[PATCH 2/2] score: Implement forced thread migration
Sebastian Huber
Fri May 2 16:56:49 UTC 2014
On 05/02/2014 06:23 PM, Gedare Bloom wrote:
> On Fri, May 2, 2014 at 7:39 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> >The current implementation of task migration in RTEMS has some
>> >implications with respect to the interrupt latency. It is crucial to
>> >preserve the system invariant that a task can execute on at most one
>> >processor in the system at a time. This is accomplished with a boolean
>> >indicator in the task context. The processor architecture specific
>> >low-level task context switch code will mark that a task context is no
>> >longer executing and waits that the heir context stopped execution
>> >before it restores the heir context and resumes execution of the heir
>> >task. So there is one point in time in which a processor is without a
>> >task. This is essential to avoid cyclic dependencies in case multiple
>> >tasks migrate at once. Otherwise some supervising entity is necessary to
>> >prevent life-locks. Such a global supervisor would lead to scalability
>> >problems so this approach is not used. Currently the thread dispatch is
>> >performed with interrupts disabled. So in case the heir task is
>> >currently executing on another processor then this prolongs the time of
>> >disabled interrupts since one processor has to wait for another
>> >processor to make progress.
>> >It is difficult to avoid this issue with the interrupt latency since
>> >interrupts normally store the context of the interrupted task on its
>> >stack. In case a task is marked as not executing we must not use its
>> >task stack to store such an interrupt context. We cannot use the heir
>> >stack before it stopped execution on another processor. So if we enable
>> >interrupts during this transition we have to provide an alternative task
>> >independent stack for this time frame. This issue needs further
>> >investigation.
> Thanks for the good explanation. Is the problem of using the
> non-executing task's stack that the task might get resumed on some
> other processor whlie the interrupt is running?
Yes, as soon as you set is_executing to false it may start execution on
another processor.
> When you say "cannot
> use the heir stack" do you mean cannot use it on the "idle" processor
> because the heir is executing on some oher processor where the heir
> should be getting blocked soon?
Yes, exactly, the heir may currently execute on another processor. On
this other processor it must have an heir thread and a thread dispatch
must be pending.
For example lets have a look at _Scheduler_Set() and assume that
the_thread is the currently executing thread:
RTEMS_INLINE_ROUTINE void _Scheduler_Set(
const Scheduler_Control *scheduler,
Thread_Control *the_thread
const Scheduler_Control *current_scheduler = _Scheduler_Get(
the_thread );
if ( current_scheduler != scheduler ) {
_Thread_Set_state( the_thread, STATES_MIGRATING );
<-- here we are still executing on this processor (thread
dispatching is disabled), but we have an heir for this processor
_Scheduler_Free( _Scheduler_Get( the_thread ), the_thread );
the_thread->scheduler = scheduler;
_Scheduler_Allocate( scheduler, the_thread );
_Scheduler_Update( scheduler, the_thread );
_Thread_Clear_state( the_thread, STATES_MIGRATING );
dispatching is still disabled) and we may be an heir on another
processor which just received an inter-processor interrupt
<-- high level code will eventually call _Thread_Dispatch() and we
finish the migration
>> > c/src/lib/libbsp/sparc/shared/irq_asm.S | 18 ++
>> > c/src/lib/libcpu/powerpc/new-exceptions/cpu.c | 4 +
>> > c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S | 18 ++
>> > cpukit/libmisc/cpuuse/cpuusagereport.c | 2 +-
>> > cpukit/rtems/include/rtems/rtems/tasks.h | 2 -
>> > cpukit/rtems/src/tasksetscheduler.c | 5 +-
>> > cpukit/score/cpu/arm/cpu.c | 12 +
>> > cpukit/score/cpu/arm/cpu_asm.S | 18 ++
>> > cpukit/score/cpu/arm/rtems/score/cpu.h | 16 ++
>> > cpukit/score/cpu/i386/cpu.c | 18 ++
>> > cpukit/score/cpu/i386/cpu_asm.S | 29 ++-
>> > cpukit/score/cpu/i386/rtems/score/cpu.h | 27 ++
>> > cpukit/score/cpu/no_cpu/rtems/score/cpu.h | 18 ++
>> > cpukit/score/cpu/powerpc/cpu.c | 4 +
>> > cpukit/score/cpu/powerpc/rtems/score/cpu.h | 14 +-
>> > cpukit/score/cpu/sparc/cpu.c | 8 +
>> > cpukit/score/cpu/sparc/rtems/score/cpu.h | 13 +
>> > cpukit/score/include/rtems/score/percpu.h | 11 +-
>> > cpukit/score/include/rtems/score/scheduler.h | 2 +-
>> > cpukit/score/include/rtems/score/schedulerimpl.h | 24 +--
>> > cpukit/score/include/rtems/score/schedulersmp.h | 4 +-
>> > .../score/include/rtems/score/schedulersmpimpl.h | 33 ++-
>> > cpukit/score/include/rtems/score/statesimpl.h | 2 +
>> > cpukit/score/include/rtems/score/thread.h | 11 +
>> > cpukit/score/include/rtems/score/threadimpl.h | 35 +++-
>> > cpukit/score/src/smp.c | 5 +-
>> > cpukit/score/src/threaddispatch.c | 31 +--
>> > cpukit/score/src/threadhandler.c | 4 +-
>> > cpukit/score/src/threadinitialize.c | 6 +-
>> > cpukit/score/src/threadrestart.c | 2 +-
>> > cpukit/score/src/threadstartmultitasking.c | 18 +-
>> > doc/user/smp.t | 46 ++++
>> > testsuites/smptests/Makefile.am | 1 +
>> > testsuites/smptests/configure.ac | 1 +
>> > testsuites/smptests/smpmigration02/Makefile.am | 19 ++
>> > testsuites/smptests/smpmigration02/init.c | 255 ++++++++++++++++++++
>> > .../smptests/smpmigration02/smpmigration02.doc | 12 +
>> > .../smptests/smpmigration02/smpmigration02.scn | 7 +
>> > testsuites/smptests/smpscheduler02/init.c | 4 +-
>> > 39 files changed, 679 insertions(+), 80 deletions(-)
>> > create mode 100644 testsuites/smptests/smpmigration02/Makefile.am
>> > create mode 100644 testsuites/smptests/smpmigration02/init.c
>> > create mode 100644 testsuites/smptests/smpmigration02/smpmigration02.doc
>> > create mode 100644 testsuites/smptests/smpmigration02/smpmigration02.scn
>> >diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
>> >index 3a86ad5..cdaaf6d 100644
>> >--- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
>> >+++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
>> >@@ -163,6 +163,21 @@ done_flushing:
>> > nop
>> > nop
>> >+#if defined(RTEMS_SMP)
>> >+ ! Indicate that this context is no longer executing
>> >+ stb %g0, [%o0 + SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET]
> The register usage should be documented at the declaration of
> CPU_Context_restore_heir above. Probably in the other architectures it
> should be documented as well.
%g0 is the zero register on SPARC and %o0 is the executing context, so I
don't think there is something to document here.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
