[PATCH 1/4] score: Add Resource Handler
Wed May 28 21:48:51 UTC 2014
On Wed, May 28, 2014 at 10:29 AM, Sebastian Huber
> A resource is something that has at most one owner at a time and may
> have multiple rivals in case an owner is present.  The owner and rivals
> are impersonated via resource nodes.  A resource is represented via the
> resource control structure.  The resource controls and nodes are
> organized as trees.  It is possible to detect deadlocks via such a
> resource tree.  The _Resource_Iterate() function can be used to iterate
> through such a resource tree starting at a top node.
>  cpukit/score/Makefile.am                         |    3 +
>  cpukit/score/include/rtems/score/resource.h      |  211 ++++++++++++++
>  cpukit/score/include/rtems/score/resourceimpl.h  |  163 +++++++++++
>  cpukit/score/preinstall.am                       |    8 +
>  cpukit/score/src/resourceiterate.c               |  106 +++++++
>  testsuites/sptests/Makefile.am                   |    1 +
>  testsuites/sptests/configure.ac                  |    1 +
>  testsuites/sptests/spresource01/Makefile.am      |   19 ++
>  testsuites/sptests/spresource01/init.c           |  319 ++++++++++++++++++++++
>  testsuites/sptests/spresource01/spresource01.doc |   11 +
>  testsuites/sptests/spresource01/spresource01.scn |   94 +++++++
>  11 files changed, 936 insertions(+), 0 deletions(-)
>  create mode 100644 cpukit/score/include/rtems/score/resource.h
>  create mode 100644 cpukit/score/include/rtems/score/resourceimpl.h
>  create mode 100644 cpukit/score/src/resourceiterate.c
>  create mode 100644 testsuites/sptests/spresource01/Makefile.am
>  create mode 100644 testsuites/sptests/spresource01/init.c
>  create mode 100644 testsuites/sptests/spresource01/spresource01.doc
>  create mode 100644 testsuites/sptests/spresource01/spresource01.scn
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index b9a9f28..70760c5 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -51,6 +51,8 @@ include_rtems_score_HEADERS += include/rtems/score/prioritybitmapimpl.h
>  include_rtems_score_HEADERS += include/rtems/score/profiling.h
>  include_rtems_score_HEADERS += include/rtems/score/rbtree.h
>  include_rtems_score_HEADERS += include/rtems/score/rbtreeimpl.h
> +include_rtems_score_HEADERS += include/rtems/score/resource.h
> +include_rtems_score_HEADERS += include/rtems/score/resourceimpl.h
>  include_rtems_score_HEADERS += include/rtems/score/scheduler.h
>  include_rtems_score_HEADERS += include/rtems/score/schedulerimpl.h
>  include_rtems_score_HEADERS += include/rtems/score/schedulercbs.h
> @@ -337,6 +339,7 @@ libscore_a_SOURCES += src/apiext.c src/chain.c src/chainappend.c \
>  libscore_a_SOURCES += src/debugisownerofallocator.c
>  libscore_a_SOURCES += src/profilingisrentryexit.c
>  libscore_a_SOURCES += src/once.c
> +libscore_a_SOURCES += src/resourceiterate.c
>  EXTRA_DIST = src/Unlimited.txt
> diff --git a/cpukit/score/include/rtems/score/resource.h b/cpukit/score/include/rtems/score/resource.h
> new file mode 100644
> index 0000000..ecf84a7
> --- /dev/null
> +++ b/cpukit/score/include/rtems/score/resource.h
> @@ -0,0 +1,211 @@
> + * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#ifndef _RTEMS_SCORE_RESOURCE_H
> +#define _RTEMS_SCORE_RESOURCE_H
> +#include <rtems/score/basedefs.h>
> +#include <rtems/score/chain.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> + * @defgroup ScoreResource Resource Handler
> + * @ingroup Score
> + * @brief Support for resource dependency management.
> + * A resource is something that has at most one owner at a time and may have
> + * multiple rivals in case an owner is present.  The owner and rivals are
> + * impersonated via resource nodes.  A resource is represented via the resource
> + * control structure.  The resource controls and nodes are organized as trees.
> + * It is possible to detect deadlocks via such a resource tree.  The
> + * _Resource_Iterate() function can be used to iterate through such a resource
> + * tree starting at a top node.
