[GSOC] RPi BSP RTEMS
Alan Cudmore
alan.cudmore at gmail.com
Tue May 13 20:38:12 UTC 2014
On 5/13/2014 3:48 PM, Andre Marques wrote:
> On 05/09/14 03:24, Alan Cudmore wrote:
>> I have not had much time to figure out why GDB is not working with
>> the Pi/openOCD setup yet.
>> But I started documenting my setup. The hardware details are here:
>> http://alanstechnotes.blogspot.com/2014/05/a-low-cost-jtag-debugger-for-raspberry.html
>> Next I will document how to compile openOCD and use it to load RTEMS
>> images to the Pi.
>> Alan
> Hello Alan,
> sorry for the delay, last week I had some work at the university and
> the emmc driver i'm doing for my final project is having some
> problems. I'm still trying to get myself the needed hardware for the
> debugger.
> About the needed peripherals, I thought of this display to test the
> i2c and spi interfaces:
> http://www.newhavendisplay.com/nhd0216k3zflgbwv3-p-5738.html
> What do you think?
That should work. The jumpers look like they may need to be soldered to
select SPI, I2C, or UART.
I have a few other I2C devices, I will have to pick up at least one SPI
device.
A couple of other examples:
http://www.adafruit.com/product/1231
http://www.adafruit.com/products/1602
http://www.adafruit.com/products/1564
Alan
>> On Fri, May 2, 2014 at 6:48 PM, Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>> On 3/05/2014 3:07 am, Alan Cudmore wrote:
>> Chris,
>> I can use OpenOCD to load, run, break, resume, etc, but I am
>> not having
>> luck with GDB yet.
>> Excellent.
>> I can connect to the OpenOCD remote target server, send monitor
>> commands, but I cannot load code through GDB or control the
>> target.
>> When I try loading through GDB, I end up with load failure
>> messages.
>> Any hints in configuring OpenOCD or GDB?
>> Send me an OpenOCD and GDB session trace.
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140513/b88e7cd3/attachment.html>
