sleep time is doubled, xilinx_zynq_zedboard
Giovanni Macciocu G.Macciocu at sron.nl
Thu May 1 10:52:07 UTC 2014
I've made some tests by changing the value of  BSP_ARM_A9MPCORE_PERIPHCLK.
The value should be 666666667U as this is my cpu clock speed.
However in the following cases
#define BSP_ARM_A9MPCORE_PERIPHCLK (2 * 666666667U)
--> a Sleep now takes 4 times as long
#define BSP_ARM_A9MPCORE_PERIPHCLK 2 (666666667U / 2)
--> The sleep is now correct
In all cases the serial port keeps working at half of the normal buadrate.
Regards,
Giovanni
>>> "Giovanni Macciocu" <G.Macciocu at sron.nl> 5/1/2014 10:53 AM >>>
In my bspopt.h
/* ARM Cortex-A9 MPCore PERIPHCLK clock frequency in Hz */
#define BSP_ARM_A9MPCORE_PERIPHCLK 666666667U
This is the correct processor speed for my platform.
>>> Chris Johns <chrisj at rtems.org> 5/1/2014 10:24 AM >>>
t you take a look at the BSPOPTS for the zync BSP. There are
some clocks you can set and one of these may help. I think
BSP_ARM_A9MPCORE_PERIPHCLK is the one.
rtems-devel mailing list
rtems-devel at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-devel
