - RTEMS_INCORRECT_STATE" );
- /* bad Id */
- status = rtems_task_suspend( 100 );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_suspend with illegal id"
- puts( "TA1 - rtems_task_suspend - RTEMS_INVALID_ID" );
- /* NULL param */
- status = rtems_task_mode( RTEMS_SELF, 0, NULL );
- status,
- "rtems_task_mode with NULL param"
- puts( "TA1 - rtems_task_mode - RTEMS_INVALID_ADDRESS" );
diff --git a/testsuites/sptests/sp09/screen02.c b/testsuites/sptests/sp09/screen02.c
index 5fa0786..0000000
--- a/testsuites/sptests/sp09/screen02.c
+++ /dev/null
@@ -1,313 +0,0 @@
-/* Screen2
- * This routine generates error screen 2 for test 9.
- * Input parameters: NONE
- * COPYRIGHT (c) 1989-2011.
-#endif
-void Screen2()
- rtems_time_of_day time;
- rtems_interval interval;
- struct timeval tv;
- puts( "TA1 - rtems_clock_get_tod - RTEMS_INVALID_ADDRESS" );
- status = rtems_clock_get_tod( NULL );
- status,
- "rtems_clock_get_tod NULL param"
-/* errors before clock is set */
- status = rtems_clock_get_tod( &time );
- if ( status == RTEMS_SUCCESSFUL ) {
- puts(
- "TA1 - rtems_clock_get_tod - RTEMS_NOT_DEFINED -- "
- "DID BSP SET THE TIME OF DAY?"
- } else {
- status,
- RTEMS_NOT_DEFINED,
- "rtems_clock_get_tod before clock is set #1"
- puts( "TA1 - rtems_clock_get_tod - RTEMS_NOT_DEFINED" );
- puts( "TA1 - rtems_clock_get_seconds_since_epoch - RTEMS_INVALID_ADDRESS" );
- status = rtems_clock_get_seconds_since_epoch( NULL );
- status,
- "rtems_clock_get_seconds_since_epoch NULL param"
- status = rtems_clock_get_seconds_since_epoch( &interval );
- puts(
- "TA1 - rtems_clock_get_seconds_since_epoch - RTEMS_NOT_DEFINED -- "
- } else {
- status,
- "rtems_clock_get_seconds_before_epoch"
- puts( "TA1 - rtems_clock_get_seconds_since_epoch - RTEMS_NOT_DEFINED" );
- puts( "TA1 - rtems_clock_get_uptime - RTEMS_INVALID_ADDRESS" );
- status = rtems_clock_get_uptime( NULL );
- status,
- "rtems_clock_get_uptime NULL param"
- puts( "TA1 - rtems_clock_get_uptime_timeval" );
- rtems_clock_get_uptime_timeval( &tv );
- puts( "TA1 - rtems_clock_get_uptime_seconds" );
- rtems_clock_get_uptime_seconds();
- puts( "TA1 - rtems_clock_get_uptime_nanoseconds" );
- rtems_clock_get_uptime_nanoseconds();
- puts( "TA1 - rtems_clock_get_tod_timeval - RTEMS_INVALID_ADDRESS" );
- status = rtems_clock_get_tod_timeval( NULL );
- status,
- "rtems_clock_get_tod_timeval NULL param"
- status = rtems_clock_get_tod_timeval( &tv );
- puts(
- "TA1 - rtems_clock_get_tod_timeval - RTEMS_NOT_DEFINED -- "
- } else {
- status,
- "rtems_clock_get_timeval"
- puts( "TA1 - rtems_clock_get_tod_timeval - RTEMS_NOT_DEFINED" );
- puts( "TA1 - rtems_clock_set_nanoseconds_extension - RTEMS_INVALID_ADDRESS" );
- status = rtems_clock_set_nanoseconds_extension( NULL );
- status,
- "rtems_clock_set_nanoseconds_extension NULL param"
- /* NULL parameter */
- status = rtems_clock_set( NULL );
- status,
- "rtems_clock_set sull pointer"
- puts( "TA1 - rtems_clock_set - RTEMS_INVALID_ADDRESS" );
- /* wake when NULL param */
- status = rtems_task_wake_when( NULL );
- status,
- "rtems_task_wake_when NULL param"
- puts( "TA1 - rtems_task_wake_when - RTEMS_INVALID_ADDRESS" );
- /* wake when before set */
- status = rtems_task_wake_when( &time );
- puts(
- "TA1 - rtems_task_wake_when - RTEMS_NOT_DEFINED -- "
- } else {
- status,
- "rtems_task_wake_when before clock is set"
- puts( "TA1 - rtems_task_wake_when - RTEMS_NOT_DEFINED" );
- /* before time set */
- status = rtems_timer_fire_when( 0, &time, Delayed_routine, NULL );
- puts(
- "TA1 - timer_wake_when - RTEMS_NOT_DEFINED -- DID BSP SET THE TIME OF DAY?"
