[PATCH 2/2] bsps/sparc: Add XtratuM BSP.
Christian Mauderer Christian.Mauderer at embedded-brains.de
Wed May 21 08:04:22 UTC 2014
First of all: Thanks for your comments. You will find answers below.
Am 20.05.2014 16:58, schrieb Gedare Bloom:
> On Tue, May 20, 2014 at 5:16 AM, Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
>>  c/src/lib/libbsp/shared/include/fatal.h            |   6 +-
>>  c/src/lib/libbsp/sparc/acinclude.m4                |   2 +
>>  c/src/lib/libbsp/sparc/shared/irq_asm.S            |  97 ++++++++++++++++
>>  c/src/lib/libbsp/sparc/shared/start/start.S        |  58 +++++++++-
>>  .../lib/libbsp/sparc/shared/startup/linkcmds.base  |  19 ++++
>>  c/src/lib/libbsp/sparc/xtratum/Makefile.am         | 119 ++++++++++++++++++++
>>  c/src/lib/libbsp/sparc/xtratum/README              |   8 ++
>>  c/src/lib/libbsp/sparc/xtratum/bsp_specs           |  17 +++
>>  .../sparc/xtratum/clock/clock-xtratum-exec.c       |  23 ++++
>>  .../libbsp/sparc/xtratum/clock/clock-xtratum-hw.c  |  21 ++++
>>  .../lib/libbsp/sparc/xtratum/clock/clock-xtratum.h | 103 +++++++++++++++++
>>  c/src/lib/libbsp/sparc/xtratum/configure.ac        |  33 ++++++
>>  .../libbsp/sparc/xtratum/console/console-config.c  |  27 +++++
>>  .../libbsp/sparc/xtratum/console/printk-support.c  |  28 +++++
>>  .../sparc/xtratum/console/xtratum-hyper-console.c  |  71 ++++++++++++
>>  c/src/lib/libbsp/sparc/xtratum/include/bsp.h       |  52 +++++++++
>>  c/src/lib/libbsp/sparc/xtratum/include/cache_.h    | 113 +++++++++++++++++++
>>  .../sparc/xtratum/include/clock-xtratum-exec.h     |  26 +++++
>>  c/src/lib/libbsp/sparc/xtratum/include/irq.h       |   2 +
>>  c/src/lib/libbsp/sparc/xtratum/include/tm27.h      |  30 +++++
>>  .../sparc/xtratum/include/xtratum-hyper-console.h  |  30 +++++
>>  c/src/lib/libbsp/sparc/xtratum/include/xtratum.h   |  87 +++++++++++++++
>>  c/src/lib/libbsp/sparc/xtratum/irq/irq.c           |  77 +++++++++++++
>>  .../libbsp/sparc/xtratum/make/custom/xtratum.cfg   |  55 +++++++++
>>  c/src/lib/libbsp/sparc/xtratum/preinstall.am       | 123 +++++++++++++++++++++
>>  .../libbsp/sparc/xtratum/startup/bsppredriver.c    |   7 ++
>>  c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c  |  52 +++++++++
>>  c/src/lib/libbsp/sparc/xtratum/startup/bspsmp.c    | 104 +++++++++++++++++
>>  c/src/lib/libbsp/sparc/xtratum/startup/bspstart.c  |  22 ++++
>>  .../libbsp/sparc/xtratum/startup/example_xm_cf.xml |  66 +++++++++++
>>  .../lib/libbsp/sparc/xtratum/startup/isr-en-dis.S  |  50 +++++++++
>>  .../libbsp/sparc/xtratum/startup/linkcmds.xtratum  |  20 ++++
>>  c/src/lib/libbsp/sparc/xtratum/startup/psr.c       |  26 +++++
>>  c/src/lib/libbsp/sparc/xtratum/startup/setvec.c    |  61 ++++++++++
>>  c/src/lib/libbsp/sparc/xtratum/startup/spurious.c  |  35 ++++++
>>  c/src/lib/libbsp/sparc/xtratum/startup/tbr.c       |  30 +++++
>>  c/src/lib/libbsp/sparc/xtratum/xm/xmhdr.c          |  36 ++++++
>>  cpukit/score/cpu/sparc/rtems/score/cpu.h           |  11 +-
>>  testsuites/smptests/smpfatal08/init.c              |   3 +-
>>  39 files changed, 1735 insertions(+), 15 deletions(-)
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/Makefile.am
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/README
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/bsp_specs
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-exec.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum-hw.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/clock/clock-xtratum.h
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/configure.ac
