[GSOC] RPi BSP RTEMS
Andre Marques
andre.lousa.marques at gmail.com
Tue May 13 19:48:55 UTC 2014
On 05/09/14 03:24, Alan Cudmore wrote:
> I have not had much time to figure out why GDB is not working with the
> Pi/openOCD setup yet.
> But I started documenting my setup. The hardware details are here:
> http://alanstechnotes.blogspot.com/2014/05/a-low-cost-jtag-debugger-for-raspberry.html
> Next I will document how to compile openOCD and use it to load RTEMS
> images to the Pi.
> Alan
Hello Alan,
sorry for the delay, last week I had some work at the university and the
emmc driver i'm doing for my final project is having some problems. I'm
still trying to get myself the needed hardware for the debugger.
About the needed peripherals, I thought of this display to test the i2c
and spi interfaces:
http://www.newhavendisplay.com/nhd0216k3zflgbwv3-p-5738.html
What do you think?
> On Fri, May 2, 2014 at 6:48 PM, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 3/05/2014 3:07 am, Alan Cudmore wrote:
> Chris,
> I can use OpenOCD to load, run, break, resume, etc, but I am
> not having
> luck with GDB yet.
> Excellent.
> I can connect to the OpenOCD remote target server, send monitor
> commands, but I cannot load code through GDB or control the
> target.
> When I try loading through GDB, I end up with load failure
> messages.
> Any hints in configuring OpenOCD or GDB?
> Send me an OpenOCD and GDB session trace.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140513/9ef068fd/attachment.html>
