[GSOC] RPi BSP RTEMS
Alan Cudmore alan.cudmore at gmail.com
Fri May 2 17:07:45 UTC 2014
Chris,
I can use OpenOCD to load, run, break, resume, etc, but I am not having
luck with GDB yet.
I can connect to the OpenOCD remote target server, send monitor commands,
but I cannot load code through GDB or control the target.
When I try loading through GDB, I end up with load failure messages.
Any hints in configuring OpenOCD or GDB?
Thanks,
Alan
On Mon, Apr 28, 2014 at 8:55 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 29/04/2014 10:37 am, Alan Cudmore wrote:
>> I will definitely try that out. It would be great to automate all tests
>> on this board.
>> It seems less than 10 seconds to load a 1 megabyte RTEMS image to the Pi
>> using JTAG.
> The last test from the Beagleboard xM test log shows ...
> [498/498] p:488 f:1   t:8   i:0   | arm/beagleboardxm: tmoverhd.exe
> Result: passed     Time: 0:00:12.141110
> This test took just over 12 seconds so this seems close to what we have.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140502/d4cbbf71/attachment.html>
