[PATCH 1/3] bsps/sparc: Make lines in SPARC BSPs adhere to 80 character limit.
Daniel Cederman cederman at gaisler.com
Mon May 12 14:39:07 UTC 2014
 c/src/lib/libbsp/sparc/configure.ac                |    3 +-
 c/src/lib/libbsp/sparc/erc32/configure.ac          |   13 +-
 .../lib/libbsp/sparc/erc32/console/erc32_console.c |    9 +-
 .../lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c |    3 +-
 c/src/lib/libbsp/sparc/erc32/include/bsp.h         |    4 +-
 c/src/lib/libbsp/sparc/erc32/include/erc32.h       |   34 ++--
 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c         |    6 +-
 c/src/lib/libbsp/sparc/leon2/clock/ckinit.c        |    6 +-
 c/src/lib/libbsp/sparc/leon2/configure.ac          |   13 +-
 c/src/lib/libbsp/sparc/leon2/include/bsp.h         |    4 +-
 c/src/lib/libbsp/sparc/leon2/include/leon.h        |    6 +-
 c/src/lib/libbsp/sparc/leon2/include/rasta.h       |   18 +-
 c/src/lib/libbsp/sparc/leon2/pci/pci.c             |  181 +++++++++++++-------
 c/src/lib/libbsp/sparc/leon2/rasta/rasta.c         |   12 +-
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |    3 +-
 c/src/lib/libbsp/sparc/leon3/configure.ac          |    7 +-
 c/src/lib/libbsp/sparc/leon3/include/bsp.h         |   13 +-
 c/src/lib/libbsp/sparc/leon3/include/leon.h        |   14 +-
 .../sparc/leon3/leon_smc91111/leon_smc91111.c      |    3 +-
 c/src/lib/libbsp/sparc/leon3/pci/pci.c             |  118 ++++++++-----
 c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c      |    5 +-
 21 files changed, 292 insertions(+), 183 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/configure.ac b/c/src/lib/libbsp/sparc/configure.ac
index 72655f3..de5a642 100644
--- a/c/src/lib/libbsp/sparc/configure.ac
+++ b/c/src/lib/libbsp/sparc/configure.ac
@@ -1,7 +1,8 @@
 ## Process this file with autoconf to produce a configure script.
 AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libbsp-sparc],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
+AC_INIT([rtems-c-src-lib-libbsp-sparc],
+[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
 AC_CONFIG_SRCDIR([shared])
 RTEMS_TOP(../../../../..)
diff --git a/c/src/lib/libbsp/sparc/erc32/configure.ac b/c/src/lib/libbsp/sparc/erc32/configure.ac
index 8155514..4cbfb7e 100644
--- a/c/src/lib/libbsp/sparc/erc32/configure.ac
+++ b/c/src/lib/libbsp/sparc/erc32/configure.ac
@@ -1,7 +1,8 @@
 AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libbsp-sparc-erc32],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
+AC_INIT([rtems-c-src-lib-libbsp-sparc-erc32],
 AC_CONFIG_SRCDIR([bsp_specs])
 RTEMS_TOP(../../../../../..)
@@ -23,11 +24,11 @@ AM_CONDITIONAL(HAS_SMP,[test "$rtems_cv_HAS_SMP" = "yes"])
 RTEMS_BSPOPTS_SET([CONSOLE_USE_INTERRUPTS],[*],[0])
 RTEMS_BSPOPTS_HELP([CONSOLE_USE_INTERRUPTS],
 [The erc32 console driver can operate in either polled or interrupt mode.
-Under the simulator (especially when FAST_UART is defined), polled seems to operate
-better.  It is common for a task to print a line (like the end of test message) and
-then exit.  In this case, the program returns control to the simulator command line
-before the program has even queued the output to the uart.  Thus sis has no chance
-of getting the data out.])
+Under the simulator (especially when FAST_UART is defined), polled seems
+to operate better. It is common for a task to print a line (like the end
+of test message) and then exit.  In this case, the program returns control
+to the simulator command line before the program has even queued the output
+to the uart.  Thus sis has no chance of getting the data out.])
 RTEMS_BSPOPTS_SET([SIMSPARC_FAST_IDLE],[*],[])
 RTEMS_BSPOPTS_HELP([SIMSPARC_FAST_IDLE],
diff --git a/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c b/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c
index 4965f2f..212d5e0 100644
--- a/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c
+++ b/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c
@@ -147,7 +147,8 @@ static int erc32_console_first_open(int major, int minor, void *arg)
 #if (CONSOLE_USE_INTERRUPTS)
-static ssize_t erc32_console_write_support_int(int minor, const char *buf, size_t len)
+static ssize_t erc32_console_write_support_int(
+		int minor, const char *buf, size_t len)
   if (len > 0) {
     console_data *cd = &Console_Port_Data[minor];
@@ -155,13 +156,15 @@ static ssize_t erc32_console_write_support_int(int minor, const char *buf, size_
     if (minor == 0) { /* uart a */
       for (k = 0;
-           k < len && (ERC32_MEC.UART_Status & ERC32_MEC_UART_STATUS_THEA); k ++) {
+           k < len && (ERC32_MEC.UART_Status & ERC32_MEC_UART_STATUS_THEA);
+           k ++) {
         ERC32_MEC.UART_Channel_A = (unsigned char)buf[k];
       ERC32_Force_interrupt(ERC32_INTERRUPT_UART_A_RX_TX);
     } else { /* uart b */
       for (k = 0;
-           k < len && (ERC32_MEC.UART_Status & ERC32_MEC_UART_STATUS_THEB); k ++) {
+           k < len && (ERC32_MEC.UART_Status & ERC32_MEC_UART_STATUS_THEB);
+           k ++) {
         ERC32_MEC.UART_Channel_B = (unsigned char)buf[k];
       ERC32_Force_interrupt(ERC32_INTERRUPT_UART_B_RX_TX);
diff --git a/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c b/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c
index 31f81b7..baa39ed 100644
--- a/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c
+++ b/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c
@@ -98,7 +98,8 @@ sonic_configuration_t erc32_sonic_configuration = {
 int rtems_erc32_sonic_driver_attach(struct rtems_bsdnet_ifconfig *config)
-  ERC32_MEC.IO_Configuration |= (0x15 << (((SONIC_BASE_ADDRESS >> 24) & 0x3) * 8));
+  ERC32_MEC.IO_Configuration |=
+		  (0x15 << (((SONIC_BASE_ADDRESS >> 24) & 0x3) * 8));
   ERC32_MEC.Control &= ~0x60001; /* Disable DMA time-out, parity & power-down */
   ERC32_MEC.Control |= 0x10000; 		/* Enable DMA */
   ERC32_MEC.Interrupt_Mask &= ~(1 << (SONIC_VECTOR - 0x10));
diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
index 47aefdd..b2c1b91 100644
--- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
@@ -98,8 +98,8 @@ void bsp_spurious_initialize( void );
 /* Allocate 8-byte aligned non-freeable pre-malloc() memory. The function
  * can be called at any time. The work-area will shrink when called before
- * bsp_work_area_initialize(). malloc() is called to get memory when this function
- * is called after bsp_work_area_initialize().
