rtems-tester on realview BSP
Sat May 31 23:16:28 UTC 2014
On 1/06/2014 12:54 am, Joel Sherrill wrote:
> On 5/31/2014 5:05 AM, Chris Johns wrote:
>> On 31/05/2014 7:23 am, Joel Sherrill wrote:
>>> Also <ctl>-c has no impact.
>> I have pushed a fix for this. Please try.
> Doesn't appear to be any different to me.
Does ctl-C work ? This is all the fix addresses.
I have not looked at the other issues you raised yet.
> Should the machine argument to qemu for the realview BSP also
> change?
> Why is the serial IO directed to /dev/null? How will the script
> get any output?
Did you try removing the this ?
I remember there being issues with serial ports on different hosts.\ but
I cannot remember what it was.
>  This command works and is what the sim-scripts
> use:
> qemu-system-arm -no-reboot -net none -nographic -M real-bash-4.2$
> qemu-system-arm -no-reboot -net none -nographic -M realview-pbx-a9 -m
> 256M -kernel
> ./arm-rtems4.11/c/realview_pbx_a9_qemu/testsuites/samples/hello/hello.exe
>> Chris
