[PATCH 2/2] CAN bus Kvaser PCI CAN-S (single SJA1000 channel) emulation added.
Pavel Pisa pisa at cmp.felk.cvut.cz
Fri May 9 18:15:39 UTC 2014
Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz>
 hw/net/Makefile.objs    |   1 +
 hw/net/can_kvaser_pci.c | 355 ++++++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 356 insertions(+)
 create mode 100644 hw/net/can_kvaser_pci.c
diff --git a/hw/net/Makefile.objs b/hw/net/Makefile.objs
index 28679fc..3d66ca9 100644
--- a/hw/net/Makefile.objs
+++ b/hw/net/Makefile.objs
@@ -27,6 +27,7 @@ common-obj-$(CONFIG_LANCE) += lance.o
 obj-$(CONFIG_CAN_SJA1000) += can_core.o
 obj-$(CONFIG_CAN_SJA1000) += can_sja1000.o
 obj-$(CONFIG_CAN_PCI) += can_pci.o
+obj-$(CONFIG_CAN_PCI) += can_kvaser_pci.o
 obj-$(CONFIG_ETRAXFS) += etraxfs_eth.o
 obj-$(CONFIG_COLDFIRE) += mcf_fec.o
diff --git a/hw/net/can_kvaser_pci.c b/hw/net/can_kvaser_pci.c
new file mode 100644
index 0000000..b76de5f
--- /dev/null
+++ b/hw/net/can_kvaser_pci.c
@@ -0,0 +1,355 @@
+ * Kvaser PCI CAN device (SJA1000 based) emulation
+ * Copyright (c) 2013-2014 Jin Yang
+ * Copyright (c) 2014 Pavel Pisa
+ * Partially based on educational PCIexpress APOHW hardware
+ * emulator used fro class A0B36APO at CTU FEE course by
+ *    Rostislav Lisovy and Pavel Pisa
+ * Initial development supported by Google GSoC 2013 from RTEMS project slot
+ * Permission is hereby granted, free of charge, to any person obtaining a copy
+ * of this software and associated documentation files (the "Software"), to deal
+ * in the Software without restriction, including without limitation the rights
+ * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
+ * copies of the Software, and to permit persons to whom the Software is
+ * furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included in
+ * all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
+ * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
+ * THE SOFTWARE.
+#include "hw/hw.h"
+#include "hw/pci/pci.h"
+#include "qemu/event_notifier.h"
+#include "qemu/osdep.h"
+#include "qemu/thread.h"
+#include "qemu/sockets.h"
+#include "sysemu/char.h"
+#include "net/can_emu.h"
+#include "can_sja1000.h"
+#define TYPE_CAN_PCI_DEV "kvaser_pci"
+#define KVASER_PCI_DEV(obj) \
+    OBJECT_CHECK(KvaserPCIState, (obj), TYPE_CAN_PCI_DEV)
+#ifndef KVASER_PCI_VENDOR_ID1
+#define KVASER_PCI_VENDOR_ID1     0x10e8    /* the PCI device and vendor IDs */
+#endif
+#ifndef KVASER_PCI_DEVICE_ID1
+#define KVASER_PCI_DEVICE_ID1     0x8406
+#endif
+#define KVASER_PCI_S5920_RANGE    0x80
+#define KVASER_PCI_SJA_RANGE      0x80
+#define KVASER_PCI_XILINX_RANGE   0x8
+#define KVASER_PCI_BYTES_PER_SJA  0x20
+#define S5920_OMB                 0x0C
+#define S5920_IMB                 0x1C
+#define S5920_MBEF                0x34
+#define S5920_INTCSR              0x38
+#define S5920_RCR                 0x3C
+#define S5920_PTCR                0x60
+#define S5920_INTCSR_ADDON_INTENABLE_M        0x2000
+#define S5920_INTCSR_INTERRUPT_ASSERTED_M     0x800000
+#define KVASER_PCI_XILINX_VERINT  7   /* Lower nibble simulate interrupts,
+                                         high nibble version number. */
+typedef struct KvaserPCIState {
+    /*< private >*/
+    PCIDevice       dev;
+    /*< public >*/
+    MemoryRegion    s5920_io;
+    MemoryRegion    sja_io;
+    MemoryRegion    xilinx_io;
+    CanSJA1000State sja_state;