+ * bsp_work_area_initialize(). malloc() is called to get memory when this
+ * function is called after bsp_work_area_initialize().
 void *bsp_early_malloc(int size);
diff --git a/c/src/lib/libbsp/sparc/erc32/include/erc32.h b/c/src/lib/libbsp/sparc/erc32/include/erc32.h
index 5520cdb..f3eb293 100644
--- a/c/src/lib/libbsp/sparc/erc32/include/erc32.h
+++ b/c/src/lib/libbsp/sparc/erc32/include/erc32.h
@@ -257,23 +257,23 @@ typedef struct {
  *  The following defines the bits in the Timer Control Register.
-#define ERC32_MEC_TIMER_CONTROL_GCR    0x00000001  /* 1 = reload at 0 */
-                                               /* 0 = stop at 0 */
-#define ERC32_MEC_TIMER_CONTROL_GCL    0x00000002  /* 1 = load and start */
-                                               /* 0 = no function */
-#define ERC32_MEC_TIMER_CONTROL_GSE    0x00000004  /* 1 = enable counting */
-                                               /* 0 = hold scalar and counter */
-#define ERC32_MEC_TIMER_CONTROL_GSL    0x00000008  /* 1 = load scalar and start */
-#define ERC32_MEC_TIMER_CONTROL_RTCCR  0x00000100  /* 1 = reload at 0 */
-#define ERC32_MEC_TIMER_CONTROL_RTCCL  0x00000200  /* 1 = load and start */
-#define ERC32_MEC_TIMER_CONTROL_RTCSE  0x00000400  /* 1 = enable counting */
-#define ERC32_MEC_TIMER_CONTROL_RTCSL  0x00000800  /* 1 = load scalar and start */
+#define ERC32_MEC_TIMER_CONTROL_GCR   0x00000001 /* 1 = reload at 0 */
+                                              /* 0 = stop at 0 */
+#define ERC32_MEC_TIMER_CONTROL_GCL   0x00000002 /* 1 = load and start */
+                                              /* 0 = no function */
+#define ERC32_MEC_TIMER_CONTROL_GSE   0x00000004 /* 1 = enable counting */
+                                              /* 0 = hold scalar and counter */
+#define ERC32_MEC_TIMER_CONTROL_GSL   0x00000008 /* 1 = load scalar and start*/
+#define ERC32_MEC_TIMER_CONTROL_RTCCR 0x00000100 /* 1 = reload at 0 */
+#define ERC32_MEC_TIMER_CONTROL_RTCCL 0x00000200 /* 1 = load and start */
+#define ERC32_MEC_TIMER_CONTROL_RTCSE 0x00000400 /* 1 = enable counting */
+#define ERC32_MEC_TIMER_CONTROL_RTCSL 0x00000800 /* 1 = load scalar and start*/
  *  The following defines the bits in the UART Control Registers.
diff --git a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c b/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
index 241dcdd..c1f4d43 100644
--- a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
+++ b/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
@@ -166,7 +166,8 @@ int init_pcif(void){
 	printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",1,ambab->bar1,pcib->bar1);
 	printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",2,ambab->bar2,pcib->bar2);
 #endif
-	ambab->ambabars[0] = 0x40000000; /* 0xe0000000(AMBA) ==> 0x40000000(PCI) ==> 0x40000000(AT697 AMBA) */
+	/* 0xe0000000(AMBA) ==> 0x40000000(PCI) ==> 0x40000000(AT697 AMBA) */
+	ambab->ambabars[0] = 0x40000000;
 	/* Scan bus for AMBA devices */
 	abus = &cc1.amba_bus;
@@ -328,7 +329,8 @@ void cchip1_set_isr(void *handler, int irqno, void *arg){
 	int_handlers[irqno].handler = handler;
 	int_handlers[irqno].arg = arg;
 #ifdef DEBUG
-	printk("Registering IRQ %d to 0x%lx(%d,0x%lx)\n\r",irqno,(unsigned int)handler,irqno,(unsigned int)arg);
+	printk("Registering IRQ %d to 0x%lx(%d,0x%lx)\n\r",
+			irqno,(unsigned int)handler,irqno,(unsigned int)arg);
 #endif
 	cc1.pcib->imask |= 1<<irqno; /* Enable the registered IRQ */
diff --git a/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
index 345ef37..70e8e81 100644
--- a/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
@@ -46,7 +46,8 @@ extern int CLOCK_SPEED;
 #define Clock_driver_support_initialize_hardware() \
   do { \
-    LEON_REG.Timer_Reload_1 = rtems_configuration_get_microseconds_per_tick() - 1; \
+    LEON_REG.Timer_Reload_1 = \
+		rtems_configuration_get_microseconds_per_tick() - 1; \
     LEON_REG.Timer_Control_1 = ( \
       LEON_REG_TIMER_COUNTER_ENABLE_COUNTING |  \
@@ -77,6 +78,7 @@ static uint32_t bsp_clock_nanoseconds_since_last_tick(void)
   return usecs * 1000;
-#define Clock_driver_nanoseconds_since_last_tick bsp_clock_nanoseconds_since_last_tick
+#define Clock_driver_nanoseconds_since_last_tick \
+    bsp_clock_nanoseconds_since_last_tick
 #include "../../../shared/clockdrv_shell.h"
diff --git a/c/src/lib/libbsp/sparc/leon2/configure.ac b/c/src/lib/libbsp/sparc/leon2/configure.ac
index fdfbd87..6c7e25d 100644
--- a/c/src/lib/libbsp/sparc/leon2/configure.ac
+++ b/c/src/lib/libbsp/sparc/leon2/configure.ac
@@ -1,7 +1,8 @@
 AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libbsp-sparc-leon2],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
+AC_INIT([rtems-c-src-lib-libbsp-sparc-leon2],
 [The leon2 console driver can operate in either polled or interrupt mode.
diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
index 85ee883..8e40903 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
@@ -119,8 +119,8 @@ void bsp_spurious_initialize( void );
diff --git a/c/src/lib/libbsp/sparc/leon2/include/leon.h b/c/src/lib/libbsp/sparc/leon2/include/leon.h
index d122f29..b60c1d5 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/leon.h
@@ -224,11 +224,11 @@ typedef struct {
 #define LEON_REG_TIMER_CONTROL_EN    0x00000001  /* 1 = enable counting */
 #define LEON_REG_TIMER_CONTROL_RL    0x00000002  /* 1 = reload at 0 */
 #define LEON_REG_TIMER_CONTROL_LD    0x00000004  /* 1 = load counter */
diff --git a/c/src/lib/libbsp/sparc/leon2/include/rasta.h b/c/src/lib/libbsp/sparc/leon2/include/rasta.h
index 0073ad7..8352900 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/rasta.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/rasta.h
@@ -88,12 +88,18 @@ struct uart_reg {
 void uart_register(unsigned int baseaddr);
-rtems_device_driver uart_initialize(rtems_device_major_number  major, rtems_device_minor_number  minor, void *arg);
-rtems_device_driver uart_open(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
-rtems_device_driver uart_close(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
-rtems_device_driver uart_read(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
-rtems_device_driver uart_write(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
-rtems_device_driver uart_control(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
+rtems_device_driver uart_initialize(rtems_device_major_number  major,
+		rtems_device_minor_number  minor, void *arg);
+rtems_device_driver uart_open(rtems_device_major_number major,
+rtems_device_driver uart_close(rtems_device_major_number major,
+rtems_device_driver uart_read(rtems_device_major_number major,
+rtems_device_driver uart_write(rtems_device_major_number major,
+rtems_device_driver uart_control(rtems_device_major_number major,
 struct gpio_reg {
diff --git a/c/src/lib/libbsp/sparc/leon2/pci/pci.c b/c/src/lib/libbsp/sparc/leon2/pci/pci.c
index fcc63df..f34a173 100644
--- a/c/src/lib/libbsp/sparc/leon2/pci/pci.c
+++ b/c/src/lib/libbsp/sparc/leon2/pci/pci.c
@@ -44,14 +44,14 @@
 /* allow for overriding these definitions */
 #ifndef PCI_CONFIG_ADDR
-#define PCI_CONFIG_ADDR			0xcf8
+#define PCI_CONFIG_ADDR      0xcf8
 #endif
 #ifndef PCI_CONFIG_DATA
-#define PCI_CONFIG_DATA			0xcfc
+#define PCI_CONFIG_DATA      0xcfc
 #endif
 /* define a shortcut */
-#define pci	BSP_pci_configuration
+#define pci  BSP_pci_configuration
  * Bit encode for PCI_CONFIG_HEADER_TYPE register
@@ -59,34 +59,62 @@
 unsigned char ucMaxPCIBus;
 typedef struct {
-    volatile unsigned int pciid1;        /* 0x80000100 - PCI Device identification register 1         */
-    volatile unsigned int pcisc;         /* 0x80000104 - PCI Status & Command                         */
-    volatile unsigned int pciid2;        /* 0x80000108 - PCI Device identification register 2         */
-    volatile unsigned int pcibhlc;       /* 0x8000010c - BIST, Header type, Cache line size register  */
-    volatile unsigned int mbar1;         /* 0x80000110 - Memory Base Address Register 1               */
-    volatile unsigned int mbar2;         /* 0x80000114 - Memory Base Address Register 2               */
-    volatile unsigned int iobar3;        /* 0x80000118 - IO Base Address Register 3                   */
-    volatile unsigned int dummy1[4];     /* 0x8000011c - 0x80000128                                   */
-    volatile unsigned int pcisid;        /* 0x8000012c - Subsystem identification register            */
-    volatile unsigned int dummy2;        /* 0x80000130                                                */
-    volatile unsigned int pcicp;         /* 0x80000134 - PCI capabilities pointer register            */
-    volatile unsigned int dummy3;        /* 0x80000138                                                */
-    volatile unsigned int pcili;         /* 0x8000013c - PCI latency interrupt register               */
-    volatile unsigned int pcirt;         /* 0x80000140 - PCI retry, trdy config                       */
-    volatile unsigned int pcicw;         /* 0x80000144 - PCI configuration write register             */
-    volatile unsigned int pcisa;         /* 0x80000148 - PCI Initiator Start Address                  */
-    volatile unsigned int pciiw;         /* 0x8000014c - PCI Initiator Write Register                 */
-    volatile unsigned int pcidma;        /* 0x80000150 - PCI DMA configuration register               */
-    volatile unsigned int pciis;         /* 0x80000154 - PCI Initiator Status Register                */
-    volatile unsigned int pciic;         /* 0x80000158 - PCI Initiator Configuration                  */
