[PATCH v2] score: Multiprocessor Resource Sharing Protocol
Sebastian Huber
Wed May 21 15:14:32 UTC 2014
Add basic support for the Multiprocessor Resource Sharing Protocol
(MrsP).
The Multiprocessor Resource Sharing Protocol (MrsP) is defined in A.
Burns and A.J. Wellings, A Schedulability Compatible Multiprocessor
Resource Sharing Protocol - MrsP, Proceedings of the 25th Euromicro
Conference on Real-Time Systems (ECRTS 2013), July 2013. It is a
generalization of the Priority Ceiling Protocol to SMP systems. Each
MrsP semaphore uses a ceiling priority per scheduler instance. These
ceiling priorities can be specified with rtems_semaphore_set_priority().
A task obtaining or owning a MrsP semaphore will execute with the
ceiling priority for its scheduler instance as specified by the MrsP
semaphore object. Tasks waiting to get ownership of a MrsP semaphore
will not relinquish the processor voluntarily. In case the owner of a
MrsP semaphore gets preempted it can ask all tasks waiting for this
semaphore to help out and temporarily borrow the right to execute on one
of their assigned processors.
The help out feature is not implemented with this patch.
cpukit/rtems/Makefile.am | 1 +
cpukit/rtems/include/rtems/rtems/attr.h | 14 +
cpukit/rtems/include/rtems/rtems/attrimpl.h | 31 ++
cpukit/rtems/include/rtems/rtems/sem.h | 46 +++
cpukit/rtems/include/rtems/rtems/semimpl.h | 9 +
cpukit/rtems/src/semcreate.c | 38 ++-
cpukit/rtems/src/semdelete.c | 21 +-
cpukit/rtems/src/semflush.c | 13 +-
cpukit/rtems/src/semobtain.c | 19 +-
cpukit/rtems/src/semrelease.c | 14 +-
cpukit/rtems/src/semsetpriority.c | 116 +++++++
cpukit/sapi/include/confdefs.h | 14 +-
cpukit/score/Makefile.am | 2 +
cpukit/score/include/rtems/score/mrsp.h | 135 ++++++++
cpukit/score/include/rtems/score/mrspimpl.h | 308 ++++++++++++++++++
cpukit/score/include/rtems/score/schedulerimpl.h | 10 +
cpukit/score/preinstall.am | 8 +
doc/user/Makefile.am | 2 +-
doc/user/conf.t | 32 ++
doc/user/sem.t | 198 +++++++++++-
testsuites/smptests/Makefile.am | 1 +
testsuites/smptests/configure.ac | 1 +
testsuites/smptests/smpmrsp01/Makefile.am | 19 ++
testsuites/smptests/smpmrsp01/init.c | 287 +++++++++++++++++
testsuites/smptests/smpmrsp01/smpmrsp01.doc | 15 +
testsuites/smptests/smpmrsp01/smpmrsp01.scn | 2 +
testsuites/sptests/Makefile.am | 1 +
testsuites/sptests/configure.ac | 1 +
testsuites/sptests/spmrsp01/Makefile.am | 19 ++
testsuites/sptests/spmrsp01/init.c | 374 ++++++++++++++++++++++
testsuites/sptests/spmrsp01/spmrsp01.doc | 13 +
testsuites/sptests/spmrsp01/spmrsp01.scn | 8 +
32 files changed, 1756 insertions(+), 16 deletions(-)
create mode 100644 cpukit/rtems/src/semsetpriority.c
create mode 100644 cpukit/score/include/rtems/score/mrsp.h
create mode 100644 cpukit/score/include/rtems/score/mrspimpl.h
create mode 100644 testsuites/smptests/smpmrsp01/Makefile.am
create mode 100644 testsuites/smptests/smpmrsp01/init.c
create mode 100644 testsuites/smptests/smpmrsp01/smpmrsp01.doc
create mode 100644 testsuites/smptests/smpmrsp01/smpmrsp01.scn
create mode 100644 testsuites/sptests/spmrsp01/Makefile.am
create mode 100644 testsuites/sptests/spmrsp01/init.c
create mode 100644 testsuites/sptests/spmrsp01/spmrsp01.doc
create mode 100644 testsuites/sptests/spmrsp01/spmrsp01.scn
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index 4b84fa1..eb9b16e 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -206,6 +206,7 @@ librtems_a_SOURCES += src/semrelease.c
librtems_a_SOURCES += src/semflush.c
librtems_a_SOURCES += src/semtranslatereturncode.c
librtems_a_SOURCES += src/semdata.c
+librtems_a_SOURCES += src/semsetpriority.c
## EVENT_C_FILES
librtems_a_SOURCES += src/event.c
diff --git a/cpukit/rtems/include/rtems/rtems/attr.h b/cpukit/rtems/include/rtems/rtems/attr.h
index d326539..7e8fa48 100644
--- a/cpukit/rtems/include/rtems/rtems/attr.h
+++ b/cpukit/rtems/include/rtems/rtems/attr.h
@@ -139,6 +139,20 @@ typedef uint32_t rtems_attribute;
#define RTEMS_PRIORITY_CEILING 0x00000080
+ * This attribute constant indicates that the Classic API Semaphore instance
+ * created will NOT use the Multiprocessor Resource Sharing Protocol.
+#define RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING 0x00000000
+ * created will use the Multiprocessor Resource Sharing Protocol.
+ * @note The semaphore instance must be a binary semaphore.
+#define RTEMS_MULTIPROCESSOR_RESOURCE_SHARING 0x00000100
/******************** RTEMS Barrier Specific Attributes ********************/
diff --git a/cpukit/rtems/include/rtems/rtems/attrimpl.h b/cpukit/rtems/include/rtems/rtems/attrimpl.h
index 0f78c44..a32c370 100644
--- a/cpukit/rtems/include/rtems/rtems/attrimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/attrimpl.h
@@ -185,6 +185,23 @@ RTEMS_INLINE_ROUTINE bool _Attributes_Is_inherit_priority(
+ * @brief Returns true if the attribute set has at most one protocol, and false
+ * otherwise.
+ * The protocols are RTEMS_INHERIT_PRIORITY, RTEMS_PRIORITY_CEILING and
+ * RTEMS_MULTIPROCESSOR_RESOURCE_SHARING.
+RTEMS_INLINE_ROUTINE bool _Attributes_Has_at_most_one_protocol(
+ rtems_attribute attribute_set
+ attribute_set &= RTEMS_INHERIT_PRIORITY | RTEMS_PRIORITY_CEILING
+ | RTEMS_MULTIPROCESSOR_RESOURCE_SHARING;
+ return ( attribute_set & ( attribute_set - 1 ) ) == 0;
* @brief Checks if the priority ceiling attribute
* is enabled in the attribute_set
@@ -199,6 +216,20 @@ RTEMS_INLINE_ROUTINE bool _Attributes_Is_priority_ceiling(
+ * @brief Checks if the Multiprocessor Resource Sharing Protocol attribute
+ * is enabled in the attribute_set
+ * This function returns TRUE if the Multiprocessor Resource Sharing Protocol
+ * attribute is enabled in the attribute_set and FALSE otherwise.