> + * The following diagram shows an example resource tree with sixteen resource
> + * nodes n0 up to n15 and sixteen resources r0 up to r15.  The root of this
> + * tree is n0.  As a use case threads can be associated with resource nodes.
> + * In this case a thread represented by node n0 owns resources r0, r1, r2, r3,
> + * r6, r11 and r12 and is in the ready state.  The threads represented by nodes
> + * n1 up to n15 wait directly or indirectly via resources owned by n0 and are
> + * in a blocked state.
> + * @dot
> + * digraph {
> + *   n0 [style=filled, fillcolor=green];
> + *   n0 -> r0;
> + *   subgraph {
> + *     rank=same;
> + *     n1 [style=filled, fillcolor=green];
> + *     r0 -> n1;
> + *     n2 [style=filled, fillcolor=green];
> + *     n1 -> n2;
> + *     n4 [style=filled, fillcolor=green];
> + *     n2 -> n4;
> + *     n6 [style=filled, fillcolor=green];
> + *     n4 -> n6;
> + *     n8 [style=filled, fillcolor=green];
> + *     n6 -> n8;
> + *     n15 [style=filled, fillcolor=green];
> + *     n8 -> n15;
> + *   n1 -> r5;
> + *   subgraph {
> + *     rank=same;
> + *     n3 [style=filled, fillcolor=green];
> + *     r5 -> n3;
> + *     n12 [style=filled, fillcolor=green];
> + *     n3 -> n12;
> + *   n3 -> r10;
> + *   r10 -> r13;
> + *   r13 -> r15;
> + *   subgraph {
> + *     rank=same;
> + *     n10 [style=filled, fillcolor=green];
> + *     r15 -> n10;
> + *   r5 -> r7;
> + *   subgraph {
> + *     rank=same;
> + *     n11 [style=filled, fillcolor=green];
> + *     r7 -> n11;
> + *     n14 [style=filled, fillcolor=green];
> + *     n11 -> n14;
> + *   n14 -> r4;
> + *   r7 -> r8;
> + *   subgraph {
> + *     rank=same;
> + *     n13 [style=filled, fillcolor=green];
> + *     r8 -> n13;
> + *   r8 -> r9;
> + *   n8 -> r14;
> + *   r0 -> r1;
> + *   subgraph {
> + *     rank=same;
> + *     n7 [style=filled, fillcolor=green];
> + *     r1 -> n7;
> + *   r1 -> r2;
> + *   r2 -> r3;
> + *   r3 -> r6;
> + *   r6 -> r11;
> + *   r11 -> r12;
> + *   subgraph {
> + *     rank=same;
> + *     n5 [style=filled, fillcolor=green];
> + *     r12 -> n5;
> + *     n9 [style=filled, fillcolor=green];
> + *     n5 -> n9;
> + * @enddot
> + * The following example illustrates a deadlock situation.  The root of the
> + * tree tries to get ownership of a resource owned by one of its children.
> + * @dot
> + * digraph {
> + *   n0 -> r0;
> + *   subgraph {
> + *     rank=same;
> + *     r0 -> n1;
> + *   n1 -> r1;
> + *   n0 -> r1 [label=deadlock, style=dotted];
> + * @enddot
> +typedef struct Resource_Node Resource_Node;
> +typedef struct Resource_Control Resource_Control;
> + * @brief Resource node to reflect ownership of resources and a dependency on a
> + * resource.
> +struct Resource_Node {
> +   * @brief Node to build a chain of rivals depending on a resource.
> +   * @see Resource_Control::Rivals.
> +  Chain_Node Node;
> +   * @brief A chain of resources owned by this node.
> +   * @see Resource_Control::Node.
> +  Chain_Control Resources;
> +   * @brief Reference to a resource in case this node has to wait for ownership
> +   * of this resource.
> +   * It is @c NULL in case this node has no open resource dependency.
> +  Resource_Control *dependency;
> +   * @brief Reference to the root of the resource tree.
> +   * The root references itself.
> +  Resource_Node *root;
> + * @brief Resource control to manage ownership and rival nodes depending on a
> + * resource.
> +struct Resource_Control {
> +   * @brief Node to build a chain of resources owned by a resource node.
> +   * @see Resource_Node::Resources.
> +  Chain_Node Node;
> +   * @brief A chain of rivals waiting for resource ownership.
> +   * @see Resource_Node::Node.
> +  Chain_Control Rivals;
> +   * @brief The owner of this resource.
