[PATCH 1/2] CAN bus simple SJA1000 PCI card emulation for QEMU
Pavel Pisa
pisa at cmp.felk.cvut.cz
Fri May 9 18:14:31 UTC 2014
The work is based on Jin Yang GSoC 2013 work funded
by Google and mentored in frame of RTEMS project GSoC
slot donated to QEMU.
Update from QEMU-1.4 version and architecture cleanup
by Pavel Pisa (Czech Technical University in Prague).
The core SJA1000 support is independent of provided
PCI board. The simple core CAN bus infrastructure
is independent as well.
Connection to the real host CAN bus network through
SocketCAN network interface is available for Linux
host system as well.
Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz>
default-configs/pci.mak | 2 +
hw/net/Makefile.objs | 4 +
hw/net/can_core.c | 350 +++++++++++++++++++
hw/net/can_pci.c | 238 +++++++++++++
hw/net/can_sja1000.c | 878 ++++++++++++++++++++++++++++++++++++++++++++++++
hw/net/can_sja1000.h | 163 +++++++++
include/net/can_emu.h | 123 +++++++
7 files changed, 1758 insertions(+)
create mode 100644 hw/net/can_core.c
create mode 100644 hw/net/can_pci.c
create mode 100644 hw/net/can_sja1000.c
create mode 100644 hw/net/can_sja1000.h
create mode 100644 include/net/can_emu.h
diff --git a/default-configs/pci.mak b/default-configs/pci.mak
index 91b1e92..1260d6d 100644
--- a/default-configs/pci.mak
+++ b/default-configs/pci.mak
@@ -30,3 +30,5 @@ CONFIG_IPACK=y
CONFIG_WDT_IB6300ESB=y
CONFIG_PCI_TESTDEV=y
CONFIG_NVME_PCI=y
+CONFIG_CAN_SJA1000=y
+CONFIG_CAN_PCI=y
diff --git a/hw/net/Makefile.objs b/hw/net/Makefile.objs
index ea93293..28679fc 100644
--- a/hw/net/Makefile.objs
+++ b/hw/net/Makefile.objs
@@ -24,6 +24,10 @@ common-obj-$(CONFIG_CADENCE) += cadence_gem.o
common-obj-$(CONFIG_STELLARIS_ENET) += stellaris_enet.o
common-obj-$(CONFIG_LANCE) += lance.o
+obj-$(CONFIG_CAN_SJA1000) += can_core.o
+obj-$(CONFIG_CAN_SJA1000) += can_sja1000.o
+obj-$(CONFIG_CAN_PCI) += can_pci.o
obj-$(CONFIG_ETRAXFS) += etraxfs_eth.o
obj-$(CONFIG_COLDFIRE) += mcf_fec.o
obj-$(CONFIG_MILKYMIST) += milkymist-minimac2.o
diff --git a/hw/net/can_core.c b/hw/net/can_core.c
new file mode 100644
index 0000000..3fa57f5
--- /dev/null
+++ b/hw/net/can_core.c
@@ -0,0 +1,350 @@
+ * CAN common CAN bus emulation support
+ * Copyright (c) 2013-2014 Jin Yang
+ * Copyright (c) 2014 Pavel Pisa
+ * Initial development supported by Google GSoC 2013 from RTEMS project slot
+ * Permission is hereby granted, free of charge, to any person obtaining a copy
+ * of this software and associated documentation files (the "Software"), to deal
+ * in the Software without restriction, including without limitation the rights
+ * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
+ * copies of the Software, and to permit persons to whom the Software is
+ * furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included in
+ * all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
+ * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
+ * THE SOFTWARE.
+#include "hw/hw.h"
+#include "qemu/osdep.h"
+#include "sysemu/char.h"
+#include "qemu/sockets.h"
+#include "net/can_emu.h"
+#ifdef __linux__
+#include <sys/ioctl.h>
+#include <net/if.h>
+#include <linux/can.h>
+#include <linux/can/raw.h>
+#define NUM_FILTER 4
+#define CAN_READ_BUF_LEN 5
+typedef struct {
+ CanBusClientState bus_client;
+ qemu_can_filter rfilter[NUM_FILTER];
+ can_err_mask_t err_mask;
+ qemu_can_frame buf[CAN_READ_BUF_LEN];
+ int bufcnt;
+ int bufptr;
+ int max_size;
+ int fd;
+} CanBusHostConnectState;
+#endif /*__linux__*/
+static QTAILQ_HEAD(, CanBusState) can_buses = QTAILQ_HEAD_INITIALIZER(can_buses);
+CanBusState *can_bus_find_by_name(const char *name, bool create_missing)
+ CanBusState *bus;
+ if (name == NULL)
+ name = "canbus0";
+ QTAILQ_FOREACH(bus, &can_buses, next) {
+ if (!strcmp(bus->name, name))
+ return bus;
+ if (!create_missing)
+ return 0;
+ bus = g_malloc0(sizeof(*bus));
+ if (bus == NULL)
+ return NULL;
+ QTAILQ_INIT(&bus->clients);
+ bus->name = g_strdup(name);
+ QTAILQ_INSERT_TAIL(&can_buses, bus, next);
+ return bus;
+int can_bus_insert_client(CanBusState *bus, CanBusClientState *client)
+ client->bus = bus;
+ QTAILQ_INSERT_TAIL(&bus->clients, client, next);
+ return 0;
+int can_bus_remove_client(CanBusClientState *client)
+ CanBusState *bus = client->bus;
+ if (bus == NULL)
+ return 0;
+ QTAILQ_REMOVE(&bus->clients, client, next);
+ client->bus = NULL;
+ return 1;
+ssize_t can_bus_client_send(CanBusClientState *client,
+ const struct qemu_can_frame *frames, size_t frames_cnt)
+ int ret = 0;
+ CanBusClientState *peer;
+ if (bus == NULL)
+ return -1;
+ QTAILQ_FOREACH(peer, &bus->clients, next) {
+ if (peer->info->can_receive(peer)) {
+ if (peer == client) {
+ /* No loopback support for now */
+ continue;
+ if (peer->info->receive(peer, frames, frames_cnt) > 0)
+ ret = 1;
+ return ret;
+int can_bus_client_set_filters(CanBusClientState *client,
+ const struct qemu_can_filter *filters, size_t filters_cnt)
+ return 0;
+#ifdef DEBUG_CAN
+static void can_display_msg(struct qemu_can_frame *msg)
+ int i;
+ printf("%03X [%01d]:", (msg->can_id & 0x1fffffff), msg->can_dlc);
+ for(i = 0; i < msg->can_dlc; i++) {
+ printf(" %02X", msg->data[i]);
+ printf("\n");
+#endif
+#ifdef __linux__
+// >0 can read
+static int can_bus_host_read_poll(void *opaque)
+ CanBusHostConnectState *c = opaque;
+ c->max_size = sizeof(qemu_can_frame);
+ return c->max_size;
+static void can_bus_host_read(void *opaque)
+ if (c->max_size == 0)
+ return;
+ /* CAN_READ_BUF_LEN for multiple messages syscall is possible for future */
+ c->bufcnt = read(c->fd, c->buf, sizeof(qemu_can_frame));
+ if(c->bufcnt < 0) {
+ perror("CAN bus host read");
+ return;
+ can_bus_client_send(&c->bus_client, c->buf, 1);
+#ifdef DEBUG_CAN
+ can_display_msg(c->buf);// Just display the first one.
