[PATCH 3/3] bsps/sparc: Change tabs to spaces.
Mon May 12 15:09:07 UTC 2014
tabs to spaces in C are OK if the alignment of the code looks
the same.  The diff looks OK but you need to eyeball the files.
I don't know what the policy on tabs in .S is. If you expand it
to 8, then it should look the same. Expanding to 2 messes it
up.
On 5/12/2014 9:39 AM, Daniel Cederman wrote:
>  c/src/lib/libbsp/sparc/erc32/clock/ckinit.c        |    6 +-
>  .../lib/libbsp/sparc/erc32/console/erc32_console.c |    4 +-
>  .../lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c |    4 +-
>  c/src/lib/libbsp/sparc/erc32/include/bsp.h         |    4 +-
>  c/src/lib/libbsp/sparc/erc32/startup/boardinit.S   |   88 ++--
>  c/src/lib/libbsp/sparc/erc32/startup/spurious.c    |    4 +-
>  c/src/lib/libbsp/sparc/leon2/cchip/cchip.c         |  434 ++++++++++----------
>  c/src/lib/libbsp/sparc/leon2/clock/ckinit.c        |    2 +-
>  c/src/lib/libbsp/sparc/leon2/console/console.c     |    2 +-
>  c/src/lib/libbsp/sparc/leon2/include/bsp.h         |    2 +-
>  c/src/lib/libbsp/sparc/leon2/include/leon.h        |   92 ++---
>  c/src/lib/libbsp/sparc/leon2/include/rasta.h       |   12 +-
>  c/src/lib/libbsp/sparc/leon2/rasta/rasta.c         |    2 +-
>  c/src/lib/libbsp/sparc/leon2/startup/spurious.c    |    6 +-
>  c/src/lib/libbsp/sparc/leon3/include/bsp.h         |    8 +-
>  c/src/lib/libbsp/sparc/leon3/include/leon.h        |    6 +-
>  .../sparc/leon3/leon_smc91111/leon_smc91111.c      |    7 +-
>  c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c        |    4 +-
>  c/src/lib/libbsp/sparc/leon3/startup/spurious.c    |    6 +-
>  19 files changed, 346 insertions(+), 347 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
> index 0ae8482..6b18824 100644
> --- a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
> +++ b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
> @@ -83,13 +83,13 @@ static CPU_Counter_ticks erc32_counter_difference(
>      ERC32_MEC_Set_Real_Time_Clock_Timer_Control( \
>        ERC32_MEC_TIMER_COUNTER_ENABLE_COUNTING | \
> -       ERC32_MEC_TIMER_COUNTER_LOAD_SCALER | \
> -           ERC32_MEC_TIMER_COUNTER_LOAD_COUNTER \
> +      ERC32_MEC_TIMER_COUNTER_LOAD_SCALER | \
> +      ERC32_MEC_TIMER_COUNTER_LOAD_COUNTER \
> -           ERC32_MEC_TIMER_COUNTER_RELOAD_AT_ZERO \
> +      ERC32_MEC_TIMER_COUNTER_RELOAD_AT_ZERO \
>      _SPARC_Counter_initialize( \
>        &ERC32_MEC.Real_Time_Clock_Counter, \
> diff --git a/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c b/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c
> index 212d5e0..92da9f0 100644
> --- a/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c
> +++ b/c/src/lib/libbsp/sparc/erc32/console/erc32_console.c
> @@ -148,7 +148,7 @@ static int erc32_console_first_open(int major, int minor, void *arg)
>  #if (CONSOLE_USE_INTERRUPTS)
>  static ssize_t erc32_console_write_support_int(
> -               int minor, const char *buf, size_t len)
> +  int minor, const char *buf, size_t len)
>    if (len > 0) {
>      console_data *cd = &Console_Port_Data[minor];
> @@ -264,7 +264,7 @@ static void erc32_console_isr_b(
>        buf[i] = ERC32_MEC.UART_Channel_B;
>        ++i;
> -    if ( i )
> +    if ( i )
>        rtems_termios_enqueue_raw_characters(cd->termios_data, buf, i);
>      /* dequeue transmitted chars */
> diff --git a/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c b/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c
> index c818db4..6100eca 100644
> --- a/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c
> +++ b/c/src/lib/libbsp/sparc/erc32/erc32sonic/erc32sonic.c
> @@ -106,9 +106,9 @@ int rtems_erc32_sonic_driver_attach(struct rtems_bsdnet_ifconfig *config)
>    ERC32_MEC.IO_Configuration |=
> -                 (0x15 << (((SONIC_BASE_ADDRESS >> 24) & 0x3) * 8));
> +      (0x15 << (((SONIC_BASE_ADDRESS >> 24) & 0x3) * 8));
>    ERC32_MEC.Control &= ~0x60001; /* Disable DMA time-out, parity & power-down */
> -  ERC32_MEC.Control |= 0x10000;                /* Enable DMA */
> +  ERC32_MEC.Control |= 0x10000;  /* Enable DMA */
>    ERC32_MEC.Interrupt_Mask &= ~(1 << (SONIC_VECTOR - 0x10));
>    return(rtems_sonic_driver_attach( config, &erc32_sonic_configuration ));
> diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> index b2c1b91..e35b9fb 100644
> --- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> @@ -63,8 +63,8 @@ struct rtems_bsdnet_ifconfig;
>  extern int rtems_erc32_sonic_driver_attach(
> -#define RTEMS_BSP_NETWORK_DRIVER_NAME  "sonic1"
> -#define RTEMS_BSP_NETWORK_DRIVER_ATTACH        rtems_erc32_sonic_driver_attach
> +#define RTEMS_BSP_NETWORK_DRIVER_NAME "sonic1"
> +#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_erc32_sonic_driver_attach
>  /* Constants */
> diff --git a/c/src/lib/libbsp/sparc/erc32/startup/boardinit.S b/c/src/lib/libbsp/sparc/erc32/startup/boardinit.S
> index 046678f..5ab149c 100644
> --- a/c/src/lib/libbsp/sparc/erc32/startup/boardinit.S
> +++ b/c/src/lib/libbsp/sparc/erc32/startup/boardinit.S
> @@ -15,75 +15,75 @@
>  #include <rtems/asm.h>
>  #include <erc32.h>
> -        .global __bsp_board_init
> +.global __bsp_board_init
>  __bsp_board_init:
> -/* Check if MEC is initialised. If not, this means that we are
> -   running on the simulator. Initiate some of the parameters
> -   that are done by the boot-prom otherwise.
