[PATCH] [RSB] Add support for building rtems-or1k tool-chain.
Hesham Moustafa
heshamelmatary at gmail.com
Mon May 26 01:06:34 UTC 2014
On Mon, May 26, 2014 at 2:45 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 26/05/2014 10:07 am, Hesham Moustafa wrote:
>> On Mon, May 26, 2014 at 12:57 AM, Chris Johns <chris at contemporary.net.au
>> <mailto:chris at contemporary.net.au>> wrote:
>> Just looking at this file I cannot see what has changed ? Why do we
>> need a special gdb build script ?
>> There is a configuration option added to disable linking with libsim.a.
>> The current port for gdb only support remote debugging with or1ksim
>> simulator. Can we get it working with if (target==or1k) or something
>> similar in the original gdb build script?
> Ah ok. See below..
>> @@ -0,0 +1,95 @@
>> +# GDB 7.xx Version 1.
>> +# This configuration file configure's, make's and install's gdb.
>> +%include %{_configdir}/checks.cfg
>> +# Select Snapshot Macro Maps
>> +%select gdb-snapshot
>> +%select expat-snapshot
>> +# The description.
>> +Name: %{_target}-gdb-%{gdb_version}-__%{release}
>> +Summary: GDB v%{gdb_version} for target %{_target} on host
>> %{_host}
>> +Version: %{gdb_version}
>> +Release: %{release}
>> +URL: http://www.gnu.org/software/__gdb/
>> <http://www.gnu.org/software/gdb/>
>> +BuildRoot: %{_tmppath}/%{name}-root-%(%{____id_u} -n)
>> +# Source
>> +%source set gdb
>> http://ftp.gnu.org/gnu/gdb/__gdb-%{gdb_version}.tar.bz2
>> <http://ftp.gnu.org/gnu/gdb/gdb-%{gdb_version}.tar.bz2>
>> +# Prepare the source code.
>> +%prep
>> + build_top=$(pwd)
>> + source_dir_gdb="gdb-%{gdb___version}"
>> + %source setup gdb -q -n gdb-%{gdb_version}
>> + %patch setup gdb -p1
>> + cd ${build_top}
>> +%build
>> + build_top=$(pwd)
>> + %{build_directory}
>> + mkdir -p ${build_dir}
>> + cd ${build_dir}
>> + %{host_build_flags}
>> + if test "%{_build}" != "%{_host}" ; then
>> + GDB_LIBS_STATIC="-lexpat"
>> + else
>> + GDB_LIBS="%{_forced_static}"
>> + fi
>> + LIBS_STATIC=${GDB_LIBS_STATIC} \
>> + LIBS=${GDB_LIBS} \
>> + ../${source_dir_gdb}/configure \
>> + --build=%{_build} --host=%{_host} \
>> + --target=%{_target} \
>> + --verbose --disable-nls \
>> + --without-included-gettext \
>> + --disable-win32-registry \
>> + --disable-werror \
>> + --disable-sim \
> Is this the change ?
> We could make this conditional and enabled by default then disable it in
> the bset file. An example in the gcc configuration is:
> http://git.rtems.org/rtems-source-builder/tree/source-
> builder/config/gcc-common-1.cfg#n145
Great! Before submitting the next fixed patch, I would like you give a
feedback regarding this change.
1- I have added a new "%define gdb-disable-sim 1" line to rtems-or1k.bset
2- Add "%{!?gdb-disable-sim:--enable-sim}%{?gdb-disable-sim:--disable-sim}"
to gdb-7-1.cfg (the common gdb file)
Should gdb-disable-sim be defined (with 0 or 1) for all targets? or not
defining it is OK (means that it's 0) ?
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140526/6145781c/attachment.html>
