BSP question: nested interrupts?
Chris Nott chrisn at vl.com.au
Fri May 2 17:22:33 UTC 2014
On 2/05/2014 3:02 AM, Sebastian Huber wrote:
> Hello Chris,
> On 2014-05-01 19:53, Chris Nott wrote:
> <snip>
>> I'm not quite familiar with ARM family yet to be sure how this is
>> normally
>> accomplished or if there is an existing supported ARM with the same
>> interrupt
>> controller structure. TI provide sample source including interrupt
>> handler that
>> supports this stuff. It might be a good place to start playing with
>> it, the
>> source pretty much compiles fine in the RTEMS environment.
> The interrupt priority handling must be accomplished by the interrupt
> controller.
The interrupt dispatch code needs to manage the interrupt controller
priority manually on this platform.
