[PATCH 12/12] bsp/altera-cyclone-v: Cleanup
Ralf Kirchner ralf.kirchner at embedded-brains.de
Tue May 27 14:50:53 UTC 2014
 c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c |    6 +++---
 1 Datei geändert, 3 Zeilen hinzugefügt(+), 3 Zeilen entfernt(-)
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c
index 18c65b4..e9147ea 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c
@@ -115,16 +115,16 @@ BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
   const uint32_t         CORES  = BSPSTARTHOOKS_MIN(
     (uintptr_t) bsp_processor_count,
     rtems_configuration_get_maximum_processors() );
   assert( cpu_id < CORES );
   if( cpu_id < CORES ) {
     if( cpu_id == 0 ) {
       ctrl = arm_cp15_mmu_disable( 32 );
       ctrl &= ~( ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_Z );
       arm_cp15_set_control( ctrl );
       /* Enable Snoop Control Unit (SCU) */
       arm_a9mpcore_start_scu_enable( scu );
1.7.10.4
