[PATCH] score: PR2179: Fix initially locked PCP mutexes
Sebastian Huber
Thu May 22 07:40:06 UTC 2014
Elevate the priority of the creating task to the ceiling priority in
case a semaphore is created as initially locked.
cpukit/score/src/coremutex.c | 14 +++++++++-----
testsuites/sptests/sp65/init.c | 35 +++++++++++++++++++++++++++++++++++
testsuites/sptests/sp65/sp65.doc | 2 ++
3 files changed, 46 insertions(+), 5 deletions(-)
diff --git a/cpukit/score/src/coremutex.c b/cpukit/score/src/coremutex.c
index 96b11c9..17956a1 100644
--- a/cpukit/score/src/coremutex.c
+++ b/cpukit/score/src/coremutex.c
@@ -43,17 +43,21 @@ CORE_mutex_Status _CORE_mutex_Initialize(
the_mutex->holder = executing;
if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ||
_CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ) {
+ Priority_Control ceiling = the_mutex->Attributes.priority_ceiling;
- if ( executing->current_priority <
- the_mutex->Attributes.priority_ceiling )
- return CORE_MUTEX_STATUS_CEILING_VIOLATED;
+ if ( executing->current_priority < ceiling )
+ return CORE_MUTEX_STATUS_CEILING_VIOLATED;
#ifdef __RTEMS_STRICT_ORDER_MUTEX__
- _Chain_Prepend_unprotected( &executing->lock_mutex,
+ _Chain_Prepend_unprotected( &executing->lock_mutex,
&the_mutex->queue.lock_queue );
- the_mutex->queue.priority_before = executing->current_priority;
+ the_mutex->queue.priority_before = executing->current_priority;
#endif
executing->resource_count++;
+ _Thread_Disable_dispatch();
+ _Thread_Change_priority( executing, ceiling, false );
+ _Thread_Enable_dispatch();
} else {
the_mutex->nest_count = 0;
diff --git a/testsuites/sptests/sp65/init.c b/testsuites/sptests/sp65/init.c
index cba836d..7c6d8d3 100644
--- a/testsuites/sptests/sp65/init.c
+++ b/testsuites/sptests/sp65/init.c
@@ -28,6 +28,17 @@ rtems_task Task_1(rtems_task_argument arg);
#define TASK_PRIORITY 1
#endif
+static void assert_priority(rtems_task_priority expected)
+ rtems_status_code sc;
+ rtems_task_priority prio;
+ sc = rtems_task_set_priority(RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &prio);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ rtems_test_assert(prio == expected);
rtems_task Init(
rtems_task_argument ignored
@@ -38,6 +49,30 @@ rtems_task Init(
TEST_BEGIN();
+ * Verify that an initially locked priority ceiling mutex elevates the
+ * priority of the creating task.
+ status = rtems_semaphore_create(
+ rtems_build_name( 's','e','m','1' ),
+ 0,
+ RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_PRIORITY_CEILING,
+ 1,
+ &Mutex_id
+ rtems_test_assert(status == RTEMS_SUCCESSFUL);
+ assert_priority(1);
+ status = rtems_semaphore_release(Mutex_id);
+ assert_priority(TASK_PRIORITY);
+ status = rtems_semaphore_delete(Mutex_id);
* Create binary semaphore (a.k.a. Mutex) with Priority Ceiling
* attribute.
diff --git a/testsuites/sptests/sp65/sp65.doc b/testsuites/sptests/sp65/sp65.doc
index 73786ee..854dede 100644
--- a/testsuites/sptests/sp65/sp65.doc
+++ b/testsuites/sptests/sp65/sp65.doc
@@ -23,3 +23,5 @@ concepts:
+ Verify the priority ceiling mutex getting released which results in a thread
being unblocked and the unblocked thread's priority being elevated.
++ Verify that an initially locked priority ceiling mutex elevates the priority
+ of the creating task.
1.7.7