+RTEMS_INLINE_ROUTINE bool _Attributes_Is_multiprocessor_resource_sharing(
+ return ( attribute_set & RTEMS_MULTIPROCESSOR_RESOURCE_SHARING ) != 0;
* @brief Checks if the barrier automatic release
diff --git a/cpukit/rtems/include/rtems/rtems/sem.h b/cpukit/rtems/include/rtems/rtems/sem.h
index 782314d..2442010 100644
--- a/cpukit/rtems/include/rtems/rtems/sem.h
+++ b/cpukit/rtems/include/rtems/rtems/sem.h
@@ -38,6 +38,7 @@
#include <rtems/score/coremutex.h>
#include <rtems/score/coresem.h>
+#include <rtems/score/mrsp.h>
#ifdef __cplusplus
extern "C" {
@@ -88,6 +89,10 @@ typedef struct {
* API Semaphore instance.
CORE_semaphore_Control semaphore;
+#if defined(RTEMS_SMP)
+ MRSP_Control mrsp;
+#endif
} Core_control;
} Semaphore_Control;
@@ -208,6 +213,47 @@ rtems_status_code rtems_semaphore_flush(
rtems_id id
+ * @brief Sets the priority value with respect to the specified scheduler of a
+ * semaphore.
+ * The special priority value @ref RTEMS_CURRENT_PRIORITY can be used to get
+ * the current priority value without changing it.
+ * The interpretation of the priority value depends on the protocol of the
+ * semaphore object.
+ * - The Multiprocessor Resource Sharing Protocol needs a ceiling priority per
+ * scheduler instance. This operation can be used to specify these priority
+ * values.
+ * - For the Priority Ceiling Protocol the ceiling priority is used with this
+ * operation.
+ * - For other protocols this operation is not defined.
+ * @param[in] semaphore_id Identifier of the semaphore.
+ * @param[in] scheduler_id Identifier of the scheduler.
+ * @param[in] new_priority The new priority value. Use
+ * @ref RTEMS_CURRENT_PRIORITY to not set a new priority and only get the
+ * current priority.
+ * @param[out] old_priority Reference to store the old priority value.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_ID Invalid semaphore or scheduler identifier.
+ * @retval RTEMS_INVALID_ADDRESS The old priority reference is @c NULL.
+ * @retval RTEMS_INVALID_PRIORITY The new priority value is invalid.
+ * @retval RTEMS_NOT_DEFINED The set priority operation is not defined for the
+ * protocol of this semaphore object.
+ * @retval RTEMS_ILLEGAL_ON_REMOTE_OBJECT Not supported for remote semaphores.
+ * @see rtems_scheduler_ident() and rtems_task_set_priority().
+rtems_status_code rtems_semaphore_set_priority(
+ rtems_id semaphore_id,
+ rtems_id scheduler_id,
+ rtems_task_priority new_priority,
+ rtems_task_priority *old_priority
#ifdef __cplusplus
diff --git a/cpukit/rtems/include/rtems/rtems/semimpl.h b/cpukit/rtems/include/rtems/rtems/semimpl.h
index 51da4cd..e0a35a2 100644
--- a/cpukit/rtems/include/rtems/rtems/semimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/semimpl.h
@@ -20,6 +20,7 @@
#include <rtems/rtems/sem.h>
#include <rtems/score/coresemimpl.h>
+#include <rtems/score/mrspimpl.h>
#ifdef __cplusplus
extern "C" {
@@ -92,6 +93,14 @@ _Semaphore_Translate_core_mutex_return_code(
return _Semaphore_Translate_core_mutex_return_code_[status];
+RTEMS_INLINE_ROUTINE rtems_status_code
+_Semaphore_Translate_MRSP_status_code( MRSP_Status mrsp_status )
+ return (rtems_status_code) mrsp_status;
+#endif
* @brief Semaphore Translate Core Semaphore Return Code
diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
index fb597d1..5e93e02 100644
--- a/cpukit/rtems/src/semcreate.c
+++ b/cpukit/rtems/src/semcreate.c
@@ -78,12 +78,19 @@ rtems_status_code rtems_semaphore_create(
return RTEMS_MP_NOT_CONFIGURED;
if ( _Attributes_Is_inherit_priority( attribute_set ) ||
- _Attributes_Is_priority_ceiling( attribute_set ) )
+ _Attributes_Is_priority_ceiling( attribute_set ) ||
+ _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) )
return RTEMS_NOT_DEFINED;
} else
#endif
+ if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) &&
+ !( _Attributes_Is_binary_semaphore( attribute_set ) &&
+ !_Attributes_Is_priority( attribute_set ) ) ) {
+ return RTEMS_NOT_DEFINED;
_Attributes_Is_priority_ceiling( attribute_set ) ) {
@@ -93,13 +100,22 @@ rtems_status_code rtems_semaphore_create(
- if ( _Attributes_Is_inherit_priority( attribute_set ) &&
+ if ( !_Attributes_Has_at_most_one_protocol( attribute_set ) )
if ( !_Attributes_Is_counting_semaphore( attribute_set ) && ( count > 1 ) )
return RTEMS_INVALID_NUMBER;
+#if !defined(RTEMS_SMP)
+ * On uni-processor configurations the Multiprocessor Resource Sharing
+ * Protocol is equivalent to the Priority Ceiling Protocol.
+ if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) ) {
+ attribute_set |= RTEMS_PRIORITY_CEILING | RTEMS_PRIORITY;
+#endif
the_semaphore = _Semaphore_Allocate();
if ( !the_semaphore ) {
@@ -144,6 +160,22 @@ rtems_status_code rtems_semaphore_create(
&the_semaphore_attr,
count
+ } else if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) ) {
+ MRSP_Status mrsp_status = _MRSP_Initialize(
+ &the_semaphore->Core_control.mrsp,
+ priority_ceiling,
+ _Thread_Get_executing(),
+ count != 1
+ if ( mrsp_status != MRSP_SUCCESSFUL ) {
+ _Semaphore_Free( the_semaphore );
+ _Objects_Allocator_unlock();
+ return _Semaphore_Translate_MRSP_status_code( mrsp_status );
+#endif
} else {
* It is either simple binary semaphore or a more powerful mutex
diff --git a/cpukit/rtems/src/semdelete.c b/cpukit/rtems/src/semdelete.c
index 6e7c5ea..52bb14e 100644
--- a/cpukit/rtems/src/semdelete.c
+++ b/cpukit/rtems/src/semdelete.c
@@ -43,6 +43,7 @@ rtems_status_code rtems_semaphore_delete(
Semaphore_Control *the_semaphore;
Objects_Locations location;
+ rtems_attribute attribute_set;
_Objects_Allocator_lock();
@@ -50,10 +51,22 @@ rtems_status_code rtems_semaphore_delete(
switch ( location ) {
case OBJECTS_LOCAL:
- if ( !_Attributes_Is_counting_semaphore(the_semaphore->attribute_set) ) {
+ attribute_set = the_semaphore->attribute_set;
+ MRSP_Status mrsp_status = _MRSP_Destroy(
+ _Objects_Put( &the_semaphore->Object );
+ } else
+#endif
+ if ( !_Attributes_Is_counting_semaphore( attribute_set ) ) {
if ( _CORE_mutex_Is_locked( &the_semaphore->Core_control.mutex ) &&
- !_Attributes_Is_simple_binary_semaphore(
- the_semaphore->attribute_set ) ) {
+ !_Attributes_Is_simple_binary_semaphore( attribute_set ) ) {
return RTEMS_RESOURCE_IN_USE;
@@ -74,7 +87,7 @@ rtems_status_code rtems_semaphore_delete(
_Objects_Close( &_Semaphore_Information, &the_semaphore->Object );
#if defined(RTEMS_MULTIPROCESSING)
- if ( _Attributes_Is_global( the_semaphore->attribute_set ) ) {
+ if ( _Attributes_Is_global( attribute_set ) ) {
_Objects_MP_Close( &_Semaphore_Information, the_semaphore->Object.id );
diff --git a/cpukit/rtems/src/semflush.c b/cpukit/rtems/src/semflush.c
index f73c929..0981569 100644
--- a/cpukit/rtems/src/semflush.c
+++ b/cpukit/rtems/src/semflush.c
@@ -43,12 +43,23 @@ rtems_status_code rtems_semaphore_flush(
the_semaphore = _Semaphore_Get( id, &location );
case OBJECTS_LOCAL:
+ * On uni-processor configurations the Priority Ceiling Protocol is
+ * used in case MrsP is selected. Since MrsP will not support the
+ * flush operation we have to issue an error here unconditionally to be
+ * consistent.