> +  Resource_Node *owner;
> +#ifdef __cplusplus
> +#endif /* _RTEMS_SCORE_RESOURCE_H */
> diff --git a/cpukit/score/include/rtems/score/resourceimpl.h b/cpukit/score/include/rtems/score/resourceimpl.h
> index 0000000..4f5a8d8
> --- /dev/null
> +++ b/cpukit/score/include/rtems/score/resourceimpl.h
> @@ -0,0 +1,163 @@
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> +#ifndef _RTEMS_SCORE_RESOURCEIMPL_H
> +#define _RTEMS_SCORE_RESOURCEIMPL_H
> +#include <rtems/score/resource.h>
> +#include <rtems/score/chainimpl.h>
> +#ifdef __cplusplus
> +extern "C" {
> + * @addtogroup ScoreResource
> + * @brief Visitor function for resource node iteration.
> + * The visitor is allowed to extract the node.
> + * @param[in] node The current resource node.
> + * @param[in] arg The argument passed to _Resource_Iterate().
> + * @retval true Stop the iteration.
> + * @retval false Continue the iteration.
> +typedef bool (*Resource_Node_visitor)( Resource_Node *node, void *arg );
> + * @brief Iterates over all nodes of a resource dependency tree.
> + * @param[in] top The top node to start the iteration.  The visitor function is
> + * not invoked for the top node.
> + * @param[in] visitor The visitor function.
> + * @param[in] arg The argument for the visitor function.
> +void _Resource_Iterate(
> +  Resource_Node         *top,
> +  Resource_Node_visitor  visitor,
> +  void                  *arg
> +RTEMS_INLINE_ROUTINE void _Resource_Node_initialize( Resource_Node *node )
> +  node->dependency = NULL;
> +  node->root = node;
> +  _Chain_Initialize_empty( &node->Resources );
> +RTEMS_INLINE_ROUTINE void _Resource_Node_set_dependency(
> +  Resource_Node    *node,
> +  node->dependency = dependency;
> +RTEMS_INLINE_ROUTINE Resource_Node *_Resource_Node_get_root(
> +  const Resource_Node *node
> +  return node->root;
> +RTEMS_INLINE_ROUTINE void _Resource_Node_set_root(
> +  node->root = root;
> +RTEMS_INLINE_ROUTINE bool _Resource_Node_owns_resources( const Resource_Node *node )
> +  return !_Chain_Is_empty( &node->Resources );
> +RTEMS_INLINE_ROUTINE void _Resource_Node_add_resource(
> +  Resource_Control *resource
> +  _Chain_Prepend_unprotected( &node->Resources, &resource->Node );
> + * @brief Returns true if this is the most recent resource of the node, and
> + * false otherwise.
> + * Resources are organized in last in first out order (LIFO).
> + * @param[in] node The node containing the resource.
> + * @param[in] resource The resource in question.
> +RTEMS_INLINE_ROUTINE bool _Resource_Is_most_recent_resource_of_node(
> +  const Resource_Node    *node,
> +  const Resource_Control *resource
At first this function name confused me when I saw it used. I'm not
sure if a better name exists but it may be worth considering. Also,
this whole Resource handler is a bit odd compared to other data
structures in RTEMS, in that the interface functions take a Node first
and a Control second. Usually the Control comes first.
