BSP submitting requirements
Marcos Díaz marcos.diaz at tallertechnologies.com
Fri May 30 15:38:02 UTC 2014
It doesn't run in any simulator..
I have another question:
We are developing a bsp for a board with very little memory (32k) when
we tried to run tmtest (and others) we encounter that couldnt allocate
more RAM, and one of the things that we saw we could improve is the
stack size passed for each task.
For this there exists the CPU_STACK_MINIMUM_SIZE macro, but
unfortunately it is defined to 4k for ARM, which is too much for us
(http://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/rtems/score/cpu.h#n176)
The question is:
Can we change this macro like for the m68k boards:
http://git.rtems.org/rtems/tree/cpukit/score/cpu/m68k/rtems/score/cpu.h#n384
and
http://git.rtems.org/rtems/tree/cpukit/score/cpu/m68k/rtems/score/m68k.h#n160
Is this the correct way to do this?
Thanks!
On Fri, May 30, 2014 at 12:33 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 5/30/2014 9:51 AM, Marcos Díaz wrote:
>> thanks to all! We will try to submit it soon!
> Does the BSP run on any simulator? If so, there are a
> couple of other things we like to have to aid automated
> testing.
> Also there is a new file .tcfg which can list the files
> which do not link or run with a known/expected
> failure on your BSP.  See
> libbsp/arm/gdbarmsim/make/custom/arm1136jfs-testsuite.tcfg
> for an example. This is a great way to ignore tests
> which do not fit on the target.
>> On Thu, May 29, 2014 at 5:16 PM, Joel Sherrill
>>> On 5/29/2014 2:34 PM, Gedare Bloom wrote:
>>>> On Thu, May 29, 2014 at 3:02 PM, Marcos Díaz
>>>> <marcos.diaz at tallertechnologies.com> wrote:
>>>>> Hi! We are about to submit a BSP but we have some doubts:
>>>>> In http://www.rtems.org/wiki/index.php/Submitting_a_BSP
>>>>> there is a point that refers to:
>>>>> Do all files have a CVS $Id$ in them?
>>>>> What does this mean?
>>>> That is outdated and shouldn't be there. There is a script in the
>>>> rtems-testing.git repository located at merge-helpers/check_submission
>>>> that may be useful to run. I don't know there is much documentation
>>>> for it, but you just run it from your bsp directory and it does some
>>>> checks about what is expected to exist in a bsp.
>>>>> There is other:
>>>>> Did you provide a TIMES files with the results of the tmtests?
>>>>> is there any example of a file like this in order to see how it should be
>>>> I think this is old too and can be ignored for now, I only see one
>>>> example in the tree under libbsp/m68k/uC5282/TIMES
>>> There are more times* files in the tree.
>>> These are certainly optional but give the next person a good handle on
>>> what the expected performance is.
>>>> -Gedare
>>>>> Thanks!
>>>>> ______________________________
>>>>> Marcos Díaz
>>>>> Software Engineer
>>>>> San Lorenzo 47, 3rd Floor, Office 5
>>>>> Córdoba, Argentina
>>>>> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>>>> Skype: markdiaz22
>>>>> _______________________________________________
>>>>> rtems-devel mailing list
>>>>> rtems-devel at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
Marcos Díaz
Software Engineer
Córdoba, Argentina
Skype: markdiaz22