-    volatile unsigned int pcitpa;        /* 0x8000015c - PCI Target Page Address Register             */
-    volatile unsigned int pcitsc;        /* 0x80000160 - PCI Target Status-Command Register           */
-    volatile unsigned int pciite;        /* 0x80000164 - PCI Interrupt Enable Register                */
-    volatile unsigned int pciitp;        /* 0x80000168 - PCI Interrupt Pending Register               */
-    volatile unsigned int pciitf;        /* 0x8000016c - PCI Interrupt Force Register                 */
-    volatile unsigned int pcid;          /* 0x80000170 - PCI Data Register                            */
-    volatile unsigned int pcibe;         /* 0x80000174 - PCI Burst End Register                       */
-    volatile unsigned int pcidmaa;       /* 0x80000178 - PCI DMA Address Register                     */
+  /* 0x80000100 - PCI Device identification register 1         */
+    volatile unsigned int pciid1;
+    /* 0x80000104 - PCI Status & Command                         */
+    volatile unsigned int pcisc;
+    /* 0x80000108 - PCI Device identification register 2         */
+    volatile unsigned int pciid2;
+    /* 0x8000010c - BIST, Header type, Cache line size register  */
+    volatile unsigned int pcibhlc;
+    /* 0x80000110 - Memory Base Address Register 1               */
+    volatile unsigned int mbar1;
+    /* 0x80000114 - Memory Base Address Register 2               */
+    volatile unsigned int mbar2;
+    /* 0x80000118 - IO Base Address Register 3                   */
+    volatile unsigned int iobar3;
+    /* 0x8000011c - 0x80000128                                   */
+    volatile unsigned int dummy1[4];
+    /* 0x8000012c - Subsystem identification register            */
+    volatile unsigned int pcisid;
+    /* 0x80000130                                                */
+    volatile unsigned int dummy2;
+    /* 0x80000134 - PCI capabilities pointer register            */
+    volatile unsigned int pcicp;
+    /* 0x80000138                                                */
+    volatile unsigned int dummy3;
+    /* 0x8000013c - PCI latency interrupt register               */
+    volatile unsigned int pcili;
+    /* 0x80000140 - PCI retry, trdy config                       */
+    volatile unsigned int pcirt;
+    /* 0x80000144 - PCI configuration write register             */
+    volatile unsigned int pcicw;
+    /* 0x80000148 - PCI Initiator Start Address                  */
+    volatile unsigned int pcisa;
+    /* 0x8000014c - PCI Initiator Write Register                 */
+    volatile unsigned int pciiw;
+    /* 0x80000150 - PCI DMA configuration register               */
+    volatile unsigned int pcidma;
+    /* 0x80000154 - PCI Initiator Status Register                */
+    volatile unsigned int pciis;
+    /* 0x80000158 - PCI Initiator Configuration                  */
+    volatile unsigned int pciic;
+    /* 0x8000015c - PCI Target Page Address Register             */
+    volatile unsigned int pcitpa;
+    /* 0x80000160 - PCI Target Status-Command Register           */
+    volatile unsigned int pcitsc;
+    /* 0x80000164 - PCI Interrupt Enable Register                */
+    volatile unsigned int pciite;
+    /* 0x80000168 - PCI Interrupt Pending Register               */
+    volatile unsigned int pciitp;
+    /* 0x8000016c - PCI Interrupt Force Register                 */
+    volatile unsigned int pciitf;
+    /* 0x80000170 - PCI Data Register                            */
+    volatile unsigned int pcid;
+    /* 0x80000174 - PCI Burst End Register                       */
+    volatile unsigned int pcibe;
+    /* 0x80000178 - PCI DMA Address Register                     */
+    volatile unsigned int pcidmaa;
 } AT697_PCI_Map;
 AT697_PCI_Map *pcic = (AT697_PCI_Map *) 0x80000100;
@@ -107,7 +135,8 @@ struct pci_res {
 static int
-BSP_pci_read_config_dword(unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, unsigned int *val) {
+BSP_pci_read_config_dword(unsigned char bus, unsigned char slot,
+    unsigned char function, unsigned char offset, unsigned int *val) {
     volatile unsigned int data;
@@ -131,14 +160,17 @@ BSP_pci_read_config_dword(unsigned char bus, unsigned char slot, unsigned char f
     else
         *val = data;
-    DBG("pci_read - bus: %d, dev: %d, fn: %d, off: %d => addr: %x, val: %x\n", bus, slot, function, offset,  (1<<(11+slot) ) | ((function & 7)<<8) |  (offset&0x3f), *val);
+    DBG("pci_read - bus: %d, dev: %d, fn: %d, off: %d => addr: %x, val: %x\n",
+        bus, slot, function, offset,
+        (1<<(11+slot) ) | ((function & 7)<<8) |  (offset&0x3f), *val);
     return PCIBIOS_SUCCESSFUL;
 static int