> +  /* Check if MEC is initialised. If not, this means that we are
> +     running on the simulator. Initiate some of the parameters
> +     that are done by the boot-prom otherwise.
> -        set     SYM(ERC32_MEC), %g3  ! g3 = base address of peripherals
> -       ld      [%g3], %g2
> -       set     0xfe080000, %g1
> -       andcc   %g1, %g2, %g0
> -       bne     2f
> +  set SYM(ERC32_MEC), %g3  ! g3 = base address of peripherals
> +  ld  [%g3], %g2
> +  set  0xfe080000, %g1
> +  andcc  %g1, %g2, %g0
> +  bne  2f
>   /* Stop the watchdog */
> -       st      %g0, [%g3 + SYM(ERC32_MEC_WATCHDOG_TRAP_DOOR_SET_OFFSET)]
> +   st  %g0, [%g3 + SYM(ERC32_MEC_WATCHDOG_TRAP_DOOR_SET_OFFSET)]
>   /* Set zero waitstates */
> -       st      %g0, [%g3 + SYM(ERC32_MEC_WAIT_STATE_CONFIGURATION_OFFSET)]
> +  st  %g0, [%g3 + SYM(ERC32_MEC_WAIT_STATE_CONFIGURATION_OFFSET)]
>   /* Set the correct memory size in MEC memory config register */
> -       set     SYM(PROM_SIZE), %l0
> -       set     0, %l1
> -       srl     %l0, 18, %l0
> +  set  SYM(PROM_SIZE), %l0
> +  set  0, %l1
> +  srl  %l0, 18, %l0
>  1:
> -       tst     %l0
> -       srl     %l0, 1, %l0
> -       bne,a   1b
> -       inc     %l1
> -       sll     %l1, 8, %l1
> -       set     SYM(RAM_SIZE), %l0
> -       srl     %l0, 19, %l0
> +  tst  %l0
> +  srl  %l0, 1, %l0
> +  bne,a  1b
> +  inc  %l1
> +  sll  %l1, 8, %l1
> +  set  SYM(RAM_SIZE), %l0
> +  srl  %l0, 19, %l0
>  1:
> -       tst     %l0
> -       srl     %l0, 1, %l0
> -       bne,a   1b
> -       inc     %l1
> -       sll     %l1, 10, %l1
> +  tst  %l0
> +  srl  %l0, 1, %l0
> +  bne,a  1b
> +   inc  %l1
> +  sll  %l1, 10, %l1
> -                                           ! set the Memory Configuration
> -        st     %l1, [ %g3 + ERC32_MEC_MEMORY_CONFIGURATION_OFFSET ]
> +  ! set the Memory Configuration
> +  st  %l1, [ %g3 + ERC32_MEC_MEMORY_CONFIGURATION_OFFSET ]
> -       set     SYM(RAM_START), %l1  ! Cannot use RAM_END due to bug in linker
> -       set     SYM(RAM_SIZE), %l2
> -       add     %l1, %l2, %sp
> +  set  SYM(RAM_START), %l1  ! Cannot use RAM_END due to bug in linker
> +  set  SYM(RAM_SIZE), %l2
> +  add  %l1, %l2, %sp
> -       set     SYM(CLOCK_SPEED), %g6   ! Use 14 MHz in simulator
> -       set     14, %g1
> -       st      %g1, [%g6]
> +  set  SYM(CLOCK_SPEED), %g6  ! Use 14 MHz in simulator
> +  set  14, %g1
> +  st   %g1, [%g6]
>  2:
>   /* Initialise timer */
> -       set     SYM(_ERC32_MEC_Timer_Control_Mirror), %l2
> -       st      %g0, [%l2]
> -       st      %g0, [%g3 + SYM(ERC32_MEC_TIMER_CONTROL_OFFSET)]
> +  set  SYM(_ERC32_MEC_Timer_Control_Mirror), %l2
> +  st  %g0, [%l2]
> +  st  %g0, [%g3 + SYM(ERC32_MEC_TIMER_CONTROL_OFFSET)]
>   /* Enable power-down */
> -       ld      [%g3 + SYM(ERC32_MEC_CONTROL_OFFSET)], %l2
> -       or      %l2, ERC32_CONFIGURATION_POWER_DOWN_ALLOWED, %l2
> -       st      %l2, [%g3 + SYM(ERC32_MEC_CONTROL_OFFSET)]
> +  ld  [%g3 + SYM(ERC32_MEC_CONTROL_OFFSET)], %l2
> +  or  %l2, ERC32_CONFIGURATION_POWER_DOWN_ALLOWED, %l2
> +  st  %l2, [%g3 + SYM(ERC32_MEC_CONTROL_OFFSET)]
> -       retl
> -       nop
> +  retl
> +   nop
>  /* end of file */
> diff --git a/c/src/lib/libbsp/sparc/erc32/startup/spurious.c b/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
> index b8408f2..8c27e80 100644
> --- a/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
> +++ b/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
> @@ -161,8 +161,8 @@ void bsp_spurious_initialize()
>       if (( trap == 5 || trap == 6 ) ||
> -       (( trap >= 0x11 ) && ( trap <= 0x1f )) ||
> -       (( trap >= 0x70 ) && ( trap <= 0x83 )))
> +       (( trap >= 0x11 ) && ( trap <= 0x1f )) ||
> +       (( trap >= 0x70 ) && ( trap <= 0x83 )))
>        continue;
>      set_vector( (rtems_isr_entry) bsp_spurious_handler,
> diff --git a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c b/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
> index fe45f2e..7fa57ef 100644
> --- a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
> +++ b/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
> @@ -50,70 +50,70 @@ void cchip1_set_isr(void *handler, int irqno, void *arg);
