[PATCH] score: Simplify _Thread_Change_priority()
Wed May 14 15:32:59 UTC 2014
The function to change a thread priority was too complex.  Simplify it
with a new scheduler operation.  This increases the average case
performance due to the simplified logic.  The interrupt disabled
critical section is a bit prolonged since now the extract, update and
enqueue steps are executed atomically.  This should however not impact
the worst-case interrupt latency since at least for the Deterministic
Priority Scheduler this sequence can be carried out with a wee bit of
instructions and no loops.
Add _Scheduler_Change_priority() to replace
  - _Thread_Set_transient(),
  - _Scheduler_Extract(),
  - _Scheduler_Enqueue(), and
  - _Scheduler_Enqueue_first().
Delete STATES_TRANSIENT, _States_Is_transient() and
_Thread_Set_transient() since this state is now superfluous.
With this change it is possible to get rid of the
SCHEDULER_SMP_NODE_IN_THE_AIR state.  This considerably simplifies the
implementation of the new SMP locking protocols.
 cpukit/libmisc/capture/capture.c                   |    3 +-
 cpukit/libmisc/monitor/mon-prmisc.c                |    1 -
 cpukit/posix/src/pthreadexit.c                     |    5 +-
 cpukit/posix/src/pthreadjoin.c                     |    8 +-
 cpukit/score/Makefile.am                           |   16 +--
 cpukit/score/include/rtems/score/scheduler.h       |   17 +-
 cpukit/score/include/rtems/score/schedulercbs.h    |    4 +-
 cpukit/score/include/rtems/score/scheduleredf.h    |   50 +-----
 .../score/include/rtems/score/scheduleredfimpl.h   |   25 +++
 cpukit/score/include/rtems/score/schedulerimpl.h   |   70 +++-----
 .../score/include/rtems/score/schedulerpriority.h  |   54 +-----
 .../rtems/score/schedulerpriorityaffinitysmp.h     |    6 +-
 .../include/rtems/score/schedulerpriorityimpl.h    |   13 +-
 .../include/rtems/score/schedulerprioritysmp.h     |   23 +--
 cpukit/score/include/rtems/score/schedulersimple.h |   71 +-------
 .../include/rtems/score/schedulersimpleimpl.h      |   28 +--
 .../score/include/rtems/score/schedulersimplesmp.h |   19 +--
 cpukit/score/include/rtems/score/schedulersmp.h    |   17 +--
 .../score/include/rtems/score/schedulersmpimpl.h   |  184 ++++++++------------
 cpukit/score/include/rtems/score/statesimpl.h      |   17 --
 cpukit/score/src/schedulercbsunblock.c             |    1 +
 cpukit/score/src/scheduleredfchangepriority.c      |   36 ++++
 cpukit/score/src/scheduleredfenqueue.c             |   34 ----
 cpukit/score/src/scheduleredfenqueuefirst.c        |   32 ----
 cpukit/score/src/scheduleredfextract.c             |   34 ----
 cpukit/score/src/scheduleredfunblock.c             |    2 +-
 cpukit/score/src/schedulerprioritychangepriority.c |   61 +++++++
 cpukit/score/src/schedulerpriorityenqueue.c        |   37 ----
 cpukit/score/src/schedulerpriorityenqueuefirst.c   |   38 ----
 cpukit/score/src/schedulerpriorityextract.c        |   30 ----
 cpukit/score/src/schedulerprioritysmp.c            |  133 ++++++++-------
 cpukit/score/src/schedulerpriorityupdate.c         |    2 +-
 cpukit/score/src/schedulersimplechangepriority.c   |   41 +++++
 cpukit/score/src/schedulersimpleenqueue.c          |   30 ----
 cpukit/score/src/schedulersimpleenqueuefirst.c     |   29 ---
 cpukit/score/src/schedulersimpleextract.c          |   32 ----
 .../score/src/schedulersimplereadyqueueenqueue.c   |   32 ----
 .../src/schedulersimplereadyqueueenqueuefirst.c    |   32 ----
 cpukit/score/src/schedulersimplesmp.c              |  105 ++++++-----
 cpukit/score/src/schedulersimpleunblock.c          |    5 +-
 cpukit/score/src/schedulersimpleyield.c            |    5 +-
 cpukit/score/src/schedulersmpvalidstatechanges.c   |   11 +-
 cpukit/score/src/threadchangepriority.c            |   89 +++-------
 cpukit/score/src/threadsettransient.c              |   44 -----
 testsuites/sptests/Makefile.am                     |    1 -
 testsuites/sptests/configure.ac                    |    1 -
 testsuites/sptests/spintrcritical19/Makefile.am    |   20 --
 testsuites/sptests/spintrcritical19/init.c         |  136 ---------------
 .../sptests/spintrcritical19/spintrcritical19.doc  |   13 --
 .../sptests/spintrcritical19/spintrcritical19.scn  |    4 -
 50 files changed, 511 insertions(+), 1190 deletions(-)
 create mode 100644 cpukit/score/src/scheduleredfchangepriority.c
 delete mode 100644 cpukit/score/src/scheduleredfenqueue.c
 delete mode 100644 cpukit/score/src/scheduleredfenqueuefirst.c
 delete mode 100644 cpukit/score/src/scheduleredfextract.c
 create mode 100644 cpukit/score/src/schedulerprioritychangepriority.c
 delete mode 100644 cpukit/score/src/schedulerpriorityenqueue.c
 delete mode 100644 cpukit/score/src/schedulerpriorityenqueuefirst.c
 delete mode 100644 cpukit/score/src/schedulerpriorityextract.c
 create mode 100644 cpukit/score/src/schedulersimplechangepriority.c
 delete mode 100644 cpukit/score/src/schedulersimpleenqueue.c
 delete mode 100644 cpukit/score/src/schedulersimpleenqueuefirst.c
 delete mode 100644 cpukit/score/src/schedulersimpleextract.c
 delete mode 100644 cpukit/score/src/schedulersimplereadyqueueenqueue.c
 delete mode 100644 cpukit/score/src/schedulersimplereadyqueueenqueuefirst.c
 delete mode 100644 cpukit/score/src/threadsettransient.c
 delete mode 100644 testsuites/sptests/spintrcritical19/Makefile.am
 delete mode 100644 testsuites/sptests/spintrcritical19/init.c
 delete mode 100644 testsuites/sptests/spintrcritical19/spintrcritical19.doc
 delete mode 100644 testsuites/sptests/spintrcritical19/spintrcritical19.scn
diff --git a/cpukit/libmisc/capture/capture.c b/cpukit/libmisc/capture/capture.c
index da9d785..118e4ff 100644
--- a/cpukit/libmisc/capture/capture.c
+++ b/cpukit/libmisc/capture/capture.c
@@ -913,8 +913,7 @@ rtems_capture_switch_task (rtems_tcb* current_task,
     rtems_capture_task_t* ht;
-    if (_States_Is_transient (current_task->current_state)
-     || _States_Is_dormant (current_task->current_state))
+    if (_States_Is_dormant (current_task->current_state))
       rtems_id ct_id = current_task->Object.id;
diff --git a/cpukit/libmisc/monitor/mon-prmisc.c b/cpukit/libmisc/monitor/mon-prmisc.c
index 9126767..b22ae55 100644
--- a/cpukit/libmisc/monitor/mon-prmisc.c
+++ b/cpukit/libmisc/monitor/mon-prmisc.c
@@ -116,7 +116,6 @@ rtems_monitor_dump_priority(rtems_task_priority priority)
 static const rtems_assoc_t rtems_monitor_state_assoc[] = {
     { "DORM",   STATES_DORMANT, 0 },
     { "SUSP",   STATES_SUSPENDED, 0 },
-    { "TRANS",  STATES_TRANSIENT, 0 },
     { "DELAY",  STATES_DELAYING, 0 },
     { "Wtime",  STATES_WAITING_FOR_TIME, 0 },
     { "Wbuf",   STATES_WAITING_FOR_BUFFER, 0 },
diff --git a/cpukit/posix/src/pthreadexit.c b/cpukit/posix/src/pthreadexit.c
index 40cd160..6b3a09a 100644
--- a/cpukit/posix/src/pthreadexit.c
+++ b/cpukit/posix/src/pthreadexit.c
@@ -54,10 +54,7 @@ void _POSIX_Thread_Exit(
         *(void **)unblocked->Wait.return_argument = value_ptr;
       } while ( (unblocked = _Thread_queue_Dequeue( &api->Join_List )) );
     } else {
-      _Thread_Set_state(
-        the_thread,
-        STATES_WAITING_FOR_JOIN_AT_EXIT | STATES_TRANSIENT
+      _Thread_Set_state( the_thread, STATES_WAITING_FOR_JOIN_AT_EXIT );
       _Thread_Enable_dispatch();
       /* now waiting for thread to arrive */
       _Thread_Disable_dispatch();
diff --git a/cpukit/posix/src/pthreadjoin.c b/cpukit/posix/src/pthreadjoin.c
index 5033c37..136eea6 100644
--- a/cpukit/posix/src/pthreadjoin.c
+++ b/cpukit/posix/src/pthreadjoin.c
@@ -61,13 +61,9 @@ on_EINTR:
        *  Put ourself on the threads join list
-      if ( the_thread->current_state ==
-             (STATES_WAITING_FOR_JOIN_AT_EXIT | STATES_TRANSIENT) ) {
+      if ( the_thread->current_state == STATES_WAITING_FOR_JOIN_AT_EXIT ) {
          return_pointer = the_thread->Wait.return_argument;
-         _Thread_Clear_state(
-           the_thread,