-BSP_pci_read_config_word(unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, unsigned short *val) {
+BSP_pci_read_config_word(unsigned char bus, unsigned char slot,
+    unsigned char function, unsigned char offset, unsigned short *val) {
     unsigned int v;
     if (offset & 1) return PCIBIOS_BAD_REGISTER_NUMBER;
@@ -151,7 +183,8 @@ BSP_pci_read_config_word(unsigned char bus, unsigned char slot, unsigned char fu
 static int
-BSP_pci_read_config_byte(unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, unsigned char *val) {
+BSP_pci_read_config_byte(unsigned char bus, unsigned char slot,
+    unsigned char function, unsigned char offset, unsigned char *val) {
     unsigned int v;
     pci_read_config_dword(bus, slot, function, offset&~3, &v);
@@ -163,7 +196,8 @@ BSP_pci_read_config_byte(unsigned char bus, unsigned char slot, unsigned char fu
 static int
-BSP_pci_write_config_dword(unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, unsigned int val) {
+BSP_pci_write_config_dword(unsigned char bus, unsigned char slot,
+    unsigned char function, unsigned char offset, unsigned int val) {
     if (offset & 3) return PCIBIOS_BAD_REGISTER_NUMBER;
@@ -182,14 +216,17 @@ BSP_pci_write_config_dword(unsigned char bus, unsigned char slot, unsigned char
     pcic->pciitp = 0xff; /* clear interrupts */
-/*    DBG("pci write - bus: %d, dev: %d, fn: %d, off: %d => addr: %x, val: %x\n", bus, slot, function, offset, (1<<(11+slot) ) | ((function & 7)<<8) |  (offset&0x3f), val); */
+/*  DBG("pci write - bus: %d, dev: %d, fn: %d, off: %d => addr: %x, val: %x\n",
+    (1<<(11+slot) ) | ((function & 7)<<8) |  (offset&0x3f), val); */
 static int
-BSP_pci_write_config_word(unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, unsigned short val) {
+BSP_pci_write_config_word(unsigned char bus, unsigned char slot,
+    unsigned char function, unsigned char offset, unsigned short val) {
     unsigned int v;
@@ -203,7 +240,8 @@ BSP_pci_write_config_word(unsigned char bus, unsigned char slot, unsigned char f
 static int
-BSP_pci_write_config_byte(unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, unsigned char val) {
+BSP_pci_write_config_byte(unsigned char bus, unsigned char slot,
+    unsigned char function, unsigned char offset, unsigned char val) {
     unsigned int v;
@@ -236,7 +274,8 @@ static void init_at697_pci(void) {
     /* Reset */
     pcic->pciic = 0xffffffff;
-    /* Map system RAM at pci address 0x40000000 and system SDRAM to pci address 0x60000000  */
+    /* Map system RAM at pci address 0x40000000
+       and system SDRAM to pci address 0x60000000  */
     pcic->mbar1  = 0x40000000;
     pcic->mbar2  = 0x60000000;
     pcic->pcitpa = 0x40006000;
@@ -247,7 +286,8 @@ static void init_at697_pci(void) {
     /* Set latency timer to 64 */
     pcic->pcibhlc = 0x00004000;
-    /* Set Inititator configuration so that AHB slave accesses generate memory read/write commands */
+    /* Set Inititator configuration so that AHB slave accesses
+       generate memory read/write commands */
     pcic->pciic = 0x41;
     pcic->pciite = 0xff;
@@ -383,19 +423,23 @@ int dma_from_pci(unsigned int addr, unsigned int paddr, unsigned int len) {
     return 0;
-void pci_mem_enable(unsigned char bus, unsigned char slot, unsigned char function) {
+void pci_mem_enable(unsigned char bus, unsigned char slot,
+    unsigned char function) {
     unsigned int data;
     pci_read_config_dword(0, slot, function, PCI_COMMAND, &data);
-    pci_write_config_dword(0, slot, function, PCI_COMMAND, data | PCI_COMMAND_MEMORY);
+    pci_write_config_dword(0, slot, function, PCI_COMMAND,
+        data | PCI_COMMAND_MEMORY);
-void pci_master_enable(unsigned char bus, unsigned char slot, unsigned char function) {
+void pci_master_enable(unsigned char bus, unsigned char slot,
     unsigned int data;
-    pci_write_config_dword(0, slot, function, PCI_COMMAND, data | PCI_COMMAND_MASTER);
+        data | PCI_COMMAND_MASTER);
@@ -409,18 +453,19 @@ static inline void swap_res(struct pci_res **p1, struct pci_res **p2) {
 /* pci_allocate_resources
- * This function scans the bus and assigns PCI addresses to all devices. It handles both
- * single function and multi function devices. All allocated devices are enabled and
- * latency timers are set to 40.
+ * This function scans the bus and assigns PCI addresses to all devices. It
+ * handles both single function and multi function devices. All allocated
+ * devices are enabled and latency timers are set to 40.
- * NOTE that it only allocates PCI memory space devices. IO spaces are not enabled.
- * Also, it does not handle pci-pci bridges. They are left disabled.
+ * NOTE that it only allocates PCI memory space devices. IO spaces are
+ * not enabled. Also, it does not handle pci-pci bridges. They are left
+ * disabled.