>  #define READ_REG(address) _READ_REG((unsigned int)address)
>  static __inline__ unsigned int _READ_REG(unsigned int addr) {
> -       unsigned int tmp;
> -       __asm__ ("lda [%1]1, %0 "
> -         : "=r"(tmp)
> -         : "r"(addr)
> -       return tmp;
> +  unsigned int tmp;
> +  __asm__ ("lda [%1]1, %0 "
> +    : "=r"(tmp)
> +    : "r"(addr)
> +  return tmp;
>  /* PCI bride reg layout on AMBA side */
>  typedef struct {
> -       unsigned int bar0;
> -       unsigned int bar1;
> -       unsigned int bar2;
> -       unsigned int bar3;
> -       unsigned int bar4;/* 0x10 */
> +  unsigned int bar0;
> +  unsigned int bar1;
> +  unsigned int bar2;
> +  unsigned int bar3;
> +  unsigned int bar4;/* 0x10 */
> -       unsigned int unused[4*3-1];
> +  unsigned int unused[4*3-1];
> -       unsigned int ambabars[1]; /* 0x40 */
> +  unsigned int ambabars[1]; /* 0x40 */
>  } amba_bridge_regs;
>  /* PCI bride reg layout on PCI side */
>  typedef struct {
> -       unsigned int bar4; /* 0x10 */
> -       unsigned int ilevel;
> -       unsigned int ipend;
> -       unsigned int iforce;
> -       unsigned int istatus;
> -       unsigned int iclear;
> -       unsigned int imask;
> +  unsigned int bar4; /* 0x10 */
> +  unsigned int ilevel;
> +  unsigned int ipend;
> +  unsigned int iforce;
> +  unsigned int istatus;
> +  unsigned int iclear;
> +  unsigned int imask;
>  } pci_bridge_regs;
>  typedef struct {
> -       pci_bridge_regs  *pcib;
> -       amba_bridge_regs *ambab;
> +  pci_bridge_regs  *pcib;
> +  amba_bridge_regs *ambab;
> -       /* AT697 PCI */
> -       unsigned int bars[5];
> -       int bus, dev, fun;
> +  /* AT697 PCI */
> +  unsigned int bars[5];
> +  int bus, dev, fun;
> -       /* AMBA bus */
> -       struct ambapp_bus amba_bus;
> -       struct ambapp_mmap amba_maps[2];
> +  /* AMBA bus */
> +  struct ambapp_bus amba_bus;
> +  struct ambapp_mmap amba_maps[2];
> -       /* FT AHB SRAM */
> -       int ftsram_size; /* kb */
> -       unsigned int ftsram_start;
> -       unsigned int ftsram_end;
> +  /* FT AHB SRAM */
> +  int ftsram_size; /* kb */
> +  unsigned int ftsram_start;
> +  unsigned int ftsram_end;
>  } cchip1;
>  cchip1 cc1;
>  int init_pcif(void){
> -       unsigned int com1;
> -       int i,bus,dev,fun;
> -       struct ambapp_bus *abus;
> +  unsigned int com1;
> +  int i,bus,dev,fun;
> +  struct ambapp_bus *abus;
>    if ( BSP_pciFindDevice(0x1AC8, 0x0701, 0, &bus, &dev, &fun) == 0 ) {
> @@ -126,247 +126,247 @@ int init_pcif(void){
>    /* found Companionship PCI board, Set it up: */
> -       pci_read_config_dword(bus, dev, fun, 0x10, &cc1.bars[0]);
> -       pci_read_config_dword(bus, dev, fun, 0x14, &cc1.bars[1]);
> -       pci_read_config_dword(bus, dev, fun, 0x18, &cc1.bars[2]);
> -       pci_read_config_dword(bus, dev, fun, 0x1c, &cc1.bars[3]);
> -       pci_read_config_dword(bus, dev, fun, 0x20, &cc1.bars[4]);
> +  pci_read_config_dword(bus, dev, fun, 0x10, &cc1.bars[0]);
> +  pci_read_config_dword(bus, dev, fun, 0x14, &cc1.bars[1]);
> +  pci_read_config_dword(bus, dev, fun, 0x18, &cc1.bars[2]);
> +  pci_read_config_dword(bus, dev, fun, 0x1c, &cc1.bars[3]);
> +  pci_read_config_dword(bus, dev, fun, 0x20, &cc1.bars[4]);
>  #ifdef DEBUG
> -       for(i=0; i<5; i++){
> -               printk("PCI: BAR%d: 0x%x\n\r",i,cc1.bars[i]);
> +  for(i=0; i<5; i++){
> +    printk("PCI: BAR%d: 0x%x\n\r",i,cc1.bars[i]);
>  #endif
> -       /* Set up PCI ==> AMBA */
> -       pcib = (void *)cc1.bars[0];
> -       pcib->bar0 = 0xfc000000;
> -/*     pcib->bar1 = 0xff000000;*/
> +  /* Set up PCI ==> AMBA */
> +  pcib = (void *)cc1.bars[0];
> +  pcib->bar0 = 0xfc000000;
> +/*  pcib->bar1 = 0xff000000;*/
>  #ifdef BOARD_INFO
> -       printk("Found CCHIP1 Board at 0x%lx\n\r",(unsigned int)pcib);
> +  printk("Found CCHIP1 Board at 0x%lx\n\r",(unsigned int)pcib);
>  #endif
> -       /* AMBA MAP cc1.bars[1] (in CPU) ==> 0xf0000000(remote amba address) */
> -       cc1.amba_maps[0].size = 0x04000000;
> -       cc1.amba_maps[0].local_adr = cc1.bars[1];
> -       cc1.amba_maps[0].remote_adr = 0xfc000000;
> +  /* AMBA MAP cc1.bars[1] (in CPU) ==> 0xf0000000(remote amba address) */