+         _Thread_Clear_state( the_thread, STATES_WAITING_FOR_JOIN_AT_EXIT );
       } else {
         executing->Wait.return_argument = &return_pointer;
         _Thread_queue_Enter_critical_section( &api->Join_List );
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 8fb11d7..ed68ee0 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -208,9 +208,7 @@ libscore_a_SOURCES += src/schedulerdefaultupdate.c
 ## SCHEDULERPRIORITY_C_FILES
 libscore_a_SOURCES += src/schedulerpriority.c \
     src/schedulerpriorityblock.c \
-    src/schedulerpriorityenqueue.c \
-    src/schedulerpriorityenqueuefirst.c \
-    src/schedulerpriorityextract.c \
+    src/schedulerprioritychangepriority.c \
     src/schedulerpriorityprioritycompare.c \
     src/schedulerpriorityschedule.c \
     src/schedulerpriorityunblock.c \
@@ -220,11 +218,7 @@ libscore_a_SOURCES += src/schedulerpriority.c \
 ## SCHEDULERSIMPLE_C_FILES
 libscore_a_SOURCES += src/schedulersimple.c \
     src/schedulersimpleblock.c \
-    src/schedulersimpleenqueue.c \
-    src/schedulersimpleenqueuefirst.c \
-    src/schedulersimpleextract.c \
-    src/schedulersimplereadyqueueenqueue.c \
-    src/schedulersimplereadyqueueenqueuefirst.c \
+    src/schedulersimplechangepriority.c \
     src/schedulersimpleschedule.c \
     src/schedulersimpleunblock.c \
@@ -233,9 +227,7 @@ libscore_a_SOURCES += src/schedulersimple.c \
 libscore_a_SOURCES += src/scheduleredf.c \
     src/scheduleredfallocate.c \
     src/scheduleredfblock.c \
-    src/scheduleredfenqueue.c \
-    src/scheduleredfenqueuefirst.c \
-    src/scheduleredfextract.c \
+    src/scheduleredfchangepriority.c \
     src/scheduleredfprioritycompare.c \
     src/scheduleredfreleasejob.c \
     src/scheduleredfschedule.c \
@@ -282,7 +274,7 @@ libscore_a_SOURCES += src/thread.c src/threadchangepriority.c \
     src/threadget.c src/threadhandler.c src/threadinitialize.c \
     src/threadloadenv.c src/threadready.c \
     src/threadrestart.c src/threadsetpriority.c \
-    src/threadsetstate.c src/threadsettransient.c \
+    src/threadsetstate.c \
     src/threadstackallocate.c src/threadstackfree.c src/threadstart.c \
     src/threadstartmultitasking.c src/iterateoverthreads.c \
     src/threadblockingoperationcancel.c
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index 7f0b43a..b1e8f8a 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -63,6 +63,14 @@ typedef struct {
   /** @see _Scheduler_Unblock() */
   void ( *unblock )( const Scheduler_Control *, Thread_Control * );
+  /** @see _Scheduler_Change_priority() */
+  void ( *change_priority )(
+    const Scheduler_Control *,
+    Thread_Control *,
+    Priority_Control,
+    bool
   /** @see _Scheduler_Allocate() */
   bool ( *allocate )( const Scheduler_Control *, Thread_Control * );
@@ -72,15 +80,6 @@ typedef struct {
   /** @see _Scheduler_Update() */
   void ( *update )( const Scheduler_Control *, Thread_Control * );
-  /** @see _Scheduler_Enqueue() */
-  void ( *enqueue )( const Scheduler_Control *, Thread_Control * );
-  /** @see _Scheduler_Enqueue_first() */
-  void ( *enqueue_first )( const Scheduler_Control *, Thread_Control * );
-  /** @see _Scheduler_Extract() */
-  void ( *extract )( const Scheduler_Control *, Thread_Control * );
   /** @see _Scheduler_Priority_compare() */
   int ( *priority_compare )(
     Priority_Control,
diff --git a/cpukit/score/include/rtems/score/schedulercbs.h b/cpukit/score/include/rtems/score/schedulercbs.h
index 6cfdfbe..46db8e5 100644
--- a/cpukit/score/include/rtems/score/schedulercbs.h
+++ b/cpukit/score/include/rtems/score/schedulercbs.h
@@ -52,12 +52,10 @@ extern "C" {
     _Scheduler_EDF_Yield,            /* yield entry point */ \
     _Scheduler_EDF_Block,            /* block entry point */ \
     _Scheduler_CBS_Unblock,          /* unblock entry point */ \
+    _Scheduler_EDF_Change_priority,  /* change priority entry point */ \
     _Scheduler_CBS_Allocate,         /* allocate entry point */ \
     _Scheduler_default_Free,         /* free entry point */ \
     _Scheduler_EDF_Update,           /* update entry point */ \
-    _Scheduler_EDF_Enqueue,          /* enqueue entry point */ \
-    _Scheduler_EDF_Enqueue_first,    /* enqueue_first entry point */ \
-    _Scheduler_EDF_Extract,          /* extract entry point */ \
     _Scheduler_EDF_Priority_compare, /* compares two priorities */ \
     _Scheduler_CBS_Release_job,      /* new period of task */ \
     _Scheduler_default_Tick,         /* tick entry point */ \
diff --git a/cpukit/score/include/rtems/score/scheduleredf.h b/cpukit/score/include/rtems/score/scheduleredf.h
index 95be94c..301940c 100644
--- a/cpukit/score/include/rtems/score/scheduleredf.h
+++ b/cpukit/score/include/rtems/score/scheduleredf.h
@@ -45,12 +45,10 @@ extern "C" {
     _Scheduler_EDF_Unblock,          /* unblock entry point */ \
     _Scheduler_EDF_Allocate,         /* allocate entry point */ \
     _Scheduler_EDF_Release_job,      /* new period of task */ \
@@ -187,6 +185,13 @@ void _Scheduler_EDF_Unblock(
   Thread_Control          *the_thread
+void _Scheduler_EDF_Change_priority(
+  const Scheduler_Control *scheduler,
+  Thread_Control          *the_thread,
+  Priority_Control         new_priority,
+  bool                     prepend_it
  *  @brief invoked when a thread wishes to voluntarily
  *  transfer control of the processor to another thread
@@ -208,45 +213,6 @@ void _Scheduler_EDF_Yield(
- *  @brief Put @a the_thread to the rbtree ready queue.
- *  This routine puts @a the_thread to the rbtree ready queue.
- *  @param[in] the_thread will be enqueued to the ready queue.
-void _Scheduler_EDF_Enqueue(
-  const Scheduler_Control *scheduler,
-  Thread_Control          *the_thread
- *  @brief Enqueue a thread to the ready queue.
- *  For the EDF scheduler this is the same as @a _Scheduler_EDF_Enqueue.
-void _Scheduler_EDF_Enqueue_first(
- *  @brief Remove a specific thread from the scheduler's set
- *  of ready threads.
- *  This routine removes a specific thread from the scheduler's set
- *  @param[in] the_thread will be extracted from the ready set.
-void _Scheduler_EDF_Extract(
  *  @brief Explicitly compare absolute dedlines (priorities) of threads.
  * This routine explicitly compares absolute dedlines (priorities) of threads.
diff --git a/cpukit/score/include/rtems/score/scheduleredfimpl.h b/cpukit/score/include/rtems/score/scheduleredfimpl.h
index 8c4cd2c..d424370 100644
--- a/cpukit/score/include/rtems/score/scheduleredfimpl.h
+++ b/cpukit/score/include/rtems/score/scheduleredfimpl.h
@@ -44,6 +44,31 @@ RTEMS_INLINE_ROUTINE Scheduler_EDF_Node *_Scheduler_EDF_Node_get(
   return (Scheduler_EDF_Node *) _Scheduler_Node_get( the_thread );
+RTEMS_INLINE_ROUTINE void _Scheduler_EDF_Enqueue(
+  Scheduler_EDF_Context *context =
+    _Scheduler_EDF_Get_context( scheduler );
+  Scheduler_EDF_Node *node = _Scheduler_EDF_Node_get( the_thread );
+  _RBTree_Insert( &context->Ready, &node->Node );
+  node->queue_state = SCHEDULER_EDF_QUEUE_STATE_YES;
+RTEMS_INLINE_ROUTINE void _Scheduler_EDF_Extract(
+  _RBTree_Extract( &context->Ready, &node->Node );
 RTEMS_INLINE_ROUTINE void _Scheduler_EDF_Schedule_body(
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index 2129493..f37a355 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -144,6 +144,35 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Unblock(
+ * @brief Propagates a priority change of a thread to the scheduler.
+ * The caller must ensure that the thread is in the ready state.  The caller
+ * must ensure that the priority value actually changed and is not equal to the
+ * current priority value.
+ * @param[in] scheduler The scheduler instance.
+ * @param[in] the_thread The thread changing its priority.
+ * @param[in] new_priority The new thread priority.
+ * @param[in] prepend_it In case this is true, then enqueue the thread as the
+ * first of its priority group, otherwise enqueue the thread as the last of its
+ * priority group.