+#endif
+static int can_bus_host_can_receive(CanBusClientState *client)
+ CanBusHostConnectState *c = container_of(client, CanBusHostConnectState, bus_client);
+ if (c->fd < 0)
+ return -1;
+ return 1;
+static ssize_t can_bus_host_receive(CanBusClientState *client,
+ const qemu_can_frame *frames, size_t frames_cnt)
+ size_t len = sizeof(qemu_can_frame);
+ int res;
+ if (c->fd < 0)
+ return -1;
+ res = write(c->fd, frames, len);
+ if (!res) {
+ fprintf(stderr, "CAN bus write to host device zero length\n");
+ return -1;
+ /* send frame */
+ if (res != len) {
+ perror("CAN bus write to host device error");
+ return -1;
+ return 1;
+static void can_bus_host_cleanup(CanBusClientState *client)
+ if (c->fd >= 0) {
+ qemu_set_fd_handler2(c->fd, NULL, NULL, NULL, c);
+ close(c->fd);
+ c->fd = -1;
+int can_bus_host_set_filters(CanBusClientState *, const struct qemu_can_filter *filters, size_t filters_cnt);
+int can_bus_host_set_filters(CanBusClientState *client, const struct qemu_can_filter *filters, size_t filters_cnt)
+#ifdef DEBUG_CAN
+ int i;
+#endif
+ if(filters_cnt > 4) return -1;
+#ifdef DEBUG_CAN
+ for(i = 0; i < filters_cnt; i++) {
+ printf("[%i] id=0x%08x maks=0x%08x\n", i, filters[i].can_id, filters[i].can_mask);
+#endif
+ setsockopt(c->fd, SOL_CAN_RAW, CAN_RAW_FILTER,
+ filters, filters_cnt * sizeof(qemu_can_filter));
+ return 0;
+static void can_bus_host_update_read_handler(CanBusHostConnectState *c)
+ if (c->fd >= 0) {
+ qemu_set_fd_handler2(c->fd, can_bus_host_read_poll,
+ can_bus_host_read, NULL, c);
+static CanBusClientInfo can_bus_host_bus_client_info = {
+ .can_receive = can_bus_host_can_receive,
+ .receive = can_bus_host_receive,
+ .cleanup = can_bus_host_cleanup,
+ .poll = NULL
+static
+CanBusHostConnectState *can_bus_host_connect_new(const char *host_dev_name)
+ int s; /* can raw socket */
+ CanBusHostConnectState *c;
+ struct sockaddr_can addr;
+ struct ifreq ifr;
+ c = g_malloc0(sizeof(CanBusHostConnectState));
+ if (c == NULL)
+ goto fail1;
+ c->fd = -1;
+ /* open socket */
+ if ((s = socket(PF_CAN, SOCK_RAW, CAN_RAW)) < 0) {
+ perror("socket");
+ goto fail;
+ addr.can_family = AF_CAN;
+ memset(&ifr.ifr_name, 0, sizeof(ifr.ifr_name));
+ strcpy(ifr.ifr_name, host_dev_name);
+ if (ioctl(s, SIOCGIFINDEX, &ifr) < 0) {
+ perror("SIOCGIFINDEX");
+ goto fail;
+ addr.can_ifindex = ifr.ifr_ifindex;
+ c->err_mask = 0xffffffff; // Receive error frame.
+ setsockopt(s, SOL_CAN_RAW, CAN_RAW_ERR_FILTER,
+ &c->err_mask, sizeof(c->err_mask));
+ c->rfilter[0].can_id = 0; // Receive all data frame. If |= CAN_INV_FILTER no data.
+ c->rfilter[0].can_mask = 0;
+ c->rfilter[0].can_mask &= ~CAN_ERR_FLAG;
+ setsockopt(s, SOL_CAN_RAW, CAN_RAW_FILTER,
+ c->rfilter, sizeof(struct qemu_can_filter));
+ if (bind(s, (struct sockaddr *)&addr, sizeof(addr)) < 0) {
+ perror("bind");
+ goto fail;
+ c->fd = s;
+ c->bus_client.info = &can_bus_host_bus_client_info;
+ can_bus_host_update_read_handler(c);
+ return c;
+fail:
+ can_bus_host_cleanup(&c->bus_client);
+ g_free(c);
+fail1:
+ return NULL;
+int can_bus_connect_to_host_device(CanBusState *bus, const char *host_dev_name)
+ c = can_bus_host_connect_new(host_dev_name);
+ if (c == NULL) {
+ qerror_report(ERROR_CLASS_GENERIC_ERROR, "CAN bus setup of host connect to \"%s\" failed\n",
+ host_dev_name);
+ exit(1);
+ if (can_bus_insert_client(bus, &c->bus_client) < 0) {
+ qerror_report(ERROR_CLASS_GENERIC_ERROR, "CAN host device \"%s\" connect to bus \"%s\" failed\n",
+ host_dev_name, bus->name);
+ exit(1);
+ return 0;
+#else /*__linux__*/
+int can_bus_connect_to_host_device(CanBusState *bus, const char *name)
+ qerror_report(ERROR_CLASS_GENERIC_ERROR, "CAN bus connect to host device not supported on this system\n");
+ exit(1);
diff --git a/hw/net/can_pci.c b/hw/net/can_pci.c
index 0000000..8b4744d
--- /dev/null
+++ b/hw/net/can_pci.c
@@ -0,0 +1,238 @@
+ * PCI CAN device (SJA1000 based) emulation
+ * Partially based on educational PCIexpress APOHW hardware
+ * emulator used fro class A0B36APO at CTU FEE course by
+ * Rostislav Lisovy and Pavel Pisa
+ * THE SOFTWARE.