- } else {
- status,
- "task_fire_when before clock is set"
- puts( "TA1 - rtems_timer_fire_when - RTEMS_NOT_DEFINED" );
- build_time( &time, 2, 5, 1987, 8, 30, 45, 0 );
- print_time( "TA1 - rtems_clock_set - ", &time, "" );
- status = rtems_clock_set( &time );
- status,
- RTEMS_INVALID_CLOCK,
- "rtems_clock_set with invalid year"
- puts( " - RTEMS_INVALID_CLOCK" );
- build_time( &time, 15, 5, 1988, 8, 30, 45, 0 );
- status,
- "rtems_clock_set with invalid month"
- build_time( &time, 2, 32, 1988, 8, 30, 45, 0 );
- status,
- "rtems_clock_set with invalid day"
- build_time( &time, 2, 5, 1988, 25, 30, 45, 0 );
- status,
- "rtems_clock_set with invalid hour"
- build_time( &time, 2, 5, 1988, 8, 61, 45, 0 );
- status,
- "rtems_clock_set with invalid minute"
- build_time( &time, 2, 5, 1988, 8, 30, 61, 0 );
- status,
- "rtems_clock_set with invalid second"
- build_time(
- &time, 2, 5, 1988, 8, 30, 45,
- rtems_clock_get_ticks_per_second() + 1
- status,
- "rtems_clock_set with invalid ticks per second"
- build_time( &time, 2, 5, 1988, 8, 30, 45, 0 );
- directive_failed( status, "rtems_clock_set successful" );
- puts( " - RTEMS_SUCCESSFUL" );
-/* rtems_task_wake_when */
- build_time(
- &time,
- 2, 5, 1988, 8, 30, 48,
- time.second += 3;
- puts( "TA1 - rtems_task_wake_when - TICKINVALID - sleep about 3 seconds" );
- /* NULL time */
- status,
- "rtems_task_wake_when with NULL"
- /* invalid ticks */
- directive_failed(
- status,
- "rtems_task_wake_when with invalid ticks per second"
- puts( "TA1 - rtems_task_wake_when - TICKINVALID - woke up RTEMS_SUCCESSFUL" );
- build_time( &time, 2, 5, 1961, 8, 30, 48, 0 );
- print_time( "TA1 - rtems_task_wake_when - ", &time, "" );
- status,
- "rtems_task_wake_when with invalid year"
- build_time( &time, 2, 5, 1988, 25, 30, 48, 0 );
- status,
- "rtems_task_wake_when with invalid hour"
- rtems_clock_get_tod( &time );
- print_time( "TA1 - current time - ", &time, "\n" );
- time.month = 1;
- status,
- "rtems_task_wake_when before current time"
diff --git a/testsuites/sptests/sp09/sp09.doc b/testsuites/sptests/sp09/sp09.doc
index 1689a1e..0000000
--- a/testsuites/sptests/sp09/sp09.doc
+++ /dev/null
@@ -1,29 +0,0 @@
-# COPYRIGHT (c) 1989-2014.
-# On-Line Applications Research Corporation (OAR).
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
-This file describes the directives and concepts tested by this test set.
-test set name: test9
-directives:
- tm_tick, t_resume, t_setpri, t_setreg, t_start, t_suspend, tm_wkafter,
- tm_wkwhen, ev_receive, ev_send, sm_create, sm_delete, sm_ident,
- sm_p, sm_v, q_broadcast, q_create, q_delete, q_ident, q_receive,
- q_send, q_urgent, as_catch, as_send, as_return
- de_init, de_open, de_read, de_write, de_close, de_cntrl
-concepts:
- a. Verifies all error codes returned by the executive in single
- processor configurations.
- b. Verifies error conditions in the following kernel routines or macros:
- _Ck_date_time, _Expired, _Q_submit, _Get_mnodes, _Get_node,
- _Free_mem, _Get_mem, _Valid_block, _Set_tcb, _Set_resource,
- _In_range, _On_boundary
diff --git a/testsuites/sptests/sp09/sp09.scn b/testsuites/sptests/sp09/sp09.scn
index 001239d..0000000
--- a/testsuites/sptests/sp09/sp09.scn
+++ /dev/null
@@ -1,59 +0,0 @@
-*** TEST 9 ***
-INIT - rtems_task_create - priority of 0 - RTEMS_INVALID_PRIORITY
-INIT - rtems_task_create - priority too high - RTEMS_INVALID_PRIORITY
-INIT - rtems_task_restart - RTEMS_INCORRECT_STATE
-TA1 - rtems_task_is_suspended - RTEMS_INVALID_ID
-TA1 - rtems_task_delete - RTEMS_INVALID_ID
-TA1 - rtems_task_get_note - RTEMS_INVALID_ADDRESS
-TA1 - rtems_task_get_note - RTEMS_INVALID_NUMBER
-TA1 - rtems_task_get_note - RTEMS_INVALID_ID
-TA1 - rtems_task_ident - RTEMS_INVALID_ADDRESS
-TA1 - rtems_task_ident - current task RTEMS_SUCCESSFUL
-TA1 - rtems_task_ident - global RTEMS_INVALID_NAME
-TA1 - rtems_task_ident - local RTEMS_INVALID_NAME
-TA1 - rtems_task_ident - RTEMS_INVALID_NODE
-TA1 - rtems_task_restart - RTEMS_INVALID_ID
-TA1 - rtems_task_resume - RTEMS_INVALID_ID
-TA1 - rtems_task_resume - RTEMS_INCORRECT_STATE
-TA1 - rtems_task_set_priority - RTEMS_INVALID_ADDRESS
-TA1 - rtems_task_set_priority - RTEMS_INVALID_PRIORITY
-TA1 - rtems_task_set_priority - RTEMS_INVALID_ID
-TA1 - rtems_task_set_note - RTEMS_INVALID_NUMBER
-TA1 - rtems_task_set_note - RTEMS_INVALID_ID
-TA1 - rtems_task_start - RTEMS_INVALID_ID
-TA1 - rtems_task_start - RTEMS_INCORRECT_STATE
-TA1 - rtems_task_suspend - RTEMS_INVALID_ID
-TA1 - rtems_task_mode - RTEMS_INVALID_ADDRESS
-<pause - screen 2>
-TA1 - rtems_clock_get_tod - RTEMS_INVALID_ADDRESS
-TA1 - rtems_clock_get_tod - RTEMS_NOT_DEFINED
-TA1 - rtems_clock_get_seconds_since_epoch - RTEMS_INVALID_ADDRESS
-TA1 - rtems_clock_get_seconds_since_epoch - RTEMS_NOT_DEFINED
-TA1 - rtems_clock_get_uptime - RTEMS_INVALID_ADDRESS
-TA1 - rtems_clock_get_uptime_timeval
-TA1 - rtems_clock_get_uptime_seconds
-TA1 - rtems_clock_get_uptime_nanoseconds
-TA1 - rtems_clock_get_tod_timeval - RTEMS_INVALID_ADDRESS
-TA1 - rtems_clock_get_tod_timeval - RTEMS_NOT_DEFINED
-TA1 - rtems_clock_set_nanoseconds_extension - RTEMS_INVALID_ADDRESS
-TA1 - rtems_clock_set - RTEMS_INVALID_ADDRESS
-TA1 - rtems_task_wake_when - RTEMS_INVALID_ADDRESS
-TA1 - rtems_task_wake_when - RTEMS_NOT_DEFINED
-TA1 - rtems_timer_fire_when - RTEMS_NOT_DEFINED
-TA1 - rtems_clock_set - 08:30:45 02/05/1987 - RTEMS_INVALID_CLOCK
-TA1 - rtems_clock_set - 08:30:45 15/05/1988 - RTEMS_INVALID_CLOCK
-TA1 - rtems_clock_set - 08:30:45 02/32/1988 - RTEMS_INVALID_CLOCK
-TA1 - rtems_clock_set - 25:30:45 02/05/1988 - RTEMS_INVALID_CLOCK
-TA1 - rtems_clock_set - 08:61:45 02/05/1988 - RTEMS_INVALID_CLOCK
-TA1 - rtems_clock_set - 08:30:61 02/05/1988 - RTEMS_INVALID_CLOCK
-TA1 - rtems_clock_set - 08:30:45 02/05/1988 - RTEMS_INVALID_CLOCK
-TA1 - rtems_clock_set - 08:30:45 02/05/1988 - RTEMS_SUCCESSFUL
-TA1 - rtems_task_wake_when - TICKINVALID - sleep about 3 seconds
-TA1 - rtems_task_wake_when - TICKINVALID - woke up RTEMS_SUCCESSFUL
-TA1 - rtems_task_wake_when - 08:30:48 02/05/1961 - RTEMS_INVALID_CLOCK
-TA1 - rtems_task_wake_when - 25:30:48 02/05/1988 - RTEMS_INVALID_CLOCK
-TA1 - current time - 08:30:51 02/05/1988
-TA1 - rtems_task_wake_when - 08:30:51 01/05/1988 - RTEMS_INVALID_CLOCK
-*** END OF TEST 9 ***
diff --git a/testsuites/sptests/sp09/system.h b/testsuites/sptests/sp09/system.h
index 30b34e1..0000000
--- a/testsuites/sptests/sp09/system.h
+++ /dev/null
@@ -1,101 +0,0 @@
- * This include file contains information that is included in every
- * function in the test set.
