[PATCH] bsps/sparc: Move flags to grlib header
Daniel Hellstrom daniel at gaisler.com
Fri May 9 12:44:07 UTC 2014
Looks good! It is wrong to call it LEON3 since the IP is named GPTIMER and not bound to a specific revision of the CPU.
Thanks!
Daniel
On 05/09/2014 02:29 PM, Sebastian Huber wrote:
> From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
> This enables re-use for other BSPs
>   c/src/lib/libbsp/sparc/leon3/clock/ckinit.c   |    4 ++--
>   c/src/lib/libbsp/sparc/leon3/include/leon.h   |    5 -----
>   c/src/lib/libbsp/sparc/shared/include/grlib.h |    8 ++++++++
>   3 files changed, 10 insertions(+), 7 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> index a799908..5faf72d 100644
> --- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> +++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> @@ -113,8 +113,8 @@ static void leon3_clock_profiling_interrupt_delay(void)
>         rtems_configuration_get_microseconds_per_tick() - 1; \
>       LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].ctrl = \
> -      LEON3_GPTIMER_EN | LEON3_GPTIMER_RL | \
> -        LEON3_GPTIMER_LD | LEON3_GPTIMER_IRQEN; \
> +      GPTIMER_TIMER_CTRL_EN | GPTIMER_TIMER_CTRL_RS | \
> +        GPTIMER_TIMER_CTRL_LD | GPTIMER_TIMER_CTRL_IE; \
>     } while (0)
>   #define Clock_driver_support_shutdown_hardware() \
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> index 6d2434d..3ca33a3 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> @@ -144,11 +144,6 @@ static __inline__ int bsp_irq_fixup(int irq)
>   /* Macros used for manipulating bits in LEON3 GP Timer Control Register */
> -#define LEON3_GPTIMER_EN 1
> -#define LEON3_GPTIMER_RL 2
> -#define LEON3_GPTIMER_LD 4
> -#define LEON3_GPTIMER_IRQEN 8
>   #define LEON3_MP_IRQ    14        /* Irq used by shared memory driver */
>   #define LEON3_IRQMPSTATUS_CPUNR     28
> diff --git a/c/src/lib/libbsp/sparc/shared/include/grlib.h b/c/src/lib/libbsp/sparc/shared/include/grlib.h
> index cfbced3..3c20793 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/grlib.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/grlib.h
> @@ -78,6 +78,14 @@ struct gptimer_timer_regs {
>     volatile unsigned int notused;
> +#define GPTIMER_TIMER_CTRL_EN 0x00000001U
> +#define GPTIMER_TIMER_CTRL_RS 0x00000002U
> +#define GPTIMER_TIMER_CTRL_LD 0x00000004U
> +#define GPTIMER_TIMER_CTRL_IE 0x00000008U
> +#define GPTIMER_TIMER_CTRL_IP 0x00000010U
> +#define GPTIMER_TIMER_CTRL_CH 0x00000020U
> +#define GPTIMER_TIMER_CTRL_DH 0x00000040U
>   /* GPTIMER common registers */
>   struct gptimer_regs {
>     volatile unsigned int scaler_value;   /* common timer registers */