+ } else if ( !_Attributes_Is_counting_semaphore( attribute_set ) ) {
_CORE_mutex_Flush(
&the_semaphore->Core_control.mutex,
SEND_OBJECT_WAS_DELETED,
diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
index c9433ca..3608a00 100644
--- a/cpukit/rtems/src/semobtain.c
+++ b/cpukit/rtems/src/semobtain.c
@@ -41,6 +41,7 @@ rtems_status_code rtems_semaphore_obtain(
ISR_Level level;
Thread_Control *executing;
bool wait;
the_semaphore = _Semaphore_Get_interrupt_disable( id, &location, &level );
@@ -48,8 +49,24 @@ rtems_status_code rtems_semaphore_obtain(
case OBJECTS_LOCAL:
executing = _Thread_Executing;
wait = !_Options_Is_no_wait( option_set );
+ MRSP_Status mrsp_status;
+ _ISR_Enable( level );
+ mrsp_status = _MRSP_Obtain(
+ executing,
+ wait,
+ timeout
+ _Objects_Put_for_get_isr_disable( &the_semaphore->Object );
+ } else
+#endif
_CORE_mutex_Seize(
executing,
diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
index ff4e792..2c4be04 100644
--- a/cpukit/rtems/src/semrelease.c
+++ b/cpukit/rtems/src/semrelease.c
@@ -73,12 +73,24 @@ rtems_status_code rtems_semaphore_release(
CORE_mutex_Status mutex_status;
CORE_semaphore_Status semaphore_status;
case OBJECTS_LOCAL:
+ MRSP_Status mrsp_status = _MRSP_Release(
+ } else
+#endif
mutex_status = _CORE_mutex_Surrender(
id,
diff --git a/cpukit/rtems/src/semsetpriority.c b/cpukit/rtems/src/semsetpriority.c
new file mode 100644
index 0000000..bb3a688
--- /dev/null
+++ b/cpukit/rtems/src/semsetpriority.c
@@ -0,0 +1,116 @@
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/rtems/semimpl.h>
+#include <rtems/rtems/attrimpl.h>
+#include <rtems/rtems/tasksimpl.h>
+#include <rtems/score/schedulerimpl.h>
+static rtems_status_code _Semaphore_Set_priorities(
+ Semaphore_Control *the_semaphore,
+ rtems_task_priority *old_priority_p
+ rtems_status_code sc;
+ rtems_attribute attribute_set = the_semaphore->attribute_set;
+ rtems_task_priority old_priority;
+ new_priority = _RTEMS_tasks_Priority_to_Core( new_priority );
+ MRSP_Control *mrsp = &the_semaphore->Core_control.mrsp;
+ uint32_t scheduler_index = _Scheduler_Get_index_by_id( scheduler_id );
+ old_priority = _MRSP_Get_ceiling_priority( mrsp, scheduler_index );
+ if ( new_priority != RTEMS_CURRENT_PRIORITY ) {
+ _MRSP_Set_ceiling_priority( mrsp, scheduler_index, new_priority );
+ sc = RTEMS_SUCCESSFUL;
+ } else
+#endif
+ if ( _Attributes_Is_priority_ceiling( attribute_set ) ) {
+ CORE_mutex_Control *mutex = &the_semaphore->Core_control.mutex;
+ old_priority = mutex->Attributes.priority_ceiling;
+ mutex->Attributes.priority_ceiling = new_priority;
+ } else {
+ old_priority = 0;
+ sc = RTEMS_NOT_DEFINED;
+ *old_priority_p = _RTEMS_tasks_Priority_from_Core( old_priority );
+ return sc;
+ Semaphore_Control *the_semaphore;
+ Objects_Locations location;
+ if ( new_priority != RTEMS_CURRENT_PRIORITY &&
+ !_RTEMS_tasks_Priority_is_valid( new_priority ) ) {
+ return RTEMS_INVALID_PRIORITY;
+ if ( old_priority == NULL ) {
+ return RTEMS_INVALID_ADDRESS;
+ if ( !_Scheduler_Is_id_valid( scheduler_id ) ) {
+ return RTEMS_INVALID_ID;
+ the_semaphore = _Semaphore_Get( semaphore_id, &location );
+ switch ( location ) {
+ case OBJECTS_LOCAL:
+ return _Semaphore_Set_priorities(
+ the_semaphore,
+ scheduler_id,
+ new_priority,
+ old_priority
+#if defined(RTEMS_MULTIPROCESSING)
+ case OBJECTS_REMOTE:
+ _Thread_Dispatch();
+ return RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
+#endif
+ case OBJECTS_ERROR:
+ break;
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 1c97d15..6978277 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -1792,6 +1792,17 @@ const rtems_libio_helper rtems_fs_init_helper =
CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS + \
CONFIGURE_NETWORKING_SEMAPHORES)
+ #if !defined(RTEMS_SMP) || \
+ !defined(CONFIGURE_MAXIMUM_MRSP_SEMAPHORES)
+ #define CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES 0
+ #else
+ #define CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES \
+ CONFIGURE_MAXIMUM_MRSP_SEMAPHORES * \
+ _Configure_From_workspace( \
+ RTEMS_ARRAY_SIZE(_Scheduler_Table) * sizeof(Priority_Control) \
+ #endif
* If there are no user or support semaphores defined, then we can assume
* that no memory need be allocated at all for semaphores.