+    qemu_irq        irq;
+    uint32_t        s5920_intcsr;
+    uint32_t        s5920_irqstate;
+    char            *model; /* The model that support, only SJA1000 now. */
+    char            *canbus;
+    char            *host;
+} KvaserPCIState;
+static void kvaser_pci_irq_raise(void *opaque)
+    KvaserPCIState *d = (KvaserPCIState *)opaque;
+    d->s5920_irqstate = 1;
+    if (d->s5920_intcsr & S5920_INTCSR_ADDON_INTENABLE_M)
+        qemu_irq_raise(d->irq);
+static void kvaser_pci_irq_lower(void *opaque)
+    d->s5920_irqstate = 0;
+    qemu_irq_lower(d->irq);
+static void
+kvaser_pci_reset(void *opaque)
+    CanSJA1000State *s = &d->sja_state;
+    can_sja_hardware_reset(s);
+static uint64_t kvaser_pci_s5920_io_read(void *opaque, hwaddr addr, unsigned size)
+    KvaserPCIState *d = opaque;
+    uint64_t val;
+    switch (addr) {
+        case S5920_INTCSR:
+            val = d->s5920_intcsr;
+            val &= ~S5920_INTCSR_INTERRUPT_ASSERTED_M;
+            if (d->s5920_irqstate)
+                val |= S5920_INTCSR_INTERRUPT_ASSERTED_M;
+            return val;
+    return 0;
+static void kvaser_pci_s5920_io_write(void *opaque, hwaddr addr, uint64_t data,
+                             unsigned size)
+    switch (addr) {
+            if (~d->s5920_intcsr & data & S5920_INTCSR_ADDON_INTENABLE_M)
+            d->s5920_intcsr = data;
+            break;
+static uint64_t kvaser_pci_sja_io_read(void *opaque, hwaddr addr, unsigned size)
+    if (addr >= KVASER_PCI_BYTES_PER_SJA)
+        return 0;
+    return can_sja_mem_read(s, addr, size);
+static void kvaser_pci_sja_io_write(void *opaque, hwaddr addr, uint64_t data,
+                             unsigned size)
+        return;
+    can_sja_mem_write(s, addr, data, size);
+static uint64_t kvaser_pci_xilinx_io_read(void *opaque, hwaddr addr, unsigned size)
+    /*KvaserPCIState *d = opaque;*/
+    switch (addr) {
+        case KVASER_PCI_XILINX_VERINT:
+           return (13 << 4) | 0;
+    return 0;
+static void kvaser_pci_xilinx_io_write(void *opaque, hwaddr addr, uint64_t data,
+                             unsigned size)
+static const MemoryRegionOps kvaser_pci_s5920_io_ops = {
+    .read = kvaser_pci_s5920_io_read,
+    .write = kvaser_pci_s5920_io_write,
+    .endianness = DEVICE_LITTLE_ENDIAN,
+    .impl = {
+        .min_access_size = 4,
+        .max_access_size = 4,
+static const MemoryRegionOps kvaser_pci_sja_io_ops = {
+    .read = kvaser_pci_sja_io_read,
+    .write = kvaser_pci_sja_io_write,
+    .impl = {
+        .min_access_size = 1,
+        .max_access_size = 1,
+static const MemoryRegionOps kvaser_pci_xilinx_io_ops = {
+    .read = kvaser_pci_xilinx_io_read,
+    .write = kvaser_pci_xilinx_io_write,
+    .impl = {
+static int kvaser_pci_init(PCIDevice *pci_dev)
+    KvaserPCIState *d = KVASER_PCI_DEV(pci_dev);
+    uint8_t *pci_conf;
+    CanBusState *can_bus;
+    if (d->model) {
+        if (strncmp(d->model, "pcican-s", 256)) { /* for security reason */
+            qerror_report(ERROR_CLASS_GENERIC_ERROR,
+                  "Can't create CAN device, the model %s is not supported now.\n", d->model);
+            exit(1);
+    can_bus = can_bus_find_by_name(d->canbus, true);
+    if (can_bus == NULL) {
+        qerror_report(ERROR_CLASS_GENERIC_ERROR, "Cannot create can find/allocate CAN bus\n");
+        exit(1);
+    if (d->host != NULL) {