 static void pci_allocate_resources(void) {
-    unsigned int slot, numfuncs, func, id, pos, size, tmp, i, swapped, addr, dev, fn;
+    unsigned int slot, numfuncs, func, id, pos, size, tmp;
+    unsigned int i, swapped, addr, dev, fn;
     unsigned char header;
     struct pci_res **res;
@@ -445,7 +490,7 @@ static void pci_allocate_resources(void) {
         pci_read_config_byte(0, slot, 0, PCI_HEADER_TYPE, &header);
-        if(header & PCI_HEADER_TYPE_MULTI_FUNCTION)	{
+        if(header & PCI_HEADER_TYPE_MULTI_FUNCTION)  {
             numfuncs = PCI_MAX_FUNCTIONS;
         else {
@@ -466,11 +511,14 @@ static void pci_allocate_resources(void) {
             for (pos = 0; pos < 6; pos++) {
-                pci_write_config_dword(0, slot, func, PCI_BASE_ADDRESS_0 + (pos<<2), 0xffffffff);
-                pci_read_config_dword(0, slot, func, PCI_BASE_ADDRESS_0 + (pos<<2), &size);
+                pci_write_config_dword(0, slot, func,
+                    PCI_BASE_ADDRESS_0 + (pos<<2), 0xffffffff);
+                pci_read_config_dword(0, slot, func,
+                    PCI_BASE_ADDRESS_0 + (pos<<2), &size);
                 if (size == 0 || size == 0xffffffff || (size & 0xff) != 0) {
-                    pci_write_config_dword(0, slot, func, PCI_BASE_ADDRESS_0 + (pos<<2), 0);
+                        PCI_BASE_ADDRESS_0 + (pos<<2), 0);
                     continue;
@@ -479,7 +527,8 @@ static void pci_allocate_resources(void) {
                     res[slot*8*6+func*6+pos]->devfn = slot*8 + func;
                     res[slot*8*6+func*6+pos]->bar   = pos;
-                    DBG("Slot: %d, function: %d, bar%d size: %x\n", slot, func, pos, ~size+1);
+                    DBG("Slot: %d, function: %d, bar%d size: %x\n",
+                        slot, func, pos, ~size+1);
@@ -516,8 +565,10 @@ static void pci_allocate_resources(void) {
         dev = res[i]->devfn >> 3;
         fn  = res[i]->devfn & 7;
-        DBG("Assigning PCI addr %x to device %d, function %d, bar %d\n", addr, dev, fn, res[i]->bar);
-        pci_write_config_dword(0, dev, fn, PCI_BASE_ADDRESS_0+res[i]->bar*4, addr);
+        DBG("Assigning PCI addr %x to device %d, function %d, bar %d\n",
+            addr, dev, fn, res[i]->bar);
+        pci_write_config_dword(0, dev, fn,
+            PCI_BASE_ADDRESS_0+res[i]->bar*4, addr);
         addr += res[i]->size;
@@ -538,7 +589,7 @@ done:
         else {
@@ -555,10 +606,12 @@ done:
                 if (id == PCI_INVALID_VENDORDEVICEID || id == 0) continue;
-                printk("\nSlot %d function: %d\nVendor id: 0x%x, device id: 0x%x\n", slot, func, id & 0xffff, id>>16);
+                printk("\nSlot %d function: %d\nVendor id: 0x%x, "
+                    "device id: 0x%x\n", slot, func, id & 0xffff, id>>16);
-                    pci_read_config_dword(0, slot, func, PCI_BASE_ADDRESS_0 + pos*4, &tmp);
+                        PCI_BASE_ADDRESS_0 + pos*4, &tmp);
                     if (tmp != 0 && tmp != 0xffffffff && (tmp & 0xff) == 0) {
@@ -620,7 +673,7 @@ int init_pci(void)
                                    0,
                                    PCI_HEADER_TYPE,
                                    &ucHeader);
-        if(ucHeader&PCI_HEADER_TYPE_MULTI_FUNCTION)	{
+        if(ucHeader&PCI_HEADER_TYPE_MULTI_FUNCTION)  {
             ucNumFuncs=PCI_MAX_FUNCTIONS;
         else {
diff --git a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
index 9d70715..b439bcb 100644
--- a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
+++ b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
@@ -57,8 +57,8 @@ struct gpio_reg *gpio0, *gpio1;
 /* static rtems_isr pci_interrupt_handler (rtems_vector_number v) { */
-/*     volatile unsigned int *pci_int = (volatile unsigned int *) 0x80000168; */
-/*     volatile unsigned int *pci_mem = (volatile unsigned int *) 0xb0400000; */
+/*     volatile unsigned int *pci_int = (volatile unsigned int *) 0x80000168;*/
+/*     volatile unsigned int *pci_mem = (volatile unsigned int *) 0xb0400000;*/
 /*     if (*pci_int & 0x20) { */
@@ -243,7 +243,8 @@ int rasta_register(void)
     /* Search old PCI vendor/device id. */
-    if ( (!found) && (BSP_pciFindDevice(0x16E3, 0x0210, 0, &bus, &dev, &fun) == 0) ) {
+    if ( (!found) &&
+            (BSP_pciFindDevice(0x16E3, 0x0210, 0, &bus, &dev, &fun) == 0) ) {
       found = 1;
@@ -257,7 +258,7 @@ int rasta_register(void)
     pci_read_config_dword(bus, dev, fun, 0x14, &bar1);
     page0 = (unsigned int *)(bar0 + 0x400000);
-    *page0 = 0x80000000;                  /* Point PAGE0 to start of APB       */
+    *page0 = 0x80000000;                  /* Point PAGE0 to start of APB     */
     apb_base = (unsigned int *)(bar0+APB2_OFFSET);
@@ -279,7 +280,8 @@ int rasta_register(void)
     irq = (struct irqmp_regs *) (bar0+IRQ_OFFSET);
     irq->iclear = 0xffff;
     irq->ilevel = 0;
-    irq->mask[0] = 0xffff & ~(UART0_IRQ|UART1_IRQ|SPW0_IRQ|SPW1_IRQ|SPW2_IRQ|GRCAN_IRQ|BRM_IRQ);
+    irq->mask[0] = 0xffff &
+           ~(UART0_IRQ|UART1_IRQ|SPW0_IRQ|SPW1_IRQ|SPW2_IRQ|GRCAN_IRQ|BRM_IRQ);
     /* Configure AT697 ioport bit 7 to input pci irq */
     regs->PIO_Direction &= ~(1<<7);
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 71d54d5..789c3d0 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -35,7 +35,8 @@ libbsp_a_SOURCES =
 libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
     ../../shared/bsppost.c ../../shared/bootcard.c startup/bspstart.c \
     ../../sparc/shared/bsppretaskinghook.c startup/bsppredriver.c \
-    ../../sparc/shared/startup/bspgetworkarea.c ../../shared/sbrk.c startup/setvec.c \
+    ../../sparc/shared/startup/bspgetworkarea.c ../../shared/sbrk.c \
+    startup/setvec.c \
     startup/spurious.c startup/bspidle.S startup/bspdelay.c \
     ../../shared/bspinit.c ../../sparc/shared/startup/early_malloc.c
 libbsp_a_SOURCES += startup/bspreset.c
diff --git a/c/src/lib/libbsp/sparc/leon3/configure.ac b/c/src/lib/libbsp/sparc/leon3/configure.ac
index dbefd3e..fd3b0a4 100644
--- a/c/src/lib/libbsp/sparc/leon3/configure.ac
+++ b/c/src/lib/libbsp/sparc/leon3/configure.ac
@@ -1,7 +1,8 @@
 AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libbsp-sparc-leon3],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
+AC_INIT([rtems-c-src-lib-libbsp-sparc-leon3],
@@ -23,8 +24,8 @@ AM_CONDITIONAL(HAS_SMP,[test "$rtems_cv_HAS_SMP" = "yes"])
 [The leon3 console driver can operate in either polled or interrupt mode.
