[PATCH 1/2] score: SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS
Sebastian Huber
Fri May 2 11:39:08 UTC 2014
Avoid the SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS fatal error and make it
a run-time error in rtems_scheduler_ident() and _Scheduler_Get_by_id().
cpukit/rtems/include/rtems/rtems/tasks.h | 2 +
cpukit/rtems/src/schedulerident.c | 12 +++-
cpukit/score/include/rtems/score/schedulerimpl.h | 21 +++++-
cpukit/score/include/rtems/score/smpimpl.h | 1 -
cpukit/score/src/smp.c | 16 ----
doc/user/conf.t | 2 -
doc/user/smp.t | 4 +-
testsuites/smptests/Makefile.am | 1 -
testsuites/smptests/configure.ac | 1 -
testsuites/smptests/smpfatal06/Makefile.am | 19 -----
testsuites/smptests/smpfatal06/init.c | 81 ----------------------
testsuites/smptests/smpfatal06/smpfatal06.doc | 11 ---
testsuites/smptests/smpfatal06/smpfatal06.scn | 2 -
testsuites/smptests/smpscheduler02/init.c | 56 +++++++++++++--
14 files changed, 82 insertions(+), 147 deletions(-)
delete mode 100644 testsuites/smptests/smpfatal06/Makefile.am
delete mode 100644 testsuites/smptests/smpfatal06/init.c
delete mode 100644 testsuites/smptests/smpfatal06/smpfatal06.doc
delete mode 100644 testsuites/smptests/smpfatal06/smpfatal06.scn
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index a9016ce..43e8c8a 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -597,6 +597,8 @@ rtems_id rtems_task_self(void);
* @retval RTEMS_SUCCESSFUL Successful operation.
* @retval RTEMS_INVALID_ADDRESS The @a id parameter is @c NULL.
* @retval RTEMS_INVALID_NAME Invalid scheduler name.
+ * @retval RTEMS_UNSATISFIED A scheduler with this name exists, but the
+ * processor set of this scheduler is empty.
rtems_status_code rtems_scheduler_ident(
rtems_name name,
diff --git a/cpukit/rtems/src/schedulerident.c b/cpukit/rtems/src/schedulerident.c
index d9e913c..ee18af0 100644
--- a/cpukit/rtems/src/schedulerident.c
+++ b/cpukit/rtems/src/schedulerident.c
@@ -33,9 +33,15 @@ rtems_status_code rtems_scheduler_ident(
sc = RTEMS_INVALID_NAME;
for ( i = 0 ; i < n && sc == RTEMS_INVALID_NAME ; ++i ) {
- if ( _Scheduler_Table[ i ].name == name ) {
- *id = _Scheduler_Build_id( i );
- sc = RTEMS_SUCCESSFUL;
+ const Scheduler_Control *scheduler = &_Scheduler_Table[ i ];
+ if ( scheduler->name == name ) {
+ if ( _Scheduler_Get_processor_count( scheduler ) > 0 ) {
+ *id = _Scheduler_Build_id( i );
+ sc = RTEMS_SUCCESSFUL;
+ } else {
+ sc = RTEMS_UNSATISFIED;
} else {
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index 35054df..6fad4e2 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -571,6 +571,19 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Change_priority_if_higher(
+RTEMS_INLINE_ROUTINE uint32_t _Scheduler_Get_processor_count(
+#if defined(RTEMS_SMP)
+ return scheduler->context->processor_count;
+#else
+ (void) scheduler;
+ return 1;
+#endif
RTEMS_INLINE_ROUTINE Objects_Id _Scheduler_Build_id( uint32_t scheduler_index )
return _Objects_Build_id(
@@ -583,15 +596,17 @@ RTEMS_INLINE_ROUTINE Objects_Id _Scheduler_Build_id( uint32_t scheduler_index )
RTEMS_INLINE_ROUTINE bool _Scheduler_Get_by_id(
Objects_Id id,
- const Scheduler_Control **scheduler
+ const Scheduler_Control **scheduler_p
uint32_t minimum_id = _Scheduler_Build_id( 0 );
uint32_t index = id - minimum_id;
+ const Scheduler_Control *scheduler = &_Scheduler_Table[ index ];
- *scheduler = &_Scheduler_Table[ index ];
+ *scheduler_p = scheduler;
- return index < _Scheduler_Count;
+ return index < _Scheduler_Count
+ && _Scheduler_Get_processor_count( scheduler ) > 0;
RTEMS_INLINE_ROUTINE uint32_t _Scheduler_Get_index(
diff --git a/cpukit/score/include/rtems/score/smpimpl.h b/cpukit/score/include/rtems/score/smpimpl.h
index c281592..27cf188 100644
--- a/cpukit/score/include/rtems/score/smpimpl.h
+++ b/cpukit/score/include/rtems/score/smpimpl.h
@@ -52,7 +52,6 @@ typedef enum {
SMP_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER,
SMP_FATAL_MANDATORY_PROCESSOR_NOT_PRESENT,
SMP_FATAL_MULTITASKING_START_ON_UNASSIGNED_PROCESSOR,
- SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS,
SMP_FATAL_START_OF_MANDATORY_PROCESSOR_FAILED
} SMP_Fatal_code;
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index f03a4c0..34db46ad 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -25,20 +25,6 @@
#include <rtems/config.h>
-static void _SMP_Check_scheduler_configuration( void )
- size_t n = _Scheduler_Count;
- size_t i;
- for ( i = 0 ; i < n ; ++i ) {
- const Scheduler_Control *scheduler = &_Scheduler_Table[ i ];
- if ( scheduler->context->processor_count == 0 ) {
- _SMP_Fatal( SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS );
static void _SMP_Start_processors( uint32_t cpu_count )
uint32_t cpu_index_self = _SMP_Get_current_processor();
