rtems_test_end()/TEST_END() issues
    Sebastian Huber
    Fri May 16 12:09:01 UTC 2014
Hello Joel,
I think this rtems_test_* stuff is a hack.  What we really need in the long run
is a proper test framework.
On 2014-05-15 17:53, Joel Sherrill wrote:
> Hi
> Some tests call rtems_test_end() directly. I haven't
> checked all but some just need to change to call
> TEST_END().
> But the samples may need to follow their own rules.
> And the block* tests appear to have their own TEST_END()
> macro in bdbuf_tests.h.  And it calls rtems_test_end() or
> rtems_test_endk() directly.
I converted this mostly using some scripts.  The goal was to use TEST_END() as
much as possible.
> This started with an examination of leon3 test output.
> At least sp39 can exit with a "END OF" message and
> a failure message. That needs to be fixed and is pretty
> easy.
Yes, tests printing "END OF" in case of a test failure are broken.
> Any thoughts on all this?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