-#include <tmacros.h>
-/* functions */
-rtems_task Init(
-rtems_task Task_1(
-rtems_task Task_2(
-rtems_task Task_3(
-rtems_timer_service_routine Io_during_interrupt(
- rtems_id ignored
-void Screen1( void );
-void Screen2( void );
-void Screen3( void );
-void Screen4( void );
-void Screen5( void );
-void Screen6( void );
-/* configuration information */
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS 9
-#define CONFIGURE_MAXIMUM_TIMERS 1
-#define CONFIGURE_MAXIMUM_SEMAPHORES 2
-#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
-#define CONFIGURE_MAXIMUM_PERIODS 1
-#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 0
-#define CONFIGURE_TICKS_PER_TIMESLICE 100
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_EXTRA_TASK_STACKS (20 * RTEMS_MINIMUM_STACK_SIZE)
-#include <rtems/confdefs.h>
-/* global variables */
-TEST_EXTERN rtems_id Task_id[ 11 ]; /* array of task ids */
-TEST_EXTERN rtems_name Task_name[ 11 ]; /* array of task names */
-TEST_EXTERN rtems_name Semaphore_name[ 4 ]; /* array of semaphore names */
-TEST_EXTERN rtems_id Semaphore_id[ 4 ]; /* array of semaphore ids */
-TEST_EXTERN rtems_name Queue_name[ 3 ]; /* array of queue names */
-TEST_EXTERN rtems_id Queue_id[ 3 ]; /* array of queue ids */
-TEST_EXTERN rtems_name Port_name[ 2 ]; /* array of port names */
-TEST_EXTERN rtems_id Port_id[ 2 ]; /* array of port ids */
-TEST_EXTERN rtems_name Period_name[ 2 ]; /* array of period names */
-TEST_EXTERN rtems_id Period_id[ 2 ]; /* array of period ids */
-TEST_EXTERN rtems_id Junk_id; /* id used to return errors */
-#define Internal_port_area (void *) 0x00001000
-#define External_port_area (void *) 0x00002000
-/* end of include file */
diff --git a/testsuites/sptests/sp09/task1.c b/testsuites/sptests/sp09/task1.c
index 27b55ef..0000000
--- a/testsuites/sptests/sp09/task1.c
+++ /dev/null
@@ -1,35 +0,0 @@
-/* Task_1
- * This task generates all possible errors for the RTEMS executive.
- * argument - task argument
-#endif
-rtems_task Task_1(
- Screen1();
- rtems_test_pause_and_screen_number( 2 );
- Screen2();
- puts( "*** END OF TEST 9 ***" );
- rtems_test_exit( 0 );
diff --git a/testsuites/sptests/sp09/task2.c b/testsuites/sptests/sp09/task2.c
index 550b6a0..0000000
--- a/testsuites/sptests/sp09/task2.c
+++ /dev/null
@@ -1,49 +0,0 @@
-/* Task_2
- * This routine serves as a test task. Its only purpose is to generate the
- * error where a semaphore is deleted while a task is waiting for it.
-#endif
-rtems_task Task_2(
- puts( "TA2 - rtems_semaphore_obtain - sem 1 - RTEMS_WAIT FOREVER" );
- status = rtems_semaphore_obtain(
- Semaphore_id[ 1 ],
- RTEMS_DEFAULT_OPTIONS,
- RTEMS_NO_TIMEOUT
- status,
- RTEMS_OBJECT_WAS_DELETED,
- "rtems_semaphore_obtain waiting to be deleted"
- puts(
- "TA2 - rtems_semaphore_obtain - woke up with RTEMS_OBJECT_WAS_DELETED"
- puts( "TA2 - rtems_task_delete - delete self - RTEMS_SUCCESSFUL" );
- directive_failed( status, "rtems_task_delete of TA2" );
diff --git a/testsuites/sptests/sp09/task3.c b/testsuites/sptests/sp09/task3.c
index 96e16ab..0000000
--- a/testsuites/sptests/sp09/task3.c
+++ /dev/null
@@ -1,54 +0,0 @@
-/* Task_3
- * This routine serves as a test task. Its only purpose in life is to
- * generate the error where a message queue is deleted while a task
- * is waiting there for a message.
- * COPYRIGHT (c) 1989-2007.