> +  cc1.amba_maps[0].size = 0x04000000;
> +  cc1.amba_maps[0].local_adr = cc1.bars[1];
> +  cc1.amba_maps[0].remote_adr = 0xfc000000;
> -       /* Mark end of table */
> -       cc1.amba_maps[1].size=0;
> -       cc1.amba_maps[1].local_adr = 0;
> -       cc1.amba_maps[1].remote_adr = 0;
> +  /* Mark end of table */
> +  cc1.amba_maps[1].size=0;
> +  cc1.amba_maps[1].local_adr = 0;
> +  cc1.amba_maps[1].remote_adr = 0;
> -       /* Enable I/O and Mem accesses */
> -       pci_read_config_dword(bus, dev, fun, 0x4, &com1);
> -       com1 |= 0x3;
> -       pci_write_config_dword(bus, dev, fun, 0x4, com1);
> +  /* Enable I/O and Mem accesses */
> +  pci_read_config_dword(bus, dev, fun, 0x4, &com1);
> +  com1 |= 0x3;
> +  pci_write_config_dword(bus, dev, fun, 0x4, com1);
> -       /* Set up AMBA Masters ==> PCI */
> -       ambab = (void *)(cc1.bars[1]+0x400);
> +  /* Set up AMBA Masters ==> PCI */
> +  ambab = (void *)(cc1.bars[1]+0x400);
>  #ifdef DEBUG
> -       printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",0,ambab->bar0,pcib->bar0);
> -       printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",1,ambab->bar1,pcib->bar1);
> -       printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",2,ambab->bar2,pcib->bar2);
> +  printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",0,ambab->bar0,pcib->bar0);
> +  printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",1,ambab->bar1,pcib->bar1);
> +  printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",2,ambab->bar2,pcib->bar2);
>  #endif
> -       /* 0xe0000000(AMBA) ==> 0x40000000(PCI) ==> 0x40000000(AT697 AMBA) */
> -       ambab->ambabars[0] = 0x40000000;
> -       /* Scan bus for AMBA devices */
> -       abus = &cc1.amba_bus;
> -       memset(abus,0,sizeof(*abus));
> -       ambapp_scan(abus, cc1.bars[1]+0x3f00000, NULL, &cc1.amba_maps[0]);
> -       /* Init all msters, max 16 */
> -       for(i=1; i<16; i++) {
> -               ambab->ambabars[i] = 0x40000000;
> -               if (READ_REG(&ambab->ambabars[i]) != 0x40000000)
> -                       break;
> -       /* Enable PCI Master */
> +  /* 0xe0000000(AMBA) ==> 0x40000000(PCI) ==> 0x40000000(AT697 AMBA) */
> +  ambab->ambabars[0] = 0x40000000;
> +  /* Scan bus for AMBA devices */
> +  abus = &cc1.amba_bus;
> +  memset(abus,0,sizeof(*abus));
> +  ambapp_scan(abus, cc1.bars[1]+0x3f00000, NULL, &cc1.amba_maps[0]);
> +  /* Init all msters, max 16 */
> +  for(i=1; i<16; i++) {
> +    ambab->ambabars[i] = 0x40000000;
> +    if (READ_REG(&ambab->ambabars[i]) != 0x40000000)
> +      break;
> +  /* Enable PCI Master */
>     com1 |= 0x4;
> -       cc1.pcib  = pcib;
> -       cc1.ambab = ambab;
> -       cc1.bus = bus;
> -       cc1.dev = dev;
> -       cc1.fun = fun;
> +  cc1.pcib  = pcib;
> +  cc1.ambab = ambab;
> +  cc1.bus = bus;
> +  cc1.dev = dev;
> +  cc1.fun = fun;
> -       return 0;
> +  return 0;
>  #ifndef GAISLER_FTAHBRAM
>   #define GAISLER_FTAHBRAM 0x50
>  #endif
>  int init_onboard_sram(void){
> -       struct ambapp_ahb_info ahb;
> -       struct ambapp_apb_info apb;
> -       unsigned int conf, size;
> -       /* Find SRAM controller
> -        * 1. AHB slave interface
> -        * 2. APB slave interface
> -       if ( ambapp_find_apbslv(&cc1.amba_bus, VENDOR_GAISLER, GAISLER_FTAHBRAM,
> +  struct ambapp_ahb_info ahb;
> +  struct ambapp_apb_info apb;
> +  unsigned int conf, size;
> +  /* Find SRAM controller
> +   * 1. AHB slave interface
> +   * 2. APB slave interface
> +  if ( ambapp_find_apbslv(&cc1.amba_bus, VENDOR_GAISLER, GAISLER_FTAHBRAM,
>                                  &apb) != 1 ){
> -               printk("On Board FT SRAM not found (APB)\n");
> -               return -1;
> +    printk("On Board FT SRAM not found (APB)\n");
> +    return -1;
> -       if ( ambapp_find_ahbslv(&cc1.amba_bus, VENDOR_GAISLER, GAISLER_FTAHBRAM,
> +  if ( ambapp_find_ahbslv(&cc1.amba_bus, VENDOR_GAISLER, GAISLER_FTAHBRAM,
>                                  &ahb) != 1 ){
> -               printk("On Board FT SRAM not found (AHB)\n");
> -               return -1;
> -       /* We have found the controller.