+RTEMS_INLINE_ROUTINE void _Scheduler_Change_priority(
+  bool                     prepend_it
+  ( *scheduler->Operations.change_priority )(
+    scheduler,
+    the_thread,
+    new_priority,
+    prepend_it
  * @brief Scheduler allocate.
  * This routine allocates @a the_thread->scheduler
@@ -183,47 +212,6 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Update(
- * @brief Enqueues a thread as the last of its priority group.
- * @param[in] scheduler The scheduler instance.
- * @param[in] the_thread The thread to enqueue.
-RTEMS_INLINE_ROUTINE void _Scheduler_Enqueue(
-  ( *scheduler->Operations.enqueue )( scheduler, the_thread );
- * @brief Enqueues a thread as the first of its priority group.
-RTEMS_INLINE_ROUTINE void _Scheduler_Enqueue_first(
-  ( *scheduler->Operations.enqueue_first )( scheduler, the_thread );
- * @brief Scheduler extract.
- * This routine extract @a the_thread->scheduler
-RTEMS_INLINE_ROUTINE void _Scheduler_Extract(
-  ( *scheduler->Operations.extract )( scheduler, the_thread );
  * @brief Compares two priority values.
diff --git a/cpukit/score/include/rtems/score/schedulerpriority.h b/cpukit/score/include/rtems/score/schedulerpriority.h
index 134dcd7..b3c1466 100644
--- a/cpukit/score/include/rtems/score/schedulerpriority.h
+++ b/cpukit/score/include/rtems/score/schedulerpriority.h
     _Scheduler_priority_Yield,            /* yield entry point */ \
     _Scheduler_priority_Block,            /* block entry point */ \
     _Scheduler_priority_Unblock,          /* unblock entry point */ \
-    _Scheduler_default_Allocate,         /* allocate entry point */ \
-    _Scheduler_default_Free,             /* free entry point */ \
+    _Scheduler_priority_Change_priority,  /* change priority entry point */ \
+    _Scheduler_default_Allocate,          /* allocate entry point */ \
+    _Scheduler_default_Free,              /* free entry point */ \
     _Scheduler_priority_Update,           /* update entry point */ \
-    _Scheduler_priority_Enqueue,          /* enqueue entry point */ \
-    _Scheduler_priority_Enqueue_first,    /* enqueue_first entry point */ \
-    _Scheduler_priority_Extract,          /* extract entry point */ \
     _Scheduler_priority_Priority_compare, /* compares two priorities */ \
     _Scheduler_default_Release_job,       /* new period of task */ \
@@ -167,6 +165,13 @@ void _Scheduler_priority_Unblock(
+void _Scheduler_priority_Change_priority(
+  bool                     prepend_it
  *  @brief The specified THREAD yields.
@@ -192,45 +197,6 @@ void _Scheduler_priority_Yield(
- *  @brief Puts @a the_thread on to the priority-based ready queue.
- *  This routine puts @a the_thread on to the priority-based ready queue.
- *  @param[in] the_thread will be enqueued at the TAIL of its priority.
-void _Scheduler_priority_Enqueue(
- *  @brief Puts @a the_thread to the head of the ready queue.
- *  This routine puts @a the_thread to the head of the ready queue.
- *  For priority-based ready queues, the thread will be the first thread
- *  at its priority level.
- *  @param[in] the_thread will be enqueued at the HEAD of its priority.
-void _Scheduler_priority_Enqueue_first(
- *  @brief Remove a specific thread from scheduler.
-void _Scheduler_priority_Extract(
  *  @brief Compare two priorities.
  *  This routine compares two priorities.
diff --git a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
index e86fd35..c21d066 100644
--- a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
@@ -53,13 +53,11 @@ extern "C" {
     _Scheduler_priority_SMP_Schedule, \
     _Scheduler_priority_SMP_Yield, \
     _Scheduler_priority_SMP_Block, \
-    _Scheduler_priority_SMP_Enqueue_fifo, \
+    _Scheduler_priority_SMP_Unblock, \
+    _Scheduler_priority_SMP_Change_priority, \
     _Scheduler_priority_affinity_SMP_Allocate, \
     _Scheduler_default_Free, \
     _Scheduler_priority_SMP_Update, \
-    _Scheduler_priority_SMP_Enqueue_lifo, \
-    _Scheduler_priority_SMP_Extract, \
     _Scheduler_priority_Priority_compare, \
     _Scheduler_default_Release_job, \
     _Scheduler_default_Tick, \
diff --git a/cpukit/score/include/rtems/score/schedulerpriorityimpl.h b/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
index ae0cd1a..95d8e6a 100644
--- a/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
@@ -196,28 +196,27 @@ RTEMS_INLINE_ROUTINE void _Scheduler_priority_Schedule_body(
- * @brief Updates the specified ready queue data according to the current
- * priority of the thread.
+ * @brief Updates the specified ready queue data according to the new priority
+ * value.
- * @param[in] the_thread The thread.
  * @param[in] ready_queue The ready queue.
+ * @param[in] new_priority The new priority.
  * @param[in] bit_map The priority bit map of the scheduler instance.
  * @param[in] ready_queues The ready queues of the scheduler instance.
 RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_update(
-  Thread_Control                 *the_thread,
   Scheduler_priority_Ready_queue *ready_queue,
   Priority_bit_map_Control       *bit_map,
   Chain_Control                  *ready_queues
-  Priority_Control priority = the_thread->current_priority;
-  ready_queue->ready_chain = &ready_queues[ priority ];
+  ready_queue->ready_chain = &ready_queues[ new_priority ];
   _Priority_bit_map_Initialize_information(
     bit_map,
     &ready_queue->Priority_map,
-    priority
+    new_priority
diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmp.h b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
index 3e7d22f..a22b323 100644
--- a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
@@ -7,7 +7,7 @@
- * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2013-2014 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -82,13 +82,11 @@ typedef struct {
     _Scheduler_priority_SMP_Allocate, \
@@ -114,22 +112,19 @@ void _Scheduler_priority_SMP_Block(
   Thread_Control *thread
-void _Scheduler_priority_SMP_Update(
+void _Scheduler_priority_SMP_Unblock(
-void _Scheduler_priority_SMP_Enqueue_fifo(
+void _Scheduler_priority_SMP_Change_priority(
-  Thread_Control *thread
+  bool                     prepend_it
-void _Scheduler_priority_SMP_Enqueue_lifo(
-void _Scheduler_priority_SMP_Extract(
+void _Scheduler_priority_SMP_Update(
diff --git a/cpukit/score/include/rtems/score/schedulersimple.h b/cpukit/score/include/rtems/score/schedulersimple.h
index 213bbb2..6b59a0a 100644
--- a/cpukit/score/include/rtems/score/schedulersimple.h
+++ b/cpukit/score/include/rtems/score/schedulersimple.h
@@ -42,12 +42,10 @@ extern "C" {
     _Scheduler_simple_Yield,              /* yield entry point */ \
     _Scheduler_simple_Block,              /* block entry point */ \
     _Scheduler_simple_Unblock,            /* unblock entry point */ \
+    _Scheduler_simple_Change_priority,    /* change priority entry point */ \
     _Scheduler_default_Update,            /* update entry point */ \
-    _Scheduler_simple_Enqueue,            /* enqueue entry point */ \
-    _Scheduler_simple_Enqueue_first,      /* enqueue_first entry point */ \
-    _Scheduler_simple_Extract,            /* extract entry point */ \
@@ -136,70 +134,11 @@ void _Scheduler_simple_Unblock(
- *  @brief Removes a simple-priority-based thread from a simple queue.
- *  This routine removes a specific thread from the specified
- *  simple-based ready queue.
- *  @param[in] the_thread is the thread to be blocked
-void _Scheduler_simple_Extract(
+void _Scheduler_simple_Change_priority(
- *  @brief Puts simple-priority-based thread onto the ready queue.
- *  This routine puts @a the_thread on to the ready queue.
- *  @param[in] the_thread is the thread to be enqueued
-void _Scheduler_simple_Enqueue(
- *  @brief Put simple-priority-based @a the_thread to
- *  the head of the ready queue.
- *  The thread will be the first thread at its priority level.
-void _Scheduler_simple_Enqueue_first(
- *  _Scheduler_simple_Ready_queue_enqueue
- *  This routine puts @a the_thread on the ready queue
- *  at the end of its priority group.
- *  @param[in] the_thread - pointer to a thread control block
-void _Scheduler_simple_Ready_queue_enqueue(
- *  @brief Puts simple-priority-based @a the_thread on to the ready queue
- *  at the beginning of its priority group.
