BSP submitting requirements
Marcos Díaz marcos.diaz at tallertechnologies.com
Fri May 30 14:51:15 UTC 2014
thanks to all! We will try to submit it soon!
On Thu, May 29, 2014 at 5:16 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 5/29/2014 2:34 PM, Gedare Bloom wrote:
>> On Thu, May 29, 2014 at 3:02 PM, Marcos Díaz
>> <marcos.diaz at tallertechnologies.com> wrote:
>>> Hi! We are about to submit a BSP but we have some doubts:
>>> In http://www.rtems.org/wiki/index.php/Submitting_a_BSP
>>> there is a point that refers to:
>>> Do all files have a CVS $Id$ in them?
>>> What does this mean?
>> That is outdated and shouldn't be there. There is a script in the
>> rtems-testing.git repository located at merge-helpers/check_submission
>> that may be useful to run. I don't know there is much documentation
>> for it, but you just run it from your bsp directory and it does some
>> checks about what is expected to exist in a bsp.
>>> There is other:
>>> Did you provide a TIMES files with the results of the tmtests?
>>> is there any example of a file like this in order to see how it should be
>> I think this is old too and can be ignored for now, I only see one
>> example in the tree under libbsp/m68k/uC5282/TIMES
> There are more times* files in the tree.
> These are certainly optional but give the next person a good handle on
> what the expected performance is.
>> -Gedare
>>> Thanks!
>>> ______________________________
>>> Marcos Díaz
>>> Software Engineer
>>> San Lorenzo 47, 3rd Floor, Office 5
>>> Córdoba, Argentina
>>> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>> Skype: markdiaz22
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
Marcos Díaz
Software Engineer
Córdoba, Argentina
Skype: markdiaz22