+#include "hw/hw.h"
+#include "hw/pci/pci.h"
+#include "qemu/event_notifier.h"
+#include "qemu/thread.h"
+#include "can_sja1000.h"
+#define TYPE_CAN_PCI_DEV "can_pci"
+#define CAN_PCI_DEV(obj) \
+ OBJECT_CHECK(CanPCIState, (obj), TYPE_CAN_PCI_DEV)
+#define PCI_VENDOR_ID_CAN_PCI PCI_VENDOR_ID_REDHAT
+#define PCI_DEVICE_ID_CAN_PCI 0xbeef
+#define PCI_REVISION_ID_CAN_PCI 0x73
+typedef struct CanPCIState {
+ /*< private >*/
+ PCIDevice dev;
+ /*< public >*/
+ MemoryRegion sja_mmio;
+ CanSJA1000State sja_state;
+ qemu_irq irq;
+ char *model; /* The model that support, only SJA1000 now. */
+ char *canbus;
+ char *host;
+} CanPCIState;
+static void can_pci_irq_raise(void *opaque)
+ CanPCIState *d = (CanPCIState *)opaque;
+ qemu_irq_raise(d->irq);
+static void can_pci_irq_lower(void *opaque)
+ qemu_irq_lower(d->irq);
+static void
+can_pci_reset(void *opaque)
+ CanSJA1000State *s = &d->sja_state;
+ can_sja_hardware_reset(s);
+static uint64_t can_pci_bar0_read(void *opaque, hwaddr addr, unsigned size)
+ CanPCIState *d = opaque;
+ return can_sja_mem_read(s, addr, size);
+static void can_pci_bar0_write(void *opaque, hwaddr addr, uint64_t data,
+ unsigned size)
+ can_sja_mem_write(s, addr, data, size);
+static const MemoryRegionOps can_pci_bar0_ops = {
+ .read = can_pci_bar0_read,
+ .write = can_pci_bar0_write,
+ .endianness = DEVICE_LITTLE_ENDIAN,
+ .impl = {
+ .min_access_size = 1,
+ .max_access_size = 1,
+static int can_pci_init(PCIDevice *pci_dev)
+ CanPCIState *d = CAN_PCI_DEV(pci_dev);
+ uint8_t *pci_conf;
+ CanBusState *can_bus;
+ if (d->model) {
+ if (strncmp(d->model, "SJA1000", 256)) { /* for security reason */
+ "Can't create CAN device, the model %s is not supported now.\n", d->model);
+ exit(1);
+ can_bus = can_bus_find_by_name(d->canbus, true);
+ if (can_bus == NULL) {
+ qerror_report(ERROR_CLASS_GENERIC_ERROR, "Cannot create can find/allocate CAN bus\n");
+ exit(1);
+ if (d->host != NULL) {
+ if (can_bus_connect_to_host_device(can_bus, d->host) < 0) {
+ qerror_report(ERROR_CLASS_GENERIC_ERROR, "Cannot connect CAN bus to host device \"%s\"\n", d->host);
+ exit(1);
+ pci_conf = pci_dev->config;
+ pci_conf[PCI_INTERRUPT_PIN] = 0x01; /* interrupt pin A */
+ d->irq = pci_allocate_irq(&d->dev);
+ can_sja_init(s, can_pci_irq_raise, can_pci_irq_lower, d);
+ qemu_register_reset(can_pci_reset, d);
+ if (can_sja_connect_to_bus(s, can_bus) < 0) {
+ "can_sja_connect_to_bus failed\n");
+ exit(1);
+ memory_region_init_io(&d->sja_mmio, OBJECT(d), &can_pci_bar0_ops, d,
+ "can_pci-bar0", CAN_SJA_MEM_SIZE);
+ pci_register_bar(pci_dev, /*BAR*/ 0, PCI_BASE_ADDRESS_SPACE_MEMORY, &d->sja_mmio);
+ return 0;
+static void can_pci_exit(PCIDevice *pci_dev)
+ can_sja_disconnect(s);
+ qemu_unregister_reset(can_pci_reset, d);
+ memory_region_destroy(&d->sja_mmio);
+ can_sja_exit(s);
+ qemu_free_irq(d->irq);
+static const VMStateDescription vmstate_can_pci = {
+ .name = "can_pci",
+ .version_id = 1,
+ .minimum_version_id = 1,
+ .minimum_version_id_old = 1,
+ .fields = (VMStateField[]) {
+ VMSTATE_PCI_DEVICE(dev, CanPCIState),
+ VMSTATE_STRUCT(sja_state, CanPCIState, 0, vmstate_can_sja, CanSJA1000State),
+ /*char *model,*/
+ VMSTATE_END_OF_LIST()
+static void qdev_can_pci_reset(DeviceState *dev)
+ CanPCIState *d = CAN_PCI_DEV(dev);
+ can_pci_reset(d);
+static Property can_pci_properties[] = {
+ DEFINE_PROP_STRING("canbus", CanPCIState, canbus),
+ DEFINE_PROP_STRING("host", CanPCIState, host),
+ DEFINE_PROP_STRING("model", CanPCIState, model),
+ DEFINE_PROP_END_OF_LIST(),
+static void can_pci_class_init(ObjectClass *klass, void *data)
+ DeviceClass *dc = DEVICE_CLASS(klass);
+ PCIDeviceClass *k = PCI_DEVICE_CLASS(klass);
+ k->init = can_pci_init;
+ k->exit = can_pci_exit;
+ k->vendor_id = PCI_VENDOR_ID_CAN_PCI;
+ k->device_id = PCI_DEVICE_ID_CAN_PCI;
+ k->revision = PCI_REVISION_ID_CAN_PCI;
+ k->class_id = PCI_CLASS_COMMUNICATION_OTHER;
+ dc->desc = "CAN PCI SJA1000";
+ dc->props = can_pci_properties;
+ dc->vmsd = &vmstate_can_pci;
+ set_bit(DEVICE_CATEGORY_MISC, dc->categories);
+ dc->reset = qdev_can_pci_reset;
+static const TypeInfo can_pci_info = {
+ .name = TYPE_CAN_PCI_DEV,
+ .parent = TYPE_PCI_DEVICE,
+ .instance_size = sizeof(CanPCIState),
+ .class_init = can_pci_class_init,
+static void can_pci_register_types(void)
+ type_register_static(&can_pci_info);
+type_init(can_pci_register_types)
diff --git a/hw/net/can_sja1000.c b/hw/net/can_sja1000.c
index 0000000..9615532
--- /dev/null
+++ b/hw/net/can_sja1000.c
@@ -0,0 +1,878 @@
+ * CAN device - SJA1000 chip emulation for QEMU
+ * THE SOFTWARE.
+#include "hw/hw.h"
+//#define DEBUG_FILTER
+static void can_sja_software_reset(CanSJA1000State *s)
+ s->mode &= ~0x31;
+ s->mode |= 0x01;
+ s->statusP &= ~0x37;
+ s->statusP |= 0x34;
+ s->rxbuf_start = 0x00;
+ s->rxmsg_cnt = 0x00;
+ s->rx_cnt = 0x00;
+void can_sja_hardware_reset(CanSJA1000State *s)
+ /* Reset by hardware, p10 */
+ s->mode = 0x01;
+ s->statusP = 0x3c;
+ s->interruptP = 0x00;
+ s->clock = 0x00;
+ s->rx_cnt = 0x00;
+ s->control = 0x01;
+ s->statusB = 0x0c;
+ s->interruptB = 0x00;
+ s->irq_lower(s->irq_opaque);
+/* Details in DS-p22, what we need to do here is to test the data. */
+static int can_sja_accept_filter(CanSJA1000State *s, const qemu_can_frame *frame)
+ uint8_t tmp1, tmp2;
+ if (s->clock & 0x80) { // PeliCAN Mode
+ if(s->mode & (1 << 3)) { // Single mode.