-void _Scheduler_simple_Ready_queue_enqueue_first(
+  bool                     prepend_it
diff --git a/cpukit/score/include/rtems/score/schedulersimpleimpl.h b/cpukit/score/include/rtems/score/schedulersimpleimpl.h
index c256071..b73a1b2 100644
--- a/cpukit/score/include/rtems/score/schedulersimpleimpl.h
+++ b/cpukit/score/include/rtems/score/schedulersimpleimpl.h
@@ -38,24 +38,6 @@ RTEMS_INLINE_ROUTINE Scheduler_simple_Context *
   return (Scheduler_simple_Context *) _Scheduler_Get_context( scheduler );
- * @param[in] the_ready_queue is a pointer to the ready queue head
-RTEMS_INLINE_ROUTINE void _Scheduler_simple_Ready_queue_requeue(
-  /* extract */
-  _Chain_Extract_unprotected( &the_thread->Object.Node );
-  /* enqueue */
-  _Scheduler_simple_Ready_queue_enqueue( scheduler, the_thread );
 RTEMS_INLINE_ROUTINE bool _Scheduler_simple_Insert_priority_lifo_order(
   const Chain_Node *to_insert,
   const Chain_Node *next
@@ -102,6 +84,16 @@ RTEMS_INLINE_ROUTINE void _Scheduler_simple_Insert_priority_fifo(
+RTEMS_INLINE_ROUTINE void _Scheduler_simple_Extract(
+  (void) scheduler;
+  _Chain_Extract_unprotected( &the_thread->Object.Node );
 RTEMS_INLINE_ROUTINE void _Scheduler_simple_Schedule_body(
diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
index 1e71225..9da65ce 100644
--- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
@@ -63,13 +63,11 @@ typedef struct {
     _Scheduler_simple_SMP_Schedule, \
     _Scheduler_simple_SMP_Yield, \
     _Scheduler_simple_SMP_Block, \
-    _Scheduler_simple_SMP_Enqueue_priority_fifo, \
+    _Scheduler_simple_SMP_Unblock, \
     _Scheduler_simple_SMP_Allocate, \
+    _Scheduler_simple_SMP_Change_priority, \
     _Scheduler_default_Update, \
-    _Scheduler_simple_SMP_Enqueue_priority_lifo, \
-    _Scheduler_simple_SMP_Extract, \
@@ -90,19 +88,16 @@ void _Scheduler_simple_SMP_Block(
-void _Scheduler_simple_SMP_Enqueue_priority_fifo(
+void _Scheduler_simple_SMP_Unblock(
-void _Scheduler_simple_SMP_Enqueue_priority_lifo(
+void _Scheduler_simple_SMP_Change_priority(
-void _Scheduler_simple_SMP_Extract(
+  bool                     prepend_it
 void _Scheduler_simple_SMP_Yield(
diff --git a/cpukit/score/include/rtems/score/schedulersmp.h b/cpukit/score/include/rtems/score/schedulersmp.h
index ee1b087..1a7aa55 100644
--- a/cpukit/score/include/rtems/score/schedulersmp.h
+++ b/cpukit/score/include/rtems/score/schedulersmp.h
@@ -80,22 +80,7 @@ typedef enum {
    * A scheduler node is ready if the corresponding thread is ready and the
    * scheduler did not allocate a processor for it.
-  SCHEDULER_SMP_NODE_READY,
-   * @brief This scheduler node is in the air.
-   * A scheduled node is in the air if it has an allocated processor and the
-   * corresponding thread is in a transient state.  Such a node is not an
-   * element of the set of scheduled nodes.  The extract operation on a
-   * scheduled node will produce a scheduler node in the air (see also
-   * _Thread_Set_transient()).  The next enqueue or schedule operation will
-   * decide what to do based on this state indication.  It can either place the
-   * scheduler node back on the set of scheduled nodes and the thread can keep
-   * its allocated processor, or it can take the processor away from the thread
-   * and give the processor to another thread of higher priority.
-  SCHEDULER_SMP_NODE_IN_THE_AIR
+  SCHEDULER_SMP_NODE_READY
 } Scheduler_SMP_Node_state;
diff --git a/cpukit/score/include/rtems/score/schedulersmpimpl.h b/cpukit/score/include/rtems/score/schedulersmpimpl.h
index 161f742..9e931c4 100644
--- a/cpukit/score/include/rtems/score/schedulersmpimpl.h
+++ b/cpukit/score/include/rtems/score/schedulersmpimpl.h
@@ -37,14 +37,12 @@ extern "C" {
  * The scheduler nodes can be in four states
  * - @ref SCHEDULER_SMP_NODE_BLOCKED,
- * - @ref SCHEDULER_SMP_NODE_SCHEDULED,
- * - @ref SCHEDULER_SMP_NODE_READY, and
- * - @ref SCHEDULER_SMP_NODE_IN_THE_AIR.
+ * - @ref SCHEDULER_SMP_NODE_SCHEDULED, and
+ * - @ref SCHEDULER_SMP_NODE_READY.
- * State transitions are triggered via basic three operations
- * - _Scheduler_SMP_Enqueue_ordered(),
- * - _Scheduler_SMP_Extract(), and
- * - _Scheduler_SMP_Schedule().
+ * State transitions are triggered via basic operations
+ * - _Scheduler_SMP_Enqueue_ordered(), and
+ * - _Scheduler_SMP_Block().
  * @dot
  * digraph {
@@ -53,39 +51,26 @@ extern "C" {
  *   bs [label="BLOCKED"];
  *   ss [label="SCHEDULED", fillcolor="green"];
  *   rs [label="READY", fillcolor="red"];
- *   as [label="IN THE AIR", fillcolor="orange"];
  *   edge [label="enqueue"];
  *   edge [fontcolor="darkgreen", color="darkgreen"];
  *   bs -> ss;
- *   as -> ss;
- *   edge [label="enqueue"];
  *   edge [fontcolor="red", color="red"];
  *   bs -> rs;
- *   as -> rs;
  *   edge [label="enqueue other"];
  *   ss -> rs;
- *   edge [label="schedule"];
- *   edge [fontcolor="black", color="black"];
- *   as -> bs;
- *   edge [label="extract"];
- *   edge [fontcolor="brown", color="brown"];
- *   ss -> as;
+ *   edge [label="block"];
  *   rs -> bs;
- *   edge [label="enqueue other\nschedule other"];
+ *   edge [label="block other"];
  *   rs -> ss;
@@ -216,38 +201,7 @@ extern "C" {
  * @enddot
- * Lets do something with A.  This can be a blocking operation or a priority
- * change.  For this an extract operation is performed first.
- * @dot
- * digraph {
- *   node [style="filled"];
- *   edge [dir="none"];
- *   subgraph {
- *     rank = same;
- *     b [label="B (2)", fillcolor="green"];
- *     a [label="A (1)", fillcolor="orange"];
- *     c [label="C (3)", fillcolor="red"];
- *     i [label="I (5)", fillcolor="red"];
- *     j [label="J (5)", fillcolor="red"];
- *     c -> i -> j;
- *   subgraph {
- *     rank = same;
- *     p0 [label="PROCESSOR 0", shape="box"];
- *     p1 [label="PROCESSOR 1", shape="box"];
- *   b -> p0;
- *   a -> p1;
- * @enddot
- * Lets change the priority of thread A to 4 and enqueue it.
+ * Lets change the priority of thread A to 4.
  * @dot
  * digraph {
@@ -278,8 +232,9 @@ extern "C" {
  * @enddot
- * Alternatively we can also do a blocking operation with thread A.  In this
- * case schedule will be called.
+ * Now perform a blocking operation with thread B.  Please note that thread A
+ * migrated now from processor 0 to processor 1 and thread C still executes on
+ * processor 1.
  * @dot
  * digraph {
@@ -289,12 +244,12 @@ extern "C" {
  *   subgraph {
  *     rank = same;
  *     c [label="C (3)", fillcolor="green"];
+ *     a [label="A (4)", fillcolor="green"];
- *     a [label="A (1)"];
- *     b -> c;
+ *     b [label="B (2)"];
+ *     c -> a;
  *     i -> j;
@@ -305,7 +260,7 @@ extern "C" {
- *   b -> p0;
+ *   a -> p0;
  *   c -> p1;
  * @enddot
@@ -332,6 +287,18 @@ typedef void ( *Scheduler_SMP_Move )(
   Thread_Control *thread_to_move
+typedef void ( *Scheduler_SMP_Update )(
+  Scheduler_Context *context,
+  Thread_Control *thread,
+typedef void ( *Scheduler_SMP_Enqueue )(
+  Thread_Control *thread_to_enqueue,
+  bool has_processor_allocated
 static inline Scheduler_SMP_Context *_Scheduler_SMP_Get_self(
@@ -360,7 +327,7 @@ static inline void _Scheduler_SMP_Node_initialize(
   node->state = SCHEDULER_SMP_NODE_BLOCKED;
-extern const bool _Scheduler_SMP_Node_valid_state_changes[ 4 ][ 4 ];
+extern const bool _Scheduler_SMP_Node_valid_state_changes[ 3 ][ 3 ];
 static inline void _Scheduler_SMP_Node_change_state(
   Scheduler_SMP_Node *node,
@@ -467,6 +434,7 @@ static inline Thread_Control *_Scheduler_SMP_Get_lowest_scheduled(
  * @param[in] context The scheduler instance context.
  * @param[in] thread The thread to enqueue.
+ * @param[in] has_processor_allocated The thread has a processor allocated.
  * @param[in] order The order function.
  * @param[in] get_highest_ready Function to get the highest ready node.