-#endif
-rtems_task Task_3(
- long buffer[ 4 ];
- size_t size;
- puts( "TA3 - rtems_message_queue_receive - Q 1 - RTEMS_WAIT FOREVER" );
- status = rtems_message_queue_receive(
- Queue_id[ 1 ],
- (long (*)[4])buffer,
- &size,
- RTEMS_NO_TIMEOUT
- status,
- "rtems_message_queue_receive waiting to be deleted"
- puts(
- "TA3 - rtems_message_queue_receive - woke up with RTEMS_OBJECT_WAS_DELETED"
- puts( "TA3 - rtems_task_delete - delete self - RTEMS_SUCCESSFUL" );
- directive_failed( status, "rtems_task_delete of TA3" );
diff --git a/testsuites/sptests/spclock_err01/Makefile.am b/testsuites/sptests/spclock_err01/Makefile.am
new file mode 100644
index 0000000..f9cf1fc
--- /dev/null
+++ b/testsuites/sptests/spclock_err01/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = spclock_err01
+spclock_err01_SOURCES = init.c delay.c system.h
+dist_rtems_tests_DATA = spclock_err01.scn
+dist_rtems_tests_DATA += spclock_err01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spclock_err01_OBJECTS)
+LINK_LIBS = $(spclock_err01_LDLIBS)
+spclock_err01$(EXEEXT): $(spclock_err01_OBJECTS) $(spclock_err01_DEPENDENCIES)
+ @rm -f spclock_err01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spclock_err01/delay.c b/testsuites/sptests/spclock_err01/delay.c
index 0000000..2469941
--- /dev/null
+++ b/testsuites/sptests/spclock_err01/delay.c
@@ -0,0 +1,29 @@
+/* Delayed_routine
+ * This routine is used as the timer routine for Timer Manager tests.
+ * Input parameters:
+ * ignored - this parameter is ignored
+ * Output parameters: NONE
+ * COPYRIGHT (c) 1989-1999.
+ * On-Line Applications Research Corporation (OAR).
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "system.h"
+rtems_timer_service_routine Delayed_routine(
+ rtems_id ignored_id,
+ void *ignored_address
diff --git a/testsuites/sptests/spclock_err01/init.c b/testsuites/sptests/spclock_err01/init.c
index 0000000..74286d1
--- /dev/null
+++ b/testsuites/sptests/spclock_err01/init.c
@@ -0,0 +1,216 @@
+ * COPYRIGHT (c) 2014.
+#endif
+#define CONFIGURE_INIT
+rtems_task Init(
+ rtems_task_argument argument
+ rtems_time_of_day time;
+ rtems_interval interval;
+ struct timeval tv;
+ rtems_status_code status;
+ puts( "\n\n*** TEST CLOCK ERROR 01 ***" );
+ puts( "TA1 - rtems_clock_get_tod - RTEMS_INVALID_ADDRESS" );
+ status = rtems_clock_get_tod( NULL );
+ fatal_directive_status(
+ status,
+ RTEMS_INVALID_ADDRESS,
+ "rtems_clock_get_tod NULL param"
+/* errors before clock is set */
+ status = rtems_clock_get_tod( &time );
+ if ( status == RTEMS_SUCCESSFUL ) {
+ puts(
+ "TA1 - rtems_clock_get_tod - RTEMS_NOT_DEFINED -- "
+ "DID BSP SET THE TIME OF DAY?"
+ } else {
+ status,
+ RTEMS_NOT_DEFINED,
+ "rtems_clock_get_tod before clock is set #1"
+ puts( "TA1 - rtems_clock_get_tod - RTEMS_NOT_DEFINED" );
+ puts( "TA1 - rtems_clock_get_seconds_since_epoch - RTEMS_INVALID_ADDRESS" );
+ status = rtems_clock_get_seconds_since_epoch( NULL );
+ status,
+ "rtems_clock_get_seconds_since_epoch NULL param"
+ status = rtems_clock_get_seconds_since_epoch( &interval );
+ puts(
+ "TA1 - rtems_clock_get_seconds_since_epoch - RTEMS_NOT_DEFINED -- "
+ } else {
+ status,
+ "rtems_clock_get_seconds_before_epoch"
+ puts( "TA1 - rtems_clock_get_seconds_since_epoch - RTEMS_NOT_DEFINED" );
+ puts( "TA1 - rtems_clock_get_uptime - RTEMS_INVALID_ADDRESS" );
+ status = rtems_clock_get_uptime( NULL );
+ status,
+ "rtems_clock_get_uptime NULL param"
+ puts( "TA1 - rtems_clock_get_uptime_timeval" );
+ rtems_clock_get_uptime_timeval( &tv );
+ puts( "TA1 - rtems_clock_get_uptime_seconds" );
+ rtems_clock_get_uptime_seconds();
+ puts( "TA1 - rtems_clock_get_uptime_nanoseconds" );
+ rtems_clock_get_uptime_nanoseconds();
+ puts( "TA1 - rtems_clock_get_tod_timeval - RTEMS_INVALID_ADDRESS" );
+ status = rtems_clock_get_tod_timeval( NULL );
+ status,
+ "rtems_clock_get_tod_timeval NULL param"
+ status = rtems_clock_get_tod_timeval( &tv );
+ puts(
+ "TA1 - rtems_clock_get_tod_timeval - RTEMS_NOT_DEFINED -- "
+ } else {
+ status,
+ "rtems_clock_get_timeval"
+ puts( "TA1 - rtems_clock_get_tod_timeval - RTEMS_NOT_DEFINED" );
+ puts( "TA1 - rtems_clock_set_nanoseconds_extension - RTEMS_INVALID_ADDRESS" );
+ status = rtems_clock_set_nanoseconds_extension( NULL );
+ status,
+ "rtems_clock_set_nanoseconds_extension NULL param"
+ /* NULL parameter */
+ status = rtems_clock_set( NULL );
+ status,
+ "rtems_clock_set sull pointer"
+ puts( "TA1 - rtems_clock_set - RTEMS_INVALID_ADDRESS" );
+ build_time( &time, 2, 5, 1987, 8, 30, 45, 0 );
+ print_time( "TA1 - rtems_clock_set - ", &time, "" );
+ status = rtems_clock_set( &time );
+ status,
+ RTEMS_INVALID_CLOCK,
+ "rtems_clock_set with invalid year"
+ puts( " - RTEMS_INVALID_CLOCK" );
+ build_time( &time, 15, 5, 1988, 8, 30, 45, 0 );
+ status,
+ "rtems_clock_set with invalid month"
+ build_time( &time, 2, 32, 1988, 8, 30, 45, 0 );
+ status,
+ "rtems_clock_set with invalid day"
+ build_time( &time, 2, 5, 1988, 25, 30, 45, 0 );
+ status,
+ "rtems_clock_set with invalid hour"
+ build_time( &time, 2, 5, 1988, 8, 61, 45, 0 );
+ status,
+ "rtems_clock_set with invalid minute"
+ build_time( &time, 2, 5, 1988, 8, 30, 61, 0 );
+ status,
+ "rtems_clock_set with invalid second"
+ build_time(
+ &time, 2, 5, 1988, 8, 30, 45,
+ rtems_clock_get_ticks_per_second() + 1
+ status,
+ "rtems_clock_set with invalid ticks per second"
+ build_time( &time, 2, 5, 1988, 8, 30, 45, 0 );
+ directive_failed( status, "rtems_clock_set successful" );
+ puts( " - RTEMS_SUCCESSFUL" );
+ rtems_clock_get_tod( &time );
+ print_time( "TA1 - current time - ", &time, "\n" );
+ puts( "*** END TEST CLOCK ERROR 01 ***" );
diff --git a/testsuites/sptests/spclock_err01/spclock_err01.doc b/testsuites/sptests/spclock_err01/spclock_err01.doc
index 0000000..431ba5e
--- /dev/null
+++ b/testsuites/sptests/spclock_err01/spclock_err01.doc
@@ -0,0 +1,26 @@
+# COPYRIGHT (c) 1989-2014.