@@ -1800,7 +1811,8 @@ const rtems_libio_helper rtems_fs_init_helper =
#define CONFIGURE_MEMORY_FOR_SEMAPHORES(_semaphores) 0
#else
#define CONFIGURE_MEMORY_FOR_SEMAPHORES(_semaphores) \
- _Configure_Object_RAM(_semaphores, sizeof(Semaphore_Control) )
+ _Configure_Object_RAM(_semaphores, sizeof(Semaphore_Control) ) + \
+ CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES
#endif
#ifndef CONFIGURE_MAXIMUM_MESSAGE_QUEUES
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 7c426025..b9a9f28 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -39,6 +39,8 @@ include_rtems_score_HEADERS += include/rtems/score/isr.h
include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
include_rtems_score_HEADERS += include/rtems/score/isrlock.h
include_rtems_score_HEADERS += include/rtems/score/freechain.h
+include_rtems_score_HEADERS += include/rtems/score/mrsp.h
+include_rtems_score_HEADERS += include/rtems/score/mrspimpl.h
include_rtems_score_HEADERS += include/rtems/score/object.h
include_rtems_score_HEADERS += include/rtems/score/objectimpl.h
include_rtems_score_HEADERS += include/rtems/score/onceimpl.h
diff --git a/cpukit/score/include/rtems/score/mrsp.h b/cpukit/score/include/rtems/score/mrsp.h
index 0000000..66b77a7
--- /dev/null
+++ b/cpukit/score/include/rtems/score/mrsp.h
@@ -0,0 +1,135 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#ifndef _RTEMS_SCORE_MRSP_H
+#define _RTEMS_SCORE_MRSP_H
+#include <rtems/score/cpuopts.h>
+#include <rtems/score/atomic.h>
+#include <rtems/score/chain.h>
+#include <rtems/score/scheduler.h>
+#include <rtems/score/thread.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup ScoreMRSP Multiprocessor Resource Sharing Protocol Handler
+ * @ingroup Score
+ * @brief Multiprocessor Resource Sharing Protocol (MrsP).
+ * The Multiprocessor Resource Sharing Protocol (MrsP) is defined in A. Burns
+ * and A.J. Wellings, A Schedulability Compatible Multiprocessor Resource
+ * Sharing Protocol - MrsP, Proceedings of the 25th Euromicro Conference on
+ * Real-Time Systems (ECRTS 2013), July 2013. It is a generalization of the
+ * Priority Ceiling Protocol to SMP systems. Each MrsP semaphore uses a
+ * ceiling priority per scheduler instance. A task obtaining or owning a MrsP
+ * semaphore will execute with the ceiling priority for its scheduler instance
+ * as specified by the MrsP semaphore object. Tasks waiting to get ownership
+ * of a MrsP semaphore will not relinquish the processor voluntarily. In case
+ * the owner of a MrsP semaphore gets preempted it can ask all tasks waiting
+ * for this semaphore to help out and temporarily borrow the right to execute
+ * on one of their assigned processors.
+ * @brief MRSP status code.
+ * The values are chosen to directly map to RTEMS status codes. In case this
+ * implementation is used for other APIs, then for example the errno values can
+ * be added with a bit shift.
+typedef enum {
+ MRSP_SUCCESSFUL = 0,
+ MRSP_TIMEOUT = 6,
+ MRSP_RESOUCE_IN_USE = 12,
+ MRSP_UNSATISFIED = 13,
+ MRSP_INVALID_PRIORITY = 19,
+ MRSP_NOT_OWNER_OF_RESOURCE = 23,
+ MRSP_NO_MEMORY = 26
+} MRSP_Status;
+ * @brief MRSP rival.
+ * The rivals are used by threads waiting for resource ownership. They are
+ * registered in the MRSP control block.
+typedef struct {
+ * @brief The node for registration in the MRSP rival chain.
+ Chain_Node Node;
+ * @brief Identification of the rival thread.
+ Thread_Control *thread;
+ * @brief The rival state.
+ * Initially no state bits are set (MRSP_RIVAL_STATE_WAITING). The rival
+ * will busy wait until a state change happens. This can be
+ * MRSP_RIVAL_STATE_NEW_OWNER or MRSP_RIVAL_STATE_TIMEOUT.
+ Atomic_Uint state;
+} MRSP_Rival;
+ * @brief MrsP control block.
+typedef struct {
+ * @brief The owner of the MRSP resource.
+ * In case this field is @c NULL, then this MRSP resource has currently no
+ * owner.
+ Thread_Control *owner;
+ * @brief The nest count in case this MRSP resource has been obtained
+ * recursively.
+ uint32_t nest_count;
+ * @brief A chain of rivals waiting for resource ownership.
+ Chain_Control Rivals;
+ * @brief One ceiling priority per scheduler instance.
+ Priority_Control *ceiling_priorities;
+} MRSP_Control;
+#ifdef __cplusplus
+#endif /* RTEMS_SMP */
+#endif /* _RTEMS_SCORE_MRSP_H */
diff --git a/cpukit/score/include/rtems/score/mrspimpl.h b/cpukit/score/include/rtems/score/mrspimpl.h
index 0000000..503d40c
--- /dev/null
+++ b/cpukit/score/include/rtems/score/mrspimpl.h
@@ -0,0 +1,308 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#ifndef _RTEMS_SCORE_MRSPIMPL_H
+#define _RTEMS_SCORE_MRSPIMPL_H
+#include <rtems/score/assert.h>
+#include <rtems/score/chainimpl.h>
+#include <rtems/score/watchdogimpl.h>
+#include <rtems/score/wkspace.h>
+#ifdef __cplusplus
+extern "C" {
+ * @addtogroup ScoreMRSP
+#define MRSP_RIVAL_STATE_WAITING 0x0U
+#define MRSP_RIVAL_STATE_NEW_OWNER 0x1U
+#define MRSP_RIVAL_STATE_TIMEOUT 0x2U
+RTEMS_INLINE_ROUTINE void _MRSP_Claim_ownership(
+ MRSP_Control *mrsp,
+ Thread_Control *new_owner,
+ Priority_Control ceiling_priority
+ ++new_owner->resource_count;
+ mrsp->owner = new_owner;
+ mrsp->nest_count = 1;
+ _Thread_Change_priority( new_owner, ceiling_priority, false );
+RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Initialize(
+ Priority_Control ceiling_priority,
+ Thread_Control *executing,
+ bool initially_locked
+ uint32_t scheduler_count = _Scheduler_Count;
+ uint32_t i;
+ if ( initially_locked ) {
+ bool priority_ok = !_Scheduler_Is_priority_higher_than(
+ _Scheduler_Get( executing ),
+ executing->current_priority,
+ ceiling_priority
+ if ( !priority_ok ) {
+ return MRSP_INVALID_PRIORITY;
+ mrsp->ceiling_priorities = _Workspace_Allocate(
+ sizeof( *mrsp->ceiling_priorities ) * scheduler_count
+ if ( mrsp->ceiling_priorities == NULL ) {
+ return MRSP_NO_MEMORY;
+ for ( i = 0 ; i < scheduler_count ; ++i ) {