> -        * Get it going.
> -        * Get size of SRAM
> -       conf = *(unsigned int *)apb.start;
> -       size = (conf >>10) & 0x7;
> -       /* 2^x kb */
> -       cc1.ftsram_size = 1<<size;
> -       cc1.ftsram_start = ahb.start[0];
> -       cc1.ftsram_end = size*1024 + cc1.ftsram_start;
> +    printk("On Board FT SRAM not found (AHB)\n");
> +    return -1;
> +  /* We have found the controller.
> +   * Get it going.
> +   * Get size of SRAM
> +  conf = *(unsigned int *)apb.start;
> +  size = (conf >>10) & 0x7;
> +  /* 2^x kb */
> +  cc1.ftsram_size = 1<<size;
> +  cc1.ftsram_start = ahb.start[0];
> +  cc1.ftsram_end = size*1024 + cc1.ftsram_start;
>  #ifdef BOARD_INFO
> -       printk("Found FT AHB SRAM %dkb at 0x%lx\n",cc1.ftsram_size,cc1.ftsram_start);
> +  printk("Found FT AHB SRAM %dkb at 0x%lx\n",cc1.ftsram_size,cc1.ftsram_start);
>  #endif
> -       return 0;
> +  return 0;
>  int cchip1_register(void){
> -       /* Init AT697 PCI Controller */
> -       init_pci();
> -       /* Find & init CChip board .
> -        * Also scan AMBA Plug&Play info for us.
> -       if ( init_pcif() ){
> -               printk("Failed to initialize CCHIP board\n\r");
> -               return -1;
> -       /* Set interrupt common board stuff */
> -       cchip1_irq_init();
> -       /* Find on board SRAM */
> -       if ( init_onboard_sram() ){
> -               printk("Failed to register On Board SRAM. It is needed by b1553BRM\n");
> -               return -1;
> -       /* Register interrupt install functions */
> -       b1553brm_pci_int_reg = cchip1_set_isr;
> -       occan_pci_int_reg = cchip1_set_isr;
> -       grspw_pci_int_reg = cchip1_set_isr;
> -       apbuart_pci_int_reg = cchip1_set_isr;
> -       /* register the BRM PCI driver, use 16k FTSRAM... */
> -       if ( b1553brm_pci_register(&cc1.amba_bus,0,0,3,cc1.ftsram_start,0xffa00000) ){
> -               printk("Failed to register BRM PCI driver\n");
> -               return -1;
> -       /* register the BRM PCI driver, no DMA memory... */
> -       if ( occan_pci_register(&cc1.amba_bus) ){
> -               printk("Failed to register OC_CAN PCI driver\n");
> -               return -1;
> -       /* register the GRSPW PCI driver, use malloc... */
> -       if ( grspw_pci_register(&cc1.amba_bus,0,0xe0000000) ){
> -               printk("Failed to register GRSPW PCI driver\n");
> -               return -1;
> -       /* register the APBUART PCI driver, no DMA memory */
> -       if ( apbuart_pci_register(&cc1.amba_bus) ){
> -               printk("Failed to register APBUART PCI driver\n");
> -               return -1;
> -       return 0;
> +  /* Init AT697 PCI Controller */
> +  init_pci();
> +  /* Find & init CChip board .
> +   * Also scan AMBA Plug&Play info for us.
> +  if ( init_pcif() ){
> +    printk("Failed to initialize CCHIP board\n\r");
> +    return -1;
> +  /* Set interrupt common board stuff */
> +  cchip1_irq_init();
> +  /* Find on board SRAM */
> +  if ( init_onboard_sram() ){
> +    printk("Failed to register On Board SRAM. It is needed by b1553BRM\n");
> +    return -1;
> +  /* Register interrupt install functions */
> +  b1553brm_pci_int_reg = cchip1_set_isr;
> +  occan_pci_int_reg = cchip1_set_isr;
> +  grspw_pci_int_reg = cchip1_set_isr;
> +  apbuart_pci_int_reg = cchip1_set_isr;
> +  /* register the BRM PCI driver, use 16k FTSRAM... */
> +  if ( b1553brm_pci_register(&cc1.amba_bus,0,0,3,cc1.ftsram_start,0xffa00000) ){
> +    printk("Failed to register BRM PCI driver\n");
> +    return -1;
> +  /* register the BRM PCI driver, no DMA memory... */
> +  if ( occan_pci_register(&cc1.amba_bus) ){
> +    printk("Failed to register OC_CAN PCI driver\n");
> +    return -1;
> +  /* register the GRSPW PCI driver, use malloc... */
> +  if ( grspw_pci_register(&cc1.amba_bus,0,0xe0000000) ){
> +    printk("Failed to register GRSPW PCI driver\n");
> +    return -1;
> +  /* register the APBUART PCI driver, no DMA memory */
> +  if ( apbuart_pci_register(&cc1.amba_bus) ){
> +    printk("Failed to register APBUART PCI driver\n");
> +    return -1;
> +  return 0;
>  static rtems_isr cchip1_interrupt_dispatcher(rtems_vector_number v);
>  static unsigned int cchip1_spurious_cnt;
>  typedef struct {
> -       unsigned int (*handler)(int irqno, void *arg);
> -       void *arg;
> +  unsigned int (*handler)(int irqno, void *arg);
> +  void *arg;
>  } int_handler;
>  static int_handler int_handlers[16];
>  void cchip1_irq_init(void){
> -       /* Configure AT697 ioport bit 7 to input pci irq */
> +  /* Configure AT697 ioport bit 7 to input pci irq */
>    regs->PIO_Direction &= ~(1<<7);
>    regs->PIO_Interrupt  = 0x87;          /* level sensitive */
>    /* Set up irq controller (mask all IRQs) */
> -       cc1.pcib->imask = 0x0000;
