[PATCH 1/2] bsps/sparc: Fix data copy in start procedure
Sebastian Huber
Wed May 14 08:57:02 UTC 2014
Use the register %g4 for the data content since it must be an even
numbered register due to the std/ldd. Use the register %g2 for the BSS
start address, so that it can be later re-used for the BSS zero loop.
c/src/lib/libbsp/sparc/shared/start/start.S | 18 +++++++++---------
1 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/start/start.S b/c/src/lib/libbsp/sparc/shared/start/start.S
index 26da7b4..a1b3ff0 100644
--- a/c/src/lib/libbsp/sparc/shared/start/start.S
+++ b/c/src/lib/libbsp/sparc/shared/start/start.S
@@ -319,25 +319,25 @@ cpu0:
* LENGTH: (__bss_start - _data_start) bytes
- sethi %hi(_endtext),%g2
- or %g2,%lo(_endtext),%g2 ! g2 = start of initialized data in ROM
+ sethi %hi(_endtext),%g1
+ or %g1,%lo(_endtext),%g1 ! g1 = start of initialized data in ROM
sethi %hi(_data_start),%g3
or %g3,%lo(_data_start),%g3 ! g3 = start of initialized data in RAM
- sethi %hi(__bss_start),%g4
- or %g4,%lo(__bss_start),%g4 ! g4 = end of initialized data in RAM
+ sethi %hi(__bss_start), %g2
+ or %g2,%lo(__bss_start),%g2 ! g2 = end of initialized data in RAM
- cmp %g2, %g3
+ cmp %g1, %g3
be 1f
nop
copy_data:
- ldd [ %g2 ], %g5
- std %g5 , [ %g3 ] ! copy this double word
+ ldd [%g1], %g4
+ std %g4 , [%g3] ! copy this double word
add %g3, 8, %g3 ! bump the destination pointer
- add %g2, 8, %g2 ! bump the source pointer
- cmp %g3, %g4 ! Is the pointer past the end of dest?
+ add %g1, 8, %g1 ! bump the source pointer
+ cmp %g3, %g2 ! Is the pointer past the end of dest?
bl copy_data
nop
1.7.7