+ if(!(frame->can_id & (1 << 31))) { // SFF
+ if(frame->can_id & (1 << 30)) // RTR
+ return 1;
+ if(frame->can_dlc == 0)
+ return 1;
+ if(frame->can_dlc == 1)
+ if((frame->data[0] & ~(s->code_mask[6])) ==
+ (s->code_mask[2] & ~(s->code_mask[6])))
+ return 1;
+ if(frame->can_dlc >= 2)
+ if(((frame->data[0] & ~(s->code_mask[6])) ==
+ (s->code_mask[2] & ~(s->code_mask[6]))) &&
+ ((frame->data[1] & ~(s->code_mask[7])) ==
+ (s->code_mask[3] & ~(s->code_mask[7]))))
+ return 1;
+ return 0;
+ } else { // Dual mode
+ if(((s->code_mask[0] & ~s->code_mask[4]) ==
+ (((frame->can_id >> 3) & 0xff) & ~s->code_mask[4])) &&
+ (((s->code_mask[1] & ~s->code_mask[5]) & 0xe0) ==
+ (((frame->can_id << 5) & ~s->code_mask[5]) & 0xe0))) {
+ return 1;
+ else {
+ tmp1 = ((s->code_mask[1] << 4) & 0xf0) |
+ (s->code_mask[2] & 0x0f);
+ tmp2 = ((s->code_mask[5] << 4) & 0xf0) |
+ (s->code_mask[6] & 0x0f);
+ tmp2 = ~tmp2;
+ if((tmp1 & tmp2) == (frame->data[0] & tmp2))
+ return 1;
+ return 0;
+ return 1;
+#ifdef DEBUG_FILTER
+static void can_display_msg(const qemu_can_frame *msg)
+ int i;
+ printf("%03X [%01d] -", (msg->can_id & 0x1fffffff), msg->can_dlc);
+ if(msg->can_id & (1 << 31)) printf("EFF "); else printf("SFF ");
+ if(msg->can_id & (1 << 30)) printf("RTR-"); else printf("DAT-");
+ for(; i < 8; i++)
+ printf(" ");
+ fflush(stdout);
+#endif
+static void buff2frameP(const uint8_t *buff, qemu_can_frame *frame)
+ uint8_t i;
+ frame->can_id = 0;
+ if (buff[0] & 0x40) // RTR
+ frame->can_id = 0x01 << 30;
+ frame->can_dlc = buff[0] & 0x0f;
+ if (buff[0] & 0x80) { // Extended
+ frame->can_id |= 0x01 << 31;
+ frame->can_id |= buff[1] << 21; // ID.28~ID.21
+ frame->can_id |= buff[2] << 13; // ID.20~ID.13
+ frame->can_id |= buff[3] << 05;
+ frame->can_id |= buff[4] >> 03;
+ for (i = 0; i < frame->can_dlc; i++)
+ frame->data[i] = buff[5+i];
+ for (; i < 8; i++)
+ frame->data[i] = 0;
+ } else {
+ frame->can_id |= buff[1] << 03;
+ frame->can_id |= buff[2] >> 05;
+ frame->data[i] = buff[3+i];
+static void buff2frameB(const uint8_t *buff, qemu_can_frame *frame)
+ uint8_t i;
+ frame->can_id = ((buff[0] << 3) & (0xff << 3)) + ((buff[1] >> 5) & 0x07);
+ if (buff[1] & 0x10) // RTR
+ frame->can_dlc = buff[1] & 0x0f;
+ frame->data[i] = buff[2+i];
+static int frame2buffP(const qemu_can_frame *frame, uint8_t *buff)
+ int i, count = 0;
+ if(frame->can_id & (1 << 29)) // error frame, NOT support now.
+ return -1;
+ buff[count] = 0x0f & frame->can_dlc; // DLC
+ buff[count] |= (1 << 6);
+ if(frame->can_id & (1 << 31)) { // EFF
+ buff[count] |= (1 << 7);
+ buff[++count] = (frame->can_id >> 21) & 0xff; // ID.28~ID.21
+ buff[++count] = (frame->can_id >> 13) & 0xff; // ID.20~ID.13
+ buff[++count] = (frame->can_id >> 05) & 0xff; // ID.12~ID.05
+ buff[++count] = (frame->can_id << 03) & 0xf8; // ID.04~ID.00,x,x,x
+ for (i = 0; i < frame->can_dlc; i++) {
+ buff[++count] = frame->data[i];
+ return count + 1;
+ } else { // SFF
+ buff[++count] = (frame->can_id >> 03) & 0xff; // ID.10~ID.03
+ buff[++count] = (frame->can_id << 05) & 0xe0; // ID.02~ID.00,x,x,x,x,x
+ return count + 1;
+ return -1;
+static int frame2buffB(const qemu_can_frame *frame, uint8_t *buff)
+ int i, count = 0;
+ if((frame->can_id & (1 << 31)) || // EFF, not support for BasicMode.
+ (frame->can_id & (1 << 29))) // or Error frame, NOT support now.
+ return -1;
+ buff[count++] = 0xff & (frame->can_id >> 3);
+ buff[count] = 0xe0 & (frame->can_id << 5);
+ buff[count] |= (1 << 4);
+ buff[count++] |= frame->can_dlc & 0x0f;
+ buff[count++] = frame->data[i];
+ printf(" ==2==");
+ for (i = 0; i < count; i++)
+ printf(" %02X", buff[i]);
+ for (; i < 10; i++)
+ printf(" ");
+#endif
+ return count;
+void can_sja_mem_write(CanSJA1000State *s, hwaddr addr, uint64_t val, unsigned size)
+ qemu_can_frame frame;
+ uint32_t tmp;
+ uint8_t tmp8, count;
+ DPRINTF("write 0x%02llx addr 0x%02x\n", (unsigned long long)val, (unsigned int)addr);
+ if(addr > CAN_SJA_MEM_SIZE)
+ return ;
+ switch (addr) {
+ case SJA_MOD: // Mode register
+ s->mode = 0x1f & val;
+ if((s->mode & 0x01) && ((val & 0x01) == 0)) {
+ // Go to operation mode from reset mode.
