Initially Locked Priority Ceiling Semaphores
Wed May 21 15:01:59 UTC 2014
On Wed, May 21, 2014 at 10:41 AM, Sebastian Huber
> Hello,
> you can create a Classic API semaphore using the Priority Ceiling Protocol
> which is initially locked by the creating task.  In this case the creating
> task is not elevated to the ceiling priority:
> CORE_mutex_Status _CORE_mutex_Initialize(
>   CORE_mutex_Control           *the_mutex,
>   Thread_Control               *executing,
>   const CORE_mutex_Attributes  *the_mutex_attributes,
>   bool                          initially_locked
> /* Add this to the RTEMS environment later ?????????
>   rtems_assert( initial_lock == CORE_MUTEX_LOCKED ||
>                 initial_lock == CORE_MUTEX_UNLOCKED );
>   the_mutex->Attributes    = *the_mutex_attributes;
>   if ( initially_locked ) {
>     the_mutex->nest_count = 1;
>     the_mutex->holder     = executing;
>     if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ||
>          _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ) {
>       if ( executing->current_priority <
>              the_mutex->Attributes.priority_ceiling )
>        return CORE_MUTEX_STATUS_CEILING_VIOLATED;
Looks like this check ensures the executing thread has got priority at
least at the priority_ceiling. If it does not, the mutex is not
initialized.
-Gedare
> Is this working as intended?
> rtems-devel mailing list
> rtems-devel at rtems.org
