[PATCH 1/2] score/sparc: Add support for para-virtualization.
Christian Mauderer christian.mauderer at embedded-brains.de
Tue May 20 09:16:00 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 cpukit/score/cpu/sparc/cpu.c               |  4 +++
 cpukit/score/cpu/sparc/rtems/score/cpu.h   | 13 +++++++--
 cpukit/score/cpu/sparc/rtems/score/sparc.h | 44 ++++++++++++++++++++++++++++++
 3 files changed, 58 insertions(+), 3 deletions(-)
diff --git a/cpukit/score/cpu/sparc/cpu.c b/cpukit/score/cpu/sparc/cpu.c
index ee0d622..dc960bb 100644
--- a/cpukit/score/cpu/sparc/cpu.c
+++ b/cpukit/score/cpu/sparc/cpu.c
@@ -82,7 +82,11 @@ SPARC_ASSERT_OFFSET(is_executing, SPARC_CONTEXT_CONTROL_IS_EXECUTING);
 const CPU_Trap_table_entry _CPU_Trap_slot_template = {
+#ifdef RTEMS_PARAVIRT
+  0x01000000,      /* nop                       */
+#else /* RTEMS_PARAVIRT */
   0xa1480000,      /* mov   %psr, %l0           */
+#endif /* RTEMS_PARAVIRT */
   0x29000000,      /* sethi %hi(_handler), %l4  */
   0x81c52000,      /* jmp   %l4 + %lo(_handler) */
   0xa6102000       /* mov   _vector, %l3        */
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index 532d882..216fc59 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -975,8 +975,15 @@ extern const CPU_Trap_table_entry _CPU_Trap_slot_template;
  * actually provides.  Currently, interrupt levels which do not
  * map onto the CPU in a straight fashion are undefined.
-#define _CPU_ISR_Set_level( _newlevel ) \
-   sparc_enable_interrupts( _newlevel << 8)
+  #define _CPU_ISR_Set_level( _newlevel ) \
+     _SPARC_ISR_Set_level( _newlevel << 8)
+void _SPARC_ISR_Set_level( uint32_t pil );
+#else
+     sparc_enable_interrupts( _newlevel << 8)
+#endif
  * @brief Obtain the current interrupt disable level.
@@ -1192,7 +1199,7 @@ register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__( "g6" );
   void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
-  #if defined(__leon__)
+  #if defined(__leon__) && !defined(RTEMS_PARAVIRT)
     static inline uint32_t _CPU_SMP_Get_current_processor( void )
       return _LEON3_Get_current_processor();
diff --git a/cpukit/score/cpu/sparc/rtems/score/sparc.h b/cpukit/score/cpu/sparc/rtems/score/sparc.h
index 4568300..b1859ea 100644
--- a/cpukit/score/cpu/sparc/rtems/score/sparc.h
+++ b/cpukit/score/cpu/sparc/rtems/score/sparc.h
@@ -164,17 +164,37 @@ extern "C" {
  * This macro returns the current contents of the PSR register in @a _psr.
+#define sparc_get_psr( _psr ) \
+  (_psr) = _SPARC_Get_PSR()
+uint32_t _SPARC_Get_PSR( void );
   do { \
      (_psr) = 0; \
      __asm__ volatile( "rd %%psr, %0" :  "=r" (_psr) : "0" (_psr) ); \
   } while ( 0 )
  * @brief Macro to set the PSR.
  * This macro sets the PSR register to the value in @a _psr.
+#define sparc_set_psr( _psr ) \
+  _SPARC_Set_PSR( _psr )
+void _SPARC_Set_PSR( uint32_t new_psr );
   do { \
     __asm__ volatile ( "mov  %0, %%psr " : "=r" ((_psr)) : "0" ((_psr)) ); \
@@ -183,27 +203,51 @@ extern "C" {
     nop(); \
   } while ( 0 )
  * @brief Macro to obtain the TBR.
  * This macro returns the current contents of the TBR register in @a _tbr.
+#define sparc_get_tbr( _tbr ) \
+  (_tbr) = _SPARC_Get_TBR()
+uint32_t _SPARC_Get_TBR( void );
   do { \
      (_tbr) = 0; /* to avoid unitialized warnings */ \
      __asm__ volatile( "rd %%tbr, %0" :  "=r" (_tbr) : "0" (_tbr) ); \
   } while ( 0 )
  * @brief Macro to set the TBR.
  * This macro sets the TBR register to the value in @a _tbr.
+#define sparc_set_tbr( _tbr ) \
+  _SPARC_Set_TBR((_tbr))
+void _SPARC_Set_TBR( uint32_t new_tbr );
   do { \
      __asm__ volatile( "wr %0, 0, %%tbr" :  "=r" (_tbr) : "0" (_tbr) ); \
   } while ( 0 )
  * @brief Macro to obtain the WIM.
1.8.4.5