> -       cc1.pcib->ipend = 0;
> -       cc1.pcib->iclear = 0xffff;
> -       cc1.pcib->iforce = 0;
> -       cc1.pcib->ilevel = 0x0;
> +  cc1.pcib->imask = 0x0000;
> +  cc1.pcib->ipend = 0;
> +  cc1.pcib->iclear = 0xffff;
> +  cc1.pcib->iforce = 0;
> +  cc1.pcib->ilevel = 0x0;
> -       memset(int_handlers,0,sizeof(int_handlers));
> +  memset(int_handlers,0,sizeof(int_handlers));
> -       /* Reset spurious counter */
> -       cchip1_spurious_cnt = 0;
> +  /* Reset spurious counter */
> +  cchip1_spurious_cnt = 0;
> -       /* Register interrupt handler */
> -       set_vector(cchip1_interrupt_dispatcher,LEON_TRAP_TYPE(CCHIP_IRQ),1);
> +  /* Register interrupt handler */
> +  set_vector(cchip1_interrupt_dispatcher,LEON_TRAP_TYPE(CCHIP_IRQ),1);
>  void cchip1_set_isr(void *handler, int irqno, void *arg){
> -       int_handlers[irqno].handler = handler;
> -       int_handlers[irqno].arg = arg;
> +  int_handlers[irqno].handler = handler;
> +  int_handlers[irqno].arg = arg;
>  #ifdef DEBUG
> -       printk("Registering IRQ %d to 0x%lx(%d,0x%lx)\n\r",
> -                       irqno,(unsigned int)handler,irqno,(unsigned int)arg);
> +  printk("Registering IRQ %d to 0x%lx(%d,0x%lx)\n\r",
> +      irqno,(unsigned int)handler,irqno,(unsigned int)arg);
>  #endif
> -       cc1.pcib->imask |= 1<<irqno; /* Enable the registered IRQ */
> +  cc1.pcib->imask |= 1<<irqno; /* Enable the registered IRQ */
>  static rtems_isr cchip1_interrupt_dispatcher(rtems_vector_number v){
> -       unsigned int pending = READ_REG(&cc1.pcib->ipend);
> -       unsigned int clr = pending;
> -       int irq=1;
> +  unsigned int pending = READ_REG(&cc1.pcib->ipend);
> +  unsigned int clr = pending;
> +  int irq=1;
> -       if ( !pending ){
> +  if ( !pending ){
>  #ifdef PRINT_SPURIOUS
> -               printk("Spurious IRQ %d: %d\n",v,cchip1_spurious_cnt);
> +    printk("Spurious IRQ %d: %d\n",v,cchip1_spurious_cnt);
>  #endif
> -               cchip1_spurious_cnt++;
> -               return;
> +    cchip1_spurious_cnt++;
> +    return;
>  #ifdef DEBUG_IRQS
>    printk("CCIRQ: 0x%x\n",(unsigned int)pending);
>  #endif
> -       /* IRQ 0 doesn't exist */
> -       irq=1;
> -       pending = pending>>1;
> -       while ( pending ){
> -               if ( (pending & 1) && (handler=int_handlers[irq].handler) ){
> -                       handler(irq,int_handlers[irq].arg);
> -               irq++;
> +  /* IRQ 0 doesn't exist */
> +  irq=1;
> +  pending = pending>>1;
> +  while ( pending ){
> +    if ( (pending & 1) && (handler=int_handlers[irq].handler) ){
> +      handler(irq,int_handlers[irq].arg);
> +    irq++;
> -       cc1.pcib->iclear = clr;
> +  cc1.pcib->iclear = clr;
> -       /*LEON_Clear_interrupt( brd->irq );*/
> +  /*LEON_Clear_interrupt( brd->irq );*/
> diff --git a/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
> index 70e8e81..7538dba 100644
> --- a/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
> +++ b/c/src/lib/libbsp/sparc/leon2/clock/ckinit.c
> @@ -47,7 +47,7 @@ extern int CLOCK_SPEED;
>  #define Clock_driver_support_initialize_hardware() \
>    do { \
>      LEON_REG.Timer_Reload_1 = \
> -               rtems_configuration_get_microseconds_per_tick() - 1; \
> +    rtems_configuration_get_microseconds_per_tick() - 1; \
>      LEON_REG.Timer_Control_1 = ( \
>        LEON_REG_TIMER_COUNTER_ENABLE_COUNTING |  \
> diff --git a/c/src/lib/libbsp/sparc/leon2/console/console.c b/c/src/lib/libbsp/sparc/leon2/console/console.c
> index 0a4059e..f31184d 100644
> --- a/c/src/lib/libbsp/sparc/leon2/console/console.c
> +++ b/c/src/lib/libbsp/sparc/leon2/console/console.c
> @@ -322,7 +322,7 @@ rtems_device_driver console_initialize(
>    LEON_REG.UART_Control_1 |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
>    LEON_REG.UART_Control_2 |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE |
> -       LEON_REG_UART_CTRL_RI;  /* rx irq default enable for remote debugger */
> +    LEON_REG_UART_CTRL_RI;  /* rx irq default enable for remote debugger */
>    LEON_REG.UART_Status_1 = 0;
>    LEON_REG.UART_Status_2 = 0;
> diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> index 8e40903..0d86c62 100644
> --- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> @@ -69,7 +69,7 @@ extern int rtems_leon_open_eth_driver_attach(
>  extern int rtems_smc91111_driver_attach_leon2(
> -#define RTEMS_BSP_NETWORK_DRIVER_NAME  "open_eth1"
> +#define RTEMS_BSP_NETWORK_DRIVER_NAME  "open_eth1"
>  #define RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH \
>  #define RTEMS_BSP_NETWORK_DRIVER_ATTACH_SMC91111 \
> diff --git a/c/src/lib/libbsp/sparc/leon2/include/leon.h b/c/src/lib/libbsp/sparc/leon2/include/leon.h
> index b60c1d5..b785902 100644
> --- a/c/src/lib/libbsp/sparc/leon2/include/leon.h
> +++ b/c/src/lib/libbsp/sparc/leon2/include/leon.h