-better.])
+to operate better.])
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index eb2669e..6bbd6ed 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -80,11 +80,14 @@ extern int rtems_leon_greth_driver_attach(
 #define RTEMS_BSP_NETWORK_DRIVER_NAME_OPENETH	"open_eth1"
-#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH	 rtems_leon_open_eth_driver_attach
+#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH	 \
+    rtems_leon_open_eth_driver_attach
 #define RTEMS_BSP_NETWORK_DRIVER_NAME_SMC91111	"smc_eth1"
-#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_SMC91111 rtems_smc91111_driver_attach_leon3
+#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_SMC91111 \
+    rtems_smc91111_driver_attach_leon3
 #define RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH	 "gr_eth1"
-#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_GRETH    rtems_leon_greth_driver_attach
+#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_GRETH \
+    rtems_leon_greth_driver_attach
 #ifndef RTEMS_BSP_NETWORK_DRIVER_NAME
 #define RTEMS_BSP_NETWORK_DRIVER_NAME   RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH
@@ -131,8 +134,8 @@ void bsp_spurious_initialize( void );
diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
index bda28f2..f1b987b 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
@@ -80,11 +80,11 @@ extern "C" {
@@ -119,8 +119,10 @@ extern "C" {
 #define LEON_REG_UART_CTRL_FL     0x00000040 /* Flow control enable */
 #define LEON_REG_UART_CTRL_LB     0x00000080 /* Loop Back enable */
-extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;  /* LEON3 Interrupt Controller */
-extern volatile struct gptimer_regs *LEON3_Timer_Regs; /* LEON3 GP Timer */
+/* LEON3 Interrupt Controller */
+extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
+/* LEON3 GP Timer */
+extern volatile struct gptimer_regs *LEON3_Timer_Regs;
 /* LEON3 CPU Index of boot CPU */
 extern uint32_t LEON3_Cpu_Index;
@@ -270,7 +272,7 @@ extern rtems_interrupt_lock LEON3_IrqCtrl_Lock;
 #if defined(RTEMS_MULTIPROCESSING)
   #define LEON3_CLOCK_INDEX \
-    (rtems_configuration_get_user_multiprocessing_table() ? LEON3_Cpu_Index : 0)
+   (rtems_configuration_get_user_multiprocessing_table() ? LEON3_Cpu_Index : 0)
 #else
   #define LEON3_CLOCK_INDEX 0
 #endif
diff --git a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
index 5b903eb..a6b73d9 100644
--- a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
+++ b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
@@ -74,7 +74,8 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
   io->dir &= ~(1 << leon_scmv91111_configuration.pio);
   /* Setup memory controller I/O waitstates */
-  *((volatile unsigned int *) addr_mctrl) |= 0x10f80000;	/* enable I/O area access */
+  *((volatile unsigned int *) addr_mctrl) |=
+		  0x10f80000;	/* enable I/O area access */
   return _rtems_smc91111_driver_attach(config, &leon_scmv91111_configuration);
diff --git a/c/src/lib/libbsp/sparc/leon3/pci/pci.c b/c/src/lib/libbsp/sparc/leon3/pci/pci.c
index b36b026..5e95cbc 100644
--- a/c/src/lib/libbsp/sparc/leon3/pci/pci.c
+++ b/c/src/lib/libbsp/sparc/leon3/pci/pci.c
@@ -49,27 +49,27 @@
 #endif
 #endif
 typedef struct {
-	volatile unsigned int cfg_stat;
-	volatile unsigned int bar0;
-	volatile unsigned int page0;
-	volatile unsigned int bar1;
-	volatile unsigned int page1;
-	volatile unsigned int iomap;
-	volatile unsigned int stat_cmd;
+  volatile unsigned int cfg_stat;
+  volatile unsigned int bar0;
+  volatile unsigned int page0;
+  volatile unsigned int bar1;
+  volatile unsigned int page1;
+  volatile unsigned int iomap;
+  volatile unsigned int stat_cmd;
 } LEON3_GRPCI_Regs_Map;
 LEON3_GRPCI_Regs_Map *pcic = (LEON3_GRPCI_Regs_Map *) PCI_ADDR;
@@ -83,7 +83,8 @@ struct pci_res {
 static inline unsigned int flip_dword (unsigned int l)
-        return ((l&0xff)<<24) | (((l>>8)&0xff)<<16) | (((l>>16)&0xff)<<8)| ((l>>24)&0xff);
+        return ((l&0xff)<<24) | (((l>>8)&0xff)<<16) |
+                (((l>>16)&0xff)<<8)| ((l>>24)&0xff);
@@ -123,14 +124,17 @@ BSP_pci_read_config_dword(
         *val = 0xffffffff;
 static int
     uint32_t v;
@@ -143,7 +147,8 @@ BSP_pci_read_config_word(unsigned char bus, unsigned char slot, unsigned char fu
 static int
     uint32_t v;
@@ -155,7 +160,8 @@ BSP_pci_read_config_byte(unsigned char bus, unsigned char slot, unsigned char fu
 static int
-BSP_pci_write_config_dword(unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint32_t val) {
+    unsigned char function, unsigned char offset, uint32_t val) {
     volatile unsigned int *pci_conf;
     unsigned int value;