+ // For EFF
+ tmp = ((s->code_mask[0] << 21) & (0xff << 21)) |
+ ((s->code_mask[1] << 13) & (0xff << 13)) |
+ ((s->code_mask[2] << 5) & (0xff << 5)) |
+ ((s->code_mask[3] >> 3) & 0x1f) |
+ (1 << 31);
+ s->filter[0].can_id = tmp;
+ tmp = ((s->code_mask[4] << 21) & (0xff << 21)) |
+ ((s->code_mask[5] << 13) & (0xff << 13)) |
+ ((s->code_mask[6] << 5) & (0xff << 5)) |
+ ((s->code_mask[7] >> 3) & 0x1f) |
+ (7 << 29);
+ s->filter[0].can_mask = ~tmp | (1 << 31);
+ if(s->code_mask[3] & (1 << 2)) // RTR
+ s->filter[0].can_id |= (1 << 30);
+ if(!(s->code_mask[7] & (1 << 2)))
+ s->filter[0].can_mask |= (1 << 30);
+ // For SFF
+ tmp = ((s->code_mask[0] << 3) & (0xff << 3)) |
+ ((s->code_mask[1] >> 5) & 0x07);
+ s->filter[1].can_id = tmp;
+ tmp = ((s->code_mask[4] << 3) & (0xff << 3)) |
+ ((s->code_mask[5] >> 5) & 0x07) |
+ (0xff << 11) | (0xff << 19) | (0x0f << 27);
+ s->filter[1].can_mask = ~tmp | (1 << 31);
+ if(s->code_mask[1] & (1 << 4)) // RTR
+ s->filter[1].can_id |= (1 << 30);
+ if(!(s->code_mask[5] & (1 << 4)))
+ s->filter[1].can_mask |= (1 << 30);
+ can_bus_client_set_filters(&s->bus_client, s->filter, 2);
+ // For EFF
+ (1 << 31);
+ (0xff << 5) | (0xff >> 3) |
+ (7 << 29);
+ tmp = ((s->code_mask[2] << 21) & (0xff << 21)) |
+ ((s->code_mask[3] << 13) & (0xff << 13)) |
+ (1 << 31);
+ tmp = ((s->code_mask[6] << 21) & (0xff << 21)) |
+ ((s->code_mask[7] << 13) & (0xff << 13)) |
+ (7 << 29);
+ // For SFF
+ s->filter[2].can_id = tmp;
+ s->filter[2].can_mask = ~tmp | (1 << 31);
+ s->filter[2].can_id |= (1 << 30);
+ s->filter[2].can_mask |= (1 << 30);
+ tmp = ((s->code_mask[2] << 3) & (0xff << 3)) |
+ ((s->code_mask[3] >> 5) & 0x07);
+ s->filter[3].can_id = tmp;
+ tmp = ((s->code_mask[6] << 3) & (0xff << 3)) |
+ ((s->code_mask[7] >> 5) & 0x07) |
+ s->filter[3].can_mask = ~tmp | (1 << 31);
+ if(s->code_mask[3] & (1 << 4)) // RTR
+ s->filter[3].can_id |= (1 << 30);
+ if(!(s->code_mask[7] & (1 << 4)))
+ s->filter[3].can_mask |= (1 << 30);
+ can_bus_client_set_filters(&s->bus_client, s->filter, 4);
+ s->rxmsg_cnt = 0;
+ s->rx_cnt = 0;
+ break;
+ case SJA_CMR: // Command register.
+ if (0x01 & val) { // Send transmission request.
+ buff2frameP(s->tx_buff, &frame);
+ can_display_msg(&frame);printf("\n");
+#endif
+ s->statusP &= ~(3 << 2); // Clear transmission complete status,
+ // and Transmit Buffer Status.
+ // write to the backends.
+ can_bus_client_send(&s->bus_client, &frame, 1);
+ s->statusP |= (3 << 2); // Set transmission complete status,
+ s->statusP &= ~(1 << 5); // Clear transmit status.
+ s->interruptP |= 0x02;
+ if (s->interrupt_en & 0x02)
+ s->irq_raise(s->irq_opaque);
+ } else if ( 0x04 & val) { // Release Receive Buffer
+ if (s->rxmsg_cnt <= 0)
+ break;
+ tmp8 = s->rx_buff[s->rxbuf_start]; count = 0;
+ if (tmp8 & (1 << 7)) // EFF
+ count += 2;
+ count += 3;
+ if (!(tmp8 & (1 << 6))) // DATA
+ count += (tmp8 & 0x0f);
+ s->rxbuf_start += count;
+ s->rxbuf_start %= SJA_RCV_BUF_LEN;
+ s->rx_cnt -= count;
+ s->rxmsg_cnt--;
+ if(s->rxmsg_cnt == 0) {
+ s->statusP &= ~(1 << 0);
+ s->interruptP &= ~(1 << 0);
+ if((s->interrupt_en & 0x01) && (s->interruptP == 0)) // no other interrupts.
+ } else if ( 0x08 & val) { // Clear data overrun
+ s->statusP &= ~(1 << 1);
+ s->interruptP &= ~(1 << 3);
+ if((s->interrupt_en & 0x80) && (s->interruptP == 0)) // no other interrupts.
+ break;
+ case SJA_SR: // Status register
+ case SJA_IR: // Interrupt register
+ break; // Do nothing
+ case SJA_IER: // Interrupt enable register
+ s->interrupt_en = val;
+ break;
+ case 16: // RX frame information addr16-28.
+ s->statusP |= (1 << 5); // Set transmit status.
+ case 17:
+ case 18:
+ case 19:
+ case 20:
+ case 21:
+ case 22:
+ case 23:
+ case 24:
+ case 25:
+ case 26:
+ case 27:
+ case 28:
+ if (s->mode & 0x01) { // Reset mode
+ if (addr < 24) {
+ s->code_mask[addr - 16] = val;
+ } else // Operation mode
+ s->tx_buff[addr - 16] = val; // Store to TX buffer directly.
+ break;
+ case SJA_CDR:
+ s->clock = val;
+ break;
+ } else { // Basic Mode
+ switch (addr) {
+ case SJA_BCAN_CTR: // Control register, addr 0
+ if((s->control & 0x01) && ((val & 0x01) == 0)) {
+ s->filter[0].can_id = (s->code << 3) & (0xff << 3);
+ tmp = (~(s->mask << 3)) & (0xff << 3);
+ tmp |= (1 << 31);// Only Basic CAN Frame.
+ s->filter[0].can_mask = tmp;
+ can_bus_client_set_filters(&s->bus_client, s->filter, 1);
+ s->rxmsg_cnt = 0;
+ s->rx_cnt = 0;
+ } else if(!(s->control & 0x01) && !(val & 0x01)){
+ can_sja_software_reset(s);
+ s->control = 0x1f & val;
+ break;
+ case SJA_BCAN_CMR: // Command register, addr 1
+ buff2frameB(s->tx_buff, &frame);
+#endif
+ s->statusB &= ~(3 << 2); // Clear transmission complete status,
+ s->statusB |= (3 << 2); // Set transmission complete status,
+ s->statusB &= ~(1 << 5); // Clear transmit status.
+ s->interruptB |= 0x02;
+ if (s->control & 0x04){
+ break;
+ qemu_mutex_lock(&s->rx_lock);
+ tmp8 = s->rx_buff[(s->rxbuf_start + 1) % SJA_RCV_BUF_LEN];
+ count = 2 + (tmp8 & 0x0f);
+ printf("\nRelease");
+ for(i = 0; i < count; i++)
+ printf(" %02X", s->rx_buff[(s->rxbuf_start + i) % SJA_RCV_BUF_LEN]);
+ for(; i < 11; i++)
+ printf(" ");
+ printf("==== cnt=%d, count=%d\n", s->rx_cnt, count);
+#endif
+ s->rxmsg_cnt--;
+ qemu_mutex_unlock(&s->rx_lock);
+ s->statusB &= ~(1 << 0);
+ s->interruptB &= ~(1 << 0);
+ if((s->control & 0x02) && (s->interruptB == 0)) // no other interrupts.