+ mrsp->ceiling_priorities[ i ] = ceiling_priority;
+ _Chain_Initialize_empty( &mrsp->Rivals );
+ _Thread_Disable_dispatch();
+ _MRSP_Claim_ownership( mrsp, executing, ceiling_priority );
+ _Thread_Enable_dispatch();
+ } else {
+ mrsp->owner = NULL;
+ mrsp->nest_count = 0;
+ return MRSP_SUCCESSFUL;
+RTEMS_INLINE_ROUTINE Priority_Control _MRSP_Get_ceiling_priority(
+ return mrsp->ceiling_priorities[ scheduler_index ];
+RTEMS_INLINE_ROUTINE void _MRSP_Set_ceiling_priority(
+ uint32_t scheduler_index,
+ mrsp->ceiling_priorities[ scheduler_index ] = ceiling_priority;
+RTEMS_INLINE_ROUTINE void _MRSP_Restore_priority( Thread_Control *thread )
+ _Thread_Change_priority( thread, thread->real_priority, true );
+RTEMS_INLINE_ROUTINE void _MRSP_Add_state(
+ MRSP_Rival *rival,
+ unsigned int state
+ _Atomic_Fetch_or_uint( &rival->state, state, ATOMIC_ORDER_RELEASE );
+RTEMS_INLINE_ROUTINE void _MRSP_Timeout(
+ Objects_Id id,
+ void *arg
+ MRSP_Rival *rival = arg;
+ (void) id;
+ _MRSP_Add_state( rival, MRSP_RIVAL_STATE_TIMEOUT );
+RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
+ Watchdog_Interval timeout
+ MRSP_Status status;
+ MRSP_Rival rival;
+ bool previous_life_protection;
+ unsigned int state;
+ _Thread_Change_priority( executing, ceiling_priority, false );
+ rival.thread = executing;
+ _Atomic_Init_uint( &rival.state, MRSP_RIVAL_STATE_WAITING );
+ _Chain_Append_unprotected( &mrsp->Rivals, &rival.Node );
+ if ( timeout > 0 ) {
+ _Watchdog_Initialize(
+ &executing->Timer,
+ _MRSP_Timeout,
+ 0,
+ &rival
+ _Watchdog_Insert_ticks( &executing->Timer, timeout );
+ previous_life_protection = _Thread_Set_life_protection( true );
+ _Assert( _Debug_Is_thread_dispatching_allowed() );
+ while (
+ _Atomic_Load_uint( &rival.state, ATOMIC_ORDER_ACQUIRE )
+ == MRSP_RIVAL_STATE_WAITING
+ /* Wait for state change */
+ _Thread_Set_life_protection( previous_life_protection );
+ _Watchdog_Remove( &executing->Timer );
+ _Chain_Extract_unprotected( &rival.Node );
+ state = _Atomic_Load_uint( &rival.state, ATOMIC_ORDER_RELAXED );
+ if ( ( state & MRSP_RIVAL_STATE_NEW_OWNER ) != 0 ) {
+ ++executing->resource_count;
+ status = MRSP_SUCCESSFUL;
+ } else {
+ if ( executing->resource_count == 0 ) {
+ _MRSP_Restore_priority( executing );
+ status = MRSP_TIMEOUT;
+ return status;
+RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Obtain(
+ bool wait,
+ const Scheduler_Control *scheduler = _Scheduler_Get( executing );
+ uint32_t scheduler_index = _Scheduler_Get_index( scheduler );
+ Priority_Control ceiling_priority =
+ _MRSP_Get_ceiling_priority( mrsp, scheduler_index );
+ scheduler,
+ ceiling_priority
+ if ( !priority_ok) {
+ if ( mrsp->owner == NULL ) {
+ } else if ( mrsp->owner == executing ) {
+ ++mrsp->nest_count;
+ } else if ( wait ) {
+ status = _MRSP_Wait_for_ownership(
+ mrsp,
+ executing,
+ ceiling_priority,
+ timeout
+ } else {
+ status = MRSP_UNSATISFIED;
+ return status;
+RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Release(
+ uint32_t nest_count = mrsp->nest_count;
+ if ( mrsp->owner != executing ) {
+ return MRSP_NOT_OWNER_OF_RESOURCE;
+ if ( nest_count == 1 ) {
+ uint32_t resource_count = executing->resource_count;
+ MRSP_Rival *rival;
+ if ( resource_count == 1 ) {
+ executing->resource_count = 0;
+ } else {
+ executing->resource_count = resource_count - 1;
+ rival = (MRSP_Rival *) _Chain_Get_unprotected( &mrsp->Rivals );
+ if ( rival == NULL ) {
+ } else {
+ mrsp->owner = rival->thread;
+ _MRSP_Add_state( rival, MRSP_RIVAL_STATE_NEW_OWNER );
+ } else {
+ mrsp->nest_count = nest_count - 1;
+RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Destroy( MRSP_Control *mrsp )
+ if ( mrsp->owner != NULL ) {
+ return MRSP_RESOUCE_IN_USE;
+ _Workspace_Free( mrsp->ceiling_priorities );
+#ifdef __cplusplus
+#endif /* _RTEMS_SCORE_MRSPIMPL_H */
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index 15a4207..be84164 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -617,6 +617,16 @@ RTEMS_INLINE_ROUTINE bool _Scheduler_Get_by_id(
&& _Scheduler_Get_processor_count( scheduler ) > 0;
+RTEMS_INLINE_ROUTINE bool _Scheduler_Is_id_valid( Objects_Id id )
+ const Scheduler_Control *scheduler;
+ bool ok = _Scheduler_Get_by_id( id, &scheduler );
+ (void) scheduler;
+ return ok;
RTEMS_INLINE_ROUTINE uint32_t _Scheduler_Get_index(
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index d00e137..45a0ce7 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -139,6 +139,14 @@ $(PROJECT_INCLUDE)/rtems/score/freechain.h: include/rtems/score/freechain.h $(PR
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/freechain.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/freechain.h
+$(PROJECT_INCLUDE)/rtems/score/mrsp.h: include/rtems/score/mrsp.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mrsp.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mrsp.h
+$(PROJECT_INCLUDE)/rtems/score/mrspimpl.h: include/rtems/score/mrspimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mrspimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mrspimpl.h
$(PROJECT_INCLUDE)/rtems/score/object.h: include/rtems/score/object.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/object.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/object.h
diff --git a/doc/user/Makefile.am b/doc/user/Makefile.am
index ef91a41..e774319 100644
--- a/doc/user/Makefile.am
+++ b/doc/user/Makefile.am
@@ -96,7 +96,7 @@ sem.texi: sem.t
-n "Barrier Manager" < $< > $@
barrier.texi: barrier.t
- $(BMENU2) -p "Semaphore Manager SEMAPHORE_FLUSH - Unblock all tasks waiting on a semaphore" \
+ $(BMENU2) -p "Semaphore Manager SEMAPHORE_SET_PRIORITY - Set priority by scheduler for a semaphore" \
-u "Top" \
-n "Message Manager" < $< > $@
diff --git a/doc/user/conf.t b/doc/user/conf.t
index b518176..d72ff06 100644
--- a/doc/user/conf.t
+++ b/doc/user/conf.t
@@ -686,6 +686,38 @@ API Semaphores that can be concurrently active.
