BSP submitting requirements
Fri May 30 15:33:19 UTC 2014
On 5/30/2014 9:51 AM, Marcos Díaz wrote:
> thanks to all! We will try to submit it soon!
Does the BSP run on any simulator? If so, there are a
couple of other things we like to have to aid automated
testing.
Also there is a new file .tcfg which can list the files
which do not link or run with a known/expected
failure on your BSP.  See
libbsp/arm/gdbarmsim/make/custom/arm1136jfs-testsuite.tcfg
for an example. This is a great way to ignore tests
which do not fit on the target.
> On Thu, May 29, 2014 at 5:16 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On 5/29/2014 2:34 PM, Gedare Bloom wrote:
>>> On Thu, May 29, 2014 at 3:02 PM, Marcos Díaz
>>> <marcos.diaz at tallertechnologies.com> wrote:
>>>> Hi! We are about to submit a BSP but we have some doubts:
>>>> In http://www.rtems.org/wiki/index.php/Submitting_a_BSP
>>>> there is a point that refers to:
>>>> Do all files have a CVS $Id$ in them?
>>>> What does this mean?
>>> That is outdated and shouldn't be there. There is a script in the
>>> rtems-testing.git repository located at merge-helpers/check_submission
>>> that may be useful to run. I don't know there is much documentation
>>> for it, but you just run it from your bsp directory and it does some
>>> checks about what is expected to exist in a bsp.
>>>> There is other:
>>>> Did you provide a TIMES files with the results of the tmtests?
>>>> is there any example of a file like this in order to see how it should be
>>> I think this is old too and can be ignored for now, I only see one
>>> example in the tree under libbsp/m68k/uC5282/TIMES
>> There are more times* files in the tree.
>> These are certainly optional but give the next person a good handle on
>> what the expected performance is.
>>> -Gedare
>>>> Thanks!
>>>> ______________________________
>>>> Marcos Díaz
>>>> Software Engineer
>>>> San Lorenzo 47, 3rd Floor, Office 5
>>>> Córdoba, Argentina
>>>> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>>> Skype: markdiaz22
>>>> _______________________________________________
>>>> rtems-devel mailing list
>>>> rtems-devel at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
