rtems-tester on realview BSP
Fri May 30 20:30:29 UTC 2014
Hi
I tried this earlier today and the tests were just timing out.
Does rtems-tester work with this BSP for anyone else?
The BSP works find with the sim-scripts so the BSP and simulator
are OK.
FWIW should audio be disabled on our qemu builds? I am
seeing warnings about not able to open the audio device
since I am ssh'ed in.