+ s->statusB &= ~(1 << 1);
+ s->interruptB &= ~(1 << 3);
+ if((s->control & 0x10) && (s->interruptB == 0)) // no other interrupts.
+ break;
+ case 4:
+ s->code = val;
+ break;
+ case 5:
+ s->mask = val;
+ break;
+ case 10:
+ s->statusB |= (1 << 5); // Set transmit status.
+ case 11:
+ case 12:
+ case 13:
+ case 14:
+ case 15:
+ case 16:
+ case 17:
+ case 18:
+ case 19:
+ if ((s->control & 0x01) == 0) { // Operation mode
+ s->tx_buff[addr - 10] = val; // Store to TX buffer directly.
+ break;
+ case SJA_CDR:
+ s->clock = val;
+ break;
+uint64_t can_sja_mem_read(CanSJA1000State *s, hwaddr addr, unsigned size)
+ uint64_t temp = 0;
+ DPRINTF("read addr 0x%x", (unsigned int)addr);
+ return 0;
+ switch (addr) {
+ case SJA_MOD: // Mode register, addr 0
+ temp = s->mode;
+ break;
+ case SJA_CMR: // Command register, addr 1
+ temp = 0x00; // Command register, cannot be read.
+ break;
+ case SJA_SR: // Status register, addr 2
+ temp = s->statusP;
+ break;
+ case SJA_IR: // Interrupt register, addr 3
+ temp = s->interruptP;
+ s->interruptP = 0;
+ if (s->rxmsg_cnt) {
+ s->interruptP |= (1 << 0); // Receive interrupt.
+ break;
+ break;
+ case SJA_IER: // Interrupt enable register, addr 4
+ temp = s->interrupt_en;
+ break;
+ case 5: // Reserved
+ case 6: // Bus timing 0, hardware related, not support now.
+ case 7: // Bus timing 1, hardware related, not support now.
+ case 8: // Output control register, hardware related, not support now.
+ case 9: // Test.
+ case 10: // Reserved
+ case 11:
+ case 12:
+ case 13:
+ case 14:
+ case 15:
+ temp = 0x00;
+ break;
+ case 16:
+ case 17:
+ case 18:
+ case 19:
+ case 20:
+ case 21:
+ case 22:
+ case 23:
+ case 24:
+ case 25:
+ case 26:
+ case 27:
+ case 28:
+ if (addr < 24)
+ temp = s->code_mask[addr - 16];
+ else
+ temp = 0x00;
+ } else { // Operation mode
+ temp = s->rx_buff[(s->rxbuf_start + addr - 16) % SJA_RCV_BUF_LEN];
+ break;
+ case SJA_CDR:
+ temp = s->clock;
+ break;
+ default:
+ temp = 0xff;
+ switch (addr) {
+ temp = s->control;
+ break;
+ case SJA_BCAN_SR: // Status register, addr 2
+ temp = s->statusB;
+ break;
+ case SJA_BCAN_IR: // Interrupt register, addr 3
+ temp = s->interruptB;
+ s->interruptB = 0;
+ s->interruptB |= (1 << 0); // Receive interrupt.
+ break;
+ break;
+ case 4:
+ temp = s->code;
+ break;
+ case 5:
+ temp = s->mask;
+ break;
+ case 20:
+ printf("Read ");
+#endif
+ case 21:
+ case 22:
+ case 23:
+ case 24:
+ case 25:
+ case 26:
+ case 27:
+ case 28:
+ case 29:
+ temp = s->rx_buff[(s->rxbuf_start + addr - 20) % SJA_RCV_BUF_LEN];
+ printf(" %02X", (unsigned int)(temp & 0xff));
+#endif
+ break;
+ case 31:
+ temp = s->clock;
+ break;
+ default:
+ temp = 0xff;
+ break;
+ DPRINTF(" %d bytes of 0x%lx from addr %d\n", size, (long unsigned int)temp, (int)addr);
+ return temp;
+int can_sja_can_receive(CanBusClientState *client)
+ CanSJA1000State *s = container_of(client, CanSJA1000State, bus_client);
+ if(s->mode & 0x01) // reset mode.
+ return 0;
+ } else { // BasicCAN mode
+ if(s->control & 0x01)
+ return 0;
+ return 1; // always return 1, when operation mode
+ssize_t can_sja_receive(CanBusClientState *client, const qemu_can_frame *frames, size_t frames_cnt)
+ static uint8_t rcv[SJA_MSG_MAX_LEN];
+ int i;
+ int ret = -1;
+ const qemu_can_frame *frame = frames;
+ if(frames_cnt <= 0)
+ return 0;
+ printf("#################################################\n");
+ can_display_msg(frame);
+#endif
+ qemu_mutex_lock(&s->rx_lock); // Just do it quickly :)
+ s->statusP |= (1 << 4); // the CAN controller is receiving a message
+ if(can_sja_accept_filter(s, frame) == 0) {
+ s->statusP &= ~(1 << 4);
+ printf(" NOT\n");
+#endif
+ goto fail;
+ if((ret = frame2buffP(frame, rcv)) < 0) {
+ printf(" ERR\n");
+#endif
+ goto fail; // maybe not support now.
+ if(s->rx_cnt + ret > SJA_RCV_BUF_LEN) { // Data overrun.
+ s->statusP |= (1 << 1); // Overrun status
+ s->interruptP |= (1 << 3);
+ if (s->interrupt_en & (1 << 3)) // Overrun interrupt enable
+ printf(" OVER\n");
+#endif
+ goto fail;
+ s->rx_cnt += ret;
+ s->rxmsg_cnt++;
+ printf(" OK\n");
+#endif
+ for(i = 0; i < ret; i++) {
+ s->rx_buff[(s->rx_ptr++) % SJA_RCV_BUF_LEN] = rcv[i];
+ s->rx_ptr %= SJA_RCV_BUF_LEN; // update the pointer.
+ s->statusP |= 0x01; // Set the Receive Buffer Status. DS-p23
+ s->interruptP |= 0x01;
+ s->statusP |= (1 << 0);
+ if(s->interrupt_en & 0x01) // Receive Interrupt enable.
