[PATCH 2/2] bsps/sparc: Add XtratuM BSP.
Tue May 20 14:58:18 UTC 2014
On Tue, May 20, 2014 at 5:16 AM, Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
>  c/src/lib/libbsp/shared/include/fatal.h            |   6 +-
>  c/src/lib/libbsp/sparc/acinclude.m4                |   2 +
>  c/src/lib/libbsp/sparc/shared/irq_asm.S            |  97 ++++++++++++++++
>  c/src/lib/libbsp/sparc/shared/start/start.S        |  58 +++++++++-
>  .../lib/libbsp/sparc/shared/startup/linkcmds.base  |  19 ++++
>  c/src/lib/libbsp/sparc/xtratum/Makefile.am         | 119 ++++++++++++++++++++
>  c/src/lib/libbsp/sparc/xtratum/README              |   8 ++
>  c/src/lib/libbsp/sparc/xtratum/bsp_specs           |  17 +++
>  .../sparc/xtratum/clock/clock-xtratum-exec.c       |  23 ++++
>  .../libbsp/sparc/xtratum/clock/clock-xtratum-hw.c  |  21 ++++
>  .../lib/libbsp/sparc/xtratum/clock/clock-xtratum.h | 103 +++++++++++++++++
>  c/src/lib/libbsp/sparc/xtratum/configure.ac        |  33 ++++++
>  .../libbsp/sparc/xtratum/console/console-config.c  |  27 +++++
>  .../libbsp/sparc/xtratum/console/printk-support.c  |  28 +++++
>  .../sparc/xtratum/console/xtratum-hyper-console.c  |  71 ++++++++++++
>  c/src/lib/libbsp/sparc/xtratum/include/bsp.h       |  52 +++++++++
>  c/src/lib/libbsp/sparc/xtratum/include/cache_.h    | 113 +++++++++++++++++++
>  .../sparc/xtratum/include/clock-xtratum-exec.h     |  26 +++++
>  c/src/lib/libbsp/sparc/xtratum/include/irq.h       |   2 +
>  c/src/lib/libbsp/sparc/xtratum/include/tm27.h      |  30 +++++
>  .../sparc/xtratum/include/xtratum-hyper-console.h  |  30 +++++
>  c/src/lib/libbsp/sparc/xtratum/include/xtratum.h   |  87 +++++++++++++++
>  c/src/lib/libbsp/sparc/xtratum/irq/irq.c           |  77 +++++++++++++
>  .../libbsp/sparc/xtratum/make/custom/xtratum.cfg   |  55 +++++++++
>  c/src/lib/libbsp/sparc/xtratum/preinstall.am       | 123 +++++++++++++++++++++
>  .../libbsp/sparc/xtratum/startup/bsppredriver.c    |   7 ++
>  c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c  |  52 +++++++++
>  c/src/lib/libbsp/sparc/xtratum/startup/bspsmp.c    | 104 +++++++++++++++++
>  c/src/lib/libbsp/sparc/xtratum/startup/bspstart.c  |  22 ++++
>  .../libbsp/sparc/xtratum/startup/example_xm_cf.xml |  66 +++++++++++
>  .../lib/libbsp/sparc/xtratum/startup/isr-en-dis.S  |  50 +++++++++
>  .../libbsp/sparc/xtratum/startup/linkcmds.xtratum  |  20 ++++
>  c/src/lib/libbsp/sparc/xtratum/startup/psr.c       |  26 +++++
>  c/src/lib/libbsp/sparc/xtratum/startup/setvec.c    |  61 ++++++++++
>  c/src/lib/libbsp/sparc/xtratum/startup/spurious.c  |  35 ++++++
>  c/src/lib/libbsp/sparc/xtratum/startup/tbr.c       |  30 +++++
>  c/src/lib/libbsp/sparc/xtratum/xm/xmhdr.c          |  36 ++++++
>  cpukit/score/cpu/sparc/rtems/score/cpu.h           |  11 +-
>  testsuites/smptests/smpfatal08/init.c              |   3 +-
>  39 files changed, 1735 insertions(+), 15 deletions(-)
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/Makefile.am
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/README
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/bsp_specs
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-exec.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-hw.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum.h
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/configure.ac
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/console-config.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/printk-support.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/xtratum-hyper-console.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/bsp.h
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/cache_.h
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/clock-xtratum-exec.h
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/irq.h
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/tm27.h
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/xtratum-hyper-console.h
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/xtratum.h
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/irq/irq.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/make/custom/xtratum.cfg
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/preinstall.am