  * @param[in] insert_ready Function to insert a node into the set of ready
@@ -481,6 +449,7 @@ static inline Thread_Control *_Scheduler_SMP_Get_lowest_scheduled(
 static inline void _Scheduler_SMP_Enqueue_ordered(
+  bool has_processor_allocated,
   Chain_Node_order order,
   Scheduler_SMP_Get_highest_ready get_highest_ready,
   Scheduler_SMP_Insert insert_ready,
@@ -492,7 +461,7 @@ static inline void _Scheduler_SMP_Enqueue_ordered(
   Scheduler_SMP_Context *self = _Scheduler_SMP_Get_self( context );
   Scheduler_SMP_Node *node = _Scheduler_SMP_Node_get( thread );
-  if ( node->state == SCHEDULER_SMP_NODE_IN_THE_AIR ) {
+  if ( has_processor_allocated) {
     Thread_Control *highest_ready = ( *get_highest_ready )( &self->Base );
@@ -501,10 +470,7 @@ static inline void _Scheduler_SMP_Enqueue_ordered(
      * NOTE: Do not exchange parameters to do the negation of the order check.
-    if (
-      highest_ready != NULL
-        && !( *order )( &thread->Object.Node, &highest_ready->Object.Node )
+    if ( !( *order )( &thread->Object.Node, &highest_ready->Object.Node ) ) {
       _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_READY );
       _Scheduler_SMP_Allocate_processor( self, highest_ready, thread );
       ( *insert_ready )( &self->Base, thread );
@@ -516,18 +482,10 @@ static inline void _Scheduler_SMP_Enqueue_ordered(
   } else {
     Thread_Control *lowest_scheduled =
       _Scheduler_SMP_Get_lowest_scheduled( self );
+    Scheduler_SMP_Node *lowest_scheduled_node =
+      _Scheduler_SMP_Node_get( lowest_scheduled );
-     * The scheduled chain is empty if nested interrupts change the priority of
-     * all scheduled threads.  These threads are in the air.
-    if (
-      lowest_scheduled != NULL
-        && ( *order )( &thread->Object.Node, &lowest_scheduled->Object.Node )
-      Scheduler_SMP_Node *lowest_scheduled_node =
-        _Scheduler_SMP_Node_get( lowest_scheduled );
+    if ( ( *order )( &thread->Object.Node, &lowest_scheduled->Object.Node ) ) {
         lowest_scheduled_node,
@@ -535,13 +493,15 @@ static inline void _Scheduler_SMP_Enqueue_ordered(
       _Scheduler_SMP_Allocate_processor( self, thread, lowest_scheduled );
       ( *insert_scheduled )( &self->Base, thread );
       ( *move_from_scheduled_to_ready )( &self->Base, lowest_scheduled );
-    } else {
-      _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_READY );
-      ( *insert_ready )( &self->Base, thread );
+static inline void _Scheduler_SMP_Extract_from_scheduled( Thread_Control *thread )
+  _Chain_Extract_unprotected( &thread->Object.Node );
 static inline void _Scheduler_SMP_Schedule_highest_ready(
   Thread_Control *victim,
@@ -558,25 +518,31 @@ static inline void _Scheduler_SMP_Schedule_highest_ready(
- * @brief Finalize a scheduling operation.
+ * @brief Blocks a thread.
  * @param[in] thread The thread of the scheduling operation.
+ * @param[in] extract_from_ready Function to extract a node from the set of
+ * ready nodes.
  * @param[in] move_from_ready_to_scheduled Function to move a node from the set
  * of ready nodes to the set of scheduled nodes.
-static inline void _Scheduler_SMP_Schedule(
+static inline void _Scheduler_SMP_Block(
+  Scheduler_SMP_Extract extract_from_ready,
   Scheduler_SMP_Move move_from_ready_to_scheduled
+  bool is_scheduled = node->state == SCHEDULER_SMP_NODE_SCHEDULED;
+  _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_BLOCKED );
-    _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_BLOCKED );
+  if ( is_scheduled ) {
+    _Scheduler_SMP_Extract_from_scheduled( thread );
       context,
@@ -584,42 +550,38 @@ static inline void _Scheduler_SMP_Schedule(
       get_highest_ready,
+  } else {
+    ( *extract_from_ready )( context, thread );
-static inline void _Scheduler_SMP_Block(
+static inline void _Scheduler_SMP_Change_priority(
-  Scheduler_SMP_Extract extract,
-  Scheduler_SMP_Get_highest_ready get_highest_ready,
-  Scheduler_SMP_Move move_from_ready_to_scheduled
+  bool prepend_it,
+  Scheduler_SMP_Update update,
+  Scheduler_SMP_Enqueue enqueue_fifo,
+  Scheduler_SMP_Enqueue enqueue_lifo
-  ( *extract )( context, thread );
+  Scheduler_SMP_Node *node = _Scheduler_SMP_Node_get( thread );
+  bool has_processor_allocated = node->state == SCHEDULER_SMP_NODE_SCHEDULED;
-    context,
-    thread,
-    get_highest_ready,
-    move_from_ready_to_scheduled
+  if ( has_processor_allocated ) {
+  } else {
- * @brief Extracts a thread from the set of scheduled or ready nodes.
- * @param[in] context The scheduler instance context.
- * @param[in] thread The thread to extract.
- * @param[in] extract Function to extract a node from the set of scheduled or
- * ready nodes.
-static inline void _Scheduler_SMP_Extract(
-  Scheduler_Context *context,
-  Thread_Control *thread,
+  ( *update )( context, thread, new_priority );
+  if ( prepend_it ) {
+    ( *enqueue_lifo )( context, thread, has_processor_allocated );
+  } else {
+    ( *enqueue_fifo )( context, thread, has_processor_allocated );
 static inline void _Scheduler_SMP_Insert_scheduled_lifo(
diff --git a/cpukit/score/include/rtems/score/statesimpl.h b/cpukit/score/include/rtems/score/statesimpl.h
index 00d1092..4251b3c 100644
--- a/cpukit/score/include/rtems/score/statesimpl.h
+++ b/cpukit/score/include/rtems/score/statesimpl.h
@@ -42,8 +42,6 @@ extern "C" {
 #define STATES_DORMANT                         0x00001
 /** This macro corresponds to a task being suspended. */
 #define STATES_SUSPENDED                       0x00002
-/** This macro corresponds to a task being in an internal state transition. */
-#define STATES_TRANSIENT                       0x00004
 /** This macro corresponds to a task which is waiting for a timeout. */
 #define STATES_DELAYING                        0x00008
 /** This macro corresponds to a task waiting until a specific TOD. */
@@ -215,21 +213,6 @@ RTEMS_INLINE_ROUTINE bool _States_Is_suspended (
- * This function returns true if the TRANSIENT state is set in
- * the_states, and false otherwise.
- * @param[in] the_states is the task state set to test
- * @return This method returns true if the desired state condition is set.
-RTEMS_INLINE_ROUTINE bool _States_Is_transient (
-  States_Control the_states
-   return (the_states & STATES_TRANSIENT);
  * This function returns true if the DELAYING state is set in
diff --git a/cpukit/score/src/schedulercbsunblock.c b/cpukit/score/src/schedulercbsunblock.c
index 411e6ce..1a374f6 100644
--- a/cpukit/score/src/schedulercbsunblock.c
+++ b/cpukit/score/src/schedulercbsunblock.c
@@ -20,6 +20,7 @@
 #endif
 #include <rtems/score/schedulercbsimpl.h>
+#include <rtems/score/scheduleredfimpl.h>
diff --git a/cpukit/score/src/scheduleredfchangepriority.c b/cpukit/score/src/scheduleredfchangepriority.c
new file mode 100644
index 0000000..dfcfef5
--- /dev/null
+++ b/cpukit/score/src/scheduleredfchangepriority.c
@@ -0,0 +1,36 @@
+ *  @file
+ *  @brief Scheduler EDF Extract
+ *  @ingroup ScoreScheduler
+ *  Copyright (C) 2011 Petr Benes.
+ *  Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+  bool                     prepend_it
diff --git a/cpukit/score/src/scheduleredfenqueue.c b/cpukit/score/src/scheduleredfenqueue.c
deleted file mode 100644
index 8973d8b..0000000
--- a/cpukit/score/src/scheduleredfenqueue.c
+++ /dev/null
@@ -1,34 +0,0 @@
- * @file
- * @brief Scheduler EDF Enqueue
- * @ingroup ScoreScheduler
- *  Copyright (C) 2011 Petr Benes.
- *  Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/score/scheduleredfimpl.h>
-  Scheduler_EDF_Context *context =
-    _Scheduler_EDF_Get_context( scheduler );
-  Scheduler_EDF_Node *node = _Scheduler_EDF_Node_get( the_thread );
-  _RBTree_Insert( &context->Ready, &node->Node );
-  node->queue_state = SCHEDULER_EDF_QUEUE_STATE_YES;
diff --git a/cpukit/score/src/scheduleredfenqueuefirst.c b/cpukit/score/src/scheduleredfenqueuefirst.c
index aafc9b4..0000000
--- a/cpukit/score/src/scheduleredfenqueuefirst.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * @file
- * @brief Enqueues a thread to the ready queue
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/system.h>
-#include <rtems/config.h>
-#include <rtems/score/scheduleredf.h>
-  _Scheduler_EDF_Enqueue( scheduler, the_thread );
diff --git a/cpukit/score/src/scheduleredfextract.c b/cpukit/score/src/scheduleredfextract.c
index 94fde0a..0000000
--- a/cpukit/score/src/scheduleredfextract.c
+++ /dev/null
@@ -1,34 +0,0 @@
- *  @file
- *  @brief Scheduler EDF Extract
-#if HAVE_CONFIG_H
-#endif
-  _RBTree_Extract( &context->Ready, &node->Node );
-  node->queue_state = SCHEDULER_EDF_QUEUE_STATE_NOT_PRESENTLY;
diff --git a/cpukit/score/src/scheduleredfunblock.c b/cpukit/score/src/scheduleredfunblock.c
index 7418b64..30fa4f0 100644
--- a/cpukit/score/src/scheduleredfunblock.c
+++ b/cpukit/score/src/scheduleredfunblock.c
@@ -18,7 +18,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulerprioritychangepriority.c b/cpukit/score/src/schedulerprioritychangepriority.c
index 0000000..448c603
--- /dev/null
+++ b/cpukit/score/src/schedulerprioritychangepriority.c
@@ -0,0 +1,61 @@
+ * @file
+ * @brief Removes Thread from Thread Queue
+ *  COPYRIGHT (c) 2011.