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/console-config.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/printk-support.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/console/xtratum-hyper-console.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/bsp.h
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/cache_.h
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/clock-xtratum-exec.h
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/irq.h
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/tm27.h
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/xtratum-hyper-console.h
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/include/xtratum.h
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/irq/irq.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/make/custom/xtratum.cfg
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/preinstall.am
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bsppredriver.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspsmp.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/bspstart.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/example_xm_cf.xml
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/isr-en-dis.S
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/linkcmds.xtratum
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/psr.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/setvec.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/startup/tbr.c
>>  create mode 100644 c/src/lib/libbsp/sparc/xtratum/xm/xmhdr.c
>> diff --git a/c/src/lib/libbsp/shared/include/fatal.h b/c/src/lib/libbsp/shared/include/fatal.h
>> index e928bba..8ca90bb 100644
>> --- a/c/src/lib/libbsp/shared/include/fatal.h
>> +++ b/c/src/lib/libbsp/shared/include/fatal.h
>> @@ -101,7 +101,11 @@ typedef enum {
>>    PPC_FATAL_EXCEPTION_INITIALIZATION = BSP_FATAL_CODE_BLOCK(7),
>>    /* Libchip fatal codes */
>> -  DWMAC_FATAL_TOO_MANY_RBUFS_CONFIGURED = BSP_FATAL_CODE_BLOCK(8)
>> +  DWMAC_FATAL_TOO_MANY_RBUFS_CONFIGURED = BSP_FATAL_CODE_BLOCK(8),
>> +  /* XtratuM fatal codes */
>> +  XTRATUM_FATAL_CLOCK_IRQ_INSTALL = BSP_FATAL_CODE_BLOCK(9),
>> +  XTRATUM_FATAL_CPU_SMP_INITIALIZE
>>  } bsp_fatal_code;
>>  RTEMS_COMPILER_NO_RETURN_ATTRIBUTE static inline void
>> diff --git a/c/src/lib/libbsp/sparc/acinclude.m4 b/c/src/lib/libbsp/sparc/acinclude.m4
>> index 4d40305..0e053fa 100644
>> --- a/c/src/lib/libbsp/sparc/acinclude.m4
>> +++ b/c/src/lib/libbsp/sparc/acinclude.m4
>> @@ -8,6 +8,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>      AC_CONFIG_SUBDIRS([leon2]);;
>>    leon3 )
>>      AC_CONFIG_SUBDIRS([leon3]);;
>> +  xtratum )
>> +    AC_CONFIG_SUBDIRS([xtratum]);;
>>      AC_MSG_ERROR([Invalid BSP]);;
>>    esac
>> diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
>> index bf2dca9..69522a2 100644
>> --- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
>> +++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
>> @@ -23,6 +23,10 @@
>>  #include <rtems/score/percpu.h>
>>  #include <bspopts.h>
>> +#ifdef RTEMS_PARAVIRT_XTRATUM
>> +#include <xm.h>
> What is this header file? I don't see it in the commit, is it part of
> the installed XtratuM?
That is correct. It's part of XtratuM. Is there some preferred way of
marking such headers?
>> +#endif /* RTEMS_PARAVIRT_XTRATUM */
>>   *  void _CPU_Context_switch(
>>   *    Context_Control  *run,
>> @@ -54,7 +58,15 @@ SYM(_CPU_Context_switch):
>>          ld      [%g6 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE], %o4
>>          ! save it a bit later so we do not waste a couple of cycles
>> +        mov     %o0, %l6
>> +        mov     sparc_get_psr_nr, %o0
>> +        __XM_AHC
> I'm guessing these symbols are defined in xm.h?