This object class can be configured in unlimited allocation mode.
@c
+ at c === CONFIGURE_MAXIMUM_MRSP_SEMAPHORES ===
+ at c
+ at subsection Specify Maximum Classic API Semaphores usable with MrsP
+ at findex CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_MAXIMUM_MRSP_SEMAPHORES}
+ at item DATA TYPE:
+Unsigned integer (@code{uint32_t}).
+ at item RANGE:
+Zero or positive.
+ at item DEFAULT VALUE:
+The default value is 0.
+ at end table
+ at subheading DESCRIPTION:
+ at code{CONFIGURE_MAXIMUM_MRSP_SEMAPHORES} is the
+maximum number of Classic API Semaphores using the Multiprocessor Resource
+Sharing Protocol (MrsP) that can be concurrently active.
+ at subheading NOTES:
+This configuration option is only used on SMP configurations. On uni-processor
+configurations the Priority Ceiling Protocol is used for MrsP semaphores and
+thus no extra memory is necessary.
+ at c
@c === CONFIGURE_MAXIMUM_MESSAGE_QUEUES ===
@c
@subsection Specify Maximum Classic API Message Queues
diff --git a/doc/user/sem.t b/doc/user/sem.t
index 9c38052..700886a 100644
--- a/doc/user/sem.t
+++ b/doc/user/sem.t
@@ -24,6 +24,8 @@ semaphore manager are:
@item @code{@value{DIRPREFIX}semaphore_obtain} - Acquire a semaphore
@item @code{@value{DIRPREFIX}semaphore_release} - Release a semaphore
@item @code{@value{DIRPREFIX}semaphore_flush} - Unblock all tasks waiting on a semaphore
+ at item @code{@value{DIRPREFIX}semaphore_set_priority} - Set priority by
+scheduler for a semaphore
@end itemize
@section Background
@@ -173,6 +175,22 @@ any of the semaphores the task holds. Only when the task
releases ALL of the binary semaphores it holds will its priority
be restored to the normal value.
+ at subsection Multiprocessor Resource Sharing Protocol
+The Multiprocessor Resource Sharing Protocol (MrsP) is defined in @cite{A.
+Burns and A.J. Wellings, A Schedulability Compatible Multiprocessor Resource
+Sharing Protocol - MrsP, Proceedings of the 25th Euromicro Conference on
+Real-Time Systems (ECRTS 2013), July 2013}. It is a generalization of the
+Priority Ceiling Protocol to SMP systems. Each MrsP semaphore uses a ceiling
+priority per scheduler instance. These ceiling priorities can be specified
+with @code{rtems_semaphore_set_priority()}. A task obtaining or owning a MrsP
+semaphore will execute with the ceiling priority for its scheduler instance as
+specified by the MrsP semaphore object. Tasks waiting to get ownership of a
+MrsP semaphore will not relinquish the processor voluntarily. In case the
+owner of a MrsP semaphore gets preempted it can ask all tasks waiting for this
+semaphore to help out and temporarily borrow the right to execute on one of
+their assigned processors.
@subsection Building a Semaphore Attribute Set
In general, an attribute set is built by a bitwise OR
@@ -198,11 +216,17 @@ inheritance (default)
@item @code{@value{RPREFIX}INHERIT_PRIORITY} - use priority inheritance
- at item @code{@value{RPREFIX}PRIORITY_CEILING} - use priority ceiling
@item @code{@value{RPREFIX}NO_PRIORITY_CEILING} - do not use priority
ceiling (default)
+ at item @code{@value{RPREFIX}PRIORITY_CEILING} - use priority ceiling
+ at item @code{@value{RPREFIX}NO_MULTIPROCESSOR_RESOURCE_SHARING} - do not use
+Multiprocessor Resource Sharing Protocol (default)
+ at item @code{@value{RPREFIX}MULTIPROCESSOR_RESOURCE_SHARING} - use
@item @code{@value{RPREFIX}LOCAL} - local semaphore (default)
@item @code{@value{RPREFIX}GLOBAL} - global semaphore
@@ -489,11 +513,17 @@ inheritance (default)
ceiling (default)
@@ -858,4 +888,164 @@ If the task to be unblocked resides on a different
node from the semaphore, then the waiting task is
unblocked, and the proxy used to represent the task is reclaimed.
+ at c
+ at c
+ at c
+ at page
+ at subsection SEMAPHORE_SET_PRIORITY - Set priority by scheduler for a semaphore
+ at cindex set priority by scheduler for a semaphore
+ at subheading CALLING SEQUENCE:
+ at ifset is-C
+ at findex rtems_semaphore_set_priority
+ at example
+ at end example
+ at end ifset
+ at subheading DIRECTIVE STATUS CODES:
+ at code{@value{RPREFIX}SUCCESSFUL} - successful operation@*
+ at code{@value{RPREFIX}INVALID_ID} - invalid semaphore or scheduler id@*
+ at code{@value{RPREFIX}INVALID_ADDRESS} - @code{old_priority} is NULL@*
+ at code{@value{RPREFIX}INVALID_PRIORITY} - invalid new priority value@*
+ at code{@value{RPREFIX}NOT_DEFINED} - operation not defined for the protocol of
+the semaphore@*
+ at code{@value{RPREFIX}ILLEGAL_ON_REMOTE_OBJECT} - not supported for remote semaphores
+This directive sets the priority value with respect to the specified scheduler
+of a semaphore.
+The special priority value @code{RTEMS_CURRENT_PRIORITY} can be used to get the
+current priority value without changing it.
+The interpretation of the priority value depends on the protocol of the
+semaphore object.
+ at itemize @bullet
+ at item The Multiprocessor Resource Sharing Protocol needs a ceiling priority per
+scheduler instance. This operation can be used to specify these priority
+values.
+ at item For the Priority Ceiling Protocol the ceiling priority is used with this
+operation.
+ at item For other protocols this operation is not defined.
+ at end itemize
+ at subheading EXAMPLE:
+ at example
+ at group
+#include <assert.h>
+#include <stdlib.h>
+#include <rtems.h>
+#define SCHED_A rtems_build_name(' ', ' ', ' ', 'A')
+#define SCHED_B rtems_build_name(' ', ' ', ' ', 'B')
+static void Init(rtems_task_argument arg)
+ rtems_id semaphore_id;
+ rtems_id scheduler_a_id;
+ rtems_id scheduler_b_id;
+ rtems_task_priority prio;
+ /* Get the scheduler identifiers */
+ sc = rtems_scheduler_ident(SCHED_A, &scheduler_a_id);
+ assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_scheduler_ident(SCHED_B, &scheduler_b_id);
+ /* Create a MrsP semaphore object */
+ sc = rtems_semaphore_create(
+ rtems_build_name('M', 'R', 'S', 'P'),
+ 1,
+ RTEMS_MULTIPROCESSOR_RESOURCE_SHARING
+ | RTEMS_BINARY_SEMAPHORE,
+ 1,
+ &semaphore_id
+ * The ceiling priority values per scheduler are equal to the value specified
+ * for object creation.
