Rtems_fsmount dosfs hanging
Andre Marques andre.lousa.marques at gmail.com
Mon May 5 09:52:59 UTC 2014
Hello,
Following the problem in
http://www.rtems.org/pipermail/rtems-devel/2014-April/006585.html
I am now trying to mount the SD card partitions on RTEMS.
Summarizing the process:
1. rtems_io_register_driver (by calling my driver with
CONFIGURE_APPLICATION_EXTRA_DRIVERS on hello sample)
2. rtems_filesystem_make_dev_t (to get the device file)
3.  rtems_disk_io_initialize
4. rtems_disk_create_phys (to create the disk, at /dev/sdc0)
5. rtems_bdpart_register_from_disk (to read and register the partitions)
6. rtems_fsmount (to mount the partitions)
For rtems_fsmount I am providing the following fs_table:
rtems_fstab_entry fs_table [] = {
      .source = "/dev/sdc0",
      .target = "/mnt/p1",
      .type = "dosfs",
      .options = RTEMS_FILESYSTEM_READ_WRITE,
      .report_reasons =  RTEMS_FSTAB_ANY,
      .abort_reasons = RTEMS_FSTAB_OK
      .source = "/dev/sdc01",
      .target = "/mnt/p2",
      .type = "dosfs",
      .abort_reasons = RTEMS_FSTAB_NONE
The SD card has only one partition starting at block number 8192.
After I call rtems_fsmount it calls my driver to read block 8192 and
8193 and then hangs.
I have tested the driver and It seems to have no problem reading single
or multiple blocks.
Any tips?
Also I am using the following confdefs configuration (some values are
exaggerated):
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
#define CONFIGURE_FILESYSTEM_DOSFS
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
#define CONFIGURE_APPLICATION_EXTRA_DRIVERS SD_CARD_DRIVER_TABLE_ENTRY
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_MAXIMUM_DRIVERS 10
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
  #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
--André Marques