Again, your assumption is right.
>> +        mov     %o0, %o2
>> +        mov     %l6, %o0
>> +#else /* RTEMS_PARAVIRT_XTRATUM */
>>          rd      %psr, %o2
> It would be cleaner code if you can write this get_psr as an assembler
> macro, e.g.
> .macro GET_PSR REG, TMP0
>   mov %o0, \TMP
>   __XM_AHC
>   mov %o0, \REG
>   mov \TMP, %o0
> #else
>   rd %psr, \REG
> #endif
> Same for some of the other functions that get used multiple times in
> this file, such as set_psr, set_pil, and clear_pil. Putting these in a
> header file would make them useful in start.S also.
>> diff --git a/c/src/lib/libbsp/sparc/shared/start/start.S b/c/src/lib/libbsp/sparc/shared/start/start.S
>> index 65dd559..158883a 100644
>> --- a/c/src/lib/libbsp/sparc/shared/start/start.S
>> +++ b/c/src/lib/libbsp/sparc/shared/start/start.S
>> @@ -354,12 +397,19 @@ zerobss:
>>          bleu,a zerobss
>>          nop
>> +        mov     %g7, %o0
>> +        call    init_libxm              ! initialize libxm
> Where is this function?
It is a function delivered by XtratuM. It initializes the libxm which
provides high-level access to para-virtualised services.
>> diff --git a/c/src/lib/libbsp/sparc/xtratum/include/irq.h b/c/src/lib/libbsp/sparc/xtratum/include/irq.h
>> new file mode 100644
>> index 0000000..afa99c0
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/xtratum/include/irq.h
>> @@ -0,0 +1,2 @@
>> +#define BSP_INTERRUPT_VECTOR_MIN 0
>> +#define BSP_INTERRUPT_VECTOR_MAX (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
>> diff --git a/c/src/lib/libbsp/sparc/xtratum/include/tm27.h b/c/src/lib/libbsp/sparc/xtratum/include/tm27.h
>> index 0000000..85c4963
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/xtratum/include/tm27.h
>> @@ -0,0 +1,30 @@
>> + *  tm27.h
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + *  http://www.rtems.org/license/LICENSE.
>> +#ifndef _RTEMS_TMTEST27
>> +#error "This is an RTEMS internal file you must not include directly."
>> +#endif
>> +#ifndef __tm27_h
>> +#define __tm27_h
>> +#define TEST_VECTOR SPARC_SYNCHRONOUS_TRAP( 0x90 )
>> +#define MUST_WAIT_FOR_INTERRUPT 1
>> +#define Install_tm27_vector( handler ) \
>> +  set_vector( (handler), TEST_VECTOR, 1 );
>> +#define Cause_tm27_intr() \
>> +  __asm__ volatile( "ta 0x10; nop " );
> I guess this won't actually work?
It did work. The synchronous traps can be nested.
>> diff --git a/c/src/lib/libbsp/sparc/xtratum/irq/irq.c b/c/src/lib/libbsp/sparc/xtratum/irq/irq.c
>> index 0000000..c061f9c
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/xtratum/irq/irq.c
>> @@ -0,0 +1,77 @@
> File needs copyright/license header.
I just forgot it. Sorry for that. I'll add it.
>> diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/bsppredriver.c b/c/src/lib/libbsp/sparc/xtratum/startup/bsppredriver.c
>> index 0000000..f99c528
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/xtratum/startup/bsppredriver.c
>> @@ -0,0 +1,7 @@
> File needs copyright/license header, although I'm not sure why this
> file is included anyway since the hook is empty.
You are right. This file is not longer necessary. It is a relic of my
development process. I'll remove it and use the default one.
>> diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c b/c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c
>> index 0000000..ec80be4
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/xtratum/startup/bspreset.c
>> @@ -0,0 +1,52 @@
>> + * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
>> + *  embedded brains GmbH
>> + *  Dornierstr. 4
>> + *  82178 Puchheim
>> + *  Germany
>> + *  <info at embedded-brains.de>
>> +#include <xm.h>
>> +#include <bsp/bootcard.h>
>> +#ifdef RTEMS_SMP
>> +void bsp_reset(void)
>> +  uint32_t self_cpu = rtems_get_current_processor();
>> +  if (self_cpu == 0) {
>> +    /* Value should give us roughly something in the range of a few
>> +     * milliseconds. */
>> +    uint32_t max_wait = 1234567;
>> +    uint32_t cpu_count = rtems_get_processor_count();
>> +    uint32_t cpus_halted = 0;
>> +    /* Wait some time for secondary processors to halt */
>> +    do {
>> +      xmVirtualCpuStatus_t status;
>> +      cpus_halted = 0;
>> +      uint32_t i;
>> +      for (i=1; i<cpu_count; ++i) {
>> +        XM_get_vcpu_status(i, &status);
>> +        if (status.state == XM_STATUS_HALTED) {
>> +          ++cpus_halted;
>> +      --max_wait;
>> +    } while (cpus_halted < cpu_count - 1 && max_wait > 0);
>> +    XM_halt_partition(XM_PARTITION_SELF);
>> +  } else {
>> +    XM_halt_vcpu(XM_VCPU_SELF);
>> +  while (1);
>> +#endif
> What if it is not RTEMS_SMP?
In this case there is a implementation for singleprocessor systems in
the shared start.S for all sparc-bsps.
>> diff --git a/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c b/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
>> index 0000000..2d4428a
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/xtratum/startup/spurious.c
>> @@ -0,0 +1,35 @@
>> + *  LEON Spurious Trap Handler
>> + *  This is just enough of a trap handler to let us know what
>> + *  the likely source of the trap was.
>> + *  Developed as part of the port of RTEMS to the LEON implementation
>> + *  of the SPARC by On-Line Applications Research Corporation (OAR)
>> + *  under contract to the European Space Agency (ESA).
>> + *  COPYRIGHT (c) 1995. European Space Agency.
>> + *  Modified for LEON3 BSP.
>> + *  COPYRIGHT (c) 2004.
>> + *  Gaisler Research.
>> + *  This terms of the RTEMS license apply to this file.
>> +#include <bsp.h>
>> +#include <rtems/bspIo.h>
>> +void _BSP_Exception_frame_print( const CPU_Exception_frame *frame )
>> +  uint32_t trap;
>> +  uint32_t real_trap;
>> +  const CPU_Interrupt_frame *isf;
>> +  trap = frame->trap;
>> +  real_trap = SPARC_REAL_TRAP_NUMBER(trap);
>> +  isf = frame->isf;
>> +  printk( "Unexpected trap (0x%02x) at address 0x%08x\n", real_trap, isf->tpc);
> I don't think this code will get called ever?
The _BSP_Exception_frame_print of the sparc gets called by the
_CPU_Exception_frame_print. This again is called by
rtems_exception_frame_print which is called i.E. in the
bsp_fatal_extension or in spfatal26-test.
>> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
>> index 216fc59..18a8c96 100644
>> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
>> @@ -975,15 +975,8 @@ extern const CPU_Trap_table_entry _CPU_Trap_slot_template;
>>   * actually provides.  Currently, interrupt levels which do not
>>   * map onto the CPU in a straight fashion are undefined.
>> -#ifdef RTEMS_PARAVIRT
>> -  #define _CPU_ISR_Set_level( _newlevel ) \
>> -     _SPARC_ISR_Set_level( _newlevel << 8)
>> -void _SPARC_ISR_Set_level( uint32_t pil );
>> -#else
>> -     sparc_enable_interrupts( _newlevel << 8)
>> -#endif
>> +#define _CPU_ISR_Set_level( _newlevel ) \
>> +  sparc_enable_interrupts( _newlevel << 8)
>>   * @brief Obtain the current interrupt disable level.
> I don't think this revert is intended?
Sebastian already stumbled across this one.
In the development process, I first separated the Set_level and
enable_interrupts function to optimize the later one. But I had to
change the enable_interrupts due to another bug so that Set_level and
enable_interrupts ended up doing the same thing again.
I'll remove the changes in both patches.
Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