+ *  On-Line Applications Research Corporation (OAR).
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/score/schedulerpriorityimpl.h>
+  bool                     prepend_it
+  Scheduler_priority_Context *context =
+    _Scheduler_priority_Get_context( scheduler );
+  Scheduler_priority_Node *node = _Scheduler_priority_Node_get( the_thread );
+  _Scheduler_priority_Ready_queue_extract(
+    the_thread,
+    &node->Ready_queue,
+    &context->Bit_map
+  _Scheduler_priority_Ready_queue_update(
+    new_priority,
+    &context->Bit_map,
+    &context->Ready[ 0 ]
+    _Scheduler_priority_Ready_queue_enqueue_first(
+      the_thread,
+      &context->Bit_map
+  } else {
+    _Scheduler_priority_Ready_queue_enqueue(
+      the_thread,
+      &context->Bit_map
diff --git a/cpukit/score/src/schedulerpriorityenqueue.c b/cpukit/score/src/schedulerpriorityenqueue.c
index aa901cc..0000000
--- a/cpukit/score/src/schedulerpriorityenqueue.c
+++ /dev/null
@@ -1,37 +0,0 @@
- *  @file
- *  @brief Scheduler Priority Enqueue
- *  COPYRIGHT (c) 2011.
- *  On-Line Applications Research Corporation (OAR).
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/score/schedulerpriorityimpl.h>
-  Scheduler_priority_Context *context =
-    _Scheduler_priority_Get_context( scheduler );
-  Scheduler_priority_Node *node = _Scheduler_priority_Node_get( the_thread );
-  _Scheduler_priority_Ready_queue_enqueue(
-    the_thread,
-    &node->Ready_queue,
-    &context->Bit_map
diff --git a/cpukit/score/src/schedulerpriorityenqueuefirst.c b/cpukit/score/src/schedulerpriorityenqueuefirst.c
index 1714fe5..0000000
--- a/cpukit/score/src/schedulerpriorityenqueuefirst.c
+++ /dev/null
@@ -1,38 +0,0 @@
- *  @file
- *  @brief Scheduler Priority Enqueue First
-#if HAVE_CONFIG_H
-#endif
-  _Scheduler_priority_Ready_queue_enqueue_first(
-    the_thread,
-    &context->Bit_map
diff --git a/cpukit/score/src/schedulerpriorityextract.c b/cpukit/score/src/schedulerpriorityextract.c
index 84dbaa4..0000000
--- a/cpukit/score/src/schedulerpriorityextract.c
+++ /dev/null
@@ -1,30 +0,0 @@
- * @file
- * @brief Removes Thread from Thread Queue
-#if HAVE_CONFIG_H
-#endif
-  _Scheduler_priority_Extract_body( scheduler, the_thread );
diff --git a/cpukit/score/src/schedulerprioritysmp.c b/cpukit/score/src/schedulerprioritysmp.c
index 8133956..0198511 100644
--- a/cpukit/score/src/schedulerprioritysmp.c
+++ b/cpukit/score/src/schedulerprioritysmp.c
@@ -70,24 +70,39 @@ bool _Scheduler_priority_SMP_Allocate(
   return true;
+static void _Scheduler_priority_SMP_Do_update(
   Scheduler_priority_SMP_Context *self =
-    _Scheduler_priority_SMP_Get_context( scheduler );
+    _Scheduler_priority_SMP_Get_self( context );
   Scheduler_priority_SMP_Node *node =
     _Scheduler_priority_SMP_Node_get( thread );
-    thread,
     &node->Ready_queue,
+    new_priority,
     &self->Bit_map,
     &self->Ready[ 0 ]
+  Scheduler_Context *context = _Scheduler_Get_context( scheduler );
+  _Scheduler_priority_SMP_Do_update(
+    context,
+    thread,
+    thread->current_priority
 static Thread_Control *_Scheduler_priority_SMP_Get_highest_ready(
@@ -179,7 +194,7 @@ static void _Scheduler_priority_SMP_Insert_ready_fifo(
-static void _Scheduler_priority_SMP_Do_extract(
+static void _Scheduler_priority_SMP_Extract_from_ready(
@@ -189,23 +204,11 @@ static void _Scheduler_priority_SMP_Do_extract(
-  if ( node->Base.state == SCHEDULER_SMP_NODE_SCHEDULED ) {
-      &node->Base,
-    _Chain_Extract_unprotected( &thread->Object.Node );
-  } else {
-      &node->Base,
-      SCHEDULER_SMP_NODE_BLOCKED
-    _Scheduler_priority_Ready_queue_extract(
-      thread,
-      &self->Bit_map
+    thread,
+    &self->Bit_map
@@ -213,13 +216,12 @@ void _Scheduler_priority_SMP_Block(
-  Scheduler_priority_SMP_Context *self =
-    &self->Base.Base,
+    context,
     thread,
-    _Scheduler_priority_SMP_Do_extract,
+    _Scheduler_priority_SMP_Extract_from_ready,
     _Scheduler_priority_SMP_Get_highest_ready,
     _Scheduler_priority_SMP_Move_from_ready_to_scheduled
@@ -228,6 +230,7 @@ void _Scheduler_priority_SMP_Block(
 static void _Scheduler_priority_SMP_Enqueue_ordered(
   Scheduler_SMP_Insert insert_scheduled
@@ -236,6 +239,7 @@ static void _Scheduler_priority_SMP_Enqueue_ordered(
     context,
     thread,
+    has_processor_allocated,
     order,
     insert_ready,
@@ -245,52 +249,66 @@ static void _Scheduler_priority_SMP_Enqueue_ordered(
+static void _Scheduler_priority_SMP_Enqueue_lifo(
-    &self->Base.Base,
+    context,
     thread,
     _Scheduler_simple_Insert_priority_lifo_order,
     _Scheduler_priority_SMP_Insert_ready_lifo,
+static void _Scheduler_priority_SMP_Enqueue_fifo(
-    &self->Base.Base,
+    context,
     thread,
     _Scheduler_simple_Insert_priority_fifo_order,
     _Scheduler_priority_SMP_Insert_ready_fifo,
     _Scheduler_SMP_Insert_scheduled_fifo
-    &self->Base.Base,
+  _Scheduler_priority_SMP_Enqueue_fifo( context, thread, false );
+  bool                     prepend_it
+  _Scheduler_SMP_Change_priority(
+    context,
     thread,
+    new_priority,
+    prepend_it,
+    _Scheduler_priority_SMP_Do_update,
+    _Scheduler_priority_SMP_Enqueue_fifo,
+    _Scheduler_priority_SMP_Enqueue_lifo
@@ -299,12 +317,13 @@ void _Scheduler_priority_SMP_Yield(
   ISR_Level level;
   _ISR_Disable( level );
-  _Scheduler_priority_SMP_Extract( scheduler, thread );
-  _Scheduler_priority_SMP_Enqueue_fifo( scheduler, thread );
+  _Scheduler_priority_SMP_Enqueue_fifo( context, thread, true );
   _ISR_Enable( level );
@@ -314,15 +333,8 @@ void _Scheduler_priority_SMP_Schedule(
-    &self->Base.Base,
-    thread,
-    _Scheduler_priority_SMP_Get_highest_ready,
-    _Scheduler_priority_SMP_Move_from_ready_to_scheduled
+  (void) scheduler;
+  (void) thread;
 void _Scheduler_priority_SMP_Start_idle(
@@ -331,8 +343,7 @@ void _Scheduler_priority_SMP_Start_idle(
   Per_CPU_Control *cpu
-  _Scheduler_SMP_Start_idle( &self->Base.Base, thread, cpu );
+  _Scheduler_SMP_Start_idle( context, thread, cpu );
diff --git a/cpukit/score/src/schedulerpriorityupdate.c b/cpukit/score/src/schedulerpriorityupdate.c
index 8a22ee6..e58a609 100644
--- a/cpukit/score/src/schedulerpriorityupdate.c
+++ b/cpukit/score/src/schedulerpriorityupdate.c
@@ -30,8 +30,8 @@ void _Scheduler_priority_Update(
-    the_thread,
     &node->Ready_queue,
+    the_thread->current_priority,
     &context->Bit_map,
diff --git a/cpukit/score/src/schedulersimplechangepriority.c b/cpukit/score/src/schedulersimplechangepriority.c
index 0000000..010f1df
--- /dev/null
+++ b/cpukit/score/src/schedulersimplechangepriority.c
@@ -0,0 +1,41 @@
+ * @file
+ * @brief Removes a Thread from the Simple Queue
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/score/schedulersimpleimpl.h>
+  bool                     prepend_it
+  Scheduler_simple_Context *context =
+    _Scheduler_simple_Get_context( scheduler );
+  _Scheduler_simple_Extract( scheduler, the_thread );
+    _Scheduler_simple_Insert_priority_lifo( &context->Ready, the_thread );
+  } else {
+    _Scheduler_simple_Insert_priority_fifo( &context->Ready, the_thread );
