[PATCH 3/4] score: Add resource node to thread control block
Wed May 28 14:29:27 UTC 2014
 cpukit/score/include/rtems/score/thread.h     |    8 ++++++++
 cpukit/score/include/rtems/score/threadimpl.h |   10 ++++++++++
 cpukit/score/src/threadinitialize.c           |    2 ++
 3 files changed, 20 insertions(+), 0 deletions(-)
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index 10c7ddc..6ae684b 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -28,6 +28,7 @@
 #include <rtems/score/priority.h>
+#include <rtems/score/resource.h>
 #include <rtems/score/stack.h>
 #include <rtems/score/states.h>
 #include <rtems/score/threadq.h>
@@ -488,6 +489,13 @@ struct Thread_Control_struct {
   Chain_Control            lock_mutex;
 #endif
+#if defined(RTEMS_SMP)
+   * @brief Resource node to build a dependency tree in case this thread owns
+   * resources or depends on a resource.
+  Resource_Node            Resource_node;
+#endif
      /*================= end of common block =================*/
 #if defined(RTEMS_MULTIPROCESSING)
   /** This field is true if the thread is offered globally */
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 1f63d06..39c40df 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -26,6 +26,7 @@
 #include <rtems/score/interr.h>
 #include <rtems/score/isr.h>
+#include <rtems/score/resourceimpl.h>
 #include <rtems/score/sysstate.h>
@@ -791,6 +792,10 @@ RTEMS_INLINE_ROUTINE bool _Thread_Is_life_changing(
  * Resources are accounted with the Thread_Control::resource_count resource
  * counter.  This counter is used by semaphore objects for example.
+ * In addition to the resource counter there is a resource dependency tree
+ * available on SMP configurations.  In case this tree is non-empty, then the
+ * thread owns resources.
  * @param[in] the_thread The thread.
 RTEMS_INLINE_ROUTINE bool _Thread_Owns_resources(
@@ -799,6 +804,11 @@ RTEMS_INLINE_ROUTINE bool _Thread_Owns_resources(
   bool owns_resources = the_thread->resource_count != 0;
+  owns_resources = owns_resources
+    || _Resource_Node_owns_resources( &the_thread->Resource_node );
+#endif
   return owns_resources;
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index b65628d..9c65d73 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -19,6 +19,7 @@
 #endif
 #include <rtems/score/stackimpl.h>
 #include <rtems/score/tls.h>
@@ -182,6 +183,7 @@ bool _Thread_Initialize(
   the_thread->scheduler               = scheduler;
+  _Resource_Node_initialize( &the_thread->Resource_node );
   _CPU_Context_Set_is_executing( &the_thread->Registers, false );
 #endif
1.7.7