+        if (can_bus_connect_to_host_device(can_bus, d->host) < 0) {
+            qerror_report(ERROR_CLASS_GENERIC_ERROR, "Cannot connect CAN bus to host device \"%s\"\n", d->host);
+            exit(1);
+    pci_conf = pci_dev->config;
+    pci_conf[PCI_INTERRUPT_PIN] = 0x01; /* interrupt pin A */
+    d->irq = pci_allocate_irq(&d->dev);
+    can_sja_init(s, kvaser_pci_irq_raise, kvaser_pci_irq_lower, d);
+    qemu_register_reset(kvaser_pci_reset, d);
+    if (can_sja_connect_to_bus(s, can_bus) < 0) {
+              "can_sja_connect_to_bus failed\n");
+        exit(1);
+    memory_region_init_io(&d->s5920_io, OBJECT(d), &kvaser_pci_s5920_io_ops, d,
+                          "kvaser_pci-s5920", KVASER_PCI_S5920_RANGE);
+    memory_region_init_io(&d->sja_io, OBJECT(d), &kvaser_pci_sja_io_ops, d,
+                          "kvaser_pci-sja", KVASER_PCI_SJA_RANGE);
+    memory_region_init_io(&d->xilinx_io, OBJECT(d), &kvaser_pci_xilinx_io_ops, d,
+                          "kvaser_pci-xilinx", KVASER_PCI_XILINX_RANGE);
+    pci_register_bar(&d->dev, /*BAR*/ 0, PCI_BASE_ADDRESS_SPACE_IO, &d->s5920_io);
+    pci_register_bar(&d->dev, /*BAR*/ 1, PCI_BASE_ADDRESS_SPACE_IO, &d->sja_io);
+    pci_register_bar(&d->dev, /*BAR*/ 2, PCI_BASE_ADDRESS_SPACE_IO, &d->xilinx_io);
+    return 0;
+static void kvaser_pci_exit(PCIDevice *pci_dev)
+    can_sja_disconnect(s);
+    qemu_unregister_reset(kvaser_pci_reset, d);
+    memory_region_destroy(&d->s5920_io);
+    memory_region_destroy(&d->sja_io);
+    memory_region_destroy(&d->xilinx_io);
+    can_sja_exit(s);
+    qemu_free_irq(d->irq);
+static const VMStateDescription vmstate_kvaser_pci = {
+    .name = "kvaser_pci",
+    .version_id = 1,
+    .minimum_version_id = 1,
+    .minimum_version_id_old = 1,
+    .fields = (VMStateField[]) {
+        VMSTATE_PCI_DEVICE(dev, KvaserPCIState),
+        VMSTATE_STRUCT(sja_state, KvaserPCIState, 0, vmstate_can_sja, CanSJA1000State),
+        /*char *model,*/
+        VMSTATE_UINT32(s5920_intcsr, KvaserPCIState),
+        VMSTATE_UINT32(s5920_irqstate, KvaserPCIState),
+        VMSTATE_END_OF_LIST()
+static void qdev_kvaser_pci_reset(DeviceState *dev)
+    KvaserPCIState *d = KVASER_PCI_DEV(dev);
+    kvaser_pci_reset(d);
+static Property kvaser_pci_properties[] = {
+    DEFINE_PROP_STRING("canbus",   KvaserPCIState, canbus),
+    DEFINE_PROP_STRING("host",  KvaserPCIState, host),
+    DEFINE_PROP_STRING("model", KvaserPCIState, model),
+    DEFINE_PROP_END_OF_LIST(),
+static void kvaser_pci_class_init(ObjectClass *klass, void *data)
+    DeviceClass *dc = DEVICE_CLASS(klass);
+    PCIDeviceClass *k = PCI_DEVICE_CLASS(klass);
+    k->init = kvaser_pci_init;
+    k->exit = kvaser_pci_exit;
+    k->vendor_id = KVASER_PCI_VENDOR_ID1;
+    k->device_id = KVASER_PCI_DEVICE_ID1;
+    k->revision = 0x00;
+    k->class_id = 0x00ff00;
+    dc->desc = "Kvaser PCICANx";
+    dc->props = kvaser_pci_properties;
+    dc->vmsd = &vmstate_kvaser_pci;
+    set_bit(DEVICE_CATEGORY_MISC, dc->categories);
+    dc->reset = qdev_kvaser_pci_reset;
+static const TypeInfo kvaser_pci_info = {
+    .name          = TYPE_CAN_PCI_DEV,
+    .parent        = TYPE_PCI_DEVICE,
+    .instance_size = sizeof(KvaserPCIState),
+    .class_init    = kvaser_pci_class_init,
+static void kvaser_pci_register_types(void)
+    type_register_static(&kvaser_pci_info);
+type_init(kvaser_pci_register_types)
1.9.1