diff --git a/cpukit/score/src/schedulersimpleenqueue.c b/cpukit/score/src/schedulersimpleenqueue.c
index 5dc8894..0000000
--- a/cpukit/score/src/schedulersimpleenqueue.c
+++ /dev/null
@@ -1,30 +0,0 @@
- * @file
- * @brief Puts Thread onto the Ready Queue
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/score/schedulersimpleimpl.h>
diff --git a/cpukit/score/src/schedulersimpleenqueuefirst.c b/cpukit/score/src/schedulersimpleenqueuefirst.c
index 2ea0a15..0000000
--- a/cpukit/score/src/schedulersimpleenqueuefirst.c
+++ /dev/null
@@ -1,29 +0,0 @@
- *  @file
- *  @brief Scheduler Simple Enqueue First
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/score/schedulersimple.h>
-  _Scheduler_simple_Ready_queue_enqueue_first( scheduler, the_thread );
diff --git a/cpukit/score/src/schedulersimpleextract.c b/cpukit/score/src/schedulersimpleextract.c
index 6b89c99..0000000
--- a/cpukit/score/src/schedulersimpleextract.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * @file
- * @brief Removes a Thread from the Simple Queue
-#if HAVE_CONFIG_H
-#endif
-  (void) scheduler;
diff --git a/cpukit/score/src/schedulersimplereadyqueueenqueue.c b/cpukit/score/src/schedulersimplereadyqueueenqueue.c
index 8e5f12d..0000000
--- a/cpukit/score/src/schedulersimplereadyqueueenqueue.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * @file
- * @brief Scheduler Simple Priority Enqueue Ready Thread
-#if HAVE_CONFIG_H
-#endif
-  Scheduler_simple_Context *context =
-    _Scheduler_simple_Get_context( scheduler );
-  _Scheduler_simple_Insert_priority_fifo( &context->Ready, the_thread );
diff --git a/cpukit/score/src/schedulersimplereadyqueueenqueuefirst.c b/cpukit/score/src/schedulersimplereadyqueueenqueuefirst.c
index c5f1e68..0000000
--- a/cpukit/score/src/schedulersimplereadyqueueenqueuefirst.c
+++ /dev/null
@@ -1,32 +0,0 @@
- *  @file
- *  @brief Scheduler Simple Ready Queue Enqueue First
-#if HAVE_CONFIG_H
-#endif
-  _Scheduler_simple_Insert_priority_lifo( &context->Ready, the_thread );
diff --git a/cpukit/score/src/schedulersimplesmp.c b/cpukit/score/src/schedulersimplesmp.c
index 8436659..a4abc7d 100644
--- a/cpukit/score/src/schedulersimplesmp.c
+++ b/cpukit/score/src/schedulersimplesmp.c
@@ -55,6 +55,17 @@ bool _Scheduler_simple_SMP_Allocate(
   return true;
+static void _Scheduler_simple_SMP_Do_update(
+  (void) context;
+  (void) thread;
+  (void) new_priority;
 static Thread_Control *_Scheduler_simple_SMP_Get_highest_ready(
@@ -131,21 +142,13 @@ static void _Scheduler_simple_SMP_Insert_ready_fifo(
-static void _Scheduler_simple_SMP_Do_extract(
+static void _Scheduler_simple_SMP_Extract_from_ready(
-  Scheduler_SMP_Node *node = _Scheduler_SMP_Node_get( thread );
   (void) context;
-  if ( node->state == SCHEDULER_SMP_NODE_SCHEDULED ) {
-    _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_IN_THE_AIR );
-  } else {
@@ -154,13 +157,12 @@ void _Scheduler_simple_SMP_Block(
-  Scheduler_simple_SMP_Context *self =
-    _Scheduler_simple_SMP_Get_context( scheduler );
-    &self->Base.Base,
+    context,
     thread,
-    _Scheduler_simple_SMP_Do_extract,
+    _Scheduler_simple_SMP_Extract_from_ready,
     _Scheduler_simple_SMP_Get_highest_ready,
     _Scheduler_simple_SMP_Move_from_ready_to_scheduled
@@ -169,6 +171,7 @@ void _Scheduler_simple_SMP_Block(
 static void _Scheduler_simple_SMP_Enqueue_ordered(
@@ -177,6 +180,7 @@ static void _Scheduler_simple_SMP_Enqueue_ordered(
     context,
     thread,
     order,
     insert_ready,
@@ -186,52 +190,66 @@ static void _Scheduler_simple_SMP_Enqueue_ordered(
+static void _Scheduler_simple_SMP_Enqueue_lifo(
-    &self->Base.Base,
+    context,
     thread,
     _Scheduler_simple_SMP_Insert_ready_lifo,
+static void _Scheduler_simple_SMP_Enqueue_fifo(
-    &self->Base.Base,
+    context,
     thread,
     _Scheduler_simple_SMP_Insert_ready_fifo,
+  _Scheduler_simple_SMP_Enqueue_fifo( context, thread, false );
-    &self->Base.Base,
+  bool                     prepend_it
+    context,
     thread,
+    new_priority,
+    prepend_it,
+    _Scheduler_simple_SMP_Do_update,
+    _Scheduler_simple_SMP_Enqueue_fifo,
+    _Scheduler_simple_SMP_Enqueue_lifo
@@ -240,12 +258,13 @@ void _Scheduler_simple_SMP_Yield(
   ISR_Level level;
-  _Scheduler_simple_SMP_Extract( scheduler, thread );
-  _Scheduler_simple_SMP_Enqueue_priority_fifo( scheduler, thread );
+  _Scheduler_simple_SMP_Enqueue_fifo( context, thread, true );
@@ -255,15 +274,8 @@ void _Scheduler_simple_SMP_Schedule(
-    &self->Base.Base,
-    thread,
-    _Scheduler_simple_SMP_Get_highest_ready,
-    _Scheduler_simple_SMP_Move_from_ready_to_scheduled
+  (void) scheduler;
+  (void) thread;
 void _Scheduler_simple_SMP_Start_idle(
@@ -272,8 +284,7 @@ void _Scheduler_simple_SMP_Start_idle(
diff --git a/cpukit/score/src/schedulersimpleunblock.c b/cpukit/score/src/schedulersimpleunblock.c
index 3a9528f..4e49bd6 100644
--- a/cpukit/score/src/schedulersimpleunblock.c
+++ b/cpukit/score/src/schedulersimpleunblock.c
@@ -26,7 +26,10 @@ void _Scheduler_simple_Unblock(
    *  If the thread that was unblocked is more important than the heir,
diff --git a/cpukit/score/src/schedulersimpleyield.c b/cpukit/score/src/schedulersimpleyield.c
index ea41892..65578d0 100644
--- a/cpukit/score/src/schedulersimpleyield.c
+++ b/cpukit/score/src/schedulersimpleyield.c
@@ -26,11 +26,14 @@ void _Scheduler_simple_Yield(
   ISR_Level       level;
-    _Scheduler_simple_Ready_queue_requeue( scheduler, the_thread );
     _ISR_Flash( level );
diff --git a/cpukit/score/src/schedulersmpvalidstatechanges.c b/cpukit/score/src/schedulersmpvalidstatechanges.c
index 61f6a7e..5e35d42 100644
--- a/cpukit/score/src/schedulersmpvalidstatechanges.c
+++ b/cpukit/score/src/schedulersmpvalidstatechanges.c
@@ -30,10 +30,9 @@
  * Table with all valid state transitions.  It is used in
  * _Scheduler_SMP_Node_change_state() in case RTEMS_DEBUG is defined.
-const bool _Scheduler_SMP_Node_valid_state_changes[ 4 ][ 4 ] = {
-  /*                 BLOCKED SCHEDULED READY  IN THE AIR */
-  /* BLOCKED    */ { false,  true,     true,  false },
-  /* SCHEDULED  */ { false,  false,    true,  true },
-  /* READY      */ { true,   true,     false, false },
-  /* IN THE AIR */ { true,   true,     true,  false }
+const bool _Scheduler_SMP_Node_valid_state_changes[ 3 ][ 3 ] = {
+  /*                 BLOCKED SCHEDULED READY */
+  /* BLOCKED    */ { false,  true,     true },
+  /* SCHEDULED  */ { false,  false,    true },
+  /* READY      */ { true,   true,     false }
diff --git a/cpukit/score/src/threadchangepriority.c b/cpukit/score/src/threadchangepriority.c
index 68eb3e8..4480b53 100644
--- a/cpukit/score/src/threadchangepriority.c
+++ b/cpukit/score/src/threadchangepriority.c
@@ -29,79 +29,40 @@ void _Thread_Change_priority(
   bool              prepend_it
-  const Scheduler_Control *scheduler = _Scheduler_Get( the_thread );
-  ISR_Level                level;
-  States_Control           state, original_state;
-   * Save original state
-  original_state = the_thread->current_state;
-   * Set a transient state for the thread so it is pulled off the Ready chains.