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bsppredriver.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspsmp.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspstart.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/example_xm_cf.xml
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/isr-en-dis.S
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/linkcmds.xtratum
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/psr.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/setvec.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/tbr.c
>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/xm/xmhdr.c
> diff --git a/c/src/lib/libbsp/shared/include/fatal.h b/c/src/lib/libbsp/shared/include/fatal.h
> index e928bba..8ca90bb 100644
> --- a/c/src/lib/libbsp/shared/include/fatal.h
> +++ b/c/src/lib/libbsp/shared/include/fatal.h
> @@ -101,7 +101,11 @@ typedef enum {
>    PPC_FATAL_EXCEPTION_INITIALIZATION = BSP_FATAL_CODE_BLOCK(7),
>    /* Libchip fatal codes */
> -  DWMAC_FATAL_TOO_MANY_RBUFS_CONFIGURED = BSP_FATAL_CODE_BLOCK(8)
> +  DWMAC_FATAL_TOO_MANY_RBUFS_CONFIGURED = BSP_FATAL_CODE_BLOCK(8),
> +  /* XtratuM fatal codes */
> +  XTRATUM_FATAL_CLOCK_IRQ_INSTALL = BSP_FATAL_CODE_BLOCK(9),
> +  XTRATUM_FATAL_CPU_SMP_INITIALIZE
>  } bsp_fatal_code;
>  RTEMS_COMPILER_NO_RETURN_ATTRIBUTE static inline void
> diff --git a/c/src/lib/libbsp/sparc/acinclude.m4 b/c/src/lib/libbsp/sparc/acinclude.m4
> index 4d40305..0e053fa 100644
> --- a/c/src/lib/libbsp/sparc/acinclude.m4
> +++ b/c/src/lib/libbsp/sparc/acinclude.m4
> @@ -8,6 +8,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>      AC_CONFIG_SUBDIRS([leon2]);;
>    leon3 )
>      AC_CONFIG_SUBDIRS([leon3]);;
> +  xtratum )
> +    AC_CONFIG_SUBDIRS([xtratum]);;
>      AC_MSG_ERROR([Invalid BSP]);;
>    esac
> diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> index bf2dca9..69522a2 100644
> --- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
> +++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> @@ -23,6 +23,10 @@
>  #include <rtems/score/percpu.h>
>  #include <bspopts.h>
> +#ifdef RTEMS_PARAVIRT_XTRATUM
> +#include <xm.h>
What is this header file? I don't see it in the commit, is it part of
the installed XtratuM?
> +#endif /* RTEMS_PARAVIRT_XTRATUM */
>   *  void _CPU_Context_switch(
>   *    Context_Control  *run,
> @@ -54,7 +58,15 @@ SYM(_CPU_Context_switch):
>          ld      [%g6 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE], %o4
>          ! save it a bit later so we do not waste a couple of cycles
> +        mov     %o0, %l6
> +        mov     sparc_get_psr_nr, %o0
> +        __XM_AHC
I'm guessing these symbols are defined in xm.h?
> +        mov     %o0, %o2
> +        mov     %l6, %o0
> +#else /* RTEMS_PARAVIRT_XTRATUM */
>          rd      %psr, %o2
It would be cleaner code if you can write this get_psr as an assembler
macro, e.g.
.macro GET_PSR REG, TMP0
  mov %o0, \TMP
  __XM_AHC
  mov %o0, \REG
  mov \TMP, %o0
#else
  rd %psr, \REG
#endif
Same for some of the other functions that get used multiple times in
this file, such as set_psr, set_pil, and clear_pil. Putting these in a
header file would make them useful in start.S also.
> diff --git a/c/src/lib/libbsp/sparc/shared/start/start.S b/c/src/lib/libbsp/sparc/shared/start/start.S
> index 65dd559..158883a 100644
> --- a/c/src/lib/libbsp/sparc/shared/start/start.S
> +++ b/c/src/lib/libbsp/sparc/shared/start/start.S
> @@ -354,12 +397,19 @@ zerobss:
>          bleu,a zerobss
>          nop
> +        mov     %g7, %o0
> +        call    init_libxm              ! initialize libxm
Where is this function?
> diff --git a/c/src/lib/libbsp/sparc/xtratum/include/irq.h b/c/src/lib/libbsp/sparc/xtratum/include/irq.h
> new file mode 100644
> index 0000000..afa99c0
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/xtratum/include/irq.h
> @@ -0,0 +1,2 @@
> +#define BSP_INTERRUPT_VECTOR_MIN 0
> +#define BSP_INTERRUPT_VECTOR_MAX (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
> diff --git a/c/src/lib/libbsp/sparc/xtratum/include/tm27.h b/c/src/lib/libbsp/sparc/xtratum/include/tm27.h
> index 0000000..85c4963
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/xtratum/include/tm27.h
> @@ -0,0 +1,30 @@
> + *  tm27.h
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#ifndef _RTEMS_TMTEST27
> +#error "This is an RTEMS internal file you must not include directly."
