[PATCH 04/12] bsp/arm: Broadcast cache maintenances
Tue May 27 15:30:48 UTC 2014
On 2014-05-27 16:45, Ralf Kirchner wrote:
>   c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h |    2 +-
>   1 Datei geändert, 1 Zeile hinzugefügt(+), 1 Zeile entfernt(-)
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
> index 578c842..97977ba 100644
> --- a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
> @@ -108,7 +108,7 @@ BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_hook_0(void)
>     /* Enable cache coherency support for this processor */
>       uint32_t actlr = arm_cp15_get_auxiliary_control();
> -    actlr |= ARM_CORTEX_A9_ACTL_SMP;
> +    actlr |= ARM_CORTEX_A9_ACTL_SMP | ARM_CORTEX_A9_ACTL_FW;
>       arm_cp15_set_auxiliary_control(actlr);
>   #endif
Is the problem with the bus errors in the network driver solved?  Otherwise we
must not apply this patch series.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