@@ -75,8 +61,6 @@ static void _SMP_Start_processors( uint32_t cpu_count )
++assignment->scheduler->context->processor_count;
- _SMP_Check_scheduler_configuration();
void _SMP_Handler_initialize( void )
diff --git a/doc/user/conf.t b/doc/user/conf.t
index 3a03df1..2c8c5f2 100644
--- a/doc/user/conf.t
+++ b/doc/user/conf.t
@@ -3931,8 +3931,6 @@ processors. The processor demand must be reduced for this system.
mandatory processor failed during system initialization. The system may not
have this processor at all or it could be a problem with a boot loader for
example. Check the @code{CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS} definition.
- at item @code{SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS} - it is prohibited to have
-a scheduler managing the empty processor set.
@item @code{SMP_FATAL_MULTITASKING_START_ON_UNASSIGNED_PROCESSOR} - it is not
allowed to start multitasking on a processor with no scheduler assigned.
@end itemize
diff --git a/doc/user/smp.t b/doc/user/smp.t
index 3d9cc29..65f5bd7 100644
--- a/doc/user/smp.t
+++ b/doc/user/smp.t
@@ -336,7 +336,9 @@ rtems_status_code rtems_scheduler_ident(
@code{@value{RPREFIX}SUCCESSFUL} - successful operation@*
@code{@value{RPREFIX}INVALID_ADDRESS} - @code{id} is NULL@*
- at code{@value{RPREFIX}INVALID_NAME} - invalid scheduler name
+ at code{@value{RPREFIX}INVALID_NAME} - invalid scheduler name@*
+ at code{@value{RPREFIX}UNSATISFIED} - - a scheduler with this name exists, but
+the processor set of this scheduler is empty
@subheading DESCRIPTION:
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index e757cf2..f16d396 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -16,7 +16,6 @@ SUBDIRS += smpfatal02
SUBDIRS += smpfatal03
SUBDIRS += smpfatal04
SUBDIRS += smpfatal05
-SUBDIRS += smpfatal06
SUBDIRS += smpfatal07
SUBDIRS += smpfatal08
SUBDIRS += smpload01
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index ee36b50..e3857f1 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -71,7 +71,6 @@ smpfatal02/Makefile
smpfatal03/Makefile
smpfatal04/Makefile
smpfatal05/Makefile
-smpfatal06/Makefile
smpfatal07/Makefile
smpfatal08/Makefile
smpload01/Makefile
diff --git a/testsuites/smptests/smpfatal06/Makefile.am b/testsuites/smptests/smpfatal06/Makefile.am
deleted file mode 100644
index c0bdf5b..0000000
--- a/testsuites/smptests/smpfatal06/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-rtems_tests_PROGRAMS = smpfatal06
-smpfatal06_SOURCES = init.c
-dist_rtems_tests_DATA = smpfatal06.scn smpfatal06.doc
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-LINK_OBJS = $(smpfatal06_OBJECTS)
-LINK_LIBS = $(smpfatal06_LDLIBS)
-smpfatal06$(EXEEXT): $(smpfatal06_OBJECTS) $(smpfatal06_DEPENDENCIES)
- @rm -f smpfatal06$(EXEEXT)
- $(make-exe)
-include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpfatal06/init.c b/testsuites/smptests/smpfatal06/init.c
index 739da7a..0000000
--- a/testsuites/smptests/smpfatal06/init.c
+++ /dev/null
@@ -1,81 +0,0 @@
- * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
- #include "config.h"
-#endif
-#include <rtems.h>
-#include <rtems/test.h>
-#include <rtems/score/smpimpl.h>
-#include <assert.h>
-#include <stdlib.h>
-const char rtems_test_name[] = "SMPFATAL 6";
-static void Init(rtems_task_argument arg)
- assert(0);
-static void fatal_extension(
- rtems_fatal_source source,
- bool is_internal,
- rtems_fatal_code code
- rtems_test_begink();
- if (
- source == RTEMS_FATAL_SOURCE_SMP
- && !is_internal
- && code == SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS
- rtems_test_endk();
-#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_INITIAL_EXTENSIONS \
- { .fatal = fatal_extension }, \
- RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_SMP_APPLICATION
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 1
-#define CONFIGURE_SCHEDULER_SIMPLE_SMP
-#include <rtems/scheduler.h>
-RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(a);
-RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(b);
-#define CONFIGURE_SCHEDULER_CONTROLS \
- RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(a, rtems_build_name('S', 'I', 'M', 'P')), \
- RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(b, rtems_build_name('S', 'I', 'M', 'P'))
-#define CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS \
- RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY)
-#define CONFIGURE_MAXIMUM_TASKS 1
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpfatal06/smpfatal06.doc b/testsuites/smptests/smpfatal06/smpfatal06.doc
index e35b3b0..0000000
--- a/testsuites/smptests/smpfatal06/smpfatal06.doc
+++ /dev/null
@@ -1,11 +0,0 @@
-This file describes the directives and concepts tested by this test set.
