[PATCH 03/12] bsp/altera-vyclone-v: Broadcast cache maintenances
Ralf Kirchner ralf.kirchner at embedded-brains.de
Tue May 27 14:45:00 UTC 2014
 c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c |    6 +++---
 1 Datei geändert, 3 Zeilen hinzugefügt(+), 3 Zeilen entfernt(-)
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c
index 140156c..18c65b4 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c
@@ -132,16 +132,16 @@ BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
 #ifdef RTEMS_SMP
     /* Enable cache coherency support for this processor */
     uint32_t actlr = arm_cp15_get_auxiliary_control();
-    actlr |= ARM_CORTEX_A9_ACTL_SMP;
+    actlr |= ARM_CORTEX_A9_ACTL_SMP | ARM_CORTEX_A9_ACTL_FW;
     arm_cp15_set_auxiliary_control(actlr);
 #endif
     if (cpu_id == 0) {
       arm_a9mpcore_start_scu_invalidate(scu, cpu_id, 0xF);
     setup_mmu_and_cache( cpu_id );
 #ifdef RTEMS_SMP
     if (cpu_id != 0) {
       arm_a9mpcore_start_set_vector_base();
1.7.10.4