> +  return &resource->Node == _Chain_Immutable_first( &node->Resources );
> +RTEMS_INLINE_ROUTINE void _Resource_Node_extract( Resource_Node *node )
> +  _Chain_Extract_unprotected( &node->Node );
> +RTEMS_INLINE_ROUTINE void _Resource_Initialize( Resource_Control *resource )
> +  resource->owner = NULL;
> +  _Chain_Initialize_empty( &resource->Rivals );
> +RTEMS_INLINE_ROUTINE void _Resource_Add_rival(
> +  Resource_Control *resource,
> +  _Chain_Append_unprotected( &resource->Rivals, &node->Node );
> +RTEMS_INLINE_ROUTINE void _Resource_Extract( Resource_Control *resource )
> +  _Chain_Extract_unprotected( &resource->Node );
> +RTEMS_INLINE_ROUTINE Resource_Node *_Resource_Get_owner(
> +  return resource->owner;
> +RTEMS_INLINE_ROUTINE void _Resource_Set_owner(
> +  resource->owner = owner;
> +#ifdef __cplusplus
> +#endif /* _RTEMS_SCORE_RESOURCEIMPL_H */
> diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
> index 45a0ce7..f5474c5 100644
> --- a/cpukit/score/preinstall.am
> +++ b/cpukit/score/preinstall.am
> @@ -187,6 +187,14 @@ $(PROJECT_INCLUDE)/rtems/score/rbtreeimpl.h: include/rtems/score/rbtreeimpl.h $(
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/rbtreeimpl.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/rbtreeimpl.h
> +$(PROJECT_INCLUDE)/rtems/score/resource.h: include/rtems/score/resource.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/resource.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/resource.h
> +$(PROJECT_INCLUDE)/rtems/score/resourceimpl.h: include/rtems/score/resourceimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/resourceimpl.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/resourceimpl.h
>  $(PROJECT_INCLUDE)/rtems/score/scheduler.h: include/rtems/score/scheduler.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/scheduler.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/scheduler.h
> diff --git a/cpukit/score/src/resourceiterate.c b/cpukit/score/src/resourceiterate.c
> index 0000000..26f9234
> --- /dev/null
> +++ b/cpukit/score/src/resourceiterate.c
> @@ -0,0 +1,106 @@
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> +#include <rtems/score/resourceimpl.h>
> +static Resource_Control *_Resource_Rival_head_to_resource( Chain_Node *head )
> +  return (Resource_Control *)
> +    ( (char *) head - offsetof( Resource_Control, Rivals.Head.Node ) );
> +static Resource_Node *_Resource_Resource_tail_to_rival( Chain_Node *tail )
> +  return (Resource_Node *)
> +    ( (char *) tail - offsetof( Resource_Node, Resources.Tail.Node ) );
> +  void                  *arg
> +  Chain_Node *resource_tail = _Chain_Tail( &top->Resources );
> +  Resource_Control *resource =
> +    (Resource_Control *) _Chain_Head( &top->Resources );
> +  Chain_Node *rival_stop = NULL;
> +  Resource_Node *rival = NULL;
> +  enum {
> +    NODE_FORWARD,
> +    NODE_BACKWARD,
> +    RESOURCE_FORWARD
> +  } dir = RESOURCE_FORWARD;
> +  bool stop = false;
> +  do {
> +    switch ( dir ) {
> +      case NODE_FORWARD:
> +        while ( !stop && &rival->Node != rival_stop ) {
> +          Resource_Node *current = rival;
> +          rival = (Resource_Node *) _Chain_Next( &rival->Node );
> +          stop = ( *visitor )( current, arg );
> +        rival_stop = _Chain_Head( &resource->Rivals );
> +        dir = NODE_BACKWARD;
> +        break;
> +      case NODE_BACKWARD:
> +        rival = (Resource_Node *) _Chain_Previous( &rival->Node );
> +        while (
> +          &rival->Node != rival_stop
> +            && _Chain_Is_empty( &rival->Resources )
> +        if ( &rival->Node != rival_stop ) {
> +          resource_tail = _Chain_Tail( &rival->Resources );
> +          resource = (Resource_Control *) _Chain_Head( &rival->Resources );