+# On-Line Applications Research Corporation (OAR).
+# The license and distribution terms for this file may be
+# found in the file LICENSE in this distribution or at
+# http://www.rtems.com/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name: spclock_err01
+directives:
+ c_gettod, c_secspoch, c_uptime, c_uptimeval, c_upsec, c_upnanosec,
+ c_todtimeval, c_nsecexten, c_set, tm_firewhen, c_ticksps,
+concepts:
+ a. Verifies all error codes returned by the executive in single
+ processor configurations.
+ b. Verifies error conditions in the following kernel routines or macros:
+ _Ck_date_time, _Expired, _Q_submit, _Get_mnodes, _Get_node,
+ _Free_mem, _Get_mem, _Valid_block, _Set_tcb, _Set_resource,
+ _In_range, _On_boundary
diff --git a/testsuites/sptests/spclock_err01/spclock_err01.scn b/testsuites/sptests/spclock_err01/spclock_err01.scn
index 0000000..887c939
--- /dev/null
+++ b/testsuites/sptests/spclock_err01/spclock_err01.scn
@@ -0,0 +1,23 @@
+*** TEST CLOCK ERROR 01 ***
+TA1 - rtems_clock_get_tod - RTEMS_INVALID_ADDRESS
+TA1 - rtems_clock_get_tod - RTEMS_NOT_DEFINED
+TA1 - rtems_clock_get_seconds_since_epoch - RTEMS_INVALID_ADDRESS
+TA1 - rtems_clock_get_seconds_since_epoch - RTEMS_NOT_DEFINED
+TA1 - rtems_clock_get_uptime - RTEMS_INVALID_ADDRESS
+TA1 - rtems_clock_get_uptime_timeval
+TA1 - rtems_clock_get_uptime_seconds
+TA1 - rtems_clock_get_uptime_nanoseconds
+TA1 - rtems_clock_get_tod_timeval - RTEMS_INVALID_ADDRESS
+TA1 - rtems_clock_get_tod_timeval - RTEMS_NOT_DEFINED
+TA1 - rtems_clock_set_nanoseconds_extension - RTEMS_INVALID_ADDRESS
+TA1 - rtems_clock_set - RTEMS_INVALID_ADDRESS
+TA1 - rtems_clock_set - 08:30:45 02/05/1987 - RTEMS_INVALID_CLOCK
+TA1 - rtems_clock_set - 08:30:45 15/05/1988 - RTEMS_INVALID_CLOCK
+TA1 - rtems_clock_set - 08:30:45 02/32/1988 - RTEMS_INVALID_CLOCK
+TA1 - rtems_clock_set - 25:30:45 02/05/1988 - RTEMS_INVALID_CLOCK
+TA1 - rtems_clock_set - 08:61:45 02/05/1988 - RTEMS_INVALID_CLOCK
+TA1 - rtems_clock_set - 08:30:61 02/05/1988 - RTEMS_INVALID_CLOCK
+TA1 - rtems_clock_set - 08:30:45 02/05/1988 - RTEMS_INVALID_CLOCK
+TA1 - rtems_clock_set - 08:30:45 02/05/1988 - RTEMS_SUCCESSFUL
+TA1 - current time - 08:30:45 02/05/1988
+*** END TEST CLOCK ERROR 01 ***
diff --git a/testsuites/sptests/spclock_err01/system.h b/testsuites/sptests/spclock_err01/system.h
index 0000000..68a14a0
--- /dev/null
+++ b/testsuites/sptests/spclock_err01/system.h
@@ -0,0 +1,69 @@
+ * This include file contains information that is included in every
+ * function in the test set.
+ * COPYRIGHT (c) 1989-2014.