+ prio = RTEMS_CURRENT_PRIORITY;
+ sc = rtems_semaphore_set_priority(semaphore_id, scheduler_a_id, prio, &prio);
+ assert(prio == 1);
+ /* Check the old value and set a new ceiling priority for scheduler B */
+ prio = 2;
+ sc = rtems_semaphore_set_priority(semaphore_id, scheduler_b_id, prio, &prio);
+ /* Check the ceiling priority values */
+ assert(prio == 2);
+ sc = rtems_semaphore_delete(semaphore_id);
+ exit(0);
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_MAXIMUM_MRSP_SEMAPHORES 1
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 2
+#define CONFIGURE_SCHEDULER_SIMPLE_SMP
+#include <rtems/scheduler.h>
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(a);
+RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(b);
+#define CONFIGURE_SCHEDULER_CONTROLS \
+ RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(a, SCHED_A), \
+ RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(b, SCHED_B)
+#define CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS \
+ RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
+ RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY)
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
+ at end group
+ at end example
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index ed6fefd..c05bf40 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -23,6 +23,7 @@ SUBDIRS += smpload01
SUBDIRS += smplock01
SUBDIRS += smpmigration01
SUBDIRS += smpmigration02
+SUBDIRS += smpmrsp01
SUBDIRS += smpscheduler01
SUBDIRS += smpscheduler02
SUBDIRS += smpscheduler03
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index f9e7662..33bc655 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -78,6 +78,7 @@ smpload01/Makefile
smplock01/Makefile
smpmigration01/Makefile
smpmigration02/Makefile
+smpmrsp01/Makefile
smppsxaffinity01/Makefile
smppsxaffinity02/Makefile
smppsxsignal01/Makefile
diff --git a/testsuites/smptests/smpmrsp01/Makefile.am b/testsuites/smptests/smpmrsp01/Makefile.am
index 0000000..7983434
--- /dev/null
+++ b/testsuites/smptests/smpmrsp01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpmrsp01
+smpmrsp01_SOURCES = init.c
+dist_rtems_tests_DATA = smpmrsp01.scn smpmrsp01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpmrsp01_OBJECTS)
+LINK_LIBS = $(smpmrsp01_LDLIBS)
+smpmrsp01$(EXEEXT): $(smpmrsp01_OBJECTS) $(smpmrsp01_DEPENDENCIES)
+ @rm -f smpmrsp01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
index 0000000..38e515e
--- /dev/null
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -0,0 +1,287 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#ifdef HAVE_CONFIG_H
+#endif
+#include <rtems.h>
+#include <rtems/libcsupport.h>
+#include <rtems/score/smpbarrier.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SMPMRSP 1";
+#define CPU_COUNT 2
+typedef struct {
+ rtems_id main_task_id;
+ rtems_id worker_task_id;
+ Thread_Control *worker_task;
+ SMP_barrier_Control barrier;
+} test_context;
+static test_context test_instance = {
+ .barrier = SMP_BARRIER_CONTROL_INITIALIZER
+static void barrier(test_context *ctx, SMP_barrier_State *bs)
+ _SMP_barrier_Wait(&ctx->barrier, bs, CPU_COUNT);
+static void assert_prio(rtems_task_priority expected_prio)
+ sc = rtems_task_set_priority(RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &prio);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ rtems_test_assert(prio == expected_prio);
+static void assert_executing_worker(test_context *ctx)
+ _CPU_Context_Get_is_executing(&ctx->worker_task->Registers)
+static void worker_task(rtems_task_argument arg)
+ test_context *ctx = &test_instance;
+ SMP_barrier_State barrier_state = SMP_BARRIER_STATE_INITIALIZER;
+ ctx->worker_task = _Thread_Get_executing();
+ assert_prio(3);
+ barrier(ctx, &barrier_state);
+ sc = rtems_semaphore_obtain(ctx->semaphore_id, RTEMS_WAIT, 4);
+ rtems_test_assert(sc == RTEMS_TIMEOUT);
+ assert_prio(3);
+ sc = rtems_semaphore_obtain(ctx->semaphore_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ assert_prio(2);
+ sc = rtems_semaphore_release(ctx->semaphore_id);
+ assert_prio(3);
+ rtems_task_suspend(RTEMS_SELF);
+ rtems_test_assert(0);
+static void test(void)
+ rtems_id scheduler_id;
+ ctx->main_task_id = rtems_task_self();
+ sc = rtems_scheduler_ident(SCHED_A, &ctx->scheduler_a_id);
+ sc = rtems_scheduler_ident(SCHED_B, &ctx->scheduler_b_id);
+ sc = rtems_task_get_scheduler(ctx->worker_task_id, &scheduler_id);
+ rtems_test_assert(ctx->scheduler_a_id == scheduler_id);
+ assert_prio(2);
+ 0,
+ 1,
+ &ctx->semaphore_id
+ assert_prio(1);
+ ctx->semaphore_id,
+ ctx->scheduler_a_id,
+ prio,
+ &prio
+ rtems_test_assert(prio == 1);
+ prio = 2;
+ ctx->scheduler_b_id,
+ prio,
+ &prio
+ prio,
+ &prio
+ prio,
+ &prio
+ rtems_test_assert(prio == 2);
+ /* Check that a thread waiting to get ownership remains executing */
+ sc = rtems_task_create(
+ rtems_build_name('W', 'O', 'R', 'K'),
+ 3,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &ctx->worker_task_id
+ sc = rtems_task_set_scheduler(ctx->worker_task_id, ctx->scheduler_b_id);
+ sc = rtems_task_start(ctx->worker_task_id, worker_task, 0);
+ sc = rtems_task_wake_after(2);
+ assert_executing_worker(ctx);
+ sc = rtems_task_delete(ctx->worker_task_id);
+ sc = rtems_semaphore_delete(ctx->semaphore_id);
+ rtems_resource_snapshot snapshot;
+ TEST_BEGIN();
+ rtems_resource_snapshot_take(&snapshot);
+ test();
+ rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_INIT_TASK_PRIORITY 2
diff --git a/testsuites/smptests/smpmrsp01/smpmrsp01.doc b/testsuites/smptests/smpmrsp01/smpmrsp01.doc
index 0000000..85badfd
--- /dev/null
+++ b/testsuites/smptests/smpmrsp01/smpmrsp01.doc
@@ -0,0 +1,15 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpmrsp01
+directives:
+ - _MRSP_Initialize()
+ - _MRSP_Obtain()
+ - _MRSP_Release()
+ - _MRSP_Get_ceiling_priority()
+ - _MRSP_Set_ceiling_priority()
+concepts:
+ - Ensure that MrsP semaphores work.
