[PATCH 11/12] cpukit/libblock: Workaround SMP problem in bdbuf
Thu May 29 13:14:15 UTC 2014
On Tue, May 27, 2014 at 11:29 AM, Sebastian Huber
> On 2014-05-27 17:21, Gedare Bloom wrote:
>> On Tue, May 27, 2014 at 10:48 AM, Ralf Kirchner
>> <ralf.kirchner at embedded-brains.de>  wrote:
>>> >Enabling and disabling preemption as done for single core will not work
>>> > for SMP.
>>> >Thus as a temporary workaround use POSIX mutexes and POSIX condition
>>> > variables for SMP instead of the combination of semaphores and preemption
>>> > handling used for single core.
>>> >  cpukit/libblock/src/bdbuf.c |  348
>>> >  1 Datei geändert, 282 Zeilen hinzugefügt(+), 66 Zeilen entfernt(-)
>>> >diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
>>> >index 1e4887c..0caf8f5 100644
>>> >--- a/cpukit/libblock/src/bdbuf.c
>>> >+++ b/cpukit/libblock/src/bdbuf.c
>>> >@@ -43,6 +43,23 @@
>>> >  #include "rtems/bdbuf.h"
>>> >+#if defined( RTEMS_SMP )
>>> >+  #if defined( RTEMS_POSIX_API )
>>> >+    /* The single core implementation with enabling and disabling
>>> > preemption
>>> >+     * will not work under SMP. Thus we need to use POSIX mutexes and
>>> > POSIX
>>> >+     * condition variables as a workaround
>>> >+     * Required POSIX mutexes and POSIX condition variables will be
>>> > allocated
>>> >+     * automatically in confdefs.h if RTEMS_SMP and RTEMS_POSIX_API
>>> >+     * are #defined
>>> >+    #define RTEMS_BDBUF_SMP_WORKAROUND
>> Workaround implies a temporary solution. Is there a longer-term
>> solution in the works? Otherwise, we should just condition this on
>> RTEMS_SMP?
> We need condition variables in the Classic API.
Is it OK and feasible to require POSIX and use posix condition
variables for applications that use the bdbuf? If so, I think this
would be better than the workaround that splits the code in these two
cases, and probably the SMP and non-SMP can share most code then?
-Gedare
>> What if RTEMS_SMP is defined, but RTEMS_POSIX_API is not? This would
>> be an error here I suppose? Or possibly elsewhere in the bdbuf
>> workaround code? Probably it should be accounted in confdefs.h and an
>> error emitted?
> RTEMS_SMP without RTEMS_POSIX_API falls back to the current situation.  You
> get a fatal error at run-time.  A compile-time error is bad, since this
> would break the test suite build.
> rtems-devel mailing list
> rtems-devel at rtems.org
