[PATCH] [RSB] Add support for building rtems-or1k tool-chain.
Mon May 26 00:41:00 UTC 2014
On 26/05/2014 10:02 am, Hesham Moustafa wrote:
> On Mon, May 26, 2014 at 12:57 AM, Chris Johns <chris at contemporary.net.au
> <mailto:chris at contemporary.net.au>> wrote:
>     If you move this to the bset file can you use rtems-binutils-2.24.cfg ?
>     Build set files support %source and %patch. This localises
>     architecture specific patches to that architecture.
> That makes sense. I was just separating the whole process of patching,
> custom configurations and building in earlier stages to easily catch up
> errors. But now after every thing works fine, I will delete all
> *or1k*.cfg files, and make changes as few as possible, most likely it
> will be just a new .bset file as you suggested.
Sure. I feel your progress is excellent so lets not mess up the repo
with files we will just delete. Thanks for cleaning this up.