> +#endif
> +#ifndef __tm27_h
> +#define __tm27_h
> +#define TEST_VECTOR SPARC_SYNCHRONOUS_TRAP( 0x90 )
> +#define MUST_WAIT_FOR_INTERRUPT 1
> +#define Install_tm27_vector( handler ) \
> +  set_vector( (handler), TEST_VECTOR, 1 );
> +#define Cause_tm27_intr() \
> +  __asm__ volatile( "ta 0x10; nop " );
I guess this won't actually work?
> diff --git a/c/src/lib/libbsp/sparc/xtratum/irq/irq.c b/c/src/lib/libbsp/sparc/xtratum/irq/irq.c
> index 0000000..c061f9c
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/xtratum/irq/irq.c
> @@ -0,0 +1,77 @@
File needs copyright/license header.
> diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/bsppredriver.c b/c/src/lib/libbsp/sparc/xtratum/startup/bsppredriver.c
> index 0000000..f99c528
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/xtratum/startup/bsppredriver.c
> @@ -0,0 +1,7 @@
File needs copyright/license header, although I'm not sure why this
file is included anyway since the hook is empty.
> diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c b/c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c
> index 0000000..ec80be4
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c
> @@ -0,0 +1,52 @@
> + * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <info at embedded-brains.de>
> +#include <xm.h>
> +#include <bsp/bootcard.h>
> +#ifdef RTEMS_SMP
> +void bsp_reset(void)
> +  uint32_t self_cpu = rtems_get_current_processor();
> +  if (self_cpu == 0) {
> +    /* Value should give us roughly something in the range of a few
> +     * milliseconds. */
> +    uint32_t max_wait = 1234567;
> +    uint32_t cpu_count = rtems_get_processor_count();
> +    uint32_t cpus_halted = 0;
> +    /* Wait some time for secondary processors to halt */
> +    do {
> +      xmVirtualCpuStatus_t status;
> +      cpus_halted = 0;
> +      uint32_t i;
> +      for (i=1; i<cpu_count; ++i) {
> +        XM_get_vcpu_status(i, &status);
> +        if (status.state == XM_STATUS_HALTED) {
> +          ++cpus_halted;
> +      --max_wait;
> +    } while (cpus_halted < cpu_count - 1 && max_wait > 0);
> +    XM_halt_partition(XM_PARTITION_SELF);
> +  } else {
> +    XM_halt_vcpu(XM_VCPU_SELF);
> +  while (1);
> +#endif
What if it is not RTEMS_SMP?
> diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c b/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
> index 0000000..2d4428a
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
> @@ -0,0 +1,35 @@
> + *  LEON Spurious Trap Handler
> + *  This is just enough of a trap handler to let us know what
> + *  the likely source of the trap was.
> + *  Developed as part of the port of RTEMS to the LEON implementation
> + *  of the SPARC by On-Line Applications Research Corporation (OAR)
> + *  under contract to the European Space Agency (ESA).
> + *  COPYRIGHT (c) 1995. European Space Agency.
> + *  Modified for LEON3 BSP.
> + *  COPYRIGHT (c) 2004.
> + *  Gaisler Research.
> + *  This terms of the RTEMS license apply to this file.
> +#include <bsp.h>
> +#include <rtems/bspIo.h>
> +void _BSP_Exception_frame_print( const CPU_Exception_frame *frame )
> +  uint32_t trap;
> +  uint32_t real_trap;
> +  const CPU_Interrupt_frame *isf;
> +  trap = frame->trap;
> +  real_trap = SPARC_REAL_TRAP_NUMBER(trap);
> +  isf = frame->isf;
> +  printk( "Unexpected trap (0x%02x) at address 0x%08x\n", real_trap, isf->tpc);
I don't think this code will get called ever?
> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> index 216fc59..18a8c96 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> @@ -975,15 +975,8 @@ extern const CPU_Trap_table_entry _CPU_Trap_slot_template;
>   * actually provides.  Currently, interrupt levels which do not
>   * map onto the CPU in a straight fashion are undefined.
> -#ifdef RTEMS_PARAVIRT
> -  #define _CPU_ISR_Set_level( _newlevel ) \
> -     _SPARC_ISR_Set_level( _newlevel << 8)
> -void _SPARC_ISR_Set_level( uint32_t pil );
> -#else
> -     sparc_enable_interrupts( _newlevel << 8)
> -#endif
> +#define _CPU_ISR_Set_level( _newlevel ) \
> +  sparc_enable_interrupts( _newlevel << 8)
>   * @brief Obtain the current interrupt disable level.
I don't think this revert is intended?