> @@ -100,49 +100,49 @@ extern "C" {
>  typedef struct {
> -       volatile unsigned int Memory_Config_1;
> -       volatile unsigned int Memory_Config_2;
> -       volatile unsigned int Edac_Control;
> -       volatile unsigned int Failed_Address;
> -       volatile unsigned int Memory_Status;
> -       volatile unsigned int Cache_Control;
> -       volatile unsigned int Power_Down;
> -       volatile unsigned int Write_Protection_1;
> -       volatile unsigned int Write_Protection_2;
> -       volatile unsigned int Leon_Configuration;
> -       volatile unsigned int dummy2;
> -       volatile unsigned int dummy3;
> -       volatile unsigned int dummy4;
> -       volatile unsigned int dummy5;
> -       volatile unsigned int dummy6;
> -       volatile unsigned int dummy7;
> -       volatile unsigned int Timer_Counter_1;
> -       volatile unsigned int Timer_Reload_1;
> -       volatile unsigned int Timer_Control_1;
> -       volatile unsigned int Watchdog;
> -       volatile unsigned int Timer_Counter_2;
> -       volatile unsigned int Timer_Reload_2;
> -       volatile unsigned int Timer_Control_2;
> -       volatile unsigned int dummy8;
> -       volatile unsigned int Scaler_Counter;
> -       volatile unsigned int Scaler_Reload;
> -       volatile unsigned int dummy9;
> -       volatile unsigned int dummy10;
> -       volatile unsigned int UART_Channel_1;
> -       volatile unsigned int UART_Status_1;
> -       volatile unsigned int UART_Control_1;
> -       volatile unsigned int UART_Scaler_1;
> -       volatile unsigned int UART_Channel_2;
> -       volatile unsigned int UART_Status_2;
> -       volatile unsigned int UART_Control_2;
> -       volatile unsigned int UART_Scaler_2;
> -       volatile unsigned int Interrupt_Mask;
> -       volatile unsigned int Interrupt_Pending;
> -       volatile unsigned int Interrupt_Force;
> -       volatile unsigned int Interrupt_Clear;
> -       volatile unsigned int PIO_Data;
> -       volatile unsigned int PIO_Direction;
> -       volatile unsigned int PIO_Interrupt;
> +  volatile unsigned int Memory_Config_1;
> +  volatile unsigned int Memory_Config_2;
> +  volatile unsigned int Edac_Control;
> +  volatile unsigned int Failed_Address;
> +  volatile unsigned int Memory_Status;
> +  volatile unsigned int Cache_Control;
> +  volatile unsigned int Power_Down;
> +  volatile unsigned int Write_Protection_1;
> +  volatile unsigned int Write_Protection_2;
> +  volatile unsigned int Leon_Configuration;
> +  volatile unsigned int dummy2;
> +  volatile unsigned int dummy3;
> +  volatile unsigned int dummy4;
> +  volatile unsigned int dummy5;
> +  volatile unsigned int dummy6;
> +  volatile unsigned int dummy7;
> +  volatile unsigned int Timer_Counter_1;
> +  volatile unsigned int Timer_Reload_1;
> +  volatile unsigned int Timer_Control_1;
> +  volatile unsigned int Watchdog;
> +  volatile unsigned int Timer_Counter_2;
> +  volatile unsigned int Timer_Reload_2;
> +  volatile unsigned int Timer_Control_2;
> +  volatile unsigned int dummy8;
> +  volatile unsigned int Scaler_Counter;
> +  volatile unsigned int Scaler_Reload;
> +  volatile unsigned int dummy9;
> +  volatile unsigned int dummy10;
> +  volatile unsigned int UART_Channel_1;
> +  volatile unsigned int UART_Status_1;
> +  volatile unsigned int UART_Control_1;
> +  volatile unsigned int UART_Scaler_1;
> +  volatile unsigned int UART_Channel_2;
> +  volatile unsigned int UART_Status_2;
> +  volatile unsigned int UART_Control_2;
> +  volatile unsigned int UART_Scaler_2;
> +  volatile unsigned int Interrupt_Mask;
> +  volatile unsigned int Interrupt_Pending;
> +  volatile unsigned int Interrupt_Force;
> +  volatile unsigned int Interrupt_Clear;
> +  volatile unsigned int PIO_Data;
> +  volatile unsigned int PIO_Direction;
> +  volatile unsigned int PIO_Interrupt;
>  } LEON_Register_Map;
>  #endif
> @@ -394,9 +394,9 @@ static __inline__ int bsp_irq_fixup(int irq)
>  /* Load 32-bit word by forcing a cache-miss */
>  static inline unsigned int leon_r32_no_cache(uintptr_t addr)
> -       unsigned int tmp;
> -       __asm__ volatile (" lda [%1] 1, %0\n" : "=r"(tmp) : "r"(addr));
> -       return tmp;
> +  unsigned int tmp;
> +  __asm__ volatile (" lda [%1] 1, %0\n" : "=r"(tmp) : "r"(addr));
> +  return tmp;
>  #endif /* !ASM */
> diff --git a/c/src/lib/libbsp/sparc/leon2/include/rasta.h b/c/src/lib/libbsp/sparc/leon2/include/rasta.h
> index dff9a49..b733a3f 100644
> --- a/c/src/lib/libbsp/sparc/leon2/include/rasta.h
> +++ b/c/src/lib/libbsp/sparc/leon2/include/rasta.h
> @@ -97,17 +97,17 @@ struct uart_reg {
>  void uart_register(unsigned int baseaddr);
>  rtems_device_driver uart_initialize(rtems_device_major_number  major,
> -               rtems_device_minor_number  minor, void *arg);