+#include <tmacros.h>
+/* functions */
+rtems_task Init(
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 10
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES 2
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
+#define CONFIGURE_MAXIMUM_PERIODS 1
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 0
+#define CONFIGURE_TICKS_PER_TIMESLICE 100
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_EXTRA_TASK_STACKS (20 * RTEMS_MINIMUM_STACK_SIZE)
+#include <rtems/confdefs.h>
+/* global variables */
+TEST_EXTERN rtems_id Task_id[ 11 ]; /* array of task ids */
+TEST_EXTERN rtems_name Task_name[ 11 ]; /* array of task names */
+TEST_EXTERN rtems_name Semaphore_name[ 4 ]; /* array of semaphore names */
+TEST_EXTERN rtems_id Semaphore_id[ 4 ]; /* array of semaphore ids */
+TEST_EXTERN rtems_name Queue_name[ 3 ]; /* array of queue names */
+TEST_EXTERN rtems_id Queue_id[ 3 ]; /* array of queue ids */
+TEST_EXTERN rtems_name Port_name[ 2 ]; /* array of port names */
+TEST_EXTERN rtems_id Port_id[ 2 ]; /* array of port ids */
+TEST_EXTERN rtems_name Period_name[ 2 ]; /* array of period names */
+TEST_EXTERN rtems_id Period_id[ 2 ]; /* array of period ids */
+TEST_EXTERN rtems_id Junk_id; /* id used to return errors */
+#define Internal_port_area (void *) 0x00001000
+#define External_port_area (void *) 0x00002000
+/* end of include file */
diff --git a/testsuites/sptests/sptask_err02/Makefile.am b/testsuites/sptests/sptask_err02/Makefile.am
index 0000000..0c0edfd
--- /dev/null
+++ b/testsuites/sptests/sptask_err02/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = sptask_err02
+sptask_err02_SOURCES = init.c system.h
+dist_rtems_tests_DATA = sptask_err02.scn
+dist_rtems_tests_DATA += sptask_err02.doc
+LINK_OBJS = $(sptask_err02_OBJECTS)
+LINK_LIBS = $(sptask_err02_LDLIBS)
+sptask_err02$(EXEEXT): $(sptask_err02_OBJECTS) $(sptask_err02_DEPENDENCIES)
+ @rm -f sptask_err02$(EXEEXT)
+ $(make-exe)
diff --git a/testsuites/sptests/sptask_err02/init.c b/testsuites/sptests/sptask_err02/init.c
index 0000000..6a387c5
--- /dev/null
+++ b/testsuites/sptests/sptask_err02/init.c
@@ -0,0 +1,117 @@
+#endif
+rtems_task Init(
+ puts( "\n\n*** TEST TASK ERROR 02 ***" );
+ /* wake when NULL param */
+ status = rtems_task_wake_when( NULL );
+ status,
+ "rtems_task_wake_when NULL param"
+ puts( "TA1 - rtems_task_wake_when - RTEMS_INVALID_ADDRESS" );
+ /* wake when before set */
+ status = rtems_task_wake_when( &time );
+ puts(
+ "TA1 - rtems_task_wake_when - RTEMS_NOT_DEFINED -- "
+ } else {
+ status,
+ "rtems_task_wake_when before clock is set"
+ puts( "TA1 - rtems_task_wake_when - RTEMS_NOT_DEFINED" );
+ /* rtems_task_wake_when */
+ build_time(
+ &time,
+ 2, 5, 1988, 8, 30, 48,
+ time.second += 3;
+ puts( "TA1 - rtems_task_wake_when - TICKINVALID - sleep about 3 seconds" );
+ /* NULL time */
+ status,
+ "rtems_task_wake_when with NULL"
+ /* invalid ticks */
+ directive_failed(
+ status,
+ "rtems_task_wake_when with invalid ticks per second"
+ puts( "TA1 - rtems_task_wake_when - TICKINVALID - woke up RTEMS_SUCCESSFUL" );
+ build_time( &time, 2, 5, 1961, 8, 30, 48, 0 );
+ print_time( "TA1 - rtems_task_wake_when - ", &time, "" );
+ status,
+ "rtems_task_wake_when with invalid year"
+ build_time( &time, 2, 5, 1988, 25, 30, 48, 0 );
+ status,
+ "rtems_task_wake_when with invalid hour"
+ time.month = 1;
+ status,
+ "rtems_task_wake_when before current time"
+ puts( "*** END TEST TASK ERROR 02 ***" );
diff --git a/testsuites/sptests/sptask_err02/sptask_err02.doc b/testsuites/sptests/sptask_err02/sptask_err02.doc
index 0000000..c37d1c2
--- /dev/null
+++ b/testsuites/sptests/sptask_err02/sptask_err02.doc
@@ -0,0 +1,25 @@
+test set name: sptask_err02
+directives:
+ t_wkwhen, c_set, c_getticksps, c_gettod
+concepts:
diff --git a/testsuites/sptests/sptask_err02/sptask_err02.scn b/testsuites/sptests/sptask_err02/sptask_err02.scn
index 0000000..1503972
--- /dev/null
+++ b/testsuites/sptests/sptask_err02/sptask_err02.scn
@@ -0,0 +1,12 @@
+*** TEST TASK ERROR 02 ***
+TA1 - rtems_task_wake_when - RTEMS_INVALID_ADDRESS
+TA1 - rtems_task_wake_when - RTEMS_NOT_DEFINED
+TA1 - rtems_task_wake_when - TICKINVALID - sleep about 3 seconds
+TA1 - rtems_task_wake_when - TICKINVALID - woke up RTEMS_SUCCESSFUL
+TA1 - rtems_task_wake_when - 08:30:48 02/05/1961 - RTEMS_INVALID_CLOCK
+TA1 - rtems_task_wake_when - 25:30:48 02/05/1988 - RTEMS_INVALID_CLOCK
+TA1 - current time - 08:30:51 02/05/1988
+TA1 - rtems_task_wake_when - 08:30:51 01/05/1988 - RTEMS_INVALID_CLOCK
+*** END TEST TASK ERROR 02 ***
diff --git a/testsuites/sptests/sptask_err02/system.h b/testsuites/sptests/sptask_err02/system.h
index 0000000..c72eea9
--- /dev/null
+++ b/testsuites/sptests/sptask_err02/system.h
@@ -0,0 +1,37 @@
+/* functions */
+rtems_task Init(
diff --git a/testsuites/sptests/sptask_err04/Makefile.am b/testsuites/sptests/sptask_err04/Makefile.am
index 0000000..7c21fc4
--- /dev/null
+++ b/testsuites/sptests/sptask_err04/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = sptask_err04
+sptask_err04_SOURCES = init.c task1.c system.h
+dist_rtems_tests_DATA = sptask_err04.scn
+dist_rtems_tests_DATA += sptask_err04.doc
+LINK_OBJS = $(sptask_err04_OBJECTS)
+LINK_LIBS = $(sptask_err04_LDLIBS)
+sptask_err04$(EXEEXT): $(sptask_err04_OBJECTS) $(sptask_err04_DEPENDENCIES)
+ @rm -f sptask_err04$(EXEEXT)
+ $(make-exe)
diff --git a/testsuites/sptests/sptask_err04/init.c b/testsuites/sptests/sptask_err04/init.c
index 0000000..52632b5
--- /dev/null
+++ b/testsuites/sptests/sptask_err04/init.c
@@ -0,0 +1,89 @@
+#endif
+#include <rtems/rtems/tasksimpl.h>
+rtems_task Init(
+ uint32_t notepad_value;
+ rtems_id self_id;
+ rtems_task_priority previous_priority;
+ puts( "\n\n*** TEST TASK ERROR 04 ***" );
+ Task_name[ 1 ] = rtems_build_name( 'T', 'A', '1', ' ' );
+ /* priority of 0 error */
