[PATCH] doc: rtems-tester.txt: Add information for building tests
Kumar Amit Mehta
gmate.amit at gmail.com
Sun May 11 23:43:59 UTC 2014
The test executables will not be generated unless they are built
explicitly by invoking 'make'.
doc/rtems-tester.txt | 1 +
1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/doc/rtems-tester.txt b/doc/rtems-tester.txt
index ea567d2..58e4c2c 100644
--- a/doc/rtems-tester.txt
+++ b/doc/rtems-tester.txt
@@ -136,6 +136,7 @@ $ cd ..
$ mkdir sis
$ ../rtems.git/configure --target=sparc-rtems4.11 \
--enable-tests --enable-rtemsbsp=sis
+$ make
It will build all the tests. There are currently 471 separate tests and you can
1.7.1