> +    rtems_device_minor_number  minor, void *arg);
>  rtems_device_driver uart_open(rtems_device_major_number major,
>  rtems_device_driver uart_close(rtems_device_major_number major,
>  rtems_device_driver uart_read(rtems_device_major_number major,
>  rtems_device_driver uart_write(rtems_device_major_number major,
>  rtems_device_driver uart_control(rtems_device_major_number major,
>  struct gpio_reg {
> diff --git a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
> index e4faaff..424f4ca 100644
> --- a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
> +++ b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
> @@ -345,7 +345,7 @@ int rasta_register(void)
>      /*brm_register(bar0   +  BRM_OFFSET, bar1);*/
>      /* register the BRM RASTA driver, use 128k on RASTA SRAM... */
>      b1553brm_rasta_int_reg=rasta_interrrupt_register;
> -         if ( b1553brm_rasta_register(&abus,2,0,3,bar1,0x40000000) ){
> +    if ( b1553brm_rasta_register(&abus,2,0,3,bar1,0x40000000) ){
>        printk("Failed to register BRM RASTA driver\n");
>        return -1;
> diff --git a/c/src/lib/libbsp/sparc/leon2/startup/spurious.c b/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
> index 5f7cf27..d10f63a 100644
> --- a/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
> +++ b/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
> @@ -148,9 +148,9 @@ void bsp_spurious_initialize()
> -      continue;
> +         continue;
>      set_vector(
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> index 6bbd6ed..5526e8f 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> @@ -79,13 +79,13 @@ extern int rtems_leon_greth_driver_attach(
>    int attach
> -#define RTEMS_BSP_NETWORK_DRIVER_NAME_OPENETH  "open_eth1"
> -#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH         \
> +#define RTEMS_BSP_NETWORK_DRIVER_NAME_OPENETH  "open_eth1"
> +#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH   \
> -#define RTEMS_BSP_NETWORK_DRIVER_NAME_SMC91111 "smc_eth1"
> +#define RTEMS_BSP_NETWORK_DRIVER_NAME_SMC91111  "smc_eth1"
>      rtems_smc91111_driver_attach_leon3
> -#define RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH     "gr_eth1"
> +#define RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH   "gr_eth1"
>  #define RTEMS_BSP_NETWORK_DRIVER_ATTACH_GRETH \
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> index f1b987b..7e8188d 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> @@ -287,9 +287,9 @@ extern rtems_interrupt_lock LEON3_IrqCtrl_Lock;
> -       unsigned int tmp;
> -       return tmp;
> +  unsigned int tmp;
> +  return tmp;
>  /* Let user override which on-chip APBUART will be debug UART
> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> index a6b73d9..093a257 100644
> --- a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> +++ b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> @@ -28,7 +28,7 @@ scmv91111_configuration_t leon_scmv91111_configuration = {
>  int
>  rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
> -                                   int attach)
> +            int attach)
>    unsigned long addr_mctrl = 0;
>    struct grgpio_regs *io;
> @@ -62,8 +62,7 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
>    addr_mctrl = (unsigned long) apbmctrl.start;
>    io = (struct grgpio_regs *) apbpio.start;
> -  printk(
> -        "Activating Leon3 io port for smsc_lan91cxx (pio:%x mctrl:%x)\n",
> +  printk("Activating Leon3 io port for smsc_lan91cxx (pio:%x mctrl:%x)\n",
>          (unsigned int)io,
>          (unsigned int)addr_mctrl);
> @@ -75,7 +74,7 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
>    /* Setup memory controller I/O waitstates */
>    *((volatile unsigned int *) addr_mctrl) |=
> -                 0x10f80000;   /* enable I/O area access */
> +      0x10f80000;  /* enable I/O area access */
>    return _rtems_smc91111_driver_attach(config, &leon_scmv91111_configuration);
> diff --git a/c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c b/c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c
> index 80bf716..0362235 100644
> --- a/c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c
> +++ b/c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c
> @@ -45,8 +45,8 @@ __asm__ (
>      ".text\n"
>      ".align 4\n"
>  "LEON3_Atomic_Swap:\n"
> -"      retl\n"
> -"      swapa [%o1] 1, %o0\n"
> +"  retl\n"
> +"  swapa [%o1] 1, %o0\n"
> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> index 210dee0..580daed 100644
> --- a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> +++ b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> @@ -152,9 +152,9 @@ void bsp_spurious_initialize()
> -      continue;
> +         continue;
>      set_vector(
> 1.7.9.5
> rtems-devel mailing list
> rtems-devel at rtems.org