-test set name: smpfatal06
-directives:
- - _SMP_Handler_initialize()
-concepts:
- - Ensure that a scheduler without processor leads to a fatal error.
diff --git a/testsuites/smptests/smpfatal06/smpfatal06.scn b/testsuites/smptests/smpfatal06/smpfatal06.scn
index 575b2b3..0000000
--- a/testsuites/smptests/smpfatal06/smpfatal06.scn
+++ /dev/null
@@ -1,2 +0,0 @@
-*** TEST SMPFATAL 6 ***
-*** END OF TEST SMPFATAL 6 ***
diff --git a/testsuites/smptests/smpscheduler02/init.c b/testsuites/smptests/smpscheduler02/init.c
index f958744..1e6b6d5 100644
--- a/testsuites/smptests/smpscheduler02/init.c
+++ b/testsuites/smptests/smpscheduler02/init.c
@@ -25,12 +25,12 @@ const char rtems_test_name[] = "SMPSCHEDULER 2";
#if defined(__RTEMS_HAVE_SYS_CPUSET_H__)
-#define CPU_COUNT 2
#define SCHED_A rtems_build_name(' ', ' ', ' ', 'A')
#define SCHED_B rtems_build_name(' ', ' ', ' ', 'B')
+#define SCHED_C rtems_build_name(' ', ' ', ' ', 'C')
static rtems_id main_task_id;
static void task(rtems_task_argument arg)
@@ -56,6 +56,7 @@ static void test(void)
rtems_id scheduler_id;
rtems_id scheduler_a_id;
rtems_id scheduler_b_id;
+ rtems_id scheduler_c_id;
cpu_set_t cpuset;
cpu_set_t first_cpu;
cpu_set_t second_cpu;
@@ -82,6 +83,9 @@ static void test(void)
rtems_test_assert(sc == RTEMS_SUCCESSFUL);
rtems_test_assert(scheduler_a_id != scheduler_b_id);
+ sc = rtems_scheduler_ident(SCHED_C, &scheduler_c_id);
+ rtems_test_assert(sc == RTEMS_UNSATISFIED);
CPU_ZERO(&cpuset);
sc = rtems_scheduler_get_processor_set(
scheduler_a_id,
@@ -122,6 +126,9 @@ static void test(void)
sc = rtems_task_set_scheduler(task_id, scheduler_b_id);
+ sc = rtems_task_set_scheduler(task_id, scheduler_b_id + 1);
+ rtems_test_assert(sc == RTEMS_INVALID_ID);
sc = rtems_task_get_scheduler(task_id, &scheduler_id);
rtems_test_assert(scheduler_id == scheduler_b_id);
@@ -191,11 +198,13 @@ static void Init(rtems_task_argument arg)
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+/* Lets see when the first RTEMS system hits this limit */
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 64
#define CONFIGURE_MAXIMUM_PRIORITY 255
#define CONFIGURE_SCHEDULER_PRIORITY_SMP
+#define CONFIGURE_SCHEDULER_SIMPLE_SMP
@@ -203,15 +212,50 @@ RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP(a, CONFIGURE_MAXIMUM_PRIORITY + 1);
RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP(b, CONFIGURE_MAXIMUM_PRIORITY + 1);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(c);
RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP(a, SCHED_A), \
- RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP(b, SCHED_B)
+ RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP(b, SCHED_B), \
+ RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(c, SCHED_C)
RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
- RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY)
+ RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
+ RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER, RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER, \
+ RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER, \
+ RTEMS_SCHEDULER_ASSIGN(2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL)
-#define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
+#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
1.7.7