+ status = rtems_task_create(
+ Task_name[1],
+ 0,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &Task_id[ 1 ]
+ status,
+ RTEMS_INVALID_PRIORITY,
+ "rtems_task_create with illegal priority"
+ puts( "INIT - rtems_task_create - priority of 0 - RTEMS_INVALID_PRIORITY" );
+ /* priority > 255 error */
+ Task_name[1],
+ 257,
+ &Task_id[ 1 ]
+ status,
+ puts(
+ "INIT - rtems_task_create - priority too high - RTEMS_INVALID_PRIORITY"
+ Task_name[ 1 ],
+ 4,
+ RTEMS_MINIMUM_STACK_SIZE * 3,
+ &Task_id[ 1 ]
+ directive_failed( status, "rtems_task_create of TA1" );
+ status = rtems_task_restart( Task_id[ 1 ], 0 );
+ status,
+ RTEMS_INCORRECT_STATE,
+ "rtems_task_restart of DORMANT task"
+ puts( "INIT - rtems_task_restart - RTEMS_INCORRECT_STATE" );
+ status = rtems_task_start( Task_id[ 1 ], Task_1, 0 );
+ directive_failed( status, "rtems_task_start of TA1" );
+ status = rtems_task_delete( RTEMS_SELF );
+ directive_failed( status, "rtems_task_delete of RTEMS_SELF" );
diff --git a/testsuites/sptests/sptask_err04/sptask_err04.doc b/testsuites/sptests/sptask_err04/sptask_err04.doc
index 0000000..3773cb6
--- /dev/null
+++ b/testsuites/sptests/sptask_err04/sptask_err04.doc
@@ -0,0 +1,27 @@
+test set name: sptask_err04
+directives:
+ t_delete, t_getnote, t_ident, t_restart, t_resume, t_setpriority,
+ t_mode, t_start, t_suspend,
+concepts:
diff --git a/testsuites/sptests/sptask_err04/sptask_err04.scn b/testsuites/sptests/sptask_err04/sptask_err04.scn
index 0000000..c21cce3
--- /dev/null
+++ b/testsuites/sptests/sptask_err04/sptask_err04.scn
@@ -0,0 +1,24 @@
+*** TEST TASK ERROR 04 ***
+TA1 - rtems_task_is_suspended - RTEMS_INVALID_ID
+TA1 - rtems_task_delete - RTEMS_INVALID_ID
+TA1 - rtems_task_get_note - RTEMS_INVALID_ADDRESS
+TA1 - rtems_task_get_note - RTEMS_INVALID_NUMBER
+TA1 - rtems_task_get_note - RTEMS_INVALID_ID
+TA1 - rtems_task_ident - RTEMS_INVALID_ADDRESS
+TA1 - rtems_task_ident - global RTEMS_INVALID_NAME
+TA1 - rtems_task_ident - local RTEMS_INVALID_NAME
+TA1 - rtems_task_ident - RTEMS_INVALID_NODE
+TA1 - rtems_task_restart - RTEMS_INVALID_ID
+TA1 - rtems_task_resume - RTEMS_INVALID_ID
+TA1 - rtems_task_resume - RTEMS_INCORRECT_STATE
+TA1 - rtems_task_set_priority - RTEMS_INVALID_ADDRESS
+TA1 - rtems_task_set_priority - RTEMS_INVALID_PRIORITY
+TA1 - rtems_task_set_priority - RTEMS_INVALID_ID
+TA1 - rtems_task_set_note - RTEMS_INVALID_NUMBER
+TA1 - rtems_task_set_note - RTEMS_INVALID_ID
+TA1 - rtems_task_start - RTEMS_INVALID_ID
+TA1 - rtems_task_start - RTEMS_INCORRECT_STATE
+TA1 - rtems_task_suspend - RTEMS_INVALID_ID
+TA1 - rtems_task_mode - RTEMS_INVALID_ADDRESS
+*** END TEST TASK DELETE ERROR 04 ***
diff --git a/testsuites/sptests/sptask_err04/system.h b/testsuites/sptests/sptask_err04/system.h
index 0000000..e6632ff
--- /dev/null
+++ b/testsuites/sptests/sptask_err04/system.h
@@ -0,0 +1,45 @@
+/* functions */
+rtems_task Init(
+rtems_task Task_1(
+#define CONFIGURE_MAXIMUM_TASKS 3
+TEST_EXTERN rtems_id Task_id[ 2 ]; /* array of task ids */
+TEST_EXTERN rtems_name Task_name[ 2 ]; /* array of task names */
diff --git a/testsuites/sptests/sptask_err04/task1.c b/testsuites/sptests/sptask_err04/task1.c
index 0000000..c9f5447
--- /dev/null
+++ b/testsuites/sptests/sptask_err04/task1.c
@@ -0,0 +1,277 @@
+/* Task_1
+ * This task generates all possible errors for the RTEMS executive.
+ * argument - task argument
+#endif
+rtems_task Task_1(
+ rtems_id self_id;
+ /* bad Id */
+ status = rtems_task_is_suspended( 100 );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_set_priority with illegal id"
+ puts( "TA1 - rtems_task_is_suspended - RTEMS_INVALID_ID" );
+ /* bad Id */
+ status = rtems_task_delete( 100 );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_delete with illegal id"
+ puts( "TA1 - rtems_task_delete - RTEMS_INVALID_ID" );
+ /* NULL return */
+ status = rtems_task_get_note( RTEMS_SELF, RTEMS_NOTEPAD_FIRST, NULL );
+ status,
+ "rtems_task_get_note with NULL param"
+ puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_ADDRESS" );
+ /* note too high */
+ status = rtems_task_get_note( RTEMS_SELF, 100, ¬epad_value );
+ status,
+ RTEMS_INVALID_NUMBER,
+ "rtems_task_get_note with illegal notepad"
+ puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_NUMBER" );
+ /* bad Id */
+ status = rtems_task_get_note( 100, RTEMS_NOTEPAD_LAST, ¬epad_value );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_get_note with illegal id"
+ puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_ID" );
+ /* unused Id so invalid now */
+ _RTEMS_tasks_Information.maximum_id,
+ RTEMS_NOTEPAD_LAST,
+ ¬epad_value
+ status,
+ RTEMS_INVALID_ID,
+ _RTEMS_tasks_Information.minimum_id + (3L<<OBJECTS_API_START_BIT),
+ ¬epad_value
+ status,
+ RTEMS_INVALID_ID,
+ rtems_build_id( OBJECTS_CLASSIC_API, 2, 1, 1 ),
+ ¬epad_value
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_get_note with non-task ID"
+ /* NULL param */
+ status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, NULL );
+ status,
+ "rtems_task_ident NULL param"
+ puts( "TA1 - rtems_task_ident - RTEMS_INVALID_ADDRESS" );
+ /* OK */
+ status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &self_id );
+ directive_failed( status, "rtems_task_ident of self" );
+ if ( self_id != Task_id[ 1 ] ) {
+ puts( "ERROR - rtems_task_ident - incorrect ID returned!" );
+ puts( "TA1 - rtems_task_ident - current task RTEMS_SUCCESSFUL" );
+ status = rtems_task_ident( 100, RTEMS_SEARCH_ALL_NODES, &Junk_id );
+ status,
+ RTEMS_INVALID_NAME,
+ "rtems_task_ident with illegal name (local)"
+ puts( "TA1 - rtems_task_ident - global RTEMS_INVALID_NAME" );
+ status = rtems_task_ident( 100, 1, &Junk_id );
+ status,
+ "rtems_task_ident with illegal name (global)"
+ puts( "TA1 - rtems_task_ident - local RTEMS_INVALID_NAME" );
+ * This one case is different if MP is enabled/disabled.
