rtems/src/scheduler* code convention issue
Tue May 13 06:16:39 UTC 2014
On 2014-05-13 01:28, Joel Sherrill wrote:
> Hi
> Both schedulerident.c and schedulergetprocessorset.c do not follow
> RTEMS Coding Conventions on avoidance of deep nesting by using
> early returns.
I don't find such a rule here:
http://www.rtems.org/wiki/index.php/Coding_Conventions
> The nesting on schedulergetprocessorset.c is pretty
> ugly and could have been avoided easily.
I prefer a single exit point.  This is also advised by MISRA Rule 15.5.  It is
required by ISO 61508 and ISO 26262.  It is also "will" rule (AV Rule 113) of
the "JOINT STRIKE FIGHTER AIR VEHICLE C++ CODING STANDARDS FOR THE SYSTEM
DEVELOPMENT AND DEMONSTRATION PROGRAM".
http://www.stroustrup.com/JSF-AV-rules.pdf
So if you ask me, then we should also add this to the our coding conventions.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
