rtems-tester on realview BSP
Fri May 30 21:23:20 UTC 2014
I found the problem. Now for Chris to suggest the best
fix. :)
The realview rtems-tester configuration has the machine as
xilinx-zynq-a9 not realview-pbx-a9.
Assuming the current realview is correct for the zynq BSP,
then the current realview needs to be copied to zynq and an
edit made.
After that edit is made locally, now all the tests appear to be
being reported as "invalid". This message is coming out
audio: Count not init 'oss' audio driver
but qemu is exiting with a 0 status.
Also <ctl>-c has no impact.
--joel
On 5/30/2014 3:30 PM, Joel Sherrill wrote:
> Hi
> I tried this earlier today and the tests were just timing out.
> Does rtems-tester work with this BSP for anyone else?
> The BSP works find with the sim-scripts so the BSP and simulator
> are OK.
> FWIW should audio be disabled on our qemu builds? I am
> seeing warnings about not able to open the audio device
> since I am ssh'ed in.