+ status = rtems_task_ident( 100, 2, &Junk_id );
+#if defined(RTEMS_MULTIPROCESSING)
+ status,
+ RTEMS_INVALID_NODE,
+ "rtems_task_ident with illegal node"
+#else
+ status,
+#endif
+ puts( "TA1 - rtems_task_ident - RTEMS_INVALID_NODE" );
+ status = rtems_task_restart( 100, 0 );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_restart with illegal id"
+ puts( "TA1 - rtems_task_restart - RTEMS_INVALID_ID" );
+ status = rtems_task_resume( 100 );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_resume with illegal id"
+ puts( "TA1 - rtems_task_resume - RTEMS_INVALID_ID" );
+ status = rtems_task_resume( RTEMS_SELF );
+ status,
+ "rtems_task_resume of ready task"
+ puts( "TA1 - rtems_task_resume - RTEMS_INCORRECT_STATE" );
+ /* NULL param */
+ status = rtems_task_set_priority( RTEMS_SELF, RTEMS_CURRENT_PRIORITY, NULL );
+ status,
+ "rtems_task_set_priority with NULL param"
+ puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_ADDRESS" );
+ /* bad priority */
+ status = rtems_task_set_priority( RTEMS_SELF, 512, &previous_priority );
+ status,
+ "rtems_task_set_priority with illegal priority"
+ puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_PRIORITY" );
+ /* bad Id */
+ status = rtems_task_set_priority( 100, 8, &previous_priority );
+ status,
+ RTEMS_INVALID_ID,
+ puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_ID" );
+ status = rtems_task_set_note(
+ RTEMS_SELF,
+ RTEMS_NOTEPAD_LAST+10,
+ notepad_value
+ status,
+ "rtems_task_set_note with illegal notepad"
+ puts( "TA1 - rtems_task_set_note - RTEMS_INVALID_NUMBER" );
+ status = rtems_task_set_note( 100, RTEMS_NOTEPAD_LAST, notepad_value );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_set_note with illegal id"
+ puts( "TA1 - rtems_task_set_note - RTEMS_INVALID_ID" );
+ status = rtems_task_start( 100, Task_1, 0 );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_start with illegal id"
+ puts( "TA1 - rtems_task_start - RTEMS_INVALID_ID" );
+ /* already started */
+ status = rtems_task_start( RTEMS_SELF, Task_1, 0 );
+ status,
+ "rtems_task_start of ready task"
+ puts( "TA1 - rtems_task_start - RTEMS_INCORRECT_STATE" );
+ /* bad Id */
+ status = rtems_task_suspend( 100 );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_suspend with illegal id"
+ puts( "TA1 - rtems_task_suspend - RTEMS_INVALID_ID" );
+ /* NULL param */
+ status = rtems_task_mode( RTEMS_SELF, 0, NULL );
+ status,
+ "rtems_task_mode with NULL param"
+ puts( "TA1 - rtems_task_mode - RTEMS_INVALID_ADDRESS" );
+ puts( "\n*** TEST TASK ERROR 04 ***" );
+ rtems_test_exit( 0 );
diff --git a/testsuites/sptests/sptimer_err01/init.c b/testsuites/sptests/sptimer_err01/init.c
index 6108ac7..37bb82c 100644
--- a/testsuites/sptests/sptimer_err01/init.c
+++ b/testsuites/sptests/sptimer_err01/init.c
@@ -36,6 +36,21 @@ rtems_task Init(
timer_name = rtems_build_name( 'T', 'M', '1', ' ' );
+ /* before time set */
+ status = rtems_timer_fire_when( 0, &time, Delayed_routine, NULL );
+ puts(
+ "TA1 - timer_wake_when - RTEMS_NOT_DEFINED -- DID BSP SET THE TIME OF DAY?"
+ } else {
+ status,
+ "task_fire_when before clock is set"
+ puts( "TA1 - rtems_timer_fire_when - RTEMS_NOT_DEFINED" );
/* Set System time */
build_time( &time, 12, 31, 1992, 9, 0, 0, 0 );
diff --git a/testsuites/sptests/sptimer_err01/sptimer_err01.scn b/testsuites/sptests/sptimer_err01/sptimer_err01.scn
index 455017e..4f11806 100644
--- a/testsuites/sptests/sptimer_err01/sptimer_err01.scn
+++ b/testsuites/sptests/sptimer_err01/sptimer_err01.scn
@@ -1,4 +1,5 @@
*** TEST SPTIMER_ERR01 ***
+TA1 - rtems_timer_fire_when - RTEMS_NOT_DEFINED
TA1 - rtems_timer_create - RTEMS_INVALID_ADDRESS
TA1 - rtems_timer_create - RTEMS_INVALID_NAME
TA1 - rtems_timer_create - 1 - RTEMS_SUCCESSFUL
@@ -20,4 +21,3 @@ TA1 - rtems_timer_fire_when - 08:30:45 02/05/1990 - before RTEMS_INVALID_CLOCK
TA1 - rtems_timer_get_information - RTEMS_INVALID_ADDRESS
TA1 - rtems_timer_get_information - RTEMS_INVALID_ID
*** END OF TEST SPTIMER_ERR01 ***
1.8.1.4