+ s->statusB |= (1 << 4); // the CAN controller is receiving a message
+ if((ret = frame2buffB(frame, rcv)) < 0) {
+ s->statusB &= ~(1 << 4);
+ printf(" NOT\n");
+#endif
+ s->statusB |= (1 << 1); // Overrun status
+ s->interruptB |= (1 << 3);
+ if (s->control & (1 << 4)) // Overrun interrupt enable
+#endif
+ goto fail;
+ s->rx_cnt += ret;
+ s->rxmsg_cnt++;
+ printf(" OK\n");
+ printf("RCV B ret=%2d, ptr=%2d cnt=%2d msg=%2d\n", ret, s->rx_ptr, s->rx_cnt, s->rxmsg_cnt);
+#endif
+ s->statusB |= 0x01; // Set the Receive Buffer Status. DS-p15
+ s->interruptB |= 0x01;
+ if(s->control & 0x02) { // Receive Interrupt enable.
+ ret = 1;
+fail:
+ return ret;
+static CanBusClientInfo can_sja_bus_client_info = {
+ .can_receive = can_sja_can_receive,
+ .receive = can_sja_receive,
+ .cleanup = NULL,
+ .poll = NULL
+int can_sja_connect_to_bus(CanSJA1000State *s, CanBusState *bus)
+ s->bus_client.info = &can_sja_bus_client_info;
+ if (can_bus_insert_client(bus, &s->bus_client) < 0)
+ return -1;
+ return 0;
+void can_sja_disconnect(CanSJA1000State *s)
+ can_bus_remove_client(&s->bus_client);
+int can_sja_init(CanSJA1000State *s, CanSJAIrqRaiseLower *irq_raise,
+ CanSJAIrqRaiseLower *irq_lower, void *irq_opaque)
+ qemu_mutex_init(&s->rx_lock);
+ s->irq_raise = irq_raise;
+ s->irq_lower = irq_lower;
+ s->irq_opaque = irq_opaque;
+ return 0;
+void can_sja_exit(CanSJA1000State *s)
+ qemu_mutex_destroy(&s->rx_lock);
+const VMStateDescription vmstate_qemu_can_filter = {
+ .name = "qemu_can_filter",
+ .version_id = 1,
+ .fields = (VMStateField []) {
+ VMSTATE_UINT32(can_id, qemu_can_filter),
+ VMSTATE_UINT32(can_mask, qemu_can_filter),
+/* VMState is needed for live migration of Qemu images */
+const VMStateDescription vmstate_can_sja = {
+ .name = "can_sja",
+ .version_id = 1,
+ VMSTATE_UINT8(mode, CanSJA1000State),
+ VMSTATE_UINT8(statusP, CanSJA1000State),
+ VMSTATE_UINT8(interruptP, CanSJA1000State),
+ VMSTATE_UINT8(interrupt_en, CanSJA1000State),
+ VMSTATE_UINT8(rxmsg_cnt, CanSJA1000State),
+ VMSTATE_UINT8(rxbuf_start, CanSJA1000State),
+ VMSTATE_UINT8(clock, CanSJA1000State),
+ VMSTATE_BUFFER(code_mask, CanSJA1000State),
+ VMSTATE_BUFFER(tx_buff, CanSJA1000State),
+ VMSTATE_BUFFER(rx_buff, CanSJA1000State),
+ VMSTATE_UINT32(rx_ptr, CanSJA1000State),
+ VMSTATE_UINT32(rx_cnt, CanSJA1000State),
+ VMSTATE_UINT8(control, CanSJA1000State),
+ VMSTATE_UINT8(statusB, CanSJA1000State),
+ VMSTATE_UINT8(interruptB, CanSJA1000State),
+ VMSTATE_UINT8(code, CanSJA1000State),
+ VMSTATE_UINT8(mask, CanSJA1000State),
+ VMSTATE_STRUCT_ARRAY(filter, CanSJA1000State, 4, 0,
+ vmstate_qemu_can_filter, qemu_can_filter),
diff --git a/hw/net/can_sja1000.h b/hw/net/can_sja1000.h
index 0000000..7f0567e
--- /dev/null
+++ b/hw/net/can_sja1000.h
@@ -0,0 +1,163 @@
+ * THE SOFTWARE.
+#ifndef HW_CAN_SJA1000_H
+#define HW_CAN_SJA1000_H
+#define CAN_SJA_MEM_SIZE 128
+/* The max size for a message buffer, EFF and DLC=8, DS-p39 */
+#define SJA_MSG_MAX_LEN 13
+/* The receive buffer size. */
+#define SJA_RCV_BUF_LEN 64
+//#define DEBUG_CAN
+#ifdef DEBUG_CAN
+#define DPRINTF(fmt, ...) \
+ do { fprintf(stderr, "[cansja]: " fmt , ## __VA_ARGS__); } while (0)
+#else
+ do {} while (0)
+#endif
+typedef void (CanSJAIrqRaiseLower)(void *opaque);
+typedef struct CanSJA1000State {
+ /* Some registers ... */
+ uint8_t mode; /* PeliCAN, addr 0, Mode register, DS-p26 */
+ /* PeliCAN, addr 1, Command register */
+ uint8_t statusP; /* PeliCAN, addr 2, Status register, p15 */
+ uint8_t interruptP; /* PeliCAN, addr 3, Interrupt register */
+ uint8_t interrupt_en; /* PeliCAN, addr 4, Interrupt Enable register */
+ uint8_t rxmsg_cnt; /* PeliCAN, addr 29, RX message counter. DS-p49 */
+ uint8_t rxbuf_start; /* PeliCAN, addr 30, RX buffer start address register, DS-p49 */
+ uint8_t clock; /* PeliCAN, addr 31, Clock Divider register, DS-p55 */
+ uint8_t code_mask[8]; /* PeliCAN, addr 16~23 */
+ uint8_t tx_buff[13]; /* PeliCAN, addr 96~108, transmit buffer */
+ /* BasicCAN, addr 10~19, transmit buffer */
+ uint8_t rx_buff[SJA_RCV_BUF_LEN]; /* 32~95, 64bytes */
+ uint32_t rx_ptr; /* Count by bytes. */
+ uint32_t rx_cnt; /* Count by bytes. */
+ uint8_t control; /* BasicCAN, addr 0, Control register */
+ /* BasicCAN, addr 1, Command register */
+ uint8_t statusB; /* BasicCAN, addr 2, Status register */
+ uint8_t interruptB; /* BasicCAN, addr 3, Interrupt register */
+ uint8_t code; /* BasicCAN, addr 4, Acceptance code register */
+ uint8_t mask; /* BasicCAN, addr 5, Acceptance mask register */
+ qemu_can_filter filter[4];
+ QemuMutex rx_lock;
+ CanSJAIrqRaiseLower *irq_raise;
+ CanSJAIrqRaiseLower *irq_lower;
+ void *irq_opaque;
+} CanSJA1000State;
+/* PeliCAN mode */
+enum SJA1000_PeliCAN_regs {
+ SJA_MOD = 0x00,
+/* Command register */
+ SJA_CMR = 0x01,
+/* Status register */
+ SJA_SR = 0x02,
+/* Interrupt register */
+ SJA_IR = 0x03,
+/* Interrupt Enable */
+ SJA_IER = 0x04,
+/* Bus Timing register 0 */
+ SJA_BTR0 = 0x06,
+/* Bus Timing register 1 */
+ SJA_BTR1 = 0x07,
