[PATCH 1/2] bsps/sparc: Fix data copy in start procedure
Daniel Hellstrom daniel at gaisler.com
Wed May 14 12:37:11 UTC 2014
Both patches in this series looks good. Thanks!
Haven't tested it though. Please merge it since we will temporary branch from mainline the coming days for the SMP project.
DanielH
On 05/14/2014 10:57 AM, Sebastian Huber wrote:
> Use the register %g4 for the data content since it must be an even
> numbered register due to the std/ldd.  Use the register %g2 for the BSS
> start address, so that it can be later re-used for the BSS zero loop.
>   c/src/lib/libbsp/sparc/shared/start/start.S |   18 +++++++++---------
>   1 files changed, 9 insertions(+), 9 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/shared/start/start.S b/c/src/lib/libbsp/sparc/shared/start/start.S
> index 26da7b4..a1b3ff0 100644
> --- a/c/src/lib/libbsp/sparc/shared/start/start.S
> +++ b/c/src/lib/libbsp/sparc/shared/start/start.S
> @@ -319,25 +319,25 @@ cpu0:
>            *  LENGTH: (__bss_start - _data_start) bytes
> -        sethi %hi(_endtext),%g2
> -        or    %g2,%lo(_endtext),%g2     ! g2 = start of initialized data in ROM
> +        sethi %hi(_endtext),%g1
> +        or    %g1,%lo(_endtext),%g1     ! g1 = start of initialized data in ROM
>           sethi %hi(_data_start),%g3
>           or    %g3,%lo(_data_start),%g3  ! g3 = start of initialized data in RAM
> -        sethi %hi(__bss_start),%g4
> -        or    %g4,%lo(__bss_start),%g4  ! g4 = end of initialized data in RAM
> +        sethi %hi(__bss_start), %g2
> +        or    %g2,%lo(__bss_start),%g2  ! g2 = end of initialized data in RAM
> -	cmp   %g2, %g3
> +	cmp   %g1, %g3
>   	be    1f
>   	nop
>   copy_data:
> -        ldd   [ %g2 ], %g5
> -        std   %g5 , [ %g3 ]             ! copy this double word
> +        ldd   [%g1], %g4
> +        std   %g4 , [%g3]               ! copy this double word
>           add   %g3, 8, %g3               ! bump the destination pointer
> -        add   %g2, 8, %g2               ! bump the source pointer
> -        cmp   %g3, %g4                  ! Is the pointer past the end of dest?
> +        add   %g1, 8, %g1               ! bump the source pointer
> +        cmp   %g3, %g2                  ! Is the pointer past the end of dest?
>           bl    copy_data
>           nop
