[GSOC] RPi BSP RTEMS
Alan Cudmore
alan.cudmore at gmail.com
Fri May 9 02:24:27 UTC 2014
I have not had much time to figure out why GDB is not working with the
Pi/openOCD setup yet.
But I started documenting my setup. The hardware details are here:
http://alanstechnotes.blogspot.com/2014/05/a-low-cost-jtag-debugger-for-raspberry.html
Next I will document how to compile openOCD and use it to load RTEMS images
to the Pi.
Alan
On Fri, May 2, 2014 at 6:48 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 3/05/2014 3:07 am, Alan Cudmore wrote:
>> Chris,
>> I can use OpenOCD to load, run, break, resume, etc, but I am not having
>> luck with GDB yet.
> Excellent.
> I can connect to the OpenOCD remote target server, send monitor
>> commands, but I cannot load code through GDB or control the target.
>> When I try loading through GDB, I end up with load failure messages.
>> Any hints in configuring OpenOCD or GDB?
> Send me an OpenOCD and GDB session trace.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140508/c3931627/attachment.html>