diff --git a/testsuites/smptests/smpmrsp01/smpmrsp01.scn b/testsuites/smptests/smpmrsp01/smpmrsp01.scn
index 0000000..27065f9
--- /dev/null
+++ b/testsuites/smptests/smpmrsp01/smpmrsp01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SMPMRSP 1 ***
+*** END OF TEST SMPMRSP 1 ***
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index ef25b25..cc5ed26 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -37,6 +37,7 @@ if HAS_SMP
else
_SUBDIRS += sp29
endif
+_SUBDIRS += spmrsp01
_SUBDIRS += spscheduler01
_SUBDIRS += spprofiling01
_SUBDIRS += spfatal28
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index b40d4dd..ebc81ed 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -40,6 +40,7 @@ AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
# Explicitly list all Makefiles here
AC_CONFIG_FILES([Makefile
+spmrsp01/Makefile
spscheduler01/Makefile
spfatal28/Makefile
spthreadlife01/Makefile
diff --git a/testsuites/sptests/spmrsp01/Makefile.am b/testsuites/sptests/spmrsp01/Makefile.am
index 0000000..122b2a9
--- /dev/null
+++ b/testsuites/sptests/spmrsp01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spmrsp01
+spmrsp01_SOURCES = init.c
+dist_rtems_tests_DATA = spmrsp01.scn spmrsp01.doc
+LINK_OBJS = $(spmrsp01_OBJECTS)
+LINK_LIBS = $(spmrsp01_LDLIBS)
+spmrsp01$(EXEEXT): $(spmrsp01_OBJECTS) $(spmrsp01_DEPENDENCIES)
+ @rm -f spmrsp01$(EXEEXT)
+ $(make-exe)
diff --git a/testsuites/sptests/spmrsp01/init.c b/testsuites/sptests/spmrsp01/init.c
index 0000000..1633561
--- /dev/null
+++ b/testsuites/sptests/spmrsp01/init.c
@@ -0,0 +1,374 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+#include <rtems.h>
+const char rtems_test_name[] = "SPMRSP 1";
+typedef struct {
+ rtems_id task_id;
+} test_mrsp_context;
+static void create_not_defined(rtems_attribute attr)
+ rtems_id id;
+ 1,
+ attr,
+ 0,
+ &id
+ rtems_test_assert(sc == RTEMS_NOT_DEFINED);
+static void test_mrsp_create_errors(void)
+ rtems_id id;
+ puts("test MRSP create errors");
+ 0,
+ 3,
+ &id
+ rtems_test_assert(sc == RTEMS_INVALID_PRIORITY);
+ create_not_defined(
+ | RTEMS_COUNTING_SEMAPHORE
+ | RTEMS_SIMPLE_BINARY_SEMAPHORE
+ | RTEMS_PRIORITY
+ | RTEMS_INHERIT_PRIORITY
+ | RTEMS_PRIORITY_CEILING
+static void test_mrsp_flush_error(void)
+ rtems_id id;
+ puts("test MRSP flush errors");
+ 1,
+ 1,
+ &id
+ sc = rtems_semaphore_flush(id);
+ sc = rtems_semaphore_delete(id);
+static void test_mrsp_obtain_release(void)
+ rtems_id id;
+ puts("test MRSP obtain and release");
+ 1,
+ 1,
+ &id
+ assert_prio(2);
+ sc = rtems_semaphore_obtain(id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ assert_prio(1);
+ assert_prio(1);
+ sc = rtems_semaphore_release(id);
+ assert_prio(1);
+ rtems_test_assert(sc == RTEMS_RESOURCE_IN_USE);
+ assert_prio(2);
+static void test_mrsp_set_priority_errors(void)
+ rtems_id id;
+ puts("test MRSP set priority errors");
+ sc = rtems_task_get_scheduler(RTEMS_SELF, &scheduler_id);
+ rtems_build_name('C', 'O', 'N', 'T'),
+ 0,
+ RTEMS_COUNTING_SEMAPHORE,
+ 0,
+ &id
+ prio = 1;
+ sc = rtems_semaphore_set_priority(RTEMS_ID_NONE, scheduler_id, prio, &prio);
+ rtems_test_assert(sc == RTEMS_INVALID_ID);
+ prio = 1;
+ sc = rtems_semaphore_set_priority(id, RTEMS_ID_NONE, prio, &prio);
+ prio = 0xffffffff;
+ sc = rtems_semaphore_set_priority(id, scheduler_id, prio, &prio);
+ prio = 1;
+ sc = rtems_semaphore_set_priority(id, scheduler_id, prio, NULL);
+ rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
+ prio = 1;
+static void test_mrsp_set_priority(void)
+ rtems_id id;
+ puts("test MRSP set priority");
+ 1,
+ 1,
+ &id
+ prio = 1;
+ prio = 2;
+static void test_mrsp_task(rtems_task_argument arg)
+ test_mrsp_context *ctx = (test_mrsp_context *) arg;
+ rtems_test_assert(sc == RTEMS_NOT_OWNER_OF_RESOURCE);
+ sc = rtems_semaphore_obtain(ctx->semaphore_id, RTEMS_NO_WAIT, 0);
+ rtems_test_assert(sc == RTEMS_UNSATISFIED);
+ sc = rtems_semaphore_obtain(ctx->semaphore_id, RTEMS_WAIT, 1);
+ sc = rtems_event_transient_send(ctx->task_id);
+ rtems_task_delete(RTEMS_SELF);
+static void test_mrsp_timeout_and_not_owner_of_resource(void)
+ rtems_id id;
+ rtems_id task_id;
+ test_mrsp_context ctx;
+ puts("test MRSP timeout and not owner of resource");
+ 0,
+ 1,
+ &id
+ 1,
+ &task_id
+ ctx.semaphore_id = id;
+ ctx.task_id = rtems_task_self();
+ sc = rtems_task_start(task_id, test_mrsp_task, (rtems_task_argument) &ctx);
+ sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ TEST_BEGIN();
+ test_mrsp_create_errors();
+ test_mrsp_flush_error();
+ test_mrsp_obtain_release();
+ test_mrsp_set_priority_errors();
+ test_mrsp_set_priority();
+ test_mrsp_timeout_and_not_owner_of_resource();
+ TEST_END();
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
diff --git a/testsuites/sptests/spmrsp01/spmrsp01.doc b/testsuites/sptests/spmrsp01/spmrsp01.doc
index 0000000..e09cff1
--- /dev/null
+++ b/testsuites/sptests/spmrsp01/spmrsp01.doc
@@ -0,0 +1,13 @@
+test set name: spmrsp01
+directives:
+ - rtems_semaphore_create()
+ - rtems_semaphore_set_priority()
+concepts:
+ - Ensure that the RTEMS_MULTIPROCESSOR_RESOURCE_SHARING attribute and
+ semaphores work on uni-processor configurations.
diff --git a/testsuites/sptests/spmrsp01/spmrsp01.scn b/testsuites/sptests/spmrsp01/spmrsp01.scn
index 0000000..11888e2
--- /dev/null
+++ b/testsuites/sptests/spmrsp01/spmrsp01.scn
@@ -0,0 +1,8 @@
+*** BEGIN OF TEST SPMRSP 1 ***
+test MRSP create errors
+test MRSP flush errors
+test MRSP obtain and release
+test MRSP set priority errors
+test MRSP timeout and not owner of resource
+*** END OF TEST SPMRSP 1 ***
1.7.7