@@ -174,14 +180,17 @@ BSP_pci_write_config_dword(unsigned char bus, unsigned char slot, unsigned char
     *pci_conf = value;
-    DBG("pci write - bus: %d, dev: %d, fn: %d, off: %d => addr: %x, val: %x\n", bus, slot, function, offset, (1<<(11+slot) ) | ((function & 7)<<8) |  (offset&0x3f), value);
+    DBG("pci write - bus: %d, dev: %d, fn: %d, off: %d => addr: %x, val: %x\n",
+        (1<<(11+slot) ) | ((function & 7)<<8) |  (offset&0x3f), value);
 static int
     uint32_t v;
@@ -195,7 +204,8 @@ BSP_pci_write_config_word(unsigned char bus, unsigned char slot, unsigned char f
 static int
     uint32_t v;
@@ -234,10 +244,14 @@ static int init_grpci(void) {
 #ifndef BT_ENABLED
     pci_write_config_dword(0,0,0,0x10, 0xffffffff);
     pci_read_config_dword(0,0,0,0x10, &addr);
-    pci_write_config_dword(0,0,0,0x10, flip_dword(0x10000000));    /* Setup bar0 to nonzero value (grpci considers BAR==0 as invalid) */
-    addr = (~flip_dword(addr)+1)>>1;                               /* page0 is accessed through upper half of bar0 */
-    pcic->cfg_stat |= 0x10000000;                                  /* Setup mmap reg so we can reach bar0 */
-    page0[addr/4] = 0;                                             /* Disable bytetwisting ... */
+    /* Setup bar0 to nonzero value (grpci considers BAR==0 as invalid) */
+    pci_write_config_dword(0,0,0,0x10, flip_dword(0x10000000));
+    /* page0 is accessed through upper half of bar0 */
+    addr = (~flip_dword(addr)+1)>>1;
+    /* Setup mmap reg so we can reach bar0 */
+    pcic->cfg_stat |= 0x10000000;
+    /* Disable bytetwisting ... */
+    page0[addr/4] = 0;
 #endif
     /* set 1:1 mapping between AHB -> PCI memory */
@@ -255,7 +269,8 @@ static int init_grpci(void) {
 /* DMA functions which uses GRPCIs optional DMA controller (len in words) */
-int dma_to_pci(unsigned int ahb_addr, unsigned int pci_addr, unsigned int len) {
+int dma_to_pci(unsigned int ahb_addr, unsigned int pci_addr,
+    unsigned int len) {
     int ret = 0;
     pcidma[0] = 0x82;
@@ -276,7 +291,8 @@ int dma_to_pci(unsigned int ahb_addr, unsigned int pci_addr, unsigned int len) {
-int dma_from_pci(unsigned int ahb_addr, unsigned int pci_addr, unsigned int len) {
+int dma_from_pci(unsigned int ahb_addr, unsigned int pci_addr,
     int ret = 0;
     pcidma[0] = 0x80;
@@ -298,19 +314,23 @@ int dma_from_pci(unsigned int ahb_addr, unsigned int pci_addr, unsigned int len)
     uint32_t data;
     uint32_t data;
@@ -324,13 +344,13 @@ static inline void swap_res(struct pci_res **p1, struct pci_res **p2) {
- * NOTE that it only allocates PCI memory space devices (that are at least 1 KB).
- * IO spaces are not enabled. Also, it does not handle pci-pci bridges. They are left disabled.
+ * It handles both single function and multi function devices. All
+ * allocated devices are enabled and latency timers are set to 40.
+ * NOTE that it only allocates PCI memory space devices (that are at
+ * least 1 KB). IO spaces are not enabled. Also, it does not handle
+ * pci-pci bridges. They are left disabled.
@@ -361,7 +381,7 @@ static void pci_allocate_resources(void) {
         else {
@@ -382,11 +402,14 @@ static void pci_allocate_resources(void) {
                 if (size == 0 || size == 0xffffffff || (size & 0x3f1) != 0){
                     continue;
                 }else {
@@ -395,7 +418,8 @@ static void pci_allocate_resources(void) {
@@ -430,8 +454,10 @@ static void pci_allocate_resources(void) {
@@ -452,7 +478,7 @@ done:
         else {
@@ -469,10 +495,12 @@ done:
                     if (tmp != 0 && tmp != 0xffffffff && (tmp & 0x3f1) == 0) {
@@ -530,7 +558,7 @@ int init_pci(void)
                                    0,
                                    PCI_HEADER_TYPE,
                                    &ucHeader);
         else {
diff --git a/c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c b/c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c
index 6129933..52bc0fd 100644
--- a/c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c
+++ b/c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c
@@ -72,6 +72,7 @@ void Shm_Get_configuration(
   int i;
   unsigned int tmp;
+  rtems_multiprocessing_table *mptable;
   BSP_shm_cfgtbl.format       = SHM_BIG;
@@ -97,8 +98,8 @@ void Shm_Get_configuration(
   if (LEON3_Cpu_Index == 0) {
     tmp = 0;
-    for (i = 1;
-         i < (rtems_configuration_get_user_multiprocessing_table())->maximum_nodes; i++)
+    mptable = rtems_configuration_get_user_multiprocessing_table();
+    for (i = 1; i < mptable->maximum_nodes; i++)
       tmp |= (1 << i);
     LEON3_IrqCtrl_Regs->mpstat = tmp;
1.7.9.5