+/* Output Control register */
+ SJA_OCR = 0x08,
+/* Arbitration Lost Capture */
+ SJA_ALC = 0x0b,
+/* Error Code Capture */
+ SJA_ECC = 0x0c,
+/* Error Warning Limit */
+ SJA_EWLR = 0x0d,
+/* RX Error Counter */
+ SJA_RXERR = 0x0e,
+/* TX Error Counter */
+ SJA_TXERR0 = 0x0e,
+ SJA_TXERR1 = 0x0f,
+/* Rx Message Counter (number of msgs. in RX FIFO */
+ SJA_RMC = 0x1d,
+/* Rx Buffer Start Addr. (address of current MSG) */
+ SJA_RBSA = 0x1e,
+/* Transmit Buffer (write) Receive Buffer (read) Frame Information */
+ SJA_FRM = 0x10,
+/* ID bytes (11 bits in 0 and 1 or 16 bits in 0,1 and 13 bits in 2,3 (extended)) */
+ SJA_ID0 = 0x11, SJA_ID1 = 0x12,
+/* ID cont. for extended frames */
+ SJA_ID2 = 0x13, SJA_ID3 = 0x14,
+/* Data start standard frame */
+ SJA_DATS = 0x13,
+/* Data start extended frame */
+ SJA_DATE = 0x15,
+/* Acceptance Code (4 bytes) in RESET mode */
+ SJA_ACR0 = 0x10,
+/* Acceptance Mask (4 bytes) in RESET mode */
+ SJA_AMR0 = 0x14,
+/* 4 bytes */
+ SJA_PeliCAN_AC_LEN = 4,
+/* Clock Divider */
+ SJA_CDR = 0x1f
+/* PeliCAN mode */
+enum SJA1000_BasicCAN_regs {
+ SJA_BCAN_CTR = 0x00,
+ SJA_BCAN_CMR = 0x01,
+ SJA_BCAN_SR = 0x02,
+ SJA_BCAN_IR = 0x03
+void can_sja_hardware_reset(CanSJA1000State *s);
+void can_sja_mem_write(CanSJA1000State *s, hwaddr addr, uint64_t val, unsigned size);
+uint64_t can_sja_mem_read(CanSJA1000State *s, hwaddr addr, unsigned size);
+int can_sja_connect_to_bus(CanSJA1000State *s, CanBusState *bus);
+void can_sja_disconnect(CanSJA1000State *s);
+ CanSJAIrqRaiseLower *irq_lower, void *irq_opaque);
+void can_sja_exit(CanSJA1000State *s);
+int can_sja_can_receive(CanBusClientState *client);
+ssize_t can_sja_receive(CanBusClientState *client, const qemu_can_frame *frames, size_t frames_cnt);
+extern const VMStateDescription vmstate_can_sja;
+#endif
diff --git a/include/net/can_emu.h b/include/net/can_emu.h
index 0000000..69b8f8a
--- /dev/null
+++ b/include/net/can_emu.h
@@ -0,0 +1,123 @@
+ * THE SOFTWARE.
+#ifndef NET_CAN_EMU_H
+#define NET_CAN_EMU_H
+#include "qemu/queue.h"
+/* NOTE: the following two structures is copied from <linux/can.h>. */
+ * Controller Area Network Identifier structure
+ * bit 0-28 : CAN identifier (11/29 bit)
+ * bit 29 : error frame flag (0 = data frame, 1 = error frame)
+ * bit 30 : remote transmission request flag (1 = rtr frame)
+ * bit 31 : frame format flag (0 = standard 11 bit, 1 = extended 29 bit)
+typedef uint32_t qemu_canid_t;
+#if defined(__GNUC__) || defined(__linux__)
+ #define QEMU_CAN_FRAME_DATA_ALIGN __attribute__((aligned(8)))
+#else
+#endif
+typedef struct qemu_can_frame {
+ qemu_canid_t can_id; /* 32 bit CAN_ID + EFF/RTR/ERR flags */
+ uint8_t can_dlc; /* data length code: 0 .. 8 */
+ uint8_t data[8] QEMU_CAN_FRAME_DATA_ALIGN;
+} qemu_can_frame;
+ * struct qemu_can_filter - CAN ID based filter in can_register().
+ * @can_id: relevant bits of CAN ID which are not masked out.
+ * @can_mask: CAN mask (see description)
+ * Description:
+ * A filter matches, when
+ * <received_can_id> & mask == can_id & mask
+ * The filter can be inverted (CAN_INV_FILTER bit set in can_id) or it can
+ * filter for error message frames (CAN_ERR_FLAG bit set in mask).
+typedef struct qemu_can_filter {
+ qemu_canid_t can_mask;
+} qemu_can_filter;
+#define CAN_INV_FILTER 0x20000000U /* to be set in qemu_can_filter.can_id */
+typedef struct CanBusClientState CanBusClientState;
+typedef struct CanBusState CanBusState;
+typedef void (CanBusClientPoll)(CanBusClientState *, bool enable);
+typedef int (CanBusClientCanReceive)(CanBusClientState *);
+typedef ssize_t (CanBusClientReceive)(CanBusClientState *, const struct qemu_can_frame *frames, size_t frames_cnt);
+typedef void (CanBusClientCleanup) (CanBusClientState *);
+typedef void (CanBusClientDestructor)(CanBusClientState *);
+typedef struct CanBusClientInfo {
+ /*CanBusClientOptionsKind type;*/
+ size_t size;
+ CanBusClientCanReceive *can_receive;
+ CanBusClientReceive *receive;
+ CanBusClientCleanup *cleanup;
+ CanBusClientPoll *poll;
+} CanBusClientInfo;
+struct CanBusClientState {
+ CanBusClientInfo *info;
+ CanBusState *bus;
+ int link_down;
+ QTAILQ_ENTRY(CanBusClientState) next;
+ /*CanBusQueue *incoming_queue;*/
+ char *model;
+ char *name;
+ /*unsigned receive_disabled : 1;*/
+ CanBusClientDestructor *destructor;
+ /*unsigned int queue_index;*/
+ /*unsigned rxfilter_notify_enabled:1;*/
+struct CanBusState {
+ char *name;
+ QTAILQ_HEAD(, CanBusClientState) clients;
+ QTAILQ_ENTRY(CanBusState) next;
+CanBusState *can_bus_find_by_name(const char *name, bool create_missing);
+int can_bus_insert_client(CanBusState *bus, CanBusClientState *client);
+int can_bus_remove_client(CanBusClientState *client);
+ssize_t can_bus_client_send(CanBusClientState *, const struct qemu_can_frame *frames, size_t frames_cnt);
+int can_bus_client_set_filters(CanBusClientState *, const struct qemu_can_filter *filters, size_t filters_cnt);
+int can_bus_connect_to_host_device(CanBusState *bus, const char *host_dev_name);
+#endif
1.9.1