-   * This will prevent it from being scheduled no matter what happens in an
-   * ISR.
-  _Thread_Set_transient( the_thread );
    *  Do not bother recomputing all the priority related information if
    *  we are not REALLY changing priority.
- if ( the_thread->current_priority != new_priority )
-    _Thread_Set_priority( the_thread, new_priority );
+  if ( the_thread->current_priority != new_priority ) {
+    ISR_Level                level;
+    const Scheduler_Control *scheduler;
-  _ISR_Disable( level );
+    _ISR_Disable( level );
-   *  If the thread has more than STATES_TRANSIENT set, then it is blocked,
-   *  If it is blocked on a thread queue, then we need to requeue it.
-  state = the_thread->current_state;
-  if ( state != STATES_TRANSIENT ) {
-    /* Only clear the transient state if it wasn't set already */
-    if ( ! _States_Is_transient( original_state ) )
-      the_thread->current_state = _States_Clear( STATES_TRANSIENT, state );
+    scheduler = _Scheduler_Get( the_thread );
+    the_thread->current_priority = new_priority;
-     * The thread may have new blocking states added by interrupt service
-     * routines after the change into the transient state.  This will not
-     * result in a _Scheduler_Block() operation.  Make sure we select an heir
-     * now.
-    _Scheduler_Schedule( scheduler, the_thread );
+    if ( _States_Is_ready( the_thread->current_state ) ) {
+      _Scheduler_Change_priority(
+        scheduler,
+        the_thread,
+        new_priority,
+        prepend_it
-    _ISR_Enable( level );
-    if ( _States_Is_waiting_on_thread_queue( state ) ) {
-      _Thread_queue_Requeue( the_thread->Wait.queue, the_thread );
-    return;
+      _ISR_Flash( level );
-  if ( ! _States_Is_transient( original_state ) ) {
-     *  Interrupts are STILL disabled.
-     *  We now know the thread will be in the READY state when we remove
-     *  the TRANSIENT state.  So we have to place it on the appropriate
-     *  Ready Queue with interrupts off.
+       *  We altered the set of thread priorities.  So let's figure out
+       *  who is the heir and if we need to switch to them.
+      _Scheduler_Schedule( scheduler, the_thread );
+    } else {
+      _Scheduler_Update( scheduler, the_thread );
+    _ISR_Enable( level );
-    if ( prepend_it )
-      _Scheduler_Enqueue_first( scheduler, the_thread );
-    else
-      _Scheduler_Enqueue( scheduler, the_thread );
+    _Thread_queue_Requeue( the_thread->Wait.queue, the_thread );
-  _ISR_Flash( level );
-   *  We altered the set of thread priorities.  So let's figure out
-   *  who is the heir and if we need to switch to them.
diff --git a/cpukit/score/src/threadsettransient.c b/cpukit/score/src/threadsettransient.c
index ead3c45..0000000
--- a/cpukit/score/src/threadsettransient.c
+++ /dev/null
@@ -1,44 +0,0 @@
- * @file
- * @brief Sets the Transient State for a Thread
- * @ingroup ScoreThread
- *  COPYRIGHT (c) 1989-2011.
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/score/threadimpl.h>
-#include <rtems/score/isrlevel.h>
-#include <rtems/score/schedulerimpl.h>
-void _Thread_Set_transient(
-  ISR_Level             level;
-  uint32_t              old_state;
-  old_state = the_thread->current_state;
-  the_thread->current_state = _States_Set( STATES_TRANSIENT, old_state );
-  if ( _States_Is_ready( old_state ) ) {
-    _Scheduler_Extract( _Scheduler_Get( the_thread ), the_thread );
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 999c758..ef25b25 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -50,7 +50,6 @@ _SUBDIRS += sptls02
 endif
 _SUBDIRS += sptls01
 _SUBDIRS += spintrcritical20
-_SUBDIRS += spintrcritical19
 _SUBDIRS += spcontext01
 _SUBDIRS += spfatal26
 _SUBDIRS += speventtransient01
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 6be14e4..b40d4dd 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -50,7 +50,6 @@ spcpucounter01/Makefile
 sptls02/Makefile
 sptls01/Makefile
 spintrcritical20/Makefile
-spintrcritical19/Makefile
 spcontext01/Makefile
 spfatal26/Makefile
 spinternalerror02/Makefile
diff --git a/testsuites/sptests/spintrcritical19/Makefile.am b/testsuites/sptests/spintrcritical19/Makefile.am
index a2350ca..0000000
--- a/testsuites/sptests/spintrcritical19/Makefile.am
+++ /dev/null
@@ -1,20 +0,0 @@
-rtems_tests_PROGRAMS = spintrcritical19
-spintrcritical19_SOURCES = init.c ../spintrcritical_support/intrcritical.c
-dist_rtems_tests_DATA = spintrcritical19.scn spintrcritical19.doc
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-AM_CPPFLAGS += -I$(top_srcdir)/spintrcritical_support
-LINK_OBJS = $(spintrcritical19_OBJECTS)
-LINK_LIBS = $(spintrcritical19_LDLIBS)
-spintrcritical19$(EXEEXT): $(spintrcritical19_OBJECTS) $(spintrcritical19_DEPENDENCIES)
-	@rm -f spintrcritical19$(EXEEXT)
-	$(make-exe)
-include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spintrcritical19/init.c b/testsuites/sptests/spintrcritical19/init.c
index 4d2eca8..0000000
--- a/testsuites/sptests/spintrcritical19/init.c
+++ /dev/null
@@ -1,136 +0,0 @@
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
-#ifdef HAVE_CONFIG_H
-  #include "config.h"
-#endif
-#include <tmacros.h>
-#include <intrcritical.h>
-#include <rtems/score/statesimpl.h>
-const char rtems_test_name[] = "SPINTRCRITICAL 19";
-#define PRIORITY_RED 1
-#define PRIORITY_GREEN 2
-#define PRIORITY_RESUMER 3
-typedef struct {
-  rtems_id master_task;
-  rtems_id resumer_task;
-  Thread_Control *master_task_tcb;
-  bool test_case_hit;
-} test_context;
-static test_context ctx_instance;
-static void resumer_task(rtems_task_argument arg)
-  test_context *ctx = (test_context *) arg;
-  while (true) {
-    rtems_status_code sc = rtems_task_resume(ctx->master_task);
-    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-static void suspend_master_task(rtems_id timer, void *arg)
-  /* The arg is NULL */
-  test_context *ctx = &ctx_instance;
-  rtems_status_code sc;
-  if (_States_Is_transient(ctx->master_task_tcb->current_state)) {
-    ctx->test_case_hit = true;
-  sc = rtems_task_suspend(ctx->master_task);
-static void Init(rtems_task_argument ignored)
-  rtems_task_priority priority = PRIORITY_RED;
-  int resets = 0;
-  TEST_BEGIN();
-  ctx->master_task = rtems_task_self();
-  ctx->master_task_tcb = _Thread_Get_executing();
-  sc = rtems_task_create(
-    rtems_build_name('R', 'E', 'S', 'U'),
-    PRIORITY_RESUMER,
-    RTEMS_MINIMUM_STACK_SIZE,
-    RTEMS_DEFAULT_MODES,
-    RTEMS_DEFAULT_ATTRIBUTES,
-    &ctx->resumer_task
-  sc = rtems_task_start(
-    ctx->resumer_task,
-    resumer_task,
-    (rtems_task_argument) ctx
-  interrupt_critical_section_test_support_initialize(
-    suspend_master_task
-  while (resets < 3 && !ctx->test_case_hit) {
-    if (interrupt_critical_section_test_support_delay()) {
-      ++resets;
-    sc = rtems_task_set_priority(RTEMS_SELF, priority, &priority);
-    rtems_test_assert(_States_Is_ready(ctx->master_task_tcb->current_state));
-  rtems_test_assert(ctx->test_case_hit);
-  sc = rtems_task_delete(ctx->resumer_task);
-  TEST_END();
-  rtems_test_exit(0);
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_MICROSECONDS_PER_TICK 1000
-#define CONFIGURE_MAXIMUM_TASKS 2
-#define CONFIGURE_MAXIMUM_TIMERS 1
-#define CONFIGURE_INIT_TASK_PRIORITY PRIORITY_GREEN
-#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
-#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spintrcritical19/spintrcritical19.doc b/testsuites/sptests/spintrcritical19/spintrcritical19.doc
index 4228ff2..0000000
--- a/testsuites/sptests/spintrcritical19/spintrcritical19.doc
+++ /dev/null
@@ -1,13 +0,0 @@
-This file describes the directives and concepts tested by this test set.
-test set name: spintrcritical19
-directives:
-  - rtems_task_suspend()
-  - rtems_task_set_priority()
-concepts:
-  - Ensure that a priority change works during suspend requests from an
-    interrupt service routine.
diff --git a/testsuites/sptests/spintrcritical19/spintrcritical19.scn b/testsuites/sptests/spintrcritical19/spintrcritical19.scn
index 3d7d209..0000000
--- a/testsuites/sptests/spintrcritical19/spintrcritical19.scn
+++ /dev/null
@@ -1,4 +0,0 @@
-*** TEST INTERRUPT CRITICAL SECTION 19 ***
-Support - rtems_timer_create - creating timer 1
-*** END OF TEST INTERRUPT CRITICAL SECTION 19 ***
1.7.7