> +        } else {
> +          resource = _Resource_Rival_head_to_resource( rival_stop );
> +          resource_tail = _Chain_Tail( &resource->owner->Resources );
> +        dir = RESOURCE_FORWARD;
> +        break;
> +      case RESOURCE_FORWARD:
> +        resource = (Resource_Control *) _Chain_Next( &resource->Node );
> +        while (
> +          &resource->Node != resource_tail
> +            && _Chain_Is_empty( &resource->Rivals )
> +        if ( &resource->Node != resource_tail ) {
> +          rival_stop = _Chain_Tail( &resource->Rivals );
> +          rival = (Resource_Node *) _Chain_First( &resource->Rivals );
> +          dir = NODE_FORWARD;
> +        } else {
> +          rival = _Resource_Resource_tail_to_rival( resource_tail );
> +          rival_stop = _Chain_Head( &rival->dependency->Rivals );
> +        break;
> +  } while ( !stop && rival != top );
> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
> index cc5ed26..e55061e 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -37,6 +37,7 @@ if HAS_SMP
>  else
>  _SUBDIRS += sp29
>  endif
> +_SUBDIRS += spresource01
>  _SUBDIRS += spmrsp01
>  _SUBDIRS += spscheduler01
>  _SUBDIRS += spprofiling01
> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
> index ebc81ed..42fb87f 100644
> --- a/testsuites/sptests/configure.ac
> +++ b/testsuites/sptests/configure.ac
> @@ -40,6 +40,7 @@ AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
>  # Explicitly list all Makefiles here
>  AC_CONFIG_FILES([Makefile
> +spresource01/Makefile
>  spmrsp01/Makefile
>  spscheduler01/Makefile
>  spfatal28/Makefile
> diff --git a/testsuites/sptests/spresource01/Makefile.am b/testsuites/sptests/spresource01/Makefile.am
> index 0000000..292dd05
> --- /dev/null
> +++ b/testsuites/sptests/spresource01/Makefile.am
> @@ -0,0 +1,19 @@
> +rtems_tests_PROGRAMS = spresource01
> +spresource01_SOURCES = init.c
> +dist_rtems_tests_DATA = spresource01.scn spresource01.doc
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> +LINK_OBJS = $(spresource01_OBJECTS)
> +LINK_LIBS = $(spresource01_LDLIBS)
> +spresource01$(EXEEXT): $(spresource01_OBJECTS) $(spresource01_DEPENDENCIES)
> +       @rm -f spresource01$(EXEEXT)
> +       $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/sptests/spresource01/init.c b/testsuites/sptests/spresource01/init.c
> index 0000000..be0ade7
> --- /dev/null
> +++ b/testsuites/sptests/spresource01/init.c
> @@ -0,0 +1,319 @@
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> +#ifdef HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <stdio.h>
> +#include <rtems.h>
> +#include "tmacros.h"
> +const char rtems_test_name[] = "SPRESOURCE 1";
> +static Resource_Control rt[16];
> +static Resource_Node nt[16];
> +#define RESOURCE_COUNT RTEMS_ARRAY_SIZE(rt)
> +#define NODE_COUNT RTEMS_ARRAY_SIZE(nt)
> +static size_t ri(Resource_Control *r)
> +  return (size_t) (r - &rt[0]);
> +static size_t ni(Resource_Node *n)
> +  return (size_t) (n - &nt[0]);
> +static void print_node(Resource_Node *n);
> +static void print_resource(Resource_Control *r)
> +  Chain_Control *rivals = &r->Rivals;
> +  if (!_Chain_Is_empty(rivals)) {
> +    const Chain_Node *tail = _Chain_Immutable_tail(rivals);
> +    Resource_Node *last = (Resource_Node *) _Chain_First(rivals);
> +    Resource_Node *next = (Resource_Node *) _Chain_Next(&last->Node);
> +    printf(
> +      "  subgraph {\n"
> +      "    rank=same;\n"
> +      "    n%zi [style=filled, fillcolor=green];\n"
> +      "    r%zi -> n%zi;\n",
> +      ni(last),
> +      ri(r),
> +      ni(last)
> +    while (&next->Node != tail) {
> +      printf(
> +        "    n%zi -> n%zi;\n",
> +        ni(next),
> +        ni(last),
> +        ni(next)
