[PATCH] LEON3: add support for IRQ16..31 for CPU!=0
Daniel Hellstrom daniel at gaisler.com
Fri May 23 13:50:19 UTC 2014
On 05/23/2014 03:17 PM, Joel Sherrill wrote:
> On 5/23/2014 7:26 AM, Daniel Hellstrom wrote:
>>   c/src/lib/libbsp/sparc/leon3/include/leon.h |    6 ++++--
>>   1 files changed, 4 insertions(+), 2 deletions(-)
>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>> index bda28f2..d21f054 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
>> +++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>> @@ -25,6 +25,7 @@
>>   #include <rtems.h>
>>   #include <amba.h>
>> +#include <rtems/score/cpu.h>
> I am surprised you need this. It is included as a side-effect of
> including rtems.h.
> Just to be sure I checked the dependencies for init.c for the
> hello world sample and it listed rtems/score/cpu.h. Try
> compiling with that .h
You're right, I will check this and resend the patch.
>>   #ifdef __cplusplus
>>   extern "C" {
>> @@ -130,11 +131,12 @@ extern int LEON3_IrqCtrl_EIrq;
>>   static __inline__ int bsp_irq_fixup(int irq)
>> -       int eirq;
>> +       int eirq, cpu;
>>          if (LEON3_IrqCtrl_EIrq != 0 && irq == LEON3_IrqCtrl_EIrq) {
>>                  /* Get interrupt number from IRQ controller */
>> -               eirq = LEON3_IrqCtrl_Regs->intid[LEON3_Cpu_Index] & 0x1f;
> Will LEON3_Cpu_Index end up being removed?
I don't think so, since it carries the boot processor in a SMP system. But lets see, I can try removing it piece by piece.
>> +               cpu = _LEON3_Get_current_processor();
>> +               eirq = LEON3_IrqCtrl_Regs->intid[cpu] & 0x1f;
>>                  if (eirq & 0x10)
>>                          irq = eirq;
> Does this method use tabs or 8 space indentation? Either isn't right.
I didn't change the coding style here. But I can make an additional patch converting to 2 spaces, applied after this so that it is clear what is changed.
Thanks for your quick response!
Daniel
