[PATCH 2/2] score: Implement forced thread migration
Fri May 2 22:46:46 UTC 2014
On 2/05/2014 9:39 pm, Sebastian Huber wrote:
> The current implementation of task migration in RTEMS has some
> implications with respect to the interrupt latency. It is crucial to
> preserve the system invariant that a task can execute on at most one
> processor in the system at a time. This is accomplished with a boolean
> indicator in the task context. The processor architecture specific
> low-level task context switch code will mark that a task context is no
> longer executing and waits that the heir context stopped execution
> before it restores the heir context and resumes execution of the heir
> task. So there is one point in time in which a processor is without a
> task. This is essential to avoid cyclic dependencies in case multiple
> tasks migrate at once. Otherwise some supervising entity is necessary to
> prevent life-locks. Such a global supervisor would lead to scalability
> problems so this approach is not used. Currently the thread dispatch is
> performed with interrupts disabled. So in case the heir task is
> currently executing on another processor then this prolongs the time of
> disabled interrupts since one processor has to wait for another
> processor to make progress.
Do you maintain a stat in the per processor data and/or task counting
the number of times a running task is moved to run on another processor
? To me it would seem excessive switching of this kind points to a user
bug in how they are managing the scheduling.
I think I see what you are addressing and have no issues there however I
am struggling to under why this would happen in a balanced system, ie
why move a running task just to make it keep running, and if migration
is the issue is this a result of dynamic migration or some other factor.
> It is difficult to avoid this issue with the interrupt latency since
> interrupts normally store the context of the interrupted task on its
> stack. In case a task is marked as not executing we must not use its
> task stack to store such an interrupt context. We cannot use the heir
> stack before it stopped execution on another processor. So if we enable
> interrupts during this transition we have to provide an alternative task
> independent stack for this time frame. This issue needs further
> investigation.
If the processor is idle would you have implicitly switched to the IDLE
context of which there is one per processor ? Would it's stack be
available ?