> +      last = next;
> +      next = (Resource_Node *) _Chain_Next(&next->Node);
> +    printf("  }\n");
> +    next = (Resource_Node *) _Chain_First(rivals);
> +      print_node(next);
> +  Chain_Control *resources = &n->Resources;
> +  if (!_Chain_Is_empty(resources)) {
> +    const Chain_Node *tail = _Chain_Immutable_tail(resources);
> +    Resource_Control *last = (Resource_Control *) _Chain_First(resources);
> +    Resource_Control *next = (Resource_Control *) _Chain_Next(&last->Node);
> +    printf("  n%zi -> r%zi;\n", ni(n), ri(last));
> +    print_resource(last);
> +      printf("  r%zi -> r%zi;\n", ri(last), ri(next));
> +      print_resource(next);
> +      last = next;
> +      next = (Resource_Control *) _Chain_Next(&next->Node);
> +static const size_t node_seq[NODE_COUNT - 1] =
> +  { 1, 2, 4, 6, 8, 15, 3, 12, 10, 11, 14, 13, 7, 5, 9 };
> +static bool visitor_all(Resource_Node *n, void *arg)
> +  size_t *index = arg;
> +  size_t i = *index;
> +  printf("n%zi\n", ni(n));
> +  rtems_test_assert(i < RTEMS_ARRAY_SIZE(node_seq));
> +  rtems_test_assert(node_seq[i] == ni(n));
> +  *index = i + 1;
> +  return false;
> +static bool visitor_seven(Resource_Node *n, void *arg)
> +  rtems_test_assert(i < 7);
> +  *index = i + 1;
> +  return i + 1 >= 7;
> +static const bool owns_resources[RESOURCE_COUNT] = {
> +  true, true, false, true, false, false, false, false, true, false, false,
> +  false, false, false, true, false
> +static void add_resource(Resource_Node *n, Resource_Control *r)
> +  _Resource_Node_add_resource(n, r);
> +  _Resource_Set_owner(r, n);
> +static void add_rival(Resource_Control *r, Resource_Node *n)
> +  _Resource_Add_rival(r, n);
> +  _Resource_Node_set_dependency(n, r);
> +  _Resource_Node_set_root(n, &nt[0]);
> +static void test_resource_iterate(void)
> +  Resource_Node *root = &nt[0];
> +  size_t i;
> +  printf("digraph {\n");
> +  for (i = 0; i < RESOURCE_COUNT; ++i) {
> +    _Resource_Initialize(&rt[i]);
> +  for (i = 0; i < NODE_COUNT; ++i) {
> +    _Resource_Node_initialize(&nt[i]);
> +  add_resource(&nt[0], &rt[12]);
> +  add_resource(&nt[0], &rt[11]);
> +  add_resource(&nt[0], &rt[6]);
> +  add_resource(&nt[0], &rt[3]);
> +  add_resource(&nt[0], &rt[2]);
> +  add_resource(&nt[0], &rt[1]);
> +  add_resource(&nt[0], &rt[0]);
> +  add_resource(&nt[1], &rt[9]);
> +  add_resource(&nt[1], &rt[8]);
> +  add_resource(&nt[1], &rt[7]);
> +  add_resource(&nt[1], &rt[5]);
> +  add_resource(&nt[3], &rt[15]);
> +  add_resource(&nt[3], &rt[13]);
> +  add_resource(&nt[3], &rt[10]);
> +  add_resource(&nt[8], &rt[14]);
> +  add_resource(&nt[14], &rt[4]);
> +  add_rival(&rt[0], &nt[1]);
> +  add_rival(&rt[0], &nt[2]);
> +  add_rival(&rt[0], &nt[4]);
> +  add_rival(&rt[0], &nt[6]);
> +  add_rival(&rt[0], &nt[8]);
> +  add_rival(&rt[0], &nt[15]);
> +  add_rival(&rt[1], &nt[7]);
> +  add_rival(&rt[5], &nt[3]);
> +  add_rival(&rt[5], &nt[12]);
> +  add_rival(&rt[7], &nt[11]);
> +  add_rival(&rt[7], &nt[14]);
> +  add_rival(&rt[8], &nt[13]);
> +  add_rival(&rt[12], &nt[5]);
> +  add_rival(&rt[12], &nt[9]);
> +  add_rival(&rt[15], &nt[10]);
> +      _Resource_Node_owns_resources(&nt[i]) == owns_resources[i]
> +  printf("  n%zi [style=filled, fillcolor=green];\n", ni(root));
> +  print_node(root);
> +  printf("}\n");
> +  i = 0;
> +  _Resource_Iterate(root, visitor_all, &i);
> +  rtems_test_assert(i == 15);
> +  i = 0;
> +  _Resource_Iterate(root, visitor_seven, &i);
> +  rtems_test_assert(i == 7);
> +static void test_resource_simple(void)
> +  Resource_Control r0;
> +  Resource_Control r1;
> +  Resource_Node n0;
> +  _Resource_Node_initialize(&n0);
> +  rtems_test_assert(!_Resource_Node_owns_resources(&n0));
> +  rtems_test_assert(_Resource_Node_get_root(&n0) == &n0);
> +  rtems_test_assert(n0.dependency == NULL);
> +  _Resource_Node_set_root(&n0, NULL);
> +  rtems_test_assert(_Resource_Node_get_root(&n0) == NULL);
> +  _Resource_Node_set_root(&n0, &n0);
> +  _Resource_Initialize(&r0);
> +  rtems_test_assert(_Resource_Get_owner(&r0) == NULL);
> +  rtems_test_assert(_Chain_Is_empty(&r0.Rivals));
> +  _Resource_Set_owner(&r0, &n0);
> +  rtems_test_assert(_Resource_Get_owner(&r0) == &n0);
> +  _Resource_Set_owner(&r0, NULL);
> +  _Resource_Initialize(&r1);
> +  _Resource_Node_add_resource(&n0, &r0);
> +  rtems_test_assert(_Resource_Node_owns_resources(&n0));
> +  rtems_test_assert(_Resource_Is_most_recent_resource_of_node(&n0, &r0));
> +  _Resource_Node_add_resource(&n0, &r1);
> +  rtems_test_assert(!_Resource_Is_most_recent_resource_of_node(&n0, &r0));
> +  rtems_test_assert(_Resource_Is_most_recent_resource_of_node(&n0, &r1));
> +  _Resource_Extract(&r1);
> +  rtems_test_assert(!_Resource_Is_most_recent_resource_of_node(&n0, &r1));
> +  _Resource_Extract(&r0);
> +  _Resource_Add_rival(&r0, &n0);
> +  rtems_test_assert(!_Chain_Is_empty(&r0.Rivals));
> +  _Resource_Node_extract(&n0);
> +static void Init(rtems_task_argument arg)
> +  TEST_BEGIN();
> +  test_resource_simple();
> +  test_resource_iterate();
> +  TEST_END();
> +  rtems_test_exit(0);
> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/sptests/spresource01/spresource01.doc b/testsuites/sptests/spresource01/spresource01.doc
> index 0000000..eda0f12
> --- /dev/null
> +++ b/testsuites/sptests/spresource01/spresource01.doc
> @@ -0,0 +1,11 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: spresource01
> +directives:
> +  - _Resource_Iterate()
> +concepts:
> +  - Ensure that interation over resource nodes works.
> diff --git a/testsuites/sptests/spresource01/spresource01.scn b/testsuites/sptests/spresource01/spresource01.scn
> index 0000000..6a4f8de
> --- /dev/null
> +++ b/testsuites/sptests/spresource01/spresource01.scn
> @@ -0,0 +1,94 @@
> +*** BEGIN OF TEST SPRESOURCE 1 ***
> +digraph {
> +  n0 [style=filled, fillcolor=green];
> +  n0 -> r0;
> +  subgraph {
> +    rank=same;
> +    n1 [style=filled, fillcolor=green];
> +    r0 -> n1;
> +    n2 [style=filled, fillcolor=green];
> +    n1 -> n2;
> +    n4 [style=filled, fillcolor=green];
> +    n2 -> n4;
> +    n6 [style=filled, fillcolor=green];
> +    n4 -> n6;
> +    n8 [style=filled, fillcolor=green];
> +    n6 -> n8;
> +    n15 [style=filled, fillcolor=green];
> +    n8 -> n15;
> +  n1 -> r5;
> +  subgraph {
> +    rank=same;
> +    n3 [style=filled, fillcolor=green];
> +    r5 -> n3;
> +    n12 [style=filled, fillcolor=green];
> +    n3 -> n12;
> +  n3 -> r10;
> +  r10 -> r13;
> +  r13 -> r15;
> +  subgraph {
> +    rank=same;
> +    n10 [style=filled, fillcolor=green];
> +    r15 -> n10;
> +  r5 -> r7;
> +  subgraph {
> +    rank=same;
> +    n11 [style=filled, fillcolor=green];
> +    r7 -> n11;
> +    n14 [style=filled, fillcolor=green];
> +    n11 -> n14;
> +  n14 -> r4;
> +  r7 -> r8;
> +  subgraph {
> +    rank=same;
> +    n13 [style=filled, fillcolor=green];
> +    r8 -> n13;
> +  r8 -> r9;
> +  n8 -> r14;
> +  r0 -> r1;
> +  subgraph {
> +    rank=same;
> +    n7 [style=filled, fillcolor=green];
> +    r1 -> n7;
> +  r1 -> r2;
> +  r2 -> r3;
> +  r3 -> r6;
> +  r6 -> r11;
> +  r11 -> r12;
> +  subgraph {
> +    rank=same;
> +    n5 [style=filled, fillcolor=green];
> +    r12 -> n5;
> +    n9 [style=filled, fillcolor=green];
> +    n5 -> n9;
> +n1
> +n2
> +n4
> +n6
> +n8
> +n15
> +n3
> +n12
> +n10
> +n11
> +n14
> +n13
> +n7
> +n5
> +n9
> +n1
> +n2
> +n4
> +n6
> +n8
> +n15
> +n3
> +*** END OF TEST SPRESOURCE 1 ***
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
